Panasonic BD-35/55 Firmware Update Available - AVS Forum | Home Theater Discussions And Reviews
post #1 of 385 Old 10-30-2008, 02:03 AM - Thread Starter
Blu-ray Reviewer
Moderator
Ralph Potts's Avatar
Quoted: 1110 Post(s)
Liked: 3534
Greetings,
FW version 1.5 is available for the Panasonic BD 35/55 players. It says it addresses playability and stability. Here is the link for each:
BD-55
BD-35
I found this out when I powered my player up this morning and a screen popped up saying that a firmware update was available for download. It first downloads the firmware and then installs it. The whole process took 10 minutes to complete.
Cheers,
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
My DVD/HD DVD/Blu-ray Collection
Follow me on Twitter @RalphAVSreviews
Ralph Potts is online now
post #2 of 385 Old 10-30-2008, 05:23 AM
LarryChanin's Avatar
Originally Posted by Ralph Potts View Post
Greetings,
BD-55
BD-35
I found this out when I powered my player up this morning and a screen popped up saying that a firmware update was available for download. It first downlaods the firmware and then installs it. The whole process took 10 minutes to complete.
Cheers,
Hi Ralph,
The Panasonic web site only mentions that the upgrade is for "Playability and Stability". Have you had a chance to observe any improvements? I don't suppose there are any new menus, etc?
Larry
LarryChanin is offline
post #3 of 385 Old 10-30-2008, 05:28 AM - Thread Starter
Blu-ray Reviewer
Moderator
Liked: 3534
Originally Posted by LarryChanin View Post
Hi Ralph,
Larry
Greetings,
None that I observed Larry. The previous firmware version on my player was 1.1. I would be curious to know what was being addressed. I watched Hancock after updating this morning. I will check a few disc that I am familar with to see if there are any improvements in load times. Seeing as the Panasonic was already very fast I doubt there will be any discernible change in that regard.
Cheers,
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
post #4 of 385 Old 10-30-2008, 07:30 AM
nith's Avatar
Thanks for the alert. I'll update my BD35 tonight and hopefully it will fix the stability issue as intended.
Issue I had w/BD35:
May be it is a one fluke thing (I haven't tried to reproduce it). I was watching the 'Journey to the center of the Earth' and then all of the sudden the player stopped responding to the remote command. The eject button on the player didn't respond either. Only the power button was responding; I pressed it and the player reboot. The remote works after that...
nith is offline
post #5 of 385 Old 10-30-2008, 08:05 AM
caa100's Avatar
Why a separate thread for this topic?
Doesn't this belong in the owners thread?
-Chris
caa100 is offline
post #6 of 385 Old 10-30-2008, 08:25 AM
Trackman's Avatar
Quoted: 114 Post(s)
Liked: 98
It is very common on this forum for firmware threads to be seperate.
Go Duke !
Trackman is offline
post #7 of 385 Old 10-30-2008, 10:23 AM
chix's Avatar
Are you a mod? A separate thread is helpful as the owners thread is huge!
chix is offline
post #8 of 385 Old 10-30-2008, 11:11 AM
mtw4991's Avatar
Just a heads up to everyone. I was having a helluva time getting accurate calibration of my 67 at 0%(black) & 100%(white) using the ramps on DVE. I was told(wrong!) that the Yamaha RX-V663 clips BTB/WTW(it doesn't). I am running monoprice HDMI 1.3 cat2 cables from my BD35 to the 663, using the 663's HDMI video out to my sammy. The BD35 has its own set of adjustments and once I set these to the correct levels(not all default settings are accurate btw), I could see ALL ramps including BTB and WTW. This allowed me to dial in the brightness/contrast almost perfectly.
HOWEVER, I did notice that switching from standard to movie mode RESETS the dynamic contrast/black to high even though it says off? Gonna be a real pain once I get my Harmony One sync'd up. Not sure how to reset it w/ a H1
Anybody else notice this? Maybe the new f/w will fixit? I just bought the 67 last week with f/w 1006.1 so it is the latest.
mtw4991 is offline
post #9 of 385 Old 10-30-2008, 03:28 PM
mikey p's Avatar
I've only had this unit an HD35 in the house less than 24 hrs, this thread SAVED my a bunch to time for sure, I've D/L the Firmware and up-dated my new player since I got home from work, kind of neat, from "my point of view"
YMMV I'm sure. Thanks.
P.S. Thanks to the OP for the links as otherwise I would not hav seen it! A big tip of the cap!
It is "WOW" TV!
mikey p is offline
post #10 of 385 Old 10-30-2008, 03:44 PM
Jack Gilvey's Avatar
Quoted: 43 Post(s)
Liked: 58
Updated my 35 today with no issues at all. It now plays all my HD-DVD's, as well as my 8-tracks. Kudos Panasonic!
Jack Gilvey
SVS Customer Service
Jack Gilvey is offline
post #11 of 385 Old 10-30-2008, 03:58 PM
Brandito's Avatar
Quoted: 18 Post(s)
does it also do laser disc now too?
Brandito is offline
post #12 of 385 Old 10-30-2008, 04:00 PM
Ken Ross's Avatar
Quoted: 6590 Post(s)
Liked: 7299
No, but it does do LPs. It's just that you have to hammer the LP in that small DVD slot.
Ken Ross is offline
post #13 of 385 Old 10-30-2008, 04:07 PM
Aetherhole's Avatar
Quoted: 327 Post(s)
Liked: 458
Nice! Let us know how thos 8-tracks work out for ya!
I picked up my BD35 today at lunch. This is replacing my Pioneer 51FD (most likely). The 51FD replaced my BD30.
Panny, Pioneer, Panny. We'll see how this one fairs compared to my 51FD.
LG OLED65C6P ISF Calibrated by David Abrams @ Avical
Marantz AV8801 / D-Sonic M2500 / Oppo UDP-203
GR Research LS-9 / GR Research X-Voce / GR Research AV-1RS / Oppo PM-1
Aetherhole is offline
post #14 of 385 Old 10-30-2008, 05:02 PM
halsan40's Avatar
I DL the update and it a bit over 27 megs. Panny's update site identifies it as a bit over 28 megs. Is this a problem?
Hal
halsan40 is offline
post #15 of 385 Old 10-30-2008, 06:25 PM
tai4de2's Avatar
The firmware update for the BD35 is available via the player's ethernet port. The update process works very nicely -- there's a percent complete indicator during the download phase (it seemed to jump in 5% increments) with a clear statement that the screen will go blank once the firmware upgrade starts upon completion of the download. During the actual upgrade the player's front panel reads "UPDx/5" where x is 1-5; and then "FINISH" after which the player restarts.
Upon restart, a message briefly appears stating that the firmware had been updated.
All settings were retained and the whole thing took ~5 minutes.
A very nice upgrade procedure.
tai4de2 is offline
post #16 of 385 Old 10-30-2008, 08:24 PM
Quoted: 43 Post(s)
Liked: 58
Yup, you guys laugh all you want, but it's really the only way to listen to the Bay City Rollers.
Jack Gilvey
post #17 of 385 Old 10-30-2008, 09:55 PM
Aetherhole's Avatar
Quoted: 327 Post(s)
Liked: 458
lol, SVS CS, huh? Boy I sure do enjoy your products! Been through a 20-39PCi, PC-Ultra (TV-12), and now the PB13-U!
Anyway, back on topic, it seems that there is a lack of LFE with LPCM through HDMI. I tried Chicken Little on my Pioneer 51FD and then hooked up the BD35 and there is a noticeable difference. Probably -5dB on the LFE.
Hopefully they fix this soon.
post #18 of 385 Old 10-30-2008, 10:21 PM
oink's Avatar
Quoted: 5299 Post(s)
Liked: 3036
Updated with a burned CD, no problems (as usual).
oink is offline
post #19 of 385 Old 10-31-2008, 02:47 AM
mathieuhatt's Avatar
I have a question : by applying the US firmware file to a region B / zone 2 player (bought in Europe), would that make the player switch to region A / zone 1 ?
It works with the sharp unit (BD HP20) (not reversible though). Does it work the same with panasonic players ?
mathieuhatt is offline
post #20 of 385 Old 10-31-2008, 07:20 AM
UHD Addict
aaronwt's Avatar
Quoted: 6221 Post(s)
Liked: 3855
Maybe this firmware will fix my BDlive problems.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #21 of 385 Old 10-31-2008, 07:29 AM
joerod's Avatar
Quoted: 721 Post(s)
Liked: 655
That was quick.
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is online now
post #22 of 385 Old 10-31-2008, 08:58 AM
TekWorm's Avatar
No, you will get a "UNSUPPORT" error and the player will not update.
TekWorm
TekWorm is offline
post #23 of 385 Old 10-31-2008, 09:04 AM
TekWorm's Avatar
Hmmm... Updated (successfully) by burned disc, last night.
No perceivable difference at all.... However, my Samsung Display now occassionally flashes the dreaded 'hot-pink', (reminicent of Sammy 65 Series board issues) during LOAD transitions.
S'pose it could be coincidental... but in almost a year, it's not done it before.
TekWorm
TekWorm is offline
post #24 of 385 Old 10-31-2008, 12:26 PM
caa100's Avatar
Ack. Thats a bit worrisome. What is the Samsung model?
-Chris
caa100 is offline
post #25 of 385 Old 10-31-2008, 01:13 PM
Rudy81's Avatar
Has anyone figured out a way to make a copy of the original or installed firmware version prior to running this new or other upcoming firmware updates. Nothing worse than running an update only to find out your system worked better with the old firmware.
Rudy81
Rudy81 is offline
post #26 of 385 Old 10-31-2008, 04:37 PM
Paul H's Avatar
Quoted: 37 Post(s)
Liked: 30
It wouldn't help if someone figured out a way to make a copy.
Noted on the DMP-BD55 Firmware V1.5 Download page:
[Note]:
If the firmware version currently installed in the Panasonic BD player is the same or more recent than the firmware version on the update disc, "UNSUP/PORT" will be displayed for approximately 5 seconds on the front display of the Panasonic BD player. In this case, an update is unnecessary -please remove the disc.
The Display on the Panasonic BD Player will read:
UNSUP / PORT
Paul
Avatar: IMAX Header
BD 3D, BD, HD DVD, DVD collection
Paul H is online now
post #27 of 385 Old 10-31-2008, 04:57 PM
Brandito's Avatar
Quoted: 18 Post(s)
i'm sure panasonic would be willing to send you a copy of the original firmware if it became neccesary.
i'm betting that the firmware is thoroughly tested before being distributed to the masses though, so i doubt there would be a need to revert.
Brandito is offline
post #28 of 385 Old 10-31-2008, 06:29 PM
chix's Avatar
I am trying to upgrade my 55 and it fails each time after 40%.
The power resets and it suggests trying again.
Any recommendations???
chix is offline
post #29 of 385 Old 10-31-2008, 07:24 PM
jpeter1093's Avatar
Unfortunately, Bandito, that won't work..read the post just prior to yours.
jpeter1093 is offline
post #30 of 385 Old 10-31-2008, 07:35 PM
Rudy81's Avatar
Good point. Having worked with pc's for a long time I developed the habit of keeping the older firmware just in case the latest and greatest wasn't so great. I think I will take the conservative road and not update until well after others have installed the update or I am having some problem that would seemingly only be fixed with an update.
Rudy81
Rudy81 is offline
Reply Blu-ray Players
Panasonic Dmp Bd55k Blu Ray Disc Player , Panasonic Dmp Bd35k 1080p Blu Ray Player , Yamaha Rx V663 Receiver
