Official Panasonic DMP-BD35/55 Owners Thread - Page 49 - AVS Forum | Home Theater Discussions And Reviews
post #1441 of 15032 Old 10-28-2008, 12:04 PM
SpHeRe31459's Avatar
Quoted: 16 Post(s)
Originally Posted by smjbh5 View Post
I'm in the same boat. Have an older Onkyo (SR600) receiver. I'm perfectly fine with plain old 5.1DD or DTS (for now). It's not going to sound any worse than a SD DVD player (via optical), is it?
No it won't sound worse, and in fact it will likely sound a bit better, because Blu-ray allows the maximum bitrate out of Dolby Digital at 640Kbit/sec whereas DVDs were locked into 448Kbit/sec. Likewise most DTS tracks on DVDs were 768Kbit/sec, and on Blu-ray the DTS tracks are usually the full 1.5Mbit/sec.
SpHeRe31459 is offline
post #1442 of 15032 Old 10-28-2008, 12:09 PM
Quoted: 16 Post(s)
So here's a question, since the BD-55/35 manuals aren't up online. Since the player supports decoding of all the audio codecs and of course it supports Bonus View, when using a PiP commentary the player I would presume, decodes both the primary and secondary audio into LPCM, and then either outputs it as LPCM over HDMI but what does it do over S/PDIF (optical)? Will it re-encode to Dolby Digital and/or DTS? or does it just leave it as is and you get 2-channel LPCM, thanks to the limitations of S/PDIF.
I'm also, pondering if with my rather basic sound system, whether it's even worth considering the BD-55 with the analog ouputs, I'm not really sure I'd hear any difference with my budget equipment.
post #1443 of 15032 Old 10-28-2008, 12:19 PM
BWG707's Avatar
Originally Posted by halsan40 View Post
I have some doubts about this rebate form. I do have a store receipt (required and a price match from EPP), but I believe from everything I have read, it is only for the BD35. Also it states that the original rebate form must be included, not a reproduction. I am very hesitant to send in my original receipt and the SKU from the box.
I wish there was a way to verify this rebate.
A few pages back is a link to the rebate form. I don't remember the two movies but sleeping beauty isn't one of them.
Just thought I would let everyone know I talked the Disney promotion people and everything is on the up and up, totatally legit. So print out the certificate, follow the instructions and hopefully the blu-ray movies will be here before X-mas. It's a great deal!
BWG707 is offline
post #1444 of 15032 Old 10-28-2008, 12:30 PM
lentiman's Avatar
Woohoo! Happy birthday to me. I just ordered a BD35 locally at our Magnolia HiFi in Seattle and will pick it up on my way home tonight. I'll be hooking this up to a Denon AVR-4308ci and then to my Elite Kuro (PRO110FD). I don't have a single blu-ray to my name though. I'm stoked about the rebate though, that sealed the deal for me. As soon as I finish my surround sound and sub wiring I'll go pick up a copy of Iron Man. Yeah! I'm running a 5.1 setup and plan on having the Denon do all the decoding so I don't anticipate having the problems everyone else is having. This will replace my Oppo 981 in my (completely full) HT cabinet.
lentiman is offline
post #1445 of 15032 Old 10-28-2008, 12:47 PM
General Kenobi's Avatar
Quoted: 357 Post(s)
Liked: 640
Source first my friend, garbage in garbage out Going with the 55 and using the analog outs will only sound better, it maybe that your current rig will bottleneck the SQ upgrade but it should still be an upgrade and one less thing you have to upgrade later.
Kenobi's 31 Days of Horror:
2012
2011
2010
2009
General Kenobi is offline
post #1446 of 15032 Old 10-28-2008, 12:52 PM
Quoted: 357 Post(s)
Liked: 640
I'm assuming you are talking about the 7.1 issues that have mustered a few questions/complaints?
I'll be using the 5.1 analogs and I'm really hoping I have the reliability with this that I have had with the 10A, it has been just flawless.
2012
2011
2010
2009
post #1447 of 15032 Old 10-28-2008, 01:03 PM
Quoted: 16 Post(s)
I hear ya, but the next thing on my list of equipment to change out is my receiver (mind you this may be a ways down the road), but it's still next. So I guess I'm wondering if I can get away with S/PDIF for ease and bass managment's sake. But I still don't know about the S/PDIF re-mixing question, I'm pretty sure the answer is no, once it decodes things into LPCM for PiP audio mixing it won't re-encode to DD or DTS for S/PDIF users to keep surround sound.
post #1448 of 15032 Old 10-28-2008, 01:09 PM
mtw4991's Avatar
Does anyone know if the BD35 clips BTB/WTW at the extreme ends. I'm pretty sure my Yamaha 663 does slightly clip both. Just checking to see which components my be slightly clipping BTW/WTW.
mtw4991 is offline
post #1449 of 15032 Old 10-28-2008, 01:17 PM
Quoted: 357 Post(s)
Liked: 640
hmmm... not sure, maybe someone else can chime in. I should have mine tomorrow and will be comparing it to my 10A which I expect to get a PQ/SQ upgrade from. I've had the 10A connected using the 5.1 analog outs and a coax. I switch to the coax input on my AVR for some movies with DD only and when playing CD's. I don't have to make any changes in the setup on the 10A just switch the selection on my AVR. I'm assuming the 35/55 will operate the same way... I have no idea if any of this helps you but fwiw.
2012
2011
2010
2009
post #1450 of 15032 Old 10-28-2008, 01:20 PM
snsguy's Avatar
Originally Posted by caa100 View Post
I have a 35 connected to a Samsung 750, which is very close to your TV. I have no problems with motion. I am running 1080p24 over HDMI to the Samsung. On the Ssamsung, I have AMP turned off. (I hate the effect of interpolation).
The picture is beautiful. The effect of fast motion is not much different than it is in a theater. Sometimes we AVS'ers look too hard for motion blur, forgetting that some of it is inherent in the 24fps framerate.
I guess I'm noticing it a lot on any type of panning scene on DVD's and it seems to happen with the incredible hulk which has a lot of movement in the action sequences. Maybe it is just me but it seems weird.
SNSGUY
snsguy is offline
post #1451 of 15032 Old 10-28-2008, 01:21 PM
snsguy's Avatar
Originally Posted by Opuntia View Post
You might also want to ask this question on the 650 thread so see if others see issues on their sets and to determine if it's specific to the TV or the BD player.
I did also post of there. Thanks for the suggestion.
SNSGUY
snsguy is offline
post #1452 of 15032 Old 10-28-2008, 01:24 PM
Quoted: 357 Post(s)
Liked: 640
SNSGUY
You're worrying me... I ordered the same unit from the same place about the same time as you... Have you made any setup adjustments to see if it makes a difference? What did the 55 replace for you?
2012
2011
2010
2009
post #1453 of 15032 Old 10-28-2008, 01:25 PM
lujan's Avatar
Quoted: 1907 Post(s)
Liked: 745
Did you send in the original receipt?
My TV is on the same receipt, and there's no way I'm sending in the original (need it for warranty).
I just printed out another receipt from the CC website. I hope it works.
lujan
132 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is offline
post #1454 of 15032 Old 10-28-2008, 01:28 PM
snsguy's Avatar
I'm a little confused as to what you ordered and where you ordered it from and what adjustments are we speaking of?
SNSGUY
snsguy is offline
post #1455 of 15032 Old 10-28-2008, 01:32 PM
Quoted: 357 Post(s)
Liked: 640
SNSGUY
Sorry, maybe I'm confusing you with another member that has posted in this thread. I'm talking about the BD55 from vanns and adjustments for component video (if in use) and 24fps. I'm still waiting for mine (should have it tomorrow) so fogive if any of this is premature.
2012
2011
2010
2009
post #1456 of 15032 Old 10-28-2008, 01:34 PM
snsguy's Avatar
Deffinetly not me I got mine at CC and I'm using HDMI and the analog's not. NO worry's though. We all need some help, other wise we wouldn't be here. hOpe you get yours figured out.
SNSGUY
snsguy is offline
post #1457 of 15032 Old 10-28-2008, 01:46 PM
smjbh5's Avatar
Quoted: 47 Post(s)
I bought my gear from Video Only (B&M store). My receipt is a carbon copy. It's strange that they're asking for the original.
smjbh5 is offline
post #1458 of 15032 Old 10-28-2008, 01:54 PM
jayridescarbon's Avatar
Guess you didn't ask whether the rebate was for the 35 only or includes the 55.
jayridescarbon is offline
post #1459 of 15032 Old 10-28-2008, 02:01 PM
boylan13's Avatar
Quoted: 17 Post(s)
Originally Posted by LarryChanin View Post
Hi Chris,
Can you please compare the noise and heat issues between the two players?
Larry
Not really, because the P3 models vary quite a bit in this respect and the one I have (60 GB) is no longer available for purchase. Yeah, mine is definitely louder than the BD55 (but it does not get hot where I have it), but I have heard the newer PS3s are much quieter.
-CB
Chris Boylan
Home Theater Editor
Big Picture Big Sound
boylan13 is offline
post #1460 of 15032 Old 10-28-2008, 02:08 PM
Ken Ross's Avatar
Quoted: 5700 Post(s)
Liked: 6066
There's nothing to worry about. Motion handling of the Panny at 1080p 24 should be no different than any other player on the market at the same frame rate.
Ken Ross is offline
post #1461 of 15032 Old 10-28-2008, 02:13 PM
Is it common for the same film to have different aspect ratios dependent on whether it is on SD DVD versus Blu-ray? The netflix page on Hulk lists it as 1.85, but the blu-ray disc I received today says its 2.35.
post #1462 of 15032 Old 10-28-2008, 02:19 PM
Quoted: 357 Post(s)
Liked: 640
Nexflix must be wrong... amazon is often wrong too. I'm looking at the copy I just picked up and it is also 2.35 and the times I've seen clips played on display it was not 1.85.
Ken Ross - Thanks, my TV is not 24 but from what I've read it does not have to be to still get a PQ upgrade from my 10A (not in 24 obviously). I'll be using the analog outs and purchased the 55 mostly for the SQ upgrade but I hope to see an improvement in PQ as well. I should have it tomorrow so I'll be sure to pop in some titles I am very familiar with to put it through some paces.
2012
2011
2010
2009
post #1463 of 15032 Old 10-28-2008, 02:24 PM
LJ25's Avatar
Quoted: 60 Post(s)
Could someone please check how the 55 handles 1080i. Meaning it successfully interlaces 1080p24 into 1080i60. Thanks!
Steam ID: J-Rod0125.
PC Specs: Gigabyte Z87X-UD4H, Intel Core i7-4771, Nvidia GTX 970, Samsung 840 Pro SSD, Western Digital Black HDD, Corsair 8GB Ram, SeaSonic SSR-650RM.
HT: Samsung 60F5300B, Wharfedale Diamond 10.4 Fronts, Wharfedale 10.CS Center, Power Sound Audio XS15-SE, Pioneer Elite SC-82.
LJ25 is offline
post #1464 of 15032 Old 10-28-2008, 02:58 PM
caa100's Avatar
They are online. Its been posted, but here are the links again:
US Manuals: http://service.us.panasonic.com/oper...px?model=DMPBD
Europe (search without hyphen, as in DMBPD35): http://www.panasonic.co.uk/html/en_G...l#anker_220239
Canada is up, too, I think its the same as the US manual.
Edit: Canada search here: http://panasonic.ca/english/customer...ions/query.asp
-Chris
caa100 is offline
post #1465 of 15032 Old 10-28-2008, 03:00 PM
Paul H's Avatar
Quoted: 33 Post(s)
Liked: 29
Both the North American and European manuals have been up online and posted in this thread for sometime now.
Here's the links to them again from post #1090
FYI reminder:
Now that both the European and North American Panasonic DMP-BD35/55 Owners manuals are posted on-line
Please note:
The European manual posted here, is different from the the North American manual posted here.
For example:
The European manual has the Analog-Audio-Out diagram on page 17.
The North American has the Analog-Audio-Out diagram on page 8.
Paul
Paul H is offline
post #1466 of 15032 Old 10-28-2008, 03:24 PM
Jack Gilvey's Avatar
Quoted: 35 Post(s)
Liked: 34
What do you see with the 35 plugged directly into your display?
Jack Gilvey
SVS Customer Service
Jack Gilvey is offline
post #1467 of 15032 Old 10-28-2008, 04:00 PM
Rick Col's Avatar
Does anyone know what the best settings for Black Level Control is when connected with HDMI? Lighter or Darker?
And am I correct in thinking that when using PCM in Digital Audio Output that it is alright to leave BD-Video Secondary Audio set to On. But if using Bitstream, Secondary Audio should be left Off? Or should I leave SA off all the time for the best sound in PCM and Bitstream?
Thanks in advance,
Rick
Rick Col is offline
post #1468 of 15032 Old 10-28-2008, 04:01 PM
mtw4991's Avatar
Jack, I haven't plugged the 35 into the set yet...lots of cables to move around, lol. A calibrator over on the Calibration thread said the Yamaha 663, like most yammys, does clip the last ramp past the 3 dots. I was just wondering if the BD35 did the same.....
What I was getting to was the fact that IF the BD35 and the 663 BOTH clipped, there would be no need or justification for a splitter. However, if it is just the 663 clipping, then PERHAPS a splitter would make sense to get a purer video signal to the 67A750 for calibration/viewing PLUS still have the DTS-MA/TrueHD played through the 663.
As it now stands, the BD35 is running HDMI thru the 663 and the 663 is clipping slightly at the last ramp.
Searching for near perfection, but accepting tradeoffs nonetheless, lol.
mtw4991 is offline
post #1469 of 15032 Old 10-28-2008, 04:13 PM
Quoted: 35 Post(s)
Liked: 34
I hear ya. I've never heard any mention in any review or thread about the 35 clipping, and people have calibrated them successfully.
C'est la vie.
Jack Gilvey
post #1470 of 15032 Old 10-28-2008, 04:23 PM
hobbyinn's Avatar
I am having a problem with pause while watching The Hulk. I can pause and unpause after a short delay, but if the pause is longer the "Universal" screen comes up and locks me out. I push Play and nothing happens. If I push Pause I get "This Operation is Disabled." Nothing happens until I push stop which takes me back to the beginning. This did not happen with Indy4, Golden Compass, Ratatouille and Iron Man.
hobbyinn is offline
Reply Blu-ray Players
Blu Ray Players , Lg Bh200 Super Blu Blu Ray Hd Dvd Combo Player , Panasonic , Panasonic Dmp Bd35k 1080p Blu Ray Player , Panasonic Dmp Bd55k Blu Ray Disc Player
