Panasonic BD-35/55 Firmware Update Available - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 385 Old 11-29-2008, 08:08 AM
Dragonfly's Avatar
Originally Posted by Paul H View Post
Sorry jtbell, I'm so used to the Mac I didn't think about the virtual PC software I have installed where I just drag & drop files and use both Windows & Mac OS on the same system.
You would need some form of Windows to use the self extracting feature of the download. Once it is extracted, the Mac can do the rest
If you have access to a windows PC, a memory stick can be used to tranfer the extracted file to the Mac.Paul
Paul:
I have an old G3 running OS10.3 classic with an external Sony CD burner and an old laptop PC that I use to download files for my FTA receiver, load to a USB stick then into my receiver, can I do the same with firmware updates, load to USB stick and then to my G3 and then burn to a CD on my Sony burner?
Be nice if someone made a player with a USB port, it would make life easier, or maybe someone does.
Dragonfly is offline
post #92 of 385 Old 11-29-2008, 12:57 PM
Paul H's Avatar
Quoted: 36 Post(s)
Liked: 30
Originally Posted by Dragonfly View Post
Paul:
It would be much easier to have a USB port. The PS3 has that option.
Don't know about the G3, OS10.3 & external CD burner, it would be a guess and I wouldn't want to be responsible if something went wrong.
All I can say is that it worked using the equipment I have and I'm sure it would have worked by transferring the expanded file with a memory stick too as that is how I update my PS3 firmware.
Paul
Avatar: IMAX Header
BD 3D, BD, HD DVD, DVD collection
Paul H is offline
post #93 of 385 Old 11-29-2008, 03:11 PM
AvGrog's Avatar
Originally Posted by mds54 View Post
I can't get my XP Pro CD Writer to complete a full burn without aborting. I also used a third party CD burner which did succeed, but then the 55 could not read it. I've burned numerous music CDs in the past without any problem.....
I ran into this problem the first time I tried to update my filmware I could not get my CD burning program to make an ISO file even when it said it would. I found and downloaded a shareware program called ISO burnersoftware and have used it on both XP and Vesta and it worked everytime. I put the downloaded zip file in a folder than click it which opens an ISO file. I than click on the ISO file and ISO burner opens and burns it to a CD. Web address for program is.
http://filegets.com/get/iso-burner.html
AvGrog is offline
post #94 of 385 Old 11-29-2008, 09:26 PM
jcflman's Avatar
Originally Posted by mark754 View Post
Sounds like no one can notice any improvements from this v 1.5 update.
Found this on the Panasonic site:
DMP-BD35 Firmware Update
Version: 1.50
Models: DMP-BD35K
Instructions:
Issues Addressed
1. Corrects block noise which appears during playback of promotion disc made for JVC LCD TV in US market.
2. Corrects jaggy noise which appears during playback of select DVDs:
* Into the Wild
* Run Fatboy Run
jcflman is offline
post #95 of 385 Old 11-29-2008, 10:43 PM
Trackman's Avatar
Quoted: 114 Post(s)
Liked: 98
Version: 1.50
Models: DMP-BD35K
Instructions:
Issues Addressed
* Into the Wild
* Run Fatboy Run
Hats off to Panny for updating firmware just to deal with a few minor issues like that!
Go Duke !
Trackman is offline
post #96 of 385 Old 11-30-2008, 10:44 PM
mds54's Avatar
Quoted: 41 Post(s)
I'll check it out.
Thanks for that!
mds54 is offline
post #97 of 385 Old 12-02-2008, 06:51 PM
Wind_Wound's Avatar
The cost of 100ft of Cat-5 cable from Radio Shack is not bad. Seems cheaper than buying wireless bridge hardware. Unless you're determined to use the underwhelming BD-live worthless and meaningless crap stuff.
Wind_Wound is offline
post #98 of 385 Old 12-02-2008, 08:50 PM
rmaestas's Avatar
Where do you go to tell what the current firmware version is on the BD35K? Just purchased mine yesterday.
rmaestas is offline
post #99 of 385 Old 12-02-2008, 10:15 PM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
Check out this site for a description of how to check the installed version.
demonfoo is offline
post #100 of 385 Old 12-05-2008, 07:21 AM
EDDIE919's Avatar
First question: Where can I find what the latest firmware fixes? I looked on the Panasonic web site can could not find it.
My player has v1.4 and it not near the home PC. I downloaded v1.5 and burned it to a CD-R but got an error message on the player when I inserted it.
I was wondering if I can plug an ethernet cable from the player to a laptop with a wireless network card and use that to get the latest firmware (as well as BD live)
EDDIE919 is offline
post #101 of 385 Old 12-05-2008, 12:31 PM
rmb1035's Avatar
Look 5 posts above yours on this same thread...
rmb1035 is offline
post #102 of 385 Old 12-06-2008, 10:40 AM
Gary Bechtold's Avatar
Quoted: 91 Post(s)
Liked: 107
Just got the unit yesterday. It had v1.4 firmware on it. I put it on the network and updated to v1.5. Simple and easy.
Gary Bechtold is offline
post #103 of 385 Old 12-06-2008, 01:31 PM
blazeby's Avatar
Same here - got the unit yesterday, upgraded to 1.5 via ethernet - zero issues - piece of cake.
blazeby is offline
post #104 of 385 Old 12-08-2008, 08:45 PM
webcrawlr's Avatar
I just updated to version 1.6 today...
Fixes are:
1. BD-V Playability
http://panasonic.jp/support/global/c...5/bd35_na.html
webcrawlr is offline
post #105 of 385 Old 12-08-2008, 08:47 PM
a3willia's Avatar
I finally updated to 1.5 last night. I just powered my player on and saw the notice that 1.6 was available.
HD A2 (Feb 07)
HD XA2 (Feb 08)
DMP-BD35K (Nov 08)
DMP-BD60K (Jun 09)
HD DVD Titles: 168
Blu-ray Titles: 430
a3willia is offline
post #106 of 385 Old 12-09-2008, 12:19 AM
Joxer's Avatar
Me too, I just updated to 1.5 earlier this evening and now I see 1.6 is up!
I tried updating with a CD-RW instead of a CD-R and it worked fine for me. Used Nero to just burn it. Don't have to waste CD-Rs for one time firmware update use, I can reuse my CD-RWs.
Joxer is offline
post #107 of 385 Old 12-09-2008, 03:54 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Panasonic has the new firmware 1.6 up for both the 35 & 55 dated 12/8
BD55 Link
http://panasonic.jp/support/global/c...ica/index.html
BD 35 Link
rwestley is offline
post #108 of 385 Old 12-09-2008, 06:52 AM
webcrawlr's Avatar
BD55 Link
BD 35 Link
Is there an echo?
post #109 of 385 Old 12-09-2008, 11:39 AM
Brahmzy's Avatar
Quoted: 469 Post(s)
Liked: 358
What is BD-V??
HTPC | 12TB NAS | Harmony Elite | DENON X4200W | Sony XBR75X940D
Philips BDP7501 | Klipsch RF7II,RC64II,CDT5650CII | SVS SB2000 x2
Brahmzy is offline
post #110 of 385 Old 12-09-2008, 11:54 AM
joerod's Avatar
Quoted: 704 Post(s)
Liked: 633
Give them credit. That is some fast updates....
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is offline
post #111 of 385 Old 12-09-2008, 12:00 PM
mds54's Avatar
Quoted: 41 Post(s)
Just FYI.....
For the few of us that don't use the Internet hookup and/or have problems burning a readable CD-R, Panasonic will mail you a firmware update CD free of charge within 2-5 biz days. I just requested mine through the Global Service Center Network - Technical Support. You will need to establish a case number.
mds54 is offline
post #112 of 385 Old 12-09-2008, 12:31 PM
Kevin Tx's Avatar
HELP
Burned cd-r disc,inserted into player, player took disc did it's thing 'ejected itself and now player says "insert disc' and tray stays open.
Put in a disc but it keeps rejecting and opens on its own with insert disc message.
WTF is up?
Kevin Tx is offline
post #113 of 385 Old 12-09-2008, 12:44 PM
General Kenobi's Avatar
Quoted: 357 Post(s)
Liked: 640
Originally Posted by Kevin Tx View Post
HELP
WTF is up?
Was this the 1.6? Has anyone else updating by disc had this issue?
Kenobi's 31 Days of Horror:
2012
2011
2010
2009
General Kenobi is offline
post #114 of 385 Old 12-09-2008, 12:48 PM
Luisfc1972's Avatar
Quoted: 290 Post(s)
Liked: 29
Luisfc1972 is offline
post #115 of 385 Old 12-09-2008, 12:51 PM
Kevin Tx's Avatar
Yes, this is 1.6 update.
Only reason I tried was because of alot of jittering and intermittant stopping while playing Master & Commander.
Anyone else having issues with this disc?
Kevin Tx is offline
post #116 of 385 Old 12-09-2008, 12:57 PM
wstanko's Avatar
1.6 was easier than ever since I did 1.5 awhile back. No problems burning or installing. Apparently, the download, burn, portion may be the "real" problem for some. I cannot explain why certain computers, programs do better than others but maybe mds54 who has had many problems previously and ordered a factory disc has the correct solution.
Myself, I have started a collection of firmware discs in case one misfires.
wstanko is offline
post #117 of 385 Old 12-09-2008, 01:01 PM
Quoted: 357 Post(s)
Liked: 640
You did power down after the update correct? I don't have that title myself, was this happening on any others? (maybe bad disc?)
Have you tried inserting a SD card? Maybe by doing so you can trick the player out of the "insert disc" request.
2012
2011
2010
2009
post #118 of 385 Old 12-09-2008, 01:13 PM
Brahmzy's Avatar
Quoted: 469 Post(s)
Liked: 358
Originally Posted by Brahmzy View Post
What is BD-V??
What is BD-V?
Why do I want to upgrade to 1.6 from 1.5?
Brahmzy is offline
post #119 of 385 Old 12-09-2008, 01:22 PM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
What is BD-V?
Blu-Ray Disc - Video; i.e., every BD released except for PS3-specific game titles.
Because it's new, and it may fix playback with certain titles - though Panasonic doesn't detail specifically what titles it affects.
demonfoo is offline
post #120 of 385 Old 12-09-2008, 01:28 PM
Kevin Tx's Avatar
Yeah I powered down. This was the first problem disc I have had. (24 Days/16-18 discs) Took a chance and unplugged the player.
Powered back up and all is well except still on version 1.3.
Guess I'll burn a new disc with a different burner or call for one from Panasonic.
Thanks all
Kevin Tx is offline
Reply Blu-ray Players
Panasonic Dmp Bd55k Blu Ray Disc Player , Panasonic Dmp Bd35k 1080p Blu Ray Player , Yamaha Rx V663 Receiver
