Samsung BD-2550/BD-P2500 Master Thread - Page 139 - AVS Forum | Home Theater Discussions And Reviews
post #4141 of 7086 Old 04-03-2009, 10:05 AM
johnny5's Avatar
The cnet review of the 2500 has the following comment.
"The BD-P2500 has comprehensive soundtrack support, with onboard decoding for Dolby TrueHD and DTS-HD Master Audio, as well as bit-stream output for both formats. Onboard decoding means that even those with older receivers will be able to enjoy Dolby TrueHD and DTS-HD Master Audio in full resolution over the HDMI output or the analog outputs."
Does this mean my older receiver, yamaha vx-r1600, should be able to play 7.1 DTS-HD MA via the HDMI output if its set to PCM???
johnny5 is offline
post #4142 of 7086 Old 04-03-2009, 10:14 AM
Gaddis78's Avatar
Yes, I've played "Quantum of Solace" successfully on my Samsung 2550....no glitches or skips at all.
Gaddis78 is offline
post #4143 of 7086 Old 04-03-2009, 10:27 AM
alokeprasad's Avatar
Quoted: 43 Post(s)
Originally Posted by NetworkTV View Post
Honestly, rather than sharing media with a PC, I'd almost rather be able to plug in a USB drive full of photos, music or videos and have the player access it directly. That way, I could, say, set up a photo slide show to run in the background on my TV when company visits without running a separate computer.
Can't the 2500 already display pictures off the USB drive?
I have thousands of MP3 files on my home network. It would be great if the 2500 could access those and feed it to an AV receiver.
alokeprasad is offline
post #4144 of 7086 Old 04-03-2009, 10:37 AM
nymjk's Avatar
Regarding analog audio output: I'm running a 5.1 setup, 2550 set to bitstream audophile. Thing is that when doing the speaker setup, the fronts and center play correctly but the surrounds play through the corresponding fronts (left surround plays via left front; right through right) and the sub doesn't play at all. Any thoughts as to settings or testing?
nymjk is offline
post #4145 of 7086 Old 04-03-2009, 11:24 AM
ResIpsa's Avatar
Yes, that's exactly what it means
ResIpsa is offline
post #4146 of 7086 Old 04-03-2009, 11:34 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 418
Sounds like you also have optical or coax digital audio connected and your AVR picked up the digital audio (2.0 stereo for test tones) instead of analog 5.1.
Foxbat121 is offline
post #4147 of 7086 Old 04-03-2009, 12:40 PM
johnny5's Avatar
Then my 2500 had issues. When connected via HDMI, I didn't see the rear speaker icons light up on the receiver's display for 7.1 movies. Also the test tone would not output to the analog surround rear connections.
I just sent it in for repair, of course the labor warranty has expired(bought the unit in November and hooked it up in January). Anyone else have this issue?
johnny5 is offline
post #4148 of 7086 Old 04-03-2009, 01:51 PM
Dubaruba's Avatar
Please forgive me if this has already been answered.
I am looking for a way to listen to audio (either Pandora or an audio CD) through my BD-P2550 with the TV turned off.
Currently the Blu-Ray player is attached by HDMI cable through an Onkyo A/V receiver and into a Samsung PN50A550 TV. When I turn off the power on the TV, the audio output from the Blu-Ray player stops.
Is there a work around for this problem or am I stuck with the annoying "Samsung" screen saver any time I want to listen to music?
Thanks in advance for helping out a newbie.
Dubaruba is offline
post #4149 of 7086 Old 04-03-2009, 02:11 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 418
It's not entirely Samsung's fault. It is how HDCP works/enforces.
Try this way:
1. Don't turn on your TV.
2. Turn on the receiver.
3. Turn on the player and somehow play the music.
If your receiver is designed properly, you will be able to listen to music without TV on. Not all the receiver can do this though.
However, if you already have TV on, the player will have HDCP linke from TV to player by design. Receiver is just act as a relay device. If you shut off the TV, the link is broken and your player should stop sending out anything that requires HDCP.
post #4150 of 7086 Old 04-03-2009, 02:22 PM
nextoo's Avatar
Try running optical from the 2550 to the Onkyo (in addition to your HDMI). Tune in Pandora, turn your TV off and switch to the optical input on the Onkyo.
nextoo is offline
post #4151 of 7086 Old 04-03-2009, 02:36 PM
Dubaruba's Avatar
Great idea. I will try this tonight! Thanks!
Dubaruba is offline
post #4152 of 7086 Old 04-03-2009, 03:55 PM
pcdo's Avatar
Quoted: 32 Post(s)
Liked: 101
What receiver and connection are you using? Bitstream audiophile will send the compressed HD audio over HDMI 1.3 so that the receiver can decode it, assuming that your receiver has the proper codecs to decode it. If you're not using HDMI 1.3 or your receiver doesn't have DDTrueHD or DTSMA codec support then you should be using PCM (if using HDMI), or you'll have to use analog outs from the player into your receiver (if you don't have HDMI). If you don't care about HD audio at all then you can just use the bitstream reencode instead.
pcdo is offline
post #4153 of 7086 Old 04-03-2009, 06:31 PM
hdtv_crazy's Avatar
Why do SD DVD menus always pixelate for a second when you select menu items? I also noticed the Samsung/Neflix/Pandora logos are heavily pixelated after a DVD stop. But they are smooth after you stop a Blu-ray or when you leave the Netflix menu. Bad Reon chip! Bad!
hdtv_crazy is offline
post #4154 of 7086 Old 04-03-2009, 06:36 PM
kevinjs123's Avatar
I just went through the FW update and have "A Netflix" as an option. But I do not have "B Pandora" I did the update check to see it missed something but is telling me no new ones. Do I have do do something special to get pandora or should it have loaded just like netflix?
kevinjs123 is offline
post #4155 of 7086 Old 04-03-2009, 06:53 PM
Quoted: 43 Post(s)
Do you have BD-2550 or BD-P2500? Only the former has Pandora.
post #4156 of 7086 Old 04-03-2009, 07:07 PM
heticor's Avatar
I got BD-2550, I look through the menu and the owner manual. I could not find where it could be activate.
any advise? thanks
heticor is offline
post #4157 of 7086 Old 04-03-2009, 07:19 PM
laserjock II's Avatar
Quoted: 778 Post(s)
Liked: 442
any advise? thanks
How did you upgrade the firmware? internet or disc/usb?
laserjock II is online now
post #4158 of 7086 Old 04-03-2009, 07:24 PM
kevinjs123's Avatar
Originally Posted by alokeprasad View Post
do you have bd-2550 or bd-p2500? Only the former has pandora.
Oooh....2500
post #4159 of 7086 Old 04-03-2009, 07:26 PM
VisionOn's Avatar
Liked: 2376
any advise? thanks
you need the updated online manual.
http://org.downloadcenter.samsung.co.../P2550_XAA.pdf
VisionOn is offline
post #4160 of 7086 Old 04-03-2009, 08:50 PM
prostar5's Avatar
Originally Posted by heaneyj View Post
Has anyone with a 2500 successfully watched 'Quantum of Solace' or 'Twilight'?
yes both.....should I have anticipated a problem???
prostar5 is offline
post #4161 of 7086 Old 04-04-2009, 06:41 AM
TheBigVanilla's Avatar
I've had the BD-P2550 for a few months now. The only recurring problem I've had is, depending on the disc, the "Bonus View" icon will show up onscreen even when I have that function turned off. Has anyone else had this problem? It happened all through "Twilight" as well as that post-apocalyptic movie with Rhona Mitra (title escapes me). Nothing I do with the remote affects this.
Any ideas?
TheBigVanilla is offline
post #4162 of 7086 Old 04-04-2009, 06:48 AM
mikeynavy1's Avatar
Quoted: 14 Post(s)
Any ideas?
I posted about this a few days ago...you're not the only one. I went to Samsung's web site and they are supposedly aware of the situation and incorporating into the next firmware update...whenever that is. To turn it off I had to go into the main player menu and change "On-screen menus" to "Off." Unfortunately, that also turns off the little bar at the top that shows you when you fast forward or rewind, or whether it's a Blu-Ray or DVD in the player. Temporary fix though...my girlfriend was annoyed when those kept popping up during Twilight.
mikeynavy1 is offline
post #4163 of 7086 Old 04-04-2009, 11:44 AM
ab2ab's Avatar
Yes, and its VERY annoying!!
I've noticed it and its definitely some sort of bug as I've had two earlier model 2550's (10/08 build dates) and one 01/09 build date model and latter does not exhibit the problem as the earlier ones. Also, you will notice that if you select the "low" setting on the Sharpness and Noise Reduction modes, you will find that this setting will introduce obvious jaggies and artifacts (SD DVD) beyond what is normally expected when selecting these modes.
Anyway, I still have my 2550 from eoutlet (I only use it to compare SD performance with my Oppo 981; I use my Samsung 1400 for BD because it offers better PQ than the 2550 on my display) and hopefully Samsung addresses this issue with a FW fix soon. However, they won't know unless you inform them.
ab2ab is offline
post #4164 of 7086 Old 04-04-2009, 11:58 AM
nymjk's Avatar
Connected to Denon 3805 via both optical digital and analog (and Pana plasma via HDMI). Further oddity is that NOW it works just fine, no matter what the 2550's setting is (although when set to PCM output does not send any digital to 3085, only when set to one of the two bitstream outputs).
nymjk is offline
post #4165 of 7086 Old 04-04-2009, 04:09 PM
mikeynavy1's Avatar
Quoted: 14 Post(s)
My 01/09 build still does it, so it isn't necessarily the month it was manufactured.
post #4166 of 7086 Old 04-04-2009, 07:15 PM
Opusnbill7's Avatar
I also haven't noticed it on my 10/08 built one, so I think there must be something else involved...
Opusnbill7 is offline
post #4167 of 7086 Old 04-05-2009, 04:42 AM
heticor's Avatar
any advise? thanks
Thanks very much, I got mine from eoutlet , I don't know what software version I had.
I will download the update.
heticor is offline
post #4168 of 7086 Old 04-05-2009, 06:36 AM
heticor's Avatar
I download the latest usb file from samsung site, then I hookup the ubs drive to the bd, every thing looked ok, then it turns off. After that I turned it on, check for the software version and it did not change. hooked up the uSB drive again the BD said that a new version of software was available, I did the whole process again. it turned off when it finished then I turned on again, nada the software version still the same.
What I did wrong?
heticor is offline
post #4169 of 7086 Old 04-05-2009, 07:32 AM
feisty1's Avatar
What I did wrong?
I upgraded via the Ethernet cable directly and initially had a problem also. Initially got nowhere like you. Since mine was a refurb. unit form E-outlet, I opened the disc drawer to see if someone had left a disc. inside. No disc. However, once I closed the drawer, the unit came alive and the download went smoothly! Try opening and closing the disc. drawer.
feisty1 is offline
post #4170 of 7086 Old 04-05-2009, 07:42 AM
rjf
rjf's Avatar
just found out that the 2550 is discontinued!! i LOVE mine but am i bit concerned about Pandora being dropped. do you think it'll continue to be supported? i love Pandora on this player!!! can't be beat! so happy i got mine and have been loving it since it was released!
rjf is offline
Reply Blu-ray Players
