Official Panasonic DMP-BD35/55 Owners Thread - Page 483 - AVS Forum | Home Theater Discussions And Reviews
post #14461 of 15032 Old 06-21-2011, 07:38 PM
m. zillch's Avatar
Quoted: 1939 Post(s)
Liked: 1235
No, I successfully applied my approach to 2 school principals' disc players.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #14462 of 15032 Old 06-22-2011, 08:27 AM
Mr. Mojo's Avatar
Originally Posted by m. zillch View Post
The blast of air works on two principles:
A) Cleaning away any small layer of dust which is blurring the laser's output or reflected view of that output.
B) Forcefully smacking it up side the head, similar to how one would kick a vending machine if it fails to dispense your soda . Your are hoping to dislodge something which is sticking. The thing is it is a delicate assembly which has to precisely focus on a surface which is so small that it is invisible to our unaided eyes.
If, let's say, your camera was having troubles , would you ever think to smack it ? Well oddly you may actually fix your camera in some instances by doing so, but do it by the wrong amount, a very hard thing to measure or describe over the web, and you may very well break some other aspect of your camera!
I guess to clean your lens more gently you could also dip a Q-tip in 99% alcohol , shake off the excess, and gently swab across the laser surface a few times, allowing it to dry before playing a disc, but I can't say I've ever done this.{ And I take no responsibility if anything goes wrong. } Others on the web talk about cleaning lasers in this way, for example Playstations, but "dirt/dust" may not even be your issue. It very well may be laser focus or angle, both which can be affected by heat build up which is supported by your observation that BD play fine for the first part of the movie and then get stuck.
You've exhausted my knowledge on the topic. Good luck.
I haven't figured out what I'm going to do yet, but I certainly appreciate the time you took here to try to help me out.
Mr. Mojo is offline
post #14463 of 15032 Old 06-29-2011, 03:52 PM
JOE.G's Avatar
When Was the last Firmware Released? Will there be more?
Samsung HL-T6176S 1080P DLP
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung PN50A650 1080P Plasma
Panasonic DMP BD 85 K
Samsung LN32C530F1F
Panasonic DMP BD10 A
JOE.G is offline
post #14464 of 15032 Old 06-29-2011, 03:58 PM
Gary J's Avatar
Quoted: 408 Post(s)
Liked: 215
Originally Posted by JOE.G View Post
Will there be more?
I can provide you with my paypal address and the answer.
Gary J is offline
post #14465 of 15032 Old 06-29-2011, 04:02 PM
JOE.G's Avatar
I figured there would not be, I went to the Panny site to check but was having problems with it.
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung LN32C530F1F
JOE.G is offline
post #14466 of 15032 Old 07-09-2011, 10:19 AM
oldie1kslowbie's Avatar
I haven't seen an update in a long time. I think the machine has been orphaned at this point.
oldie1kslowbie is offline
post #14467 of 15032 Old 07-09-2011, 12:40 PM
lujan's Avatar
Quoted: 2000 Post(s)
Liked: 807
I thought the same thing about my BTT-350 and just saw an firmware update message on the screen a day ago.
lujan
137 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is offline
post #14468 of 15032 Old 07-11-2011, 07:07 PM
Luisfc1972's Avatar
Quoted: 165 Post(s)
arent firmware updates only when a new blu ray movie comes out and doesnt play on the 35? if a new one comes out and has that problem, shouldnt they release the firmware update?
Luisfc1972 is online now
post #14469 of 15032 Old 07-12-2011, 09:20 AM
jwebb1970's Avatar
Liked: 38
That has been the case in the past. However, I'd think @ this point BD 2.0 has been around long enough that FW updates based on discs & thier certain features that may gum up the works are mostly done with.
I do seem to recall my BD35's first update that I performed had something to do w/ the Dark Knight BD & some of it's features?
Money does not buy happiness. It can, however, buy you a giant boat that you can pull up alongside happiness. - David Lee Roth
jwebb1970 is offline
post #14470 of 15032 Old 07-12-2011, 10:27 AM
m. zillch's Avatar
Liked: 1235
Yes, that's how I think it works, and here's my understanding of why:
Although I've never been able to pin it to a specific, on-line statement from a movie studio, it was my understanding that 99% of bluray 2.0 firmware "updates" are actually an exchange of " digital keys" which allow access to certain new movies, often tied to the very profitable "blockbusters", done to help the movie industry by preventing piracy.
post #14471 of 15032 Old 07-12-2011, 12:26 PM
L David Matheny's Avatar
Quoted: 17 Post(s)
Liked: 32
If that's true, and the newer movies really can't be played without player updates, then the manufacturers can never stop releasing firmware updates. I suspect that the studios are unscrupulous enough to love that sort of trickery, but it's surely a terrible burden to put on the manufacturers.
L David Matheny is offline
post #14472 of 15032 Old 07-12-2011, 01:20 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
I have original 2008 firmware on my BD55 and it has never failed to play a disc.
BIslander is offline
post #14473 of 15032 Old 07-12-2011, 01:42 PM
Rachael Bellomy's Avatar
Location: Knocksville TN, capitol por republica de Polezannia
Then all the players were not created equal. My 35 required firmware to play some Fox discs and maybe a few other thangs...it's hard to remember clearly back several players ago...
In real life I am Dot Mongur champion of the International Pacman Federation. I don't play the game, I operate it.....no dot is safe from me....
Rachael Bellomy is offline
post #14474 of 15032 Old 07-12-2011, 01:47 PM
Mr. Mojo's Avatar
Were you able to play Avatar? (blu ray version)
I couldn't get my BD35 to play it even with the latest firmware (4/26/10 FW).
Mr. Mojo is offline
post #14475 of 15032 Old 07-12-2011, 02:30 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
It's the discs that are not all created equal. Many (if not most) movies will play just fine on the early firmware versions, so if the dice fall just right, and someone happens to not watch any of the movies that DO require the updates, they'd be just fine.
Kalani is offline
post #14476 of 15032 Old 07-12-2011, 06:03 PM
JOE.G's Avatar
Avatar Would not play on my BD 10 A with the newest firmware ( 2008 ) I think, It did play on my BD 55 with the newest firmware with out an issue.
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung LN32C530F1F
JOE.G is offline
post #14477 of 15032 Old 07-12-2011, 10:25 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Yes.
post #14478 of 15032 Old 07-13-2011, 05:41 PM
Sgooter's Avatar
Quoted: 111 Post(s)
Liked: 92
I think the last FW update on my BD-35 was well over a year ago, and Avatar blu-ray plays fine. In fact, I've never had a blu-ray disc not play, and for the past 2+ years I've watched about 3-4 blu-ray movies a month via Netflix.
BD-35 been veddy veddy good to me, man.
Please enter password to view this signature.
Sgooter is offline
post #14479 of 15032 Old 07-13-2011, 06:11 PM
Luisfc1972's Avatar
Quoted: 165 Post(s)
if i remember correctly the last blu ray i couldnt play on my 35 was inglorious bastards, but then i downloaded the latest firmware and the movie worked
post #14480 of 15032 Old 07-14-2011, 12:10 AM
fmalczewski's Avatar
Quoted: 102 Post(s)
Liked: 39
Earlier in this thread there were some significant issues with one of the more recent Disney titles. Don't recall which. No firmware update since before then, so likely still an issue (although there was a pretty funky workaround, fwiw, nothing terribly obvious).
On the whole, 35 is/was veddy veddy good to me too. But, firmware's a little creaky on a few titles.
fmalczewski is offline
post #14481 of 15032 Old 07-14-2011, 06:20 AM
lujan's Avatar
Liked: 807
I know, a little off topic but it would have been better if "Inglorious Bastards" had never played. A very awful movie in my opinion.
lujan
137 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is offline
post #14482 of 15032 Old 07-14-2011, 05:46 PM
Quoted: 17 Post(s)
Liked: 32
Each to his own taste. I loved it. They did take a few liberties with history ....
post #14483 of 15032 Old 07-14-2011, 06:32 PM
Gary J's Avatar
Quoted: 408 Post(s)
Liked: 215
He got this part right.
Gary J is offline
post #14484 of 15032 Old 07-15-2011, 08:22 AM
lujan's Avatar
Liked: 807
Again, in your own opinion.
lujan
137 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is offline
post #14485 of 15032 Old 07-15-2011, 02:19 PM
kgilby's Avatar
I've had it a couple years now and it's been slow since day 1 (Slower than the old non-BluRay player). But it seems that it's even slower now. Is this typical for this player? Or are ALL BluRay players slow?
If it should not be slow, I'd love a recommendation on a new player to replace it.
kgilby is offline
post #14486 of 15032 Old 07-15-2011, 06:45 PM
Sgooter's Avatar
Quoted: 111 Post(s)
Liked: 92
Originally Posted by kgilby View Post
I've had it a couple years now and it's been slow since day 1 (Slower than the old non-BluRay player). But it seems that it's even slower now. Is this typical for this player? Or are ALL BluRay players slow? If it should not be slow, I'd love a recommendation on a new player to replace it.
When the movie is playing slow, try depressing the fast forward button one time; movie should then play a little faster, but I dunno if the sound speeds up too.
My -35 can sometimes take a minute or so to load, but plays perfectly: not too fast/not too slow.
Sgooter is offline
post #14487 of 15032 Old 07-15-2011, 08:53 PM
kgilby's Avatar
Thanks Sgooter. I didn't explain too well. The movies play at the right speed, but, like you describe, the dvd loads very slowly. And when skipping through previews, scenes, etc. it takes forever. I mean 'Go get a bowl of ice cream' slow. It seems really slow, but if all blu rays are slow there's no point in looking for a new player.
kgilby is offline
post #14488 of 15032 Old 07-15-2011, 11:16 PM
Quoted: 102 Post(s)
Liked: 39
Finally took the plunge and upgraded to an Oppo 93. It is not slow by any means. The technology marches onward. (Though I don't have BD-Live turned on for it, whereas I did for the '35). Keeping the '35 around just in case it can play something that the '35 can't; haven't had that happen yet, though.
post #14489 of 15032 Old 07-16-2011, 05:51 AM
Gary J's Avatar
Quoted: 408 Post(s)
Liked: 215
whatever... more OT.
Gary J is offline
post #14490 of 15032 Old 07-16-2011, 07:30 AM
Quoted: 102 Post(s)
Liked: 39
Not at all.
Reply Blu-ray Players
Blu Ray Players , Lg Bh200 Super Blu Blu Ray Hd Dvd Combo Player , Panasonic , Panasonic Dmp Bd35k 1080p Blu Ray Player , Panasonic Dmp Bd55k Blu Ray Disc Player
