Official Pioneer Elite BDP-05FD & BDP-51FD Owners Thread / Vs 1.32 DTS-HD MA - Page 599 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #17941 of 31008 Old 04-25-2009, 05:53 AM
NYC Guy's Avatar
Quoted: 36 Post(s)
Originally Posted by eldithomaso View Post
Also I use DOT BY DOT on all BD sources on the 111.
Can you really see a significant difference using dot by dot for your BD movies? I have a 111 & a 05; have tried dot by dot and I believe it is extremely difficult to tell the difference unless you are really scrutinizing the picture.
NYC Guy is offline
post #17942 of 31008 Old 04-25-2009, 05:57 AM
NYC Guy's Avatar
Quoted: 36 Post(s)
Probably in Japan. Mine is the same date and nearly the same Serial Number.
No problems with QOS here or any Fox disks for that matter on my 05.
I am having my 111 calibrated in two weeks and will have to move my BDI AV furniture piece away from the wall to access the rear. At that time I will definitely check it out. Based on your post I think (and hope) I have an excellent chance of it being made in Japan.
NYC Guy is offline
post #17943 of 31008 Old 04-25-2009, 05:59 AM
Rob West's Avatar
In case your wondering.
Here's the picture of where the black dot should be on the back of your 51D.
My SERIAL. NO. HIEA017448CC falls in the danger zone.
Mine does not have the black dot, if it needs to go back I will request a prepaid mailing sticker.
I'll post the outcome.
One more note this makes my Netflix turn over come to a halt.
Rob West is offline
post #17944 of 31008 Old 04-25-2009, 06:11 AM
winston9332's Avatar
Liked: 31
Amazing Pioneer Quality Control let this many defective units out...
winston9332 is offline
post #17945 of 31008 Old 04-25-2009, 06:31 AM
Rob West's Avatar
If Pioneer wants to make us really happy they should install the next firmware update with DTS HD MA added, while they have it. Then there would be no complaints, yes I know I'm dreaming..................
Rob West is offline
post #17946 of 31008 Old 04-25-2009, 07:03 AM
trex4757's Avatar
Originally Posted by WilliamZX11 View Post
Just got an email from Pioneer, it's little confusing to me. It says my player falls in that range of numbers. But unless I am misreading the order of the letters and numbers, I don't think mine is in the range of affected units. My serial is HGEA004854CC.
And if I'm not mistaken, don't these two ranges overlap each other? Looks like range is :
HHMP000001CC - HJEA022600CC
My BDP-05FD serial # is HGEA000378CC, Manufacture date is July, 08. I guess my unit is not affected.
trex4757 is offline
post #17947 of 31008 Old 04-25-2009, 07:03 AM
linusone's Avatar
Well this stinks. Mine is an Oct 08/Japan build and is a "HJE021" - I just got the friggin' thing (day 33 of my 30-day window), and is tucked away in the entertainment center! And I already have to send it in?! To quote my fav tennis player, "You CANNOT be serious!"
Really, this is extremely disappointing. I bought it after reading the reputation of its quality. Fantastic. Sorry to vent. Monday should be fun.
linusone is offline
post #17948 of 31008 Old 04-25-2009, 07:26 AM
Liked: 31
folks should be cautious on open box units - seen them triple in the past week or two on many online retailers. my local best buy had more open box than sealed - all malaysian built too.
post #17949 of 31008 Old 04-25-2009, 07:37 AM
JasonColeman's Avatar
Quoted: 24 Post(s)
I guess I just got really lucky with my two 51's...both Japan 10/08 and not in the affected range. I might be pushing my luck with a third......though the price sure is right! Maybe a trip to BB is in order.
Jason
JasonColeman is offline
post #17950 of 31008 Old 04-25-2009, 07:54 AM
Ruined's Avatar
Quoted: 999 Post(s)
Liked: 424
Its possible not every single unit in the range is affected, it could just be most of them or a large amount of them. Again, the symptom of this is being unable to play BD+ titles at all. Unless that happens to you, I probably wouldn't bother sending it in for a fix. Just try some recent Fox titles and see if they work. If they do, I wouldn't sweat it.
Ruined is offline
post #17951 of 31008 Old 04-25-2009, 07:55 AM
feisty1's Avatar
I fall in the range also-HJEA021505CC-but no black dot! Therefore no need for service. Makes sense since i have had absolutely no problems with this player. Unlike a Samsung 2550 which is now an expensive paperweight due to a Samsung firmware upgrade!!!!!!
feisty1 is offline
post #17952 of 31008 Old 04-25-2009, 08:03 AM
alerion's Avatar
um, unless I'm misreading you it is other way around:
no black dot = service (or at least call and try Fox BD's)
black dot = no service needed
alerion is offline
post #17953 of 31008 Old 04-25-2009, 08:04 AM
Saturn94's Avatar
Quoted: 139 Post(s)
Liked: 468
I would still contact your place of purchase to see if they will help you out. When I bought my 51 last year I had an issue over 60 days past the purchase date (bought at Best Buy) and I was able to talk the manager into approving an exchange.
Saturn94 is offline
post #17954 of 31008 Old 04-25-2009, 08:08 AM
Saturn94's Avatar
Quoted: 139 Post(s)
Liked: 468
Actually, it's the other way around. If you are in the range and there is NO black dot, then your unit may be affected. If you are in the range and DO have a black dot, then your unit is fine.
Are recent Fox titles working OK for you?
Saturn94 is offline
post #17955 of 31008 Old 04-25-2009, 08:38 AM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
My serial number is HHEAO11126CC and no black dot.
Am I reading this right that I am NOT affected and no need to call Pioneer?
kutlow is offline
post #17956 of 31008 Old 04-25-2009, 08:43 AM
kinglm's Avatar
Quoted: 193 Post(s)
Liked: 158
My 51's number HFEA001005CC with a June 2008 build date. Looks like it's OK too.
kinglm is offline
post #17957 of 31008 Old 04-25-2009, 09:01 AM
eldithomaso's Avatar
Yes on the right material. It removes any overscan - even the 1-2% on some discs. Try some test patterns - it will be very obvious what you are missing if you have the Kuro on Auto for Screen size.
Isn't it time someone promoted quality as value?
eldithomaso is offline
post #17958 of 31008 Old 04-25-2009, 09:19 AM
TMFNYC's Avatar
Hey guys,
I have a stupid question (after being in the AV business for 12 years) I purchased a 51 last night at BB (Brand new in box) the build date is Sept 08 and the box said "Made in Japan" so I was happy right... wrong. When I got home and opened the box it was made in Malay... but I have the black mark by the serial number.
The serial number on the unit matches the box, which is good and I did the update with no problem. My question is do I have a japan model (as the box says) or a Malay unit (like it says on the back of the unit). Do all the boxes say from Japan? My serial number is like 6 numbers from the end of the bad crop of players...
Thanks in advance,
J.Mo
TMFNYC is offline
post #17959 of 31008 Old 04-25-2009, 09:23 AM
Ruined's Avatar
Quoted: 999 Post(s)
Liked: 424
Play a few recent Fox titles. If they work, don't worry about it. If none of them work and you get the red screen, you need the fix. Simple.
Ruined is offline
post #17960 of 31008 Old 04-25-2009, 09:29 AM
kinglm's Avatar
Quoted: 193 Post(s)
Liked: 158
Ruined, I don't think it can be said enough how helpful and supportive you are - for helping us all get the best from our Pio BDPs. Thanks.
kinglm is offline
post #17961 of 31008 Old 04-25-2009, 09:48 AM
James W. Johnson's Avatar
Important: Notice of Free Update for Pioneer BDP-51FD & BDP-05FD Blu-ray Disc Players
Dear Valued Customer
Thank you for registering your Pioneer® BDP-51FD Blu-ray Disc® player. In an effort to provide you with a high quality viewing experience, we would like to make you aware of a free service update to correct a playability issue affecting only a small number of Pioneer® BDP-51FD and BDP-05FD Blu-ray Disc® Players.
According to the information you provided to us when you registered your player, it appears that your player falls within the affected range of serial numbers listed below. As such, we ask that you please determine whether you need to obtain the free service update using the information provided below. If you are unsure or have any questions, please contact Pioneer Customer Service (Warranty & Service Department) for further direction. Our contact information is listed near the bottom of this message.
AFFECTED SERIAL NUMBERS:
1. For the Pioneer BDP-05FD, players with any of the following eleven serial numbers need to obtain the free service update:
HIEA010580CC HIEA011916CC
HIEA010883CC HIEA013239CC
HIEA010970CC HIEA014915CC
HIEA011018CC HIEA014952CC
HIEA011084CC HJEA015613CC
HIEA011897CC
2. For the Pioneer BDP-51FD, players with serial numbers falling within the following two ranges may need to obtain the free service update -- please see the highlighted note below to determine what you should do next:
HIEA014000CC - HJEA022600CC**
HHMP000001CC - HIMP005000CC**
** If the player's serial numbers falls within one of the above ranges, you will need to determine whether the player has a small black dot on the back panel of the player at the center of the air outlet (as depicted in the picture below).
  • If the player DOES HAVE the small black dot, it does NOT need the free service update because the update has already been installed.
  • If the player DOES NOT HAVE the small black dot, you need to contact Pioneer Customer Service (Warranty & Service Department) and provide the player's serial number, so that Pioneer can inform you whether the update has already been installed.
If you are unsure about how to proceed, please contact Pioneer Customer Service (Warranty & Service Department) for further direction.
PURPOSE OF THE FREE SERVICE UPDATE
The purpose of the free service update is to address a playability issue which causes only the affected players described above to be unable to play certain pre-recorded Blu-ray Disc titles due to a problem with the player (not with the Blu-ray Discs). When experiencing this playability issue, the affected players will either --
1. be unable to play the affected Blu-ray Disc title and instead display on the television screen a warning message as depicted below ("Warning. Your Blu-ray Player requires an update in order to play this disc. Please visit your Blu-ray Player manufacturer's website and follow their instructions to update your Blu-ray Player."), or
2. display on the television screen a message advising you to update your player, and then attempt to play the affected Blu-ray Disc title but the picture will be severely distorted.
To obtain the free service update for an affected player or if you are unsure whether your player requires the free service update, please contact Pioneer Customer Service (Warranty & Service Department) toll free at 800-PIONEER (800-746-6337). Pioneer service representatives are available Monday through Friday from 10:00 a.m. to 7:30 p.m. (Eastern Time), except on holidays.
Unfortunately, the service update cannot be downloaded via the Internet or performed using a disc. Rather, affected players must be sent to Pioneer so that we can directly perform the service update.
Sincerely,
Pioneer Electronics (USA) Inc.
James W. Johnson is offline
post #17962 of 31008 Old 04-25-2009, 09:51 AM
Audiodork's Avatar
Liked: 37
Hello,
Between Pioneer addressing the players affected by BD+ implementation and their release of the DTS-MA for the BDP-09, it would seem rumors of Pioneer's demise have been greatly exaggerated. Couple that with Honda's investment in Pioneer and it would seem things are looking much better.
Also, once the DTS-MA upgrade is released with hopefully further optimization and the recalled players are dealt with, the BPD-51 will be a player almost without fault considering the price.
Cheers,
AD
Radio Shack SPL Meter Owner
Audiodork is offline
post #17963 of 31008 Old 04-25-2009, 10:31 AM
Quoted: 1701 Post(s)
Liked: 731
Pioneer nor Honda has announced that the investment is a done deal, yet.
Hope it happens, but its just not a reality yet.
JimP is offline
post #17964 of 31008 Old 04-25-2009, 11:00 AM
feisty1's Avatar
"Quantum of Silence" and "Transporter 3" played perfectly!! I think these are Fox, but not sure. But you are right. If you do not have the black dot, you maybe in trouble! Thanks for correcting me. Time to call Pioneer with fingers crossed! I have played mostly new stuff from Netflix for approximately two+ months. I'll call Pioneer and at the same time consider Ruined's comments. "If it ain't broke, don't fix it".
By the way of info, mine came from 6th Ave in February.
feisty1 is offline
post #17965 of 31008 Old 04-25-2009, 11:02 AM
feisty1's Avatar
As you can see, I have the disease, but none of the symptoms!!!
feisty1 is offline
post #17966 of 31008 Old 04-25-2009, 11:05 AM
feisty1's Avatar
See the title!
feisty1 is offline
post #17967 of 31008 Old 04-25-2009, 11:07 AM
LS2JSTS's Avatar
Originally Posted by Walkamo View Post
Hi Everyone,
We have identified the problem that some BDP-51FD and BDP-05FD users have experienced when playing some recent Blu-ray releases. Please visit the below URL to find out if your player is affected and how Pioneer is offering a free service update to resolve the issue.
http://www.pioneerelectronics.com/PU...y+Disc+Players
Thanks for everyone's patience and help in bringing this issue to our attention.
Chris Walker
Pioneer Electronics
Chris, thanks for the input and the link.......Good to see you and Pioneer have our backs!
05-1.3H BJC-3808-1.3H BJC-5080
LS2JSTS is offline
post #17968 of 31008 Old 04-25-2009, 11:38 AM
alerion's Avatar
I have been following this forum since before I purchased a BDP-51FD in October. It has been an amazing resource, one notable for people helping each other and even occasional good humor.
This has not been our best day.
Interestingly, in some ways it was triggered by Pioneer's own email - if they had used the phrase "may fall" rather than "falls" it probably would have saved a few posts, and some running around in circles.
I shared one poster's impatience with the churn of questions about what were for the most part very clear instructions, but questions simpler than these have been answered before here with good grace. Probably even some of my own questions.
So, LS2JSTS' suggestion of moving on is probably a good one.
So, what about that firmware update.....
alerion is offline
post #17969 of 31008 Old 04-25-2009, 11:44 AM
LS2JSTS's Avatar
Thanks.....One good thing if you have the 05, the letter was very simple to figure out.
Can we add that to the advantages of the 05 as well......lol
Ruined, any insight at all in how its possible that Pioneer could know the precise 11 SN's of the 05 that require the update? It seems very odd that it would be such a low number and also that they would know the exact SN of those affected.....What gives?
LS2JSTS is offline
post #17970 of 31008 Old 04-25-2009, 11:49 AM
02fx4dude's Avatar
LOL, I like how Pioneer calls sending in your unit for service a "Free Update", like they're doing you a favor. If it was the auto industry it would be a "recall". Hmmmmm...
I received the email from Pioneer but neither of my players seem to fall in the affected range of SN's, so I assume they sent the email to anyone that registered players.
Brian
02fx4dude is offline
Reply Blu-ray Players
Blu Ray Players , Excellent Pioneer Bdp 05fd Blu Ray Player , Pioneer Bdp 51fd Bonusview Blu Ray Player
