Official Pioneer Elite BDP-05FD & BDP-51FD Owners Thread / Vs 1.32 DTS-HD MA - Page 1029 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #30841 of 30856 Old 06-18-2015, 02:18 PM
ledd4u's Avatar
Originally Posted by FurryNutz View Post
I recommend disconnecting the HDMI cable from the player and test the play with just the RCA outputs and see if the CD works. Are you getting any operation with a CD? Is the CD spinning up or any indication on the display?
What is happening when it doesn't work. Please explain more.
The problem I saw with mine is that when the HDMI was connected to my HDMI matrix, pressing the play function on the front panel would not do anything. Even with the CD in the tay and loaded. the play button would not start. Just sat there. Once I disconnected the HDMI cable and power cycled the player, the play function worked.
Just trying to help you narrow down the issue if possible.
If just using RCA outputs only and the Cd still does not play, then the Drive in the player would need to be changed out. If you have used the player a lot over it's life time, then it would be normal that the laser would burn out. Laser drives are just like light bulbs, they don't last forever.
It turns but does not read, I get "Unknown disk". Its defenitely the cd laser portion of the assembly. I can just go out and purchase an Oppo BDP-103 and toss the POS Pioneer in the trash can. You almost can't fix these things anylonger, not cost effecient. Good thing is that the Blu-ray works! So I can watch movies and listen to some DVD audio discs. Pics attached of my unit today.
ID:	783242   Click image for larger version
ID:	783250   Click image for larger version
ledd4u is offline
post #30842 of 30856 Old 06-18-2015, 04:06 PM
FurryNutz's Avatar
Quoted: 12 Post(s)
You might try cleaning the lens with some de-natured alcohol and see.
If this doesn't work then drive replacement would be needed if you wanted the CD portion to work. You'll need to swap the FW board from told old drive to the new if you DIY.
Good Luck.
FurryNutz is offline
post #30843 of 30856 Old 07-04-2015, 03:53 AM
Rick R's Avatar
I had exactly the same problem except after the power was removed it would play CD for about half an hour and then "unknown disc" so I gave it to my pal.
But one thing I did find out while trying to fix the problem is that you can update the firmware using exactly the same procedure but by burning the ISO to a DVD instead of CD, so if you want to update the firmware then that should work. The laser is a complicated assembly and there appears from the tech manual to be 3 lasers not 2 whether the red laser is a hybrid or two lasers firing through one lens is not clear. I didn't take it to bits to find out because my pal could use it so the actual format is still a bit of a mystery to me
Rick R is offline
post #30844 of 30856 Old 07-04-2015, 08:38 PM
ledd4u's Avatar
I will give that a try, happy 4th all.
ledd4u is offline
post #30845 of 30856 Old 07-11-2015, 12:35 PM
dholmes54's Avatar
Quoted: 108 Post(s)
Liked: 36
Pioneer 51
What's a Pioneer 51 blu-ray player worth,I've got 2 with box and remote in perfect condition,great for std DVD and CD play,someone plz let me know there in my way,they play blu-rays but there slow need a firmware update havint done one in a long time thx
dholmes54 is offline
post #30846 of 30856 Old 07-14-2015, 09:36 AM
Jon S's Avatar
Quoted: 314 Post(s)
Liked: 126
Not much. I see them on sale on craigslist for about $50. They are old, extremely slow and do not offer any streaming options. It's hard to sell them when you can buy a faster player with streaming options for $80. Not too many people care about the audio qualities since most players are connected to a TV and not a audio system.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #30847 of 30856 Old 07-14-2015, 10:28 AM
erkq's Avatar
Quoted: 32 Post(s)
Liked: 101
It's a fortunate situation if you want to buy one. Yes, I'm a fanboi.
Old... oh well.
Slow... be inventive: make popcorn, pour wine, have a conversation.
No streaming... streaming is still crud.
Yeah... probably $50. I bought mine from BB years ago brand new for $100.
erkq is offline
post #30848 of 30856 Old 07-14-2015, 11:45 AM
dholmes54's Avatar
Quoted: 108 Post(s)
Liked: 36
You guys are correct! I don't want to throw them away,I guess I'll lower the price,they do make a good CD player! I just lowered the price to 100.00 for both.
post #30849 of 30856 Old 07-21-2015, 07:02 AM
LarryGM's Avatar
BDP-05 Value
Speaking of blu-ray player values, what do you believe is a reasonable value for an Elite BDP-05 player that works fine and has firmware 1.73 installed? Original packaging and owner's manual included. Someone may want it as a player while someone else may want it for parts or as a spare.
LarryGM is offline
post #30850 of 30856 Old 07-21-2015, 09:41 AM
BillP's Avatar
Quoted: 165 Post(s)
Liked: 139
dhomes and Larry, nobody is going to pay much for these players. They are several years old, very slow to load, have no internet connectivity, very poor error correction, and have a history of premature lens failures. My 51FD is basically collecting dust (I use it once a year in my bedroom).
BillP is online now
post #30851 of 30856 Old 07-21-2015, 10:06 AM
Jon S's Avatar
Quoted: 314 Post(s)
Liked: 126
Ditto... I have a BDP-09FD and a BDP-05Fd just collecting dust...
I have an Oppo BDP-95 for my home theater and a Sony BDP-S6200 for my television... Can't live without streaming from VUDU or my local wi-fi network now....
Jon S is offline
post #30852 of 30856 Old 07-21-2015, 11:09 AM
b curry's Avatar
Quoted: 119 Post(s)
Liked: 70
I couldn't get anyone interested in a BDP-05FD for $20 or "make me an offer" during our garage sale...
b curry is offline
post #30853 of 30856 Old 07-21-2015, 02:57 PM
LarryGM's Avatar
Thanks BillP and b Curry. Sounds like my Middle Atlantic shelf and faceplate for my BDP-05 are worth more than my functioning BDP-05 - well maybe the shelf is!
LarryGM is offline
post #30854 of 30856 Old 07-21-2015, 06:04 PM
b curry's Avatar
Quoted: 119 Post(s)
Liked: 70
Yep, that's about right.
Funny, I used my shelf with a new face plate for the Oppo that replaced the BDP-05FD.
b curry is offline
post #30855 of 30856 Old Today, 01:12 AM
Quoted: 42 Post(s)
Liked: 3
Hoping someone can help me. If I want to use my bdp 51fd as a CD player what's the best way to run audio out? Anolog or hdmi? I have a marantz sr5008.
Romanoandrew3 is offline
post #30856 of 30856 Unread Today, 04:44 AM
BillP's Avatar
Quoted: 165 Post(s)
Liked: 139
Analog to use the player's audio DACs, HDMI to use the receiver's audio DACs. It depends on which sounds better to your ears (there is no right or wrong answer).
BillP is online now
Reply Blu-ray Players
Blu Ray Players , Excellent Pioneer Bdp 05fd Blu Ray Player , Pioneer Bdp 51fd Bonusview Blu Ray Player
