Panasonic BD-35/55 Firmware Update Available - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 12-12-2008, 01:01 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
If it will not read any disks it will not fix the problem. I would exchange your unit ASAP. It sounds like a bad disk loader.
rwestley is offline
Old 12-12-2008, 01:16 PM
moematthews's Avatar
Originally Posted by milacqua View Post
BTW, when you clicked on the properties of the Pana_dvd.fr file does it show as a wordperfect 10 document?
I'm not a computer expert by any stretch of that definition, but that just doesn't sound right to me. My Pana_DVD file did not show as a Wordperfect document, and I'll bet that has something to do with your player being unable to read the file.
moematthews is offline
Old 12-12-2008, 02:22 PM
milacqua's Avatar
Quoted: 77 Post(s)
Liked: 27
I did not think it was right either. I don't know what happened but when I click on the file it shows in properties across from the type of file - WordPerfect 10 file. I do not know how my computer gave it that designation but that is the problem.
shortspark
milacqua is offline
Old 12-12-2008, 02:23 PM
milacqua's Avatar
Quoted: 77 Post(s)
Liked: 27
I called Panasonic and they will pay to ship it back to them for repair/replacement. I called Amazon and they said they will pay for shipping back to them and replace with a new unit. I'll go with Amazon if I can't get the thing to work.
shortspark
milacqua is offline
Old 12-12-2008, 02:29 PM
spartacus_33's Avatar
You can associate any file extension with any application. Doesn't mean that it will actually open with the application. Sounds like sometime in the past, .fmr files on your computer were associated incorrectly.
Spartacus_33
My HT
spartacus_33 is offline
Old 12-12-2008, 02:38 PM
milacqua's Avatar
Quoted: 77 Post(s)
Liked: 27
I'm sure you are correct. Something wrong with all this that is over my head. I'll just get a new 35, load the update from the disk Panasonic is sending me and be done with it. If I need updates in the future I'll just get them from Panasonic or just get a router and have the thing hooked up via earthnet.
shortspark
milacqua is offline
Old 12-12-2008, 03:14 PM
Kevin Tx's Avatar
The FRM files were wordperfect for me.
I had to burn three coasters before I finally got one to take.
Is it possible for the correct file that someone has used to be emailed?
Kevin Tx is offline
Old 12-12-2008, 08:29 PM
stash64's Avatar
Quoted: 192 Post(s)
Liked: 74
Add another to the list of those with problems trying to update by CD-R. I currently have FW v1.5. I burned the v1.6 FRM file exactly per the instructions provided by Panasonic using the right click "send to" function in Vista. The file is the correct size on disc and it does show the FRM extension on disc. When I insert the update disc, the player recognizes it, shuts down and restarts as it is suppose to... but then it simply ejects the CD-R after just a couple of seconds. The display shows "eject".
I've done half a dozen firmware updates via CD-R on other players (Toshiba, Samsung) but the Panny is the first to give me any difficulty. It seems Panasonic needs to create a FW update to fix the FW updates, or just fix there update instructions.
Sean
stash64 is offline
Old 12-13-2008, 05:38 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Stash64. I think you missed one suggestion on burning. Many have reported issues using Vista to burn the file. If you own Nero or Roxio unzip the file and burn as a data disk. If you have access to an XP machine you can unzip the file and burn it directly to XP. The issue seems to be with Vista. The updates you have done with Toshiba and Samsung players have been ISO files. This file is a data file. Panasonic should let you know that there is an issue with using Vista to burn the file.
rwestley is offline
Old 12-13-2008, 07:54 AM
dudley07726's Avatar
I called Panasonic to send me a disc for the upgraded v1.6. They told me that v1.6 was not available on disc yet and that only v1.5 was available to be mailed. I decided to just download it myself to disc. I upgraded the BD35 yesterday and it works fine.
dudley07726 is online now
Old 12-13-2008, 08:46 AM
AvGrog's Avatar
I had the same problem when burning update CD's with Vista, as stated above I had to use a CD burning program to get a working disc use data disc. None of the methods on JP or USA download sites worked with Vista. When I first built this computer and installed Vista it handled CDs just like XP. But than MS update installed Live File System and now Vista doesn't handle CD in the same way so problems with burning CDs. I first fund this when trying to burn pictures to a CD I made a lot of coasters before I found that I needed to change back to Mastered as Vista defaults to LFS. I would like to remove this as I do not like it but have been unable to find a way to do so. I would also like to remove Window Photo Gallery from Vista as I don't like either program but once MS adds something it becomes impossible to remove it.
AvGrog is offline
Old 12-13-2008, 08:49 AM
So... anyone had trouble with the FW update using a live connection? I picked up a 25' cable from a buddy and was going to give it a go this weekend.
Spartacus_33
My HT
Old 12-13-2008, 09:13 AM
Randy Mathis's Avatar
I had no problem updating to 1.5 but I can't get 1.6. I don't know why and won't worry about it until an update that actually does something appears.
All animals are created equal, but some animals are more equal than others.
Randy Mathis is offline
Old 12-13-2008, 09:23 AM
What exactly do you mean "can't get"? Is it not available live or does it not install?
Spartacus_33
My HT
Old 12-13-2008, 10:27 AM
Jano18's Avatar
I updated mine to 1.6 through the LAN port with no problems. It first took about 8 minutes to download & then it goes through the update process. I won't update with discs anymore.
Jano18 is offline
Old 12-13-2008, 10:29 AM
I just updated mine with a LAN connection as well. No problems. The device came with v 1.5. After performing the upgrade, I verified now v 1.6.
I disconnected my router and plugged directly into the modem. Unplugged the modem and then plugged back in (recommended by an IT buddy, to get a new IP address), plugged into the BD35 and followed these instructions.
Anyway...... worked great. Took less than 10 minutes.
Spartacus_33
My HT
Old 12-13-2008, 11:44 AM
WaldorfSalad's Avatar
Re: .Frm files: Its NOT a WordPerfect file, though it may show up as such if you happen to have WP installed on your PC due to Windows file type associations. OTOH, if you have Visual Basic 6 installed on your PC (as I do) then a .FRM file will show up as a VB6 Form file. But it isn't. All that matters is that its a binary file that the BD35K sees as a firmware update and it should be burned to a disc as a data file.
WaldorfSalad is offline
Old 12-13-2008, 03:46 PM
halsan40's Avatar
does anyone remember how to check the firmware verison on the Panny?
Hal
halsan40 is offline
Old 12-13-2008, 05:03 PM
moviegeek's Avatar
Setup>Display>Status
Just a reminder if anyone goes the CD route:burn the FRM file as data on a CD-R and don't touch the player until it says FINISHED.
moviegeek is offline
Old 12-13-2008, 05:26 PM
halsan40's Avatar
Thanks, I forgot the dispay part.
I have XP and I just dragged and dropped the .frm into the CDRW and it burned perfectly. Now I am on 1.6
Hal
halsan40 is offline
Old 12-14-2008, 09:58 AM
stash64's Avatar
Quoted: 192 Post(s)
Liked: 74
Yep... that did the trick. I burned it as a data disk using Roxio. Panasonic needs to update their burning instructions. Thanks.
Sean
stash64 is offline
Old 12-14-2008, 12:18 PM
randall's Avatar
Is there another way to check firmware version on a BD55? I don't see the status option above. Thanks.
randall is offline
Old 12-14-2008, 12:53 PM
jpcortese's Avatar
You need to depress the Status button on the remote and it will show the firmware version on the bottom right side.
jpcortese is offline
Old 12-14-2008, 01:26 PM
Robert_Lopez's Avatar
I thought I read earlier that one of the firmware upgrades allows the BD35 to play HD-DVDs. Can anyone else confirm this?
Robert_Lopez is offline
Old 12-14-2008, 01:35 PM
Denny_S's Avatar
You are kidding right?
Denny_S is offline
Old 12-14-2008, 01:45 PM
Brandito's Avatar
Quoted: 18 Post(s)
i think that same person also mentioned it playing 8-track tapes
Brandito is offline
Old 12-14-2008, 01:58 PM
randall's Avatar
Thanks jpcortese, I was just about to edit my post after figuring out the sequence was Setup>Display>Status button on the remote.
randall is offline
Old 12-14-2008, 03:09 PM
tundrSQ's Avatar
Is there an ISO file available? Or are there no mac users using blu-ray besides me?:-)
Tim
tundrSQ is offline
Old 12-14-2008, 03:12 PM
etcarroll's Avatar
Location: Living among the children of the corn in Oxford, (S.E.), PA.
No.
"The Bundys' proud name was built on a philosophy of lying. Well, lying, owing money and perhaps beer. Yes, lying, owing money and beer. The only thing that separates us from the Kennedys is that they have money." - Al Bundy
etcarroll is offline
Old 12-14-2008, 03:29 PM
marshallmedia's Avatar
FWIW, I did the version 1.6 update last night on my BD-35. I downloaded the firmware file on my Windows XP computer, it unzipped and showed as a Word Perfect document. Burned it to a CD-R as a data disc, using Roxio CD Easy Creator. Put it in the player, everything updated fine with no problems on the first try. Guess this is an affirmation that using XP is solid, do the burn as a data disc, and don't worry if the file shows as a Word Perfect document.
marshallmedia is offline
Panasonic Dmp Bd55k Blu Ray Disc Player , Panasonic Dmp Bd35k 1080p Blu Ray Player , Yamaha Rx V663 Receiver
