Official Pioneer Elite BDP-05FD & BDP-51FD Owners Thread / Vs 1.32 DTS-HD MA - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #151 of 30990 Old 08-12-2008, 07:56 AM
Ruined's Avatar
Quoted: 262 Post(s)
Liked: 82
Originally Posted by gonzalc3 View Post
With v1.0 firmware.
Possibly another title glitch then. Does the Patriot have any significant BD-J features? The BD-J discs are the ones that I noticed the lipsync issues with on v0.80 firmware.
Ruined is offline
post #152 of 30990 Old 08-12-2008, 07:57 AM
Ruined's Avatar
Quoted: 262 Post(s)
Liked: 82
Originally Posted by D_B_0673 View Post
That is not good news
It's a new design, there are going to be bugs; it would be unrealistic to think otherwise. Most Blu-ray players have to go through several firmware iterations before all the bugs are worked out, unless they are based on another pre-existing design that has already went through that process.
Ruined is offline
post #153 of 30990 Old 08-12-2008, 07:59 AM
BigDad's Avatar
Ruined - I think it was Patriot Games instead of The Patriot he had trouble with. But I don't think either of those have significant BD-J - although I have the Ryan films on HD-DVD, so I may be wrong.
BigDad is offline
post #154 of 30990 Old 08-12-2008, 08:08 AM
Ken Ross's Avatar
Quoted: 5613 Post(s)
Liked: 5967
Originally Posted by AndyGood View Post
I am skeptical too with the "hair"/slight sharper claims, seems like I have heard this before. The reality is that for videophiles, you may shell out bigger dollars to dissect the slight video differences among DVD players, to go down that road with bluray players, I think we are looking for something that may not be there. No, the answer is that we are addicted to this hobby and the BS that goes with it and the fact of the matter is that Pioneer makes an attractive player which is reason enough.
I'd be willing to bet in a double-blind A/B test, sharpness differences (if any) would be very minimal at best with any recent BR player regardless of price. That's not to say there aren't valid reasons for choosing player A over player B, but I'm just not sure picture sharpness is one. With that said, I'm seriously considering the 05 or 51.
Ken Ross is offline
post #155 of 30990 Old 08-12-2008, 08:11 AM
Ken Ross's Avatar
Liked: 5967
Its not a speedy DVD player, but among the Blu-ray players its one of the few that allows you to output native 480i to an external scaler/chip for deinterlacing. So if you are looking for an all-in-one solution and have a nice video processor this is your best bet.
I thought that someone (Chris or Pioneer rep?) said this would be one of the fastest BR players on the market with a 10 second boot up time. Did that not pan out or is it promised in a future firmware upgrade?
Ken Ross is offline
post #156 of 30990 Old 08-12-2008, 08:23 AM
gonzalc3's Avatar
Quoted: 167 Post(s)
Liked: 142
Ruined,
Patriot Games doesn't have any BD-J features.. It only includes somes interviews and a trailer...
You had trouble with top gun and which other title? I am beginning to think that is a problem with paramount titles, but I could be wrong...
I have clear and present danger as well and wlll give it a spin to see if there is any problem... I tested with Casino Royale and didn't find any trouble..
Chris. My DVD UHD Blu Ray and Blu Ray collection
JVC DLA-X750R (calibrated with calman 5 and c6 hdr meter), ST 100 (100") screen, B&W 803D2s mains, B&W HTM2D2 center channel, B&W 805D2 surrounds, B&W CCMM682s in-ceiling speakers (4), B&W DB1 subwoofer, Marantz AV8802A preamp, Parasound Halo A51+(2xA21)+(2xA23) amps, Oppo UDP 203 player, Roku Ultra and Harmony Elite remote.
gonzalc3 is offline
post #157 of 30990 Old 08-12-2008, 08:28 AM
Ruined's Avatar
Quoted: 262 Post(s)
Liked: 82
Chris stated it starts in ~14 seconds, and indeed the tray does eject in ~14 seconds as I stated in my post in the first page. Splash screen is ~18 seconds and disc load is at ~22 seconds. These times will vary +/- 5 seconds depending on your equipment & HDMI handshaking.
So the player does start up very fast. Where it could use improvement is in media detection. After you close the tray, half of the time quoted in my loadtimes on page 1 is spent detecting the disc. If they could speed up that algorithm then it would be really fast not only at starting up but also on disc loads.
Ruined is offline
post #158 of 30990 Old 08-12-2008, 08:29 AM
Ruined's Avatar
Quoted: 262 Post(s)
Liked: 82
Ruined,
If you check out my post on the first page I detailed pretty well the issues I've had thus far with 1.0.
Ruined is offline
post #159 of 30990 Old 08-12-2008, 08:30 AM
bzal1122's Avatar
Can you guys tell me if thisplayer allows a 480i output so that my pioneer 5010 can do the upscaling? Ruined how are you playing your sd-dvd with pioneer 51fd doing the upscaling or do you have it source direct? How are your results in each setting
bzal1122 is offline
post #160 of 30990 Old 08-12-2008, 08:31 AM
Ruined's Avatar
Quoted: 262 Post(s)
Liked: 82
Yes it outputs 480i w/ source direct enabled. I have source direct going to a Reon processor. 51FD by itself appears to not fair nearly as well as the Reon, but I only briefly tested SD performance.
Ruined is offline
post #161 of 30990 Old 08-12-2008, 08:38 AM
gonzalc3's Avatar
Quoted: 167 Post(s)
Liked: 142
From those titles I have the mummy and top gun.. I will give it a try... If you have Patriot Games, could you try it?
gonzalc3 is offline
post #162 of 30990 Old 08-12-2008, 08:41 AM
Chip913's Avatar
You should be able to set the 9.8 for "1080p" instead of "Through" in the 9.8 HDMI setup menu. You need to do this in order to enable Reon processing, otherwise it will just pass 480i to your TV with Source Direct enabled.
My HDTV is a 3 year old Sony that is only 1080i. Should I set the 9.8 to 1080i so the source direct 51FD should allow the Reon to kick in? I used to use a Denon 2910 source direct and had the same results, sound was weak with HDMI like now with the 51FD. My best results with it were HDMI from Denon to TV, bypassing the 9.8, and optical sound. But I want to run everything from the 51FD through the 9.8. I'm wondering if I have a bad unit, or just not set up right.
Chip913 is offline
post #163 of 30990 Old 08-12-2008, 08:53 AM
voltes's Avatar
I'll try to help out time the DVD layer changes tonight. Here's some that I've gathered
Star Wars ep 4
Layer switch at 63:08 at the start of chapter 28.
Lord of the Rings: The Two Towers: Special Extended Edition (2002)
The layer change in part one occurs at 48:42 just after the visit to the Dead Marshes by the Black Rider and the Fell Beast.
The layer change in part two occurs at 50:38 just as the male townsfolk are being led out to defend the walls for the coming battle of Helm's Deep.
Die Hard with A Vengeance
Layer Change: A fairly poorly placed layer change in the middle of a scene at 56:06
These were all searched in google.
voltes is offline
post #164 of 30990 Old 08-12-2008, 08:54 AM
Ruined's Avatar
Quoted: 262 Post(s)
Liked: 82
I don't have Patriot Games unfortunately.
Ruined is offline
post #165 of 30990 Old 08-12-2008, 08:55 AM
Ruined's Avatar
Quoted: 262 Post(s)
Liked: 82
I can do this one, too.
Ruined is offline
post #166 of 30990 Old 08-12-2008, 08:59 AM
Ruined's Avatar
Quoted: 262 Post(s)
Liked: 82
It sounds like you have it setup wrong. You should set the Integra to 1080i and that should at least give a cleaner interlaced output than running the DVD straight to the TV will get you. Unfortunately you will still likely be bottlenecked by the Sony's 1080i>1080p conversion, but having the Reon deinterlace 480i and upscale/re-interlace to 1080i will probably give you better results than having the TV deinterlace 480i itself.
As for the weak sound, have you used the Audyssey calibration on the 9.8? Also, do you have the Pioneer's HDMI Audio setting to "Auto"? That should provide you with bitstream sound on SD and thus should give you same results as coax/optical. Also make sure HDMI control is set to off on the 51FD to prevent the TV from interfering with it.
Ruined is offline
post #167 of 30990 Old 08-12-2008, 09:06 AM
Bilbo77's Avatar
Hi guys,
Maybe I'm the only one, but I would really appriciate some screenshots of the PQ on Blu-ray and DVD I currently own Arcam DV139 and hope to replace it soon with a Pioneer..
Thanks for a great forum!
Bilbo77 is offline
post #168 of 30990 Old 08-12-2008, 09:08 AM
Ruined's Avatar
Quoted: 262 Post(s)
Liked: 82
Originally Posted by Bilbo77 View Post
Hi guys,
I don't think you are going to gain much PQ idea from a screenshot. You will be seeing the camera's or video capture device's quality, not the player's.
Ruined is offline
post #169 of 30990 Old 08-12-2008, 09:10 AM
John Ballentine's Avatar
My 18 month old Sony BDP-S1 (1st generation) is on it's ELEVENTH firmware upgrade. It has gone from a potential boat anchor to a somewhat formidable player - thanks solely to the continuing firmware updates).
John Ballentine is offline
post #170 of 30990 Old 08-12-2008, 09:17 AM
tony @ suffolk's Avatar
Hello Folks. Sorry to note that all previous postings have been lost!
I was originally very keen to acquire this player when its clone eventually appears in the U.K., but my intention to use its analogue 7.1 outs into my surround processor appear to be not really viable because remarkably this player appears pretty hopeless in this respect!
I note from a previous posting that bass cutoff point is set at 100Hz for small speakers; what would it be for large speakers please?
Also, there appears to be no distance setting to allow for delays - very few (and certainly not my) processors allow you to set this parameter for analogue bypass.
Quite frankly I'm rather shocked that a company like Pioneer should produce a player so deficient in this area - or have I got this wrong?
tony @ suffolk is offline
post #171 of 30990 Old 08-12-2008, 09:32 AM
JoeInNVa's Avatar
Originally Posted by uw69 View Post
That says a lot about Pioneer's commitment to their players.
Psssttt...He said Sony.
Arrive
Raise Hell
Leave
JoeInNVa is offline
post #172 of 30990 Old 08-12-2008, 09:35 AM
Vader424242's Avatar
Quoted: 75 Post(s)
Liked: 65
Nope, you have it about right. The 100Hz cutoff is speculative (Pioneer has not officially stated this), but consistent with other BD players. If your speakers are set to large, there is no cutoff, as you are bypassing any BM completely (no crossover, no RB). Rumor has it that Pioneer might add more BM functionality in a future FW upgrade, but if it is to both the 51 and 05, just the 05, or is being held for the upcoming 09 is unknown...
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is offline
post #173 of 30990 Old 08-12-2008, 09:36 AM
Bilbo77's Avatar
You are probably right, but I've been waiting for this player half a year and would be greatfull for a preview :-)
Bilbo77 is offline
post #174 of 30990 Old 08-12-2008, 09:40 AM
voltes's Avatar
ill try to grab a screenshot while im testing the layer change tonight. i might even plop in the hqv benchmark disc. i just hope i remember where i put it lol
voltes is offline
post #175 of 30990 Old 08-12-2008, 09:41 AM
mrjktcvs's Avatar
I have a question for you guys. If you guys are stating that the sd dvd playback on the 51fd isnt as great as say a toshiba hd player im lost. I thought we were all in source direct mode and if that is so aren't we passing the discs native output on to the next connected device in the chain? I am wrong on this or are you changing the source direct to 1080p on the 51fd when playing sd-discs.
Also does anyone know what type of upscaler is in my Pioneer PDP-5010 my AVR has a Farojda dcdi.
It would be up to you to decide if you prefer the Faroudja to the upscaling of the 5010. I use my Reon simply because I paid for it, not necessarily because it looks better than the 5010's upscaling. Bottom line, the 5010 upscales pretty well.
mrjktcvs is offline
post #176 of 30990 Old 08-12-2008, 09:41 AM
Yes. Sony. But Pioneer has been just as efficient (firmware wise) w/ their first generation HD1 (which is kind of a sister machine to the BDP-S1)
post #177 of 30990 Old 08-12-2008, 09:45 AM
Ruined's Avatar
Quoted: 262 Post(s)
Liked: 82
Pioneer made all of the 1st and 2nd gen players for Sony.
Ruined is offline
post #178 of 30990 Old 08-12-2008, 09:53 AM
HTMan34's Avatar
Also the HD1 is still a rock solid BD player for a 1st gen player and being almost 2 years old!
Go Celtics!
HTMan34 is offline
post #179 of 30990 Old 08-12-2008, 10:05 AM
b_scott's Avatar
Quoted: 37 Post(s)
where are the people who are buying these getting them? Best Buy?
b_scott is offline
post #180 of 30990 Old 08-12-2008, 10:08 AM
gonzalc3's Avatar
Quoted: 167 Post(s)
Liked: 142
Now that there are a certain number or players out there with the 51FD v 10 firmware, I think it will be useful to create a new thread with the list of bugs found so far. This will help a lot to pioneer...
gonzalc3 is offline
Reply Blu-ray Players
Blu Ray Players , Excellent Pioneer Bdp 05fd Blu Ray Player , Pioneer Bdp 51fd Bonusview Blu Ray Player
