Panasonic BD-35/55 Firmware Update Available - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 385 Old 12-16-2009, 10:57 PM
Chewbacco's Avatar
Quoted: 42 Post(s)
Liked: 58
What is BD-V playability? is it new coding for newer disks and just being able to read it properly?..any fixes for the Crank movie issue? and does anyone know what that grinding noise is as it's trying to read the disk?..sorry if I'm late to the party. I'll do some searching but anyone's .02 cents worth would be appreciated..
Chewbacco is offline
post #362 of 385 Old 04-02-2010, 12:49 AM
sellis16's Avatar
I couldn't get Red Cliff [Original International Version] Blu-ray to play with firmware 1.8. Updated to 2.1; now it plays.
To whom it may concern.
sellis16 is offline
post #363 of 385 Old 04-27-2010, 02:04 PM
bjjones's Avatar
DMP-BD55 Firmware Ver 2.2 "Link"
Date: 04/26/2010
and the normal -
Improvements: BD-V Playability Improvement
bjjones is offline
post #364 of 385 Old 05-11-2010, 07:56 PM
THSS's Avatar
Loaded firmware update 2.1 to my BD-55. This was my first update since getting the player in 2008. I've just never have had a problem playing discs.
Anyway. I was curious if it would help load times or something.
I really enjoy the BD-55 player.
THX
THSS is offline
post #365 of 385 Old 05-12-2010, 02:19 PM
j3cwill's Avatar
Quoted: 49 Post(s)
Liked: 89
Is anybody having trouble updating the firmware after burning a disc using Windows 7 Ultimate 64-Bit?
I keep getting disc error from my Panny BD55. I have never had any problems doing this with Windows XP 32-Bit, but I just upgraded to Windows 7 and I am wondering if that is the problem.
I might try some free third party software to see if that helps.
Samsung 55JU7100 UHD / Tivo Roamio (OTA) / Samsung UBD-K8500
Denon AVR-X4200W
Monitor Audio GS10 / Monitor Audio GSLCR / Monitor Audio Silver FX / (4) Monitor Audio Pro-IC65
JTR Captivator 1400
j3cwill is online now
post #366 of 385 Old 05-13-2010, 12:52 PM
j3cwill's Avatar
Quoted: 49 Post(s)
Liked: 89
Update to my problem above:
I installed ImgBurn and made another disc. It updated the firmware without a hitch.
The Panny just did not like the disc made using the Windows burn software.
Denon AVR-X4200W
JTR Captivator 1400
post #367 of 385 Old 05-13-2010, 04:39 PM
THSS's Avatar
I guess 2.2 is also available..
http://panasonic.jp/support/global/c...5/bd55_na.html
THX
THSS is offline
post #368 of 385 Old 06-11-2010, 07:41 PM
HawkHero's Avatar
The grinding noise is the result of a buildup of dust on the rubber disc that your BD sits on. When there is too much debris on there, the rubber won't grab the disc and the grinding noise is the motor spooling up with no disc on it.
Blu-Ray Discs have a scratch resistant coating on the bottom that makes them more slick then DVDs, which is why the noise sometimes seems intermittent.
Here is how to fix it:
Remove any disc inside the player and disconnect all cables- especially the power cord.
Use a #2 philips screwdriver to remove the four screws on the side of the BD player's cover. Then remove the three screws on the back. Slide the cover toward the rear of the BD player and remove.
Inside you will see a black box in the middle where the BD is loaded. Use a #1 philips screwdriver to remove the four screw on the very top of the black case. Depress the tab on the back of the case (Sort of off-set to the right) and the cover will come off.
You will see the rubber disc and it will probably have some dust and other debris on it. Using a q-tip doused in alcohol, clean the disc until there is no more debris on it.
This will last you about 6-12 months until the noise comes back.
Hope this helps.
HawkHero is offline
post #369 of 385 Old 06-17-2010, 01:25 PM
bweissman's Avatar
Quoted: 245 Post(s)
Liked: 94
Originally Posted by bweissman View Post
Originally Posted by Paul H View Post
I use my Mac to download the .EXE file, expand the downloaded file with "StuffIt Expander" (It is free on-line for Macintosh computers) and use my Mac to burn the unzipped file on a CD.
Thank you! I will pass this info along to my Mac user friend who apparently is unaware of it. I've been burning his CDs for the past several firmware releases.
Apparently, Panasonic was unaware of this method as well. My Mac-using friend emailed them to say that StuffIt Expander did the job, and Panny wrote back:
We are happy you were able to get it sorted out. We will definately [sic] share this information with other Mac customers as well as our staff here at Panasonic.
bweissman is offline
post #370 of 385 Old 07-20-2010, 11:53 PM
randall's Avatar
I tried burning the 2.2 update to a DVD-R. I know that's a waste of a DVD, but I've got tons of them, and I haven't used a CD-R in years -- in fact only for these darn updates. I guess I'll have to go buy me some CD-Rs because I get a "not supported" message when I put the DVD-R in. How about a update to allow DVD-Rs for updates
randall is offline
post #371 of 385 Old 07-26-2010, 09:37 PM
randall's Avatar
Just wanted to report the 2.2 update was necessary to play Flash Gordon (1980) -- yep, the one with the great Queen soundtrack. An interweb search only came up with a Samsung issue with this BD, so I wanted to make note it also applies to our Panasonics.
randall is offline
post #372 of 385 Old 07-27-2010, 10:27 AM
bluesky636's Avatar
Hope this helps.
Congratulations. Depending on the type of rubber used in the manufacture of that disc, you may have succeeded in destroying it. Very bad advice to be promoting to the owners of this machine.
http://www.osha.gov/SLTC/healthguide...cognition.html
bluesky636 is offline
post #373 of 385 Old 05-10-2011, 12:14 PM
WynsWrld98's Avatar
Quoted: 325 Post(s)
Liked: 119
Is latest firmware update for BD-35 2.2?
WynsWrld98 is offline
post #374 of 385 Old 05-11-2011, 07:44 AM
Georgeb's Avatar
Yes, it was released over a year ago and there hasn't been any since.
Georgeb is offline
post #375 of 385 Old 08-02-2011, 05:36 AM
donnymac51's Avatar
My BD55 just updated to FW 2.3. Panasonic site only shows 2.2. Anyone else get this or know what it does?
Update: Found it onthe Panny global site. It says "playability and other improvements".
Precision Video Calibrations
THX Certified Video Calibrator
Calibrating Florida and Georgia
donnymac51 is offline
post #376 of 385 Old 08-02-2011, 08:37 AM
Georgeb's Avatar
Wow, nice to see Panasonic is still standing behind the older models. The 2.3 update was released Friday. I don't use my BD35 much as it is in the bedroom now, but I'll probably update it anyway.
Georgeb is offline
post #377 of 385 Old 08-18-2011, 07:36 PM
FiguredMaple's Avatar
Just updated my BD35 to ver. 2.3.
I haven't had enough time to notice any improvements, if they will be noticeable. But it is great that they are still providing updates for their older players.
FiguredMaple is offline
post #378 of 385 Old 10-25-2011, 03:41 PM
Mark Booth's Avatar
Quoted: 62 Post(s)
Liked: 63
I just checked and firmware version 2.4 is available for my Panasonic BD35! The player is downloading and installing it now.
According to Panasonic's web site, the update is dated 10/17/11 (8 days ago) and fixes "Blu-ray disc playability".
http://panasonic.jp/support/global/c...5/bd35_na.html
Mark
Mark Booth is online now
post #379 of 385 Old 10-25-2011, 07:33 PM
bweissman's Avatar
Quoted: 245 Post(s)
Liked: 94
Did it work for you?
My BD-35 is off my network, so I need to burn a disc to update it. Update failed because it (r)ejected the disc. I've done this many times before and it always worked in the past.
post #380 of 385 Old 10-25-2011, 08:11 PM
Mark Booth's Avatar
Quoted: 62 Post(s)
Liked: 63
Even with the 2.4 firmware update installed on my BD35 there were playback issues with Jurassic Park (first movie). Video would freeze (lockup) and all audio would be lost. I'm not talking brief audio dropouts, I'm talking completely loss of audio for several seconds. I replayed the problem section multiple times and had issues each time. Stopped the disc and switched the player to PCM and tried again. Then the disc played fine for the rest of the movie. Then I stopped the disc and switched back to Bitstream and tried the problem section again. It played perfectly.
I think chasing after supposed problems with DTS HD MA 7.1 playback and Bitstream vs. PCM is a red herring. I am planning to replace the BD35. I think it is simply worn out (3-5 movies per week for 3 years). My playback issues started with Star Wars but I've even had some issues with some older DTS HD MA 5.1 discs that have previously played perfectly on the player.
Mark
post #381 of 385 Old 07-07-2012, 08:20 AM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
Can the firmware CD-R be made in Windows 7? I have made 2 disks now copying the PANA_DVD.FRM file but my BD-55 will not recognize them. See in the notes that Vista does not work for this. Do I need special software?
PeterK is offline
post #382 of 385 Old 07-07-2012, 09:33 AM
Super Moderator
teachsac's Avatar
Quoted: 837 Post(s)
Liked: 1360
You need to use CDburnerXP to burn a firmware disc in Vista or Win7. It's free.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #383 of 385 Old 07-07-2012, 01:11 PM
Rich86's Avatar
Quoted: 134 Post(s)
Liked: 67
When a friend of mine had trouble creating a firmware update disc for her player, I came across this and found it helpful in creating a properly functioning firmware update disc for her Panny player.
193
I used imgburn to create the actual cd-r as I recall.
A long-time audio/video addict!
Rich86 is offline
post #384 of 385 Old 07-07-2012, 04:02 PM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
Hey teachsac that worked great!!!
Thank you so much. It fixed my playback issues.
Pete
PeterK is offline
post #385 of 385 Old 07-07-2012, 04:34 PM
Super Moderator
teachsac's Avatar
Quoted: 837 Post(s)
Liked: 1360
Pete
You're welcome. It's been the go to program for burning firmware discs for Panasonic forever. Good luck. My 55 is still going strong, too.
S~
teachsac is offline
Reply Blu-ray Players
Panasonic Dmp Bd55k Blu Ray Disc Player , Panasonic Dmp Bd35k 1080p Blu Ray Player , Yamaha Rx V663 Receiver
