Official Panasonic DMP-BD35/55 Owners Thread - Page 501 - AVS Forum | Home Theater Discussions And Reviews
post #15001 of 15021 Old 12-29-2014, 02:09 PM
ausdavep's Avatar
You can control it through Viera Link if you turn it on and your tv remote has the applicable buttons (and your brand of tv talks nice via hdmi too)
ausdavep is offline
post #15002 of 15021 Old 12-29-2014, 02:35 PM
m. zillch's Avatar
Quoted: 770 Post(s)
Liked: 449
Originally Posted by rhett7660 View Post
Hello all, I did a search but was unable to find what I was looking for. Does anybody know if you can control the DVD player via the network port? I have it connected and I was wondering so that I don't have to connect a repeater to the front of it.
I downloaded the manual and it does not mention anything about controlling the unit via network commands.
The CD, DVD and BD discs can not be controlled via the network connection, so sorry, no.
In A/V reproduction accuracy, there is no concept of "accounting for taste". We don't "pick" the level of bass, etc., any more than we pick the ending of a play. High fidelity means an unmodified, neutral, exact copy (or "reproduction") of the original artist's tonal balance, timing, dynamics, etc..
m. zillch is offline
post #15003 of 15021 Old 12-29-2014, 02:36 PM
rhett7660's Avatar
That is what I was afraid of. Thank you both.
"Me Personally, I want to slay the dragon"
rhett7660 is offline
post #15004 of 15021 Old 12-29-2014, 07:05 PM
eaayoung's Avatar
Quoted: 174 Post(s)
Liked: 114
Originally Posted by andy sullivan View Post
Very informative and really helpful. If you assume I haven't joined this century perhaps you can offer something other than sarcasm. I put pictures on dvd's so that I can send them to family and friends. They all have dvd players. What would you suggest.
Andy, the format you're using with your camera may be the problem. jpeg files are very popular and convenient. However, jpeg files can change when you transfer the file. jpeg is referred to as a "lossy format" since some of the data is discarded when you make changes to the file. Formats such as RAW, PNG or BMP are better choices since format preserves all the original data when you make changes to the photo. Those formats are referred to as "lossless formats." I shoot photos in RAW then convert to jpeg when sending a photo to someone.
The only downside with the lossless formats, they are much larger and consume a lot more memory on the card. Of course, larger files means less pictures per card.
Here's a link to article that will provide information on the subject:
Formats such as RAW, PNG or BMP are better choices for photos since format preserves all the data when changes are made to the file.
eaayoung is offline
post #15005 of 15021 Old 12-29-2014, 07:59 PM
m. zillch's Avatar
Quoted: 770 Post(s)
Liked: 449
And jpegs are the only still image format the DMP-BD35 can play, so any further discussion of what "might" be better is irrelevant. RAW, PNG, and BMP will not work on his machine. He also had no gripes about the image quality he got from his camera when he played the SD card directly rather than burning it to disc. He wrote: "I put the SD card in my 35 and the pictures looked fantastic. I then down loaded the pictures onto a top quality dvd and the pictures lost a little sharpness. Not horrible but noticeable. Seems like the computer is the obvious culprit. Any other suggestions? "
I'm confident his direct images on the camera card he finds to be "fantastic" are jpeg. Moving, aka transferring, such files from one location to another causes no alteration to the file itself so they would look identical if played from a memory card or from an optical disc or from a hard drive, his issue is he burned them to disc in "stand alone, set-top DVD player compatible mode" (rather than directly as a computer file) so his software down res'd the camera's multi-megapixel image down to VGA quality [480p/ ~ .3 Megapixel] so as to make it NTSC friendly and playable on grandma's DVD player from the 90's.
post #15006 of 15021 Old 01-03-2015, 01:11 PM
Dominic26's Avatar
Quoted: 37 Post(s)
You will need the repeater. The network port is for firmware upgrades and BD Live only.
Dominic26 is offline
post #15007 of 15021 Old 02-04-2015, 07:51 PM
loknload's Avatar
Quoted: 53 Post(s)
Panasonic DMP-BD35 Copyright Violation?
I just moved into a new house and finally got my system set up in the new media room. I used the same HDMI cables and same settings as before on my DMP-BD35, Denon receiver, and my Panasonic plasma TV. I went to play some demo material and I really like the opening scene of the remake of Flight of the Phoenix so I slapped it in and the BD35 acted like it was going to read it and stopped and flashed "Copyright Violation" on the screen. I played several othe blu-ray discs without any other problems. I also have a PS3 so I puth the Flight of the Phoenix disc in the PS3 and the PS3 wouldn't even recognize there was a disc in it. I was also able to play every other blu-ray I have in the PS3. Not done yet, I put the Flight of the Phoenix disc in the cheap Samsung 5700 blu-ray player downstairs hooked directly to a Samsung LED TV and it played just fine. So, I have no clue why the disc won't play in my BD35 or the PS3. Both of them are run to my Denon 3808ci via HDMI and then HDMI out of the Denon to my plasma. Any ideas?
Maybe it's time for a new blu-ray player? I'm not spending $500 on the Oppo but I don't have a problem spending a couple hundred. If it is time for a new one, what has good build quality and great video performance in that price range? I could care less about streamin capabilities because I have that with the PS3.
loknload is offline
post #15008 of 15021 Old 02-05-2015, 09:09 AM
Wryker's Avatar
Quoted: 87 Post(s)
Liked: 42
Sounds like it could be a handshake issue between the player and the TV. It's not a copy of a BD right? If it's a copy and a Sony title chances are it's got that watermark on it.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #15009 of 15021 Old 02-05-2015, 10:17 AM
m. zillch's Avatar
Quoted: 770 Post(s)
Liked: 449
Good question. The BD35 was made before Cinavia was introduced, I'm pretty sure, however there may still be something in a copied signal which the machines can still sense.
post #15010 of 15021 Old 02-05-2015, 11:03 AM
loknload's Avatar
Quoted: 53 Post(s)
Not a copy. It is one of the first blu-ray discs I ever bought when blu-ray first hit the market. What gets me is that I don't have this issue with any other BD, I didn't have this issue before I moved a re-set up my system, and the PS3 doesn't recognize it at all. So what do I need to do to cue the handshake issue? I am using monoprice high speed HDMI cables between my player and PS3 and my Denon AVR and the same cable from the monitor out of my AVR to the TV.
loknload is offline
post #15011 of 15021 Old 02-05-2015, 11:22 AM
Gary J's Avatar
Quoted: 315 Post(s)
Liked: 183
Comes up a lot when you put "Copyright Violation" in Search this Thread.
Gary J is offline
post #15012 of 15021 Old 02-05-2015, 11:25 AM
Super Moderator
teachsac's Avatar
Quoted: 349 Post(s)
Liked: 322
Sounds more like the disc if it doesn't play in your PS3, either. Try a gentle cleaning.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself
teachsac is online now
post #15013 of 15021 Old 02-05-2015, 11:36 AM
Wryker's Avatar
Quoted: 87 Post(s)
Liked: 42
If it's not difficult - try swapping out cables.
Wryker is offline
post #15014 of 15021 Old 02-05-2015, 02:51 PM
Rich86's Avatar
Quoted: 103 Post(s)
Liked: 51
You are correct, the Panasonic DMP-BD 35 & 55 are cinavia free.
I have never run into this problem, but other owners have diagnosed the issue as a problem with the disc. Cleaning the disc or replacing it solved the problem for them.
A long-time audio/video addict!
Rich86 is offline
post #15015 of 15021 Old 07-30-2015, 02:53 PM
Liked: 0
I have a used and in very good condition, BD35 that I thought (and the manual confirms) would play DVD as well as BD. I cannot get any DVD to play in this player. I reset the player back to factory settings and did everything I could think of, but everytime I stick a DVD disc in the player it says "No Disc".
Shaun Michael Hinds is offline
post #15016 of 15021 Old 07-30-2015, 04:05 PM
Brandito's Avatar
Quoted: 13 Post(s)
Thought I'd share in case anyone wasn't aware. I have used a harmony remote since I bought this BDP and having discrete on and off commands is important for keeping things in sync. Originally I used the codes for the bd55 for my bd35 so I could discrete on and off, well at some point Logitech removed those commands so I was left with power toggle. Through experimentation I found if you use the bd30 commands with harmony remotes you can get those discrete commands back.
Not sure if anyone else has reported on this but in the off chance they haven't here ya go.
Brandito is offline
post #15017 of 15021 Old 07-30-2015, 06:20 PM
m. zillch's Avatar
Quoted: 770 Post(s)
Liked: 449
Thanks Brandito.
post #15018 of 15021 Old 07-31-2015, 03:41 PM
Rich86's Avatar
Quoted: 103 Post(s)
Liked: 51
It sounds like the DVD laser on the laser assembly has died. I expect your player will not play CDs either? You might try cleaning the laser, in case some dirt has attached to the DVD laser.
Rich86 is offline
post #15019 of 15021 Old 12-03-2015, 10:13 PM
Liked: 0
I have a BD35 that has worked flawlessly for years. Last weekend, we watched Star Wars episode I and it started freezing up a bit towards the end. We put in episode II and made it about 1/2 way through and it froze again. Since then, it's stopped playing BD altogether. I've tried 2 different lens cleaners on it (one cheap one from walmart and a Maxell cleaner that a lot of people with PS3s recommended), confirmed latest firmware, performed the reset by holding pause/power/open until it cycled on and then off. DVDs work fine. From what I've read, sounds like the laser might be bad? Does anyone know typically how much that costs to fix? Can the parts be obtained and serviced by me? I'm no professional, but did replace the caps in my home theater last year to get the HDMI output going again. I'm definitely willing to give it a shot.
If it's too expensive to repair, might be time to replace. Any recommendations on a decent model to get that has 7.1 surround? I went through a lot of effort to wire 7.1 in the ceiling and would like to continue to take advantage of it. I'm probably looking at spending around $200 or so hopefully...
dugsdman is offline
post #15020 of 15021 Old 12-04-2015, 12:56 AM
m. zillch's Avatar
Quoted: 770 Post(s)
Liked: 449
These are not cost effectively repairable even in the eyes of Panasonic. If you send it to them they send you a replacement, at a higher price than you could find on your own. Don't fall for any claims of "They don't build 'em like they used to. Your model is worth holding on to and getting repaired!" It's baloney.
Almost any modern player will have nearly everything you could possibly want (except analog, HD component video outs; they were phased out due to Hollywood pressure) and will load much faster, at a price almost certainly lower than what you paid for yours.
post #15021 of 15021 Old 12-04-2015, 09:03 PM
Rich86's Avatar
Quoted: 103 Post(s)
Liked: 51
From an old post about my DMP-BD55 . . .
"Well, I took the player cover off and opened the sealed internal drive assembly (4 screws on top and gently release tab in rear and lift top cover off). I cleaned the laser lens assembly (both lasers) with a q-tip using denatured alcohol and removed a bunch of stuff/crud from inside the drive unit (dust/dirt balls on the rails the laser assembly rides on towards the end of the rails, hair, etc.). I was careful not to disturb or contaminate the lubricating grease on the rails. I also cleaned the small round platter the center of the disc rides on (there was crud all over the rubberized portion of it). Put it back together and been using it since. So far, so good - plays fine and no grinding noises. We'll see if this is just a tease, or the problem is actually fixed."
The BD55 has worked fine ever since . . . . adding some clean white silicone grease to the rails can't hurt . .
Rich86 is offline
Reply Blu-ray Players
Blu Ray Players , Lg Bh200 Super Blu Blu Ray Hd Dvd Combo Player , Panasonic , Panasonic Dmp Bd35k 1080p Blu Ray Player , Panasonic Dmp Bd55k Blu Ray Disc Player
