First pics of Oppo's upcoming BDP-83 BD/DVD/SACD player from CEDIA - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 2797 Old 09-11-2008, 04:16 PM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 623
I would absolutely LOVE for the 83 to support HD DVD, but everyone including me just needs to forget about that becoming even close to reality. It is NOT going to happen. So it will be the BDP-83 on top, then the Onkyo DV-HD805 on the bottom.
Smarty-pants is offline
post #362 of 2797 Old 09-11-2008, 04:39 PM
miata's Avatar
Quoted: 65 Post(s)
And right when I was getting my hopes up for an OPPO player with 5 HD DVD movies bundled.
miata is offline
post #363 of 2797 Old 09-11-2008, 05:04 PM
Rob Tomlin's Avatar
Rob Tomlin is offline
post #364 of 2797 Old 09-11-2008, 05:58 PM
bakerwi's Avatar
Quoted: 66 Post(s)
Liked: 44
Originally Posted by smarty-pants View Post
i would absolutely love for the 83 to support hd dvd, but everyone including me just needs to forget about that becoming even close to reality. It is not going to happen. So it will be the bdp-83 on top, then the onkyo dv-hd805 on the bottom.
+1
Basement: Oppo BDP-105D, Denon DVD-5910CI, Arcam FMJ BDP300
Master Bedroom: Sony BDP-S790
Family Room: Oppo BDP-93, Pioneer BDP-320
Breakfast Area: Pioneer BDP-320
Office: Pioneer BDP-320, Cambridge 640C V2
Revel F208 (pair), C208
bakerwi is offline
post #365 of 2797 Old 09-11-2008, 08:33 PM
Tiwaz's Avatar
K, here's a hypothetical / theoretical question to anyone that is familiar with Oppo 983H upscaling abilities (because I think the BDP-83 will have comparable upscaling abilities) and also the DVDO Video Processor solutions (in particular, a familiarity with what the DVDO Edge might be capable of):
I jumped on the Pre-order buy of the Edge, because I'm still learning about video processors and wanted something simple and less expensive than something like the VP-50PRO (the HDMI output of the Edge was also significant to my purchasing it). I'm rebuilding my HT, and am trying to keep most cabling to HDMI where possible. I'm thinking that the upscaling abilities of the BDP-83 will be close to those of the DVDO Edge, but with slightly less ability (and yes, the upscaling abilities of the BPD-83 would be redundant in my situation of getting an Edge). Am I correct in my unguided assessment, or am I leaving somethings out?
Appreciate any guidance,
T
Tiwaz is offline
post #366 of 2797 Old 09-11-2008, 08:43 PM
Rob Tomlin's Avatar
T
I would say that you seem to have a pretty good grasp on the issues. What display are you using?
post #367 of 2797 Old 09-11-2008, 08:48 PM
Fanboyz's Avatar
Quoted: 510 Post(s)
Liked: 158
I have had a sony Dvpns9100es, a Denon 2930, borrowed my dad's Denon 5910ci, and now a Oppo 983.
The Oppo 983 is by far the best. It is without compromise the greatest dvd player made for consumer use.
LG OLED65B6P. Klipsch: RF82, RC62, RS52, RB61, RP-140SA. SVS PB-U13. Denon 6300H. Oppo 103D. Oppo UPD 203.
Fanboyz is offline
post #368 of 2797 Old 09-11-2008, 09:46 PM
Tiwaz's Avatar
Thanks for the "insanity" check Rob. Indeed, all the HT insanity got started when I obtained a Samsung 37A550 back in March. It's not the best, but a more than admirable start into LCD flatscreens (this is the first flat panel I ever purchased). If I recall correctly, it has a native resolution of 1080P/60 (which I understand is in the Edge's default output settings). I'm just looking for a nice HT setup that is easy to use. The plan is to hookup my old Pioneer Laser Disc player (if anyone knows a good place to send it to for maintenace / cleaning in Southern California, please PM me), a Verizon FIOS DVR, a SVHS player, and possibly a media streamer to the Edge. The Edge will send, via HDMI, the AV signals to the Samsung and the audio signals to a "To Be Determined" Reciever. At first, I was looking at the Onkyo 875/876, but now with the Edge in the picture, I may be leaning towards a Denon / Marantz / Yamaha / Pioneer Elite. I want to listen to the various receivers, hopefully playing through the same speakers and setups. I've a bunch of homework to do, but AVS Forums is helping alot (just way too much reading to do is all). Regarding Blu-Ray, I'm very interested hooking the BDP-83 into the setup, I just want to spend the $$ as wisely as I can.
Tiwaz is offline
post #369 of 2797 Old 09-11-2008, 11:42 PM
Rob Tomlin's Avatar
Based on your two posts here, it is obvious to me that you are doing your homework quite well and have a good understanding of what is going on. It's hard to say how much of an advantage the Edge might give you in combination with your displays native 1080p/60 resolution, but I am guessing it wouldn't be a lot better than what you will probably get with the Oppo.
If you want a superb receiver, take a look at the Pioneer Elite SC-09TX. The thread is located here: http://www.avsforum.com/avs-vb/showthread.php?t=1027273
And remember.....I didn't say it was cheap!
post #370 of 2797 Old 09-12-2008, 12:14 AM
Tiwaz's Avatar
LOL! Yeah, I was checking out the Pio Elite 94, Denon 3808, and Yamaha 3800 (maybe the Marantz 7002). I'm not sure how much the ethernet connectivity would be to me (that's the next bit of homework I have to do), except in updating FW, maybe HD FM stations. I'm even apprehensive about the ethernet connectivity of the Blu-Ray Profile 2.0, and how the studios intend to invade one's privacy etc with it. The BDP-83 may have some redundancy in the video processing area (for my planned setup), but it could come in handy if I move the player to another room that doesn't have all the HT equipment. The cost of this box will have a lot to do with my purchase. I like flexability, and the closest competitor to Oppo's Blu-Ray is the Pio 51, IMHO. So if Oppo hits the $599 mark . . . I could easily end up with the Oppo (even with the VP redundancy). I'll take a look at the Pioneer Elite SC-09TX. It may be "more receiver" than I'm looking for though, but I can sure appreciate the "high end" and save my pennies .
Tiwaz is offline
post #371 of 2797 Old 09-12-2008, 12:55 AM
CT_Wiebe's Avatar
Tiwaz -- You might also check out the Pioneer VSX-05 and/or VSX-07 models. They are lower end versions of the SC-09 and use the same ICE amplifiers, but not all the "bells & whistles" of the SC-09.
- Claus {non-Santa model}
CT_Wiebe is offline
post #372 of 2797 Old 09-12-2008, 01:02 AM
billybob0405's Avatar
I think you mean the SC-05 and SC-07. The VSX models do not have the ICE amps.
There are no answers, only choices.
billybob0405 is offline
post #373 of 2797 Old 09-12-2008, 04:38 AM
tutelary's Avatar
You folks have placed Oppo in the sad position of trying to be all things to all people. Not everyone is going to be disappointed, but it's quite inevitable many of you will.
tutelary is offline
post #374 of 2797 Old 09-12-2008, 05:29 AM
BENN0's Avatar
It's very clear from the released information so far what this player is and isn't going to be (i.e. not a transport). The only things that are worth speculating about are features that could be added via firmware updates.
For what it's worth I hope the "Region 1 only for now" statement is a political one and not a technical one, as speculated.
BENN0 is offline
post #375 of 2797 Old 09-12-2008, 08:53 AM
Dave Vaughn's Avatar
Quoted: 897 Post(s)
Liked: 1351
Rob,
I have a review of the SC09, which should be up at UAV any day now. Great AVR, if you can afford it!
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is offline
post #376 of 2797 Old 09-12-2008, 02:49 PM
facesnorth's Avatar
+1 (on all comments)
facesnorth is offline
post #377 of 2797 Old 09-12-2008, 04:52 PM
fresno1232001's Avatar
DVD-A is alive! Mark Waldrep at AIX Records keeps turning them out, and each is a work of art! Each is a new production, recorded live. No old tapes, in fact, no tapes at all. Everything is recorded on hard drives. They are the highest fidelity recorded audio ever offered to consumers. I own ~30 and keep buying them. If you buy over $100 worth, shipping is free.
Dr. Waldrep says he is experimenting with 7.1 channel hi rez audio on BR disks, and plans to re-issue some of his 5.1 channel DVD-As as 7.1 BR disks this fall. (fall of 2008).
If you want some recommendations as to which AIX to buy, PM me.
Originally Posted by Perpendicular View Post
Are you are referring to DVD-Audio & SACD? Many consumers own multiple discs in each format and would like to play them. Also, DVD-Audio has slowed but SACD hasn't died just yet. Titles are being released presently.
fresno1232001 is offline
post #378 of 2797 Old 09-12-2008, 04:54 PM
Rob Tomlin's Avatar
Originally Posted by Dave Vaughn View Post
Rob,
Nice Dave. I'll look for your review.
If I didn't already have an Anthem Statement D2, I would seriously consider the SC09 even though it is a receiver, not separates!
post #379 of 2797 Old 09-12-2008, 04:57 PM
Rob Tomlin's Avatar
AIX rocks!
Just having some of their discs is reason alone for Oppo to support DVD-A.
post #380 of 2797 Old 09-12-2008, 05:05 PM
Neuromancer's Avatar
Quoted: 83 Post(s)
Liked: 313
Good choice in the DV-983H as your CD transport.
Dave Vaughn's Pioneer Elite SC-09TX A/V Receiver is live
Neuromancer is offline
post #381 of 2797 Old 09-12-2008, 05:13 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Originally Posted by Neuromancer View Post
As I understand it OPPO will have several options available, all automatically controlled by the DVD player through its menu system. From what I have gathered, there are three modes:
1. Always Scale: no matter what the source material is, scale to the output resolution.
2. Always Scale SD; Leave 1080p/24 native: If the source material is standard definition, always scale. If the source material is 1080p/24, pass it as 1080p/24.
3. Source Direct: Always output at the native resolution.
As for output scaling for SACD (DVD-Audio is not in the product at this point) this is something I have discussed with them on several occasions. Still do not know if they will implement a separate option for forcing the player to an upscaled resolution for SACD media.
These seem like good options. I will be interested to see how 1080i/60 Blu-rays are scaled. One of the big drawbacks of the PS3 is it's inability to scale 1080i Blu-rays, which are common with concert discs.
Sam S is offline
post #382 of 2797 Old 09-12-2008, 07:16 PM
Kevin C Brown's Avatar
Liked: 27
Oppo + BD + me = can't wait. (OK, cheesy post, but it'll make it easier for me to search for updates in the future!)
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ... Something old and something new :-)
Kevin C Brown is offline
post #383 of 2797 Old 09-12-2008, 08:29 PM
JohnAV's Avatar
Quoted: 306 Post(s)
Liked: 452
Based on Oppo's history, its easy to understand why.
Oppo Beta Group
JohnAV is online now
post #384 of 2797 Old 09-12-2008, 09:17 PM
Quoted: 747 Post(s)
Liked: 623
Yes, thinking about the high quality BR player coming to you in the near future, makes you giddy like a young boy on Christmas morning.
Iiee'm, dreamiiiing, of an Oppooo, Chrismaaas.
Sorry, I had break out in song there.
post #385 of 2797 Old 09-12-2008, 11:02 PM
Quoted: 897 Post(s)
Liked: 1351
The 983 is the best DVD player I've ever used by far...it's also one hell of a transport for CD's.
Not only is it a "Jack of all trades," it is a "master of all!"
post #386 of 2797 Old 09-12-2008, 11:43 PM
DblHelix's Avatar
SACD/DVD-A with bitstream out for Blu-Ray plus conversion of DTS-MA and Dolby True HD to PCM and DSD out for SACD and I am in
DblHelix is offline
post #387 of 2797 Old 09-13-2008, 02:40 AM
Bronco70's Avatar
It's ok. Kind of like Ralphie and the Red Ryder dream!!!
Will a significant other shoot an eye out for buying ANOTHER oppo within the same calendar year?
Bronco70 is offline
post #388 of 2797 Old 09-13-2008, 03:42 AM
Healthleon's Avatar
Originally Posted by Frank Stein View Post
You're joking, correct?
It's a great looking player. Stylish and simple.
Yes, it's so beautiful, I have seen it on the show, the thread's owner is not good at take photo,
Healthleon is offline
post #389 of 2797 Old 09-13-2008, 07:12 AM
Oppo Beta Group
RichB's Avatar
Quoted: 873 Post(s)
Liked: 571
It would be nice if there were a better picture. Based on my 980H, I think it will look great.
One question though, If I keep my 980H, can you run both using an alternate set of remote codes?
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is offline
post #390 of 2797 Old 09-13-2008, 09:40 AM
gonk's Avatar
Jon's pictures (found somewhere in this thread) offer a much clearer view of the player. In those pictures, it looks quite nice.
We don't know yet. It's something I asked about late in the 983H testing, when some early reports had surfaced that OPPO was looking more seriously at doing a Blu-ray player.
gonk
Beta tester: BDP-83 / BDP-80
gonk is offline
Closed Thread Blu-ray Players
