Samsung BD-2550/BD-P2500 Master Thread - Page 221 - AVS Forum | Home Theater Discussions And Reviews
post #6601 of 7086 Old 06-30-2010, 07:19 AM
milou6's Avatar
Originally Posted by Hotkey View Post
When inserted, it wanted to download updates. Then it played coming attraction trailers. Then BDP 2500 reads MENU but nothing ever comes on TV!?
Precisely why I disabled bd-live, studios abusing it like this. And calling it "updates" to make you think it's necessary? Arg! Not that this has anything to do with the movie not playing, just my 2 cents...
milou6 is offline
post #6602 of 7086 Old 06-30-2010, 07:21 AM
milou6's Avatar
Anyone think we may get Hulu now that Samsung will be offering it on all their newer players and tvs ("Hulu Plus", a paid subscription servide)?
milou6 is offline
post #6603 of 7086 Old 06-30-2010, 08:42 AM
Hotkey's Avatar
Is disabling that a function of the Samsung player?
Hotkey is offline
post #6604 of 7086 Old 06-30-2010, 08:11 PM
Dansyacht's Avatar
Yes. Setup --> Network Setup --> BD-Live....
Dansyacht is offline
post #6605 of 7086 Old 07-01-2010, 11:09 AM
Stanton's Avatar
Quoted: 1550 Post(s)
Liked: 798
I also turn off BD-Live so I don't get the 'Netfix keys hacked' message.
Yamaha RX-A2050 AVR (5.0.2)
(4) Polk Monitor 10B's (R/L F/R), (2) Polk Monitor 4's (TM), Polk CS300 center channel
Analog: B&O TX2 Turntable, Nakamichi Cassette Deck 1
Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-Ray
LG 65EF9500 4K OLED
Stanton is offline
post #6606 of 7086 Old 07-01-2010, 12:43 PM
Hotkey's Avatar
Originally Posted by nate358 View Post
weird I thought I just posted about my experience w/ this movie today but I don't see it.
Go to Samsung's website and update to the lastest drivers. for some reason the player won't do it itself. once at the movie menu you may need to go to scene selection in order to play the sound and video.
it took me 3 hours to get that movie to play last night. good luck
Heck I just caught up to this post! Thanks. Are you telling me that my player telling me "no updates available all good" is not correct? That's pretty lame! I'll check the website. How do I update with downloaded drivers?
I swapped discs at the store but same issues.
Hotkey is offline
post #6607 of 7086 Old 07-01-2010, 12:44 PM
Hotkey's Avatar
I turned off the BD Live thing thanks. Disc still wont play.
Hotkey is offline
post #6608 of 7086 Old 07-01-2010, 05:22 PM
Hotkey's Avatar
Updated drivers worked. Thanks!
Hotkey is offline
post #6609 of 7086 Old 07-10-2010, 02:22 PM
NavinJohnson's Avatar
Originally Posted by JAMTUFF View Post
THERE ARE THREE right under the laser lens chassis. FIX-GET A PHILIPS MINI SCREW DRIVER/TUNERS-LIKE THE ONES USED TO FIX WATCHES. DISSASEMBLE THE CD LOADING MECHANISM AND REMOVE AV CIRCUIT BOARD UNDER IT TO GET TO UNDERSIDE OF LASER CHASSIS/ASSEMBLY. (TECH KNOWLEDGE IS RECOMENDED).
NOTE ORIGINAL TUNER POSITION-doesnt realy matter if you forget. Then just turn them FULL counter clockwise continously a couple of times X15 then clockwise. DO THIS FOR ALL THREE TUNERS. REASSEMBLE THE CD MECHANISM.
I just tried this. After a few seconds of unscrewing my first screw, the screw head disintegrated and fell off. I guess my 2550 is going in the trash. Never buying another Sadsung product.
NavinJohnson is offline
post #6610 of 7086 Old 07-10-2010, 03:27 PM
Actually, if anyone wants to buy my 2550 for parts, just PM me. (I posted above that I tried the tuner screw fix and the screw disintegrated). I'll cut you a deal. It was working just fine except for the freezing.
post #6611 of 7086 Old 07-10-2010, 04:00 PM
Matt L's Avatar
Quoted: 328 Post(s)
Liked: 297
On my second unit I've been having the heat issue for as long as I've owed it. Finally got fed up, pulled the main board. Found the two foam pads positioned pretty much directly under the ICs. Removed them and the unit has been working fine since. Even left it on overnight and it still played. Still have the cover off but I've never had that much luck before.
I assume the foam pads were to act as heatsinks, but they did a lousy job of it. Might look for some "real" heat sinks and rotozip out the bottom to accommodate them. But I did pick up a Sony BX37 for $60 on ebay so this one might get shuffled to the closet for a while.
Matt L is offline
post #6612 of 7086 Old 07-11-2010, 06:59 AM
Stanton's Avatar
Liked: 798
My guess is the "cover off" is helping a lot. I would still find some way to draw the heat away from those ICs so they don't age rapidly (or put a fan behind the unit).
LG 65EF9500 4K OLED
Stanton is offline
post #6613 of 7086 Old 07-11-2010, 10:19 PM
Matt L's Avatar
Quoted: 328 Post(s)
Liked: 297
I was still having issue with the cover off, been that way for months. Once I removed the foam pads, no issues. Is this truly the proper placement for those? Seems really stupid, foam does not transfer heat well.
I may try replacing the cover and see what happens...
Matt L is offline
post #6614 of 7086 Old 07-12-2010, 04:32 AM
Stanton's Avatar
Liked: 798
That 'foam' is a special kind of heat conductor. Based on other posts, my guess is they either didn't use the proper adhesive or they weren't properly mounted (on some units), but either way you need to expel the heat from those couple of chips.
LG 65EF9500 4K OLED
Stanton is offline
post #6615 of 7086 Old 07-12-2010, 08:02 AM
TNVOL's Avatar
The Samsung is now in a bedroom without Ethernet. What is the best way to get WiFi to this unit? Can you hook up a USB WiFi to the rear USB port on the 2500 or do I need one of those expensive WiFi to Ethernet bridges?
TNVOL is offline
post #6616 of 7086 Old 07-12-2010, 08:08 AM
Stanton's Avatar
Liked: 798
You can either do a "bridge" (I converted an old Wi-Fi Router to a bridge with DD-WRT) or something like a power over ethernet adapter. Basically, there was no custom/dedicated Wi-Fi adapter for this model (which are overpriced anyway).
LG 65EF9500 4K OLED
Stanton is offline
post #6617 of 7086 Old 07-12-2010, 08:32 AM
dxjnorto's Avatar
It's cheaper to crawl around in the attic if you have access to your attic and put in cat 5e cable or (cat 6) and use one of these hubs/switches:
Cisco SF 100D-05 5 Port Desktop 10/100 Switch
dxjnorto is offline
post #6618 of 7086 Old 07-12-2010, 11:44 AM
hobbes9's Avatar
I don't know about that. I did a wireless bridge (converting an old Linksys WRT54G using DD-WRT) as well. You can get compatible routers these days for $25 and get DD-WRT up and running on it within an hour. Another 15 minutes of configuration and you're good to go.
hobbes9 is offline
post #6619 of 7086 Old 07-12-2010, 02:02 PM
Dansyacht's Avatar
Try Googling "powerline network adapter" or click HERE.
These work great. I use them at home to connect my Sammy and PS3 to my network. They are mostly plug and play with minimal or no setup required.
Dan
post #6620 of 7086 Old 07-12-2010, 08:49 PM
dxjnorto's Avatar
Nothing seems as reliable to me as good old copper. Well, you've got lots of ideas TNVOL.
dxjnorto is offline
post #6621 of 7086 Old 07-14-2010, 11:42 AM
JAMTUFF's Avatar
GUYS!! The amount of pressure needed to tune the screws is less than say "cleaning your eardrums with a q-tip"-THAT MUCH WHICH IS VERY LOW AND USE THE TINY TUNER SCREWDRIVERS.You can find them at Radioshack .
2 years and my playing wont freeze for nothing even does an increadible job of reading smudgy discs better than my 2010 sony dvd player/recorder.
JAMTUFF is offline
post #6622 of 7086 Old 07-23-2010, 11:27 AM
mikeynavy1's Avatar
Quoted: 14 Post(s)
Well, we are getting a new TV for the bedroom, and I think I'll change the 2550 to bedroom duty. Which of these players (~200) would be the best replacement for the 2550:
Panasonic BD85K
Sony S570
LG BD570
Picture quality is the main feature, but speed, reliability, and features are also important.
mikeynavy1 is offline
post #6623 of 7086 Old 07-23-2010, 09:33 PM
Matt L's Avatar
Quoted: 328 Post(s)
Liked: 297
I bought a Sony 370 to possible replace my 2550. It's FAST! Lots of extras too. But I see from various reports that the 2550 is still tops with Netfix and DVDs playback.
Matt L is offline
post #6624 of 7086 Old 07-24-2010, 06:29 AM
Stanton's Avatar
Liked: 798
The truth is none of those players really match up to the 2550. If you want comparable video quality, you'll have to spend more $$ (like the Oppo), but then you won't have Netfilx.
LG 65EF9500 4K OLED
Stanton is offline
post #6625 of 7086 Old 07-24-2010, 04:56 PM
mikeynavy1's Avatar
Quoted: 14 Post(s)
Thanks. I decided to get a Sony S570 and people on here are right. The Sony is blazing fast and a lot more responsive to commands (e.g. FF, Rewind, Chapter, etc.). Blu-Ray quality is as good if not better. The 2550 still trumps in the DVD upconvert area but the Sony isn't bad. I wish there was an affordable HQV or Anchor Bay player that had Netflix, Pandora, etc.
post #6626 of 7086 Old 07-24-2010, 05:01 PM
VisionOn's Avatar
Liked: 2376
That's a coincidence. Just last night I was thinking that it was time to get rid of the 2550 for precisely those reasons.
Over the time I've had the unit, the lack of response to transport controls and the fact it has to slowly churn through menus when all you want to do is go into the player settings and adjust the PQ has worn on my nerves.
I'm on the fence about buying another player or just waiting for the next Oppo to be released.
VisionOn is offline
post #6627 of 7086 Old 07-24-2010, 05:04 PM
VisionOn's Avatar
Liked: 2376
Nope.
Support for this unit is over beyond a major release incompatibility.
We got left behind years ago when the cheaper boxes started getting features we could easily have received.
VisionOn is offline
post #6628 of 7086 Old 07-25-2010, 10:11 AM
silvercans's Avatar
Guys without the remote, can you get a movie to play? Someone told me no, it stays on the main menu
silvercans is offline
post #6629 of 7086 Old 07-26-2010, 04:12 AM
Stanton's Avatar
Liked: 798
That's true for many DVD players. Buy a pre-programmed universal remote and select Samsung Blu-Ray for the device.
LG 65EF9500 4K OLED
Stanton is offline
post #6630 of 7086 Old 07-26-2010, 09:19 AM
silvercans's Avatar
Right the universal is no prob but doesnt the P2550 have a play button on the front panel? Shouldnt that start the movie?
Reply Blu-ray Players
