Official Pioneer Elite BDP-05FD & BDP-51FD Owners Thread / Vs 1.32 DTS-HD MA - Page 1026 - AVS Forum
post #30751 of 30757 Old 09-18-2014, 02:21 PM
JA Fant's Avatar
Quoted: 28 Post(s)
Liked: 44
Jon S-
I tried the link- not very helpful. I typed in a few zipcodes and nothing...?
JA Fant is offline
post #30752 of 30757 Old 09-18-2014, 10:40 PM
Jon S's Avatar
Quoted: 45 Post(s)
Liked: 49
Did you register on the second screen?
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #30753 of 30757 Old 09-22-2014, 03:51 PM
LJ25's Avatar
Would you guys say that Source Direct is the best setting for this player if all you're playing are Blu-Ray discs on a 1080p/24 display?
PSN: J_Rodz2588
LJ25 is offline
post #30754 of 30757 Old 09-22-2014, 09:06 PM
rjardine's Avatar
You should check out post #7
rjardine is offline
post #30755 of 30757 Old 09-23-2014, 05:55 PM
LJ25's Avatar
There is no difference between auto and source direct on my display. Switching between both options doesn't do anything.
PSN: J_Rodz2588
LJ25 is offline
post #30756 of 30757 Old 09-24-2014, 04:43 AM
stanger89's Avatar
Quoted: 134 Post(s)
Liked: 148
If your display properly supports 1080p24 (ie it doesn't have to be forced into 24fps mode), then for Blu-ray there's no difference. Source Direct is really only different for DVDs and lower than 1080p resolution content. It will switch the output resolution and timing to match the source, so (for example) DVDs are output at 480i. Handy if you've got a good video processor (either standalone, like a Lumagen, or built into your display).
See what an anamorphoscopic lens can do,
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
stanger89 is offline
post #30757 of 30757 Old 09-24-2014, 08:17 AM
LJ25's Avatar
Since I never watch DVD's, I will leave the player in Source Direct.
PSN: J_Rodz2588
LJ25 is offline
Reply Blu-ray Players
Excellent Pioneer Bdp 05fd Blu Ray Player , Pioneer Bdp 51fd Bonusview Blu Ray Player , Blu Ray Players
User Tag List
