Samsung BD-2550/BD-P2500 Master Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 7086 Old 08-24-2008, 12:50 PM
iove's Avatar
To those with a heat problem, why don't you stack it on top of a component that is not on the same time as the bluray player? I stack it on top of my Oppo dvd player that is never on at the same time. I check it after a few hours and the oppo is warm, not hot, which means it is acting like a heatsink for the bluray player.
iove is offline
post #92 of 7086 Old 08-24-2008, 12:54 PM
TSalt's Avatar
Originally Posted by mcdon283 View Post
Tsalt, now that the towel is on, i slowly lift up the player and feel on top of the dvr and it's just warm, not hot, like it was before the towel. DO you think the towel is a good idea or won't do anything?
Personally, I think it's a bad idea. I would want as much heat dissipation as possiable...
TSalt is offline
post #93 of 7086 Old 08-24-2008, 12:55 PM
narcopolo's Avatar
Originally Posted by GizmoDVD View Post
Can you 100% confirm it internally decodes DTS MA?
No mention of that on the box. I saw one at Best Buy today. So I'd say no.
narcopolo is offline
post #94 of 7086 Old 08-24-2008, 12:56 PM
mcdon283's Avatar
Well thats understandable, but would you rather touch hot metal bare handed or with a towel over your hand? I'd assume the latter. This is also assuming Samsung makes a pretty unstable product if they can't last on top of a typical DVR, but I'm just saying.
mcdon283 is offline
post #95 of 7086 Old 08-24-2008, 01:05 PM
EWL5's Avatar
TSalt told you the towel is going to act like insulation. Insulation is the lack of heat dissipation. In plain english, the heat's not going anywhere! You're just letting the heat build up!
Pioneer broke my heart.
Denon broke my wallet.
Oppo broke my thinking.
EWL5 is offline
post #96 of 7086 Old 08-24-2008, 01:12 PM
mcdon283's Avatar
You do not need to give me the definition of insulation. The idea however, is to keep the heat from geting to the BD-P2550, so maybe insulation would be a good idea in this case...still debating, because with the thin towel in between the 2, the 2550 is not nearly as hot.
mcdon283 is offline
post #97 of 7086 Old 08-24-2008, 01:17 PM
wnorris's Avatar
I put a small very thin towel in between both the DVR and the Blu Ray. I'm not going to put the DVR on top of the 2550, as the DVR is quite a bit heavier and I don't want such a heavy unit on such a fragile piece of equipment. The player is now not running hot at all.
By the way, your right in that it's probably about 125 degrees. But I also don't run my DVR 24 hours per day, more like 4 hours a day. Most of the time it's just off. Is the thin towel a good idea?
Towel on, kill your DVR quicker.
Towel off, kill your BD player quicker.
Your choice...
wnorris is offline
post #98 of 7086 Old 08-24-2008, 01:20 PM
EWL5's Avatar
To each their own. Electronics fail rather quickly when heat is allowed to build up. I guess if you're going to abuse something, the cable company's DVR is fair game. As Stew4msu stated, your DVR is really in a state of standby and not really "off."
EWL5 is offline
post #99 of 7086 Old 08-24-2008, 01:22 PM
EWL5's Avatar
Your choice...
Yeah, it doesn't get simpler than that. There is really no option other than to stack? What about a small rack?
EWL5 is offline
post #100 of 7086 Old 08-24-2008, 01:31 PM
mcdon283's Avatar
I'll have to think of something. I got a brand new TV stand thats rather expensive, and I've gone through quite a bit of hell already setting up my tv, ( Sony BDP-S350, had 2 of them, both gave static, had to take them back. Comcast DVR had a faulty HDMI Input, had to take it back) now I'm finally set up and gotta go through more ****. Jeez.
I think I'm gonna call Samsung and see what they think.
P.S. Why are there no decals on the wheel in front of this blu ray so you know which is resume and stop, etc. Seems awfully odd.
mcdon283 is offline
post #101 of 7086 Old 08-24-2008, 03:07 PM
TSalt's Avatar
Good Luck!!
But, I have a feeling they will tell you, or should tell you, as is written in the manuel, page 5 under PRECAUTIONS....
"Do not block any ventilation openings, install in accordance with the manufacturer's instructions."
Which, should cover the towel underneth the player. Notice how low profile the player is, then take note of the few small air exchanging holes on the bottom of the player...if for some reason you still insist on a towel, at least put some spacers under the feet....but again, adding insulation on top of your DVR is not a good idea...
"Do not install near any heat sources such as radiators, heat registers, or other player (including amplifiers) that
produce heat."
Pretty much says enough...so, setting ontop of another "heat source" would be a no-no....
TSalt is offline
post #102 of 7086 Old 08-24-2008, 03:07 PM
Stew4msu's Avatar
Why did you buy a brand new stand that wouldn't fit your equipment?
Stew4msu is offline
post #103 of 7086 Old 08-24-2008, 03:33 PM
mcdon283's Avatar
Good Luck!!
produce heat."
Thanks for the notice. Let me say tho that this Comcast DVR runs warm, not hot, so to think it would actually do damage would be highly unlikely, not to mention I'm only keeping this DVR for 9 months. There is space between the legs of the player and the towel, as this towel is VERY thin. The little towel has allowed this player to cool significantly. This is not a towel you shower with, it's almost napkin thin. I also might note that both players are in an open cabinent, and there's a window air conditioner about 6 feet away, not sure how much that helps, but it can't hurt. But you all honestly believe it would be best for the blu ray player if I remove the towel, I suppose I'd take your word for it.
mcdon283 is offline
post #104 of 7086 Old 08-24-2008, 03:55 PM
mcdon283's Avatar
Alright, you guys scared/convinced me enough to install a shelf on the wall next to the tv stand and I'll just place the blu ray there. But for now I'll leave it where it is ( 2 weeks, that gonna be ok? .
mcdon283 is offline
post #105 of 7086 Old 08-24-2008, 03:57 PM
rlsmith's Avatar
Originally Posted by rdjam View Post
...are you kidding us?
"New Bluray player introduced at $500 - without BD Live 2.0"
Not that I care anymore - I've given up waiting for Bluray to come down in price - I just don't care anymore. They seem so out of touch with their (potential) buyers now.
Oh well.
rdjam,
1. It is my understanding that the 2550 will have BD Live 2.0 through an udpate.
2. DTS HD MA seems to present some challenges. I recall that no HD DVD player ever was able to decode this on-board either. This is format-independent.
3. The PS3, introduced nearly 2 years ago, does decode all audio formats and is also 2.0. You can also be able to choose between a variety of machines shortly, including the Sony 350, Panasonic 50, 55, as well as highend machines like Pioneer.
At some point, we all have to decide if hd picture and sound is important to us our not.
rlsmith is offline
post #106 of 7086 Old 08-24-2008, 04:05 PM
Kage's Avatar
Quoted: 67 Post(s)
I'm really enjoy rewatching some of my dvds with this blu-ray player. The dvd performance (upscaling, playback, pq) is excellent. It's even better than the Toshiba XD-E500 dvd player that I bought yesterday.
Kage is offline
post #107 of 7086 Old 08-24-2008, 04:25 PM
TSalt's Avatar
+1
Been watching Farscape all day. Have had two freezes though....
TSalt is offline
post #108 of 7086 Old 08-24-2008, 04:46 PM
word302's Avatar
I really would consider putting the DVR on top of the 2550. The case of the 2550 should easily handle the weight of at least 2 or 3 components. Get rid of that towel before you fry both units.
Kent
word302 is offline
post #109 of 7086 Old 08-24-2008, 07:16 PM
mcdon283's Avatar
Kent
Alright, do you guys all agree that puting the DVR on top of the 2550 will be ok for both units. I really only care about the 2550, but for the DVR's sake also, I will lie the DVR on top if thats what would solve everything without having to add another shelf
mcdon283 is offline
post #110 of 7086 Old 08-24-2008, 07:28 PM
Stew4msu's Avatar
I would still add another shelf (although heat rises, the bottom of the DVR can get hot too), but for the next 2 weeks I'd put the DVR on top of the 2550.
Stew4msu is offline
post #111 of 7086 Old 08-24-2008, 07:29 PM
TSalt's Avatar
I would take the wifes/girlfriends knick knacks out the stand and make room for both...separately
TSalt is offline
post #112 of 7086 Old 08-24-2008, 08:39 PM
mcdon283's Avatar
Alright, tomorrow morn i'll unplug both units and put the DVR on top until I install the shelf. Thanks a lot guys.
mcdon283 is offline
post #113 of 7086 Old 08-25-2008, 05:30 AM
Voz
Voz's Avatar
Nice! How are the layer changes?
Voz is offline
post #114 of 7086 Old 08-25-2008, 05:41 AM
Tweakophyte's Avatar
Anyone upscaling SD DVD without using HDMI?
... starting the long process of upgrading to 4K in the Home Theater...
Tweakophyte is offline
post #115 of 7086 Old 08-25-2008, 06:29 AM
MrRoy's Avatar
Quoted: 66 Post(s)
Liked: 42
Check out coolerguys.com. I installed a kit w/ 2 80mm computer case fans that pull the heat out of my tv stand and nothing runs hot (my Onkyo 605 even runs cooler now). The power adapter converts works with the 3-pin connectors on the fans so it uses a normal wall outlet. Beware, though, you do have to cut a hole in the side/back you choose to install it in.
MrRoy is offline
post #116 of 7086 Old 08-25-2008, 07:02 AM
Kage's Avatar
Quoted: 67 Post(s)
Layer changes are quick.
Kage is offline
post #117 of 7086 Old 08-25-2008, 08:09 AM
kirbalo's Avatar
TSalt, et.al.,
What happened to all the internal pics everyone is thanking everyone else for posting...I see only two.
kirbalo is offline
post #118 of 7086 Old 08-25-2008, 08:16 AM
TSalt's Avatar
Originally Posted by kirbalo View Post
TSalt, et.al.,
still there...
TSalt is offline
post #119 of 7086 Old 08-25-2008, 09:08 AM
kirbalo's Avatar
I apologize if I stepped on anyones toes. 2550...
Note: I added the photo of the REON after it was bought to my attention it was left out.
Very strange...using Firefox 3.0. The pic downloads don't show up when I view your post. However, if I reply to the post, as I did here, then the URL's become visible.
And when I view this post, I can't see the URL's either...very strange.
kirbalo is offline
post #120 of 7086 Old 08-25-2008, 09:10 AM
Stew4msu's Avatar
I'm also using Firefox 3.0 and it works fine.
Stew4msu is offline
Reply Blu-ray Players
