AVS Master Thread: Discussion of Blu Ray Player's Upconversion Performance - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 180 Old 01-19-2012, 02:09 AM
audio/videoman's Avatar
I may try this as well. It seems to defy logic: hdmi is a pure digital signal, and the source is the same; why should component connections produce a better picture?
Originally Posted by joeriz View Post
OK...I wound up purchasing the Panasonic BD85K Blu-Ray player for use with my Samsung PN58C550 plasma. As I'm trying to figure out what setup offers the best picture quality with regular DVDs, I have the Panny hooked up to the Samsung via both HDMI and component cables. This way I am able to switch back and forth between inputs to see which looks better. So far, I think I prefer the component connection in terms of picture quality. It just looks 'smoother' overall while the image from the HDMI input looks a bit like it's 'trying too hard' to be HD when it really isn't. I suppose this could be attributed to one (or more) of several things:
1) My TV does a better job of upconverting the DVDs than the Blu-Ray player.
2) The inputs on my TV have not been sufficiently tweaked/optimized for the signals they are receiving.
3) I need to alter some settings on the Blu-Ray player to get the best from it's internal upconverter.
4) something(s) I haven't thought of yet...
Any thoughts or advice on how to proceed from here would be helpful.
Joe
audio/videoman is offline
post #152 of 180 Old 02-09-2012, 02:58 AM
sefmiller's Avatar
For a normal DVD on a plasma HDTV. Does it look better on a standard dvd player, or upscaled on a blu-ray player?
sefmiller is offline
post #153 of 180 Old 02-09-2012, 04:55 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3322 Post(s)
Liked: 2591
There is no rule. When playing DVDs a BR player is just like a DVD player. There is variability among models as to how well they handle DVD.
Note that proper calibration of the display can make a greater difference in image quality than switching gear.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #154 of 180 Old 02-13-2012, 03:17 PM
sefmiller's Avatar
Is it better to turn DVD upscaling on or off on my blu-ray player? The output is still 1080p.
post #155 of 180 Old 02-13-2012, 03:26 PM
wmcclain's Avatar
Liked: 2591
If your player is producing 1080p then it is deinterlacing and scaling the DVD video.
-Bill
post #156 of 180 Old 04-21-2012, 09:30 PM
Jon Middleton's Avatar
Quoted: 195 Post(s)
Liked: 141
I did a test a couple of nights ago to see about upscaling of standard DVDs. I watched a standard DVD played on a Samsung BD-P3600 player on my Samsung 55" HDTV, using HDMI and Component cables. Couldn't tell the difference, even though BD players are supposed to upscale standard DVDs. I thought that the PQ through Component wouldn't approach the PQ played through the HDMI cable. Would I see a difference with a different player?
Jon Middleton is offline
post #157 of 180 Old 04-22-2012, 05:38 AM
BillP's Avatar
Quoted: 277 Post(s)
Liked: 223
You aren't seeing much of a difference because the SD DVD is being upscaled both ways, either by the player or by the display. You would see a difference only if the upscaling is done much better by one of your devices. Both being Samsung, I'm guessing upscaling is pretty much done in a similar way with both devices. Yes, you may see a difference with a player that has a better upscaler. Also, you don't say what your settings are. What are you outputting over component? 480i? 480p? 720p? 1080p? And what are you outputting over HDMI? 1080p? 1080i? 720p? 480p?
BillP is offline
post #158 of 180 Old 04-22-2012, 10:15 PM
Quoted: 195 Post(s)
Liked: 141
The TV said 480 over component, not sure over HDMI. SD DVDs are limited to 480 over component cables, so I expected to see a better picture over HDMI. It looked the same.
So, the question is why SD DVDs aren't being upscaled when using the HDMI cable.
I was toying with the idea of buying an Oppo 95 and one of the HD Fury versions, but if SD DVDs aren't upscaled over HDMI, it doesn't look like I'll gain enough to justify the expense.
post #159 of 180 Old 04-23-2012, 06:21 AM
JazzGuyy's Avatar
Quoted: 339 Post(s)
Liked: 342
As was pointed out, when you have a fixed pixel display (any flat panel TV) and you feed it any signal other than the TV's native resolution, there is always upscaling taking place. If the Blu-Ray or DVD player does the upscaling, it will put out a 1080p signal (assuming your TV is 1080p) and the TV will just use it with no upscaling needed. If the player is putting out 480i or 480p, then the TV will do the upscaling to its native resolution. One thing to always check is that you have set the output of an upscaling player to the appropriate resolution of your TV. Your SD DVDs are being upscaled either way.
It is quite possible, as was mentioned in the previous reply, that both your TV and player do equivalent upscaling and therefore you see no difference since the results are the same. You need to try some other device that upscales and see if you see any differences in its performance.
JazzGuyy is online now
post #160 of 180 Old 04-23-2012, 09:40 AM
Quoted: 195 Post(s)
Liked: 141
Interesting. I was doing the test to see if buying the new gear would improve the PQ in my home theater. The display down there is a 720P DLP PJ, which I assume doesn't upscale since it's 10 years old. It doesn't have HDMI input, of course.
post #161 of 180 Old 04-23-2012, 10:13 AM
Selden Ball's Avatar
Quoted: 3429 Post(s)
Liked: 1700
Jon,
All digital displays, including DLP projectors, have to scale their inputs to match their display resolution. You need to look at the details of the scalers that you're using -- in the player, in the receiver (or pre/pro), in a separate scaler (if that's what you use), and/or in the projector. The visual differences, unless you have defective hardware, tend to be very subtle for most people and can be best seen when using appropriate test patterns, not while watching movies.
What model of projector do you have? I suspect it's capable of scaling 1080i to 720p, since both resolutions are in the original HDTV specs.
A caveat: my understanding is that while those few current-generation Blu-ray players which have component video outputs can be configured to scale to 1080i or 720p over their component video connections, future players will not be allowed to have component video outputs at all. This is due to the "analog sunset" provisions included in the license to use HDMI.
In other words, you need to start considering getting a projector (and other components) with HDMI connectivity.
Selden
Selden Ball is offline
post #162 of 180 Old 04-23-2012, 11:36 AM
Quoted: 195 Post(s)
Liked: 141
Thanks, Selden. My PJ is an NEC HT1000. So, you're saying that the 480p or 480i signal put out by my BD player over Component will be upscaled by my PJ? The question is, would a new 1080p PJ with HDMI input look better with SD DVDs. The HDFury supposedly gets around the upscaling restrictions of SD DVDs over Component, which was why I was considering it.
I watched a SD DVD played on a standard DVD player, then on a BD player. Both my wife and I thought the BD player looked better. Were our eyes playing tricks?
post #163 of 180 Old 04-23-2012, 12:12 PM
Liked: 1700
Yes. According to the spec sheet I found on the Projector Central site, your projector can handle most of the common scanrates: 1080p60, 1080i, 720p, 576p, 480p, and 480i, scaling them down or up as needed. (I don't see 576i listed, though. That's the standard the PAL/SECAM scanrate).
A native resolution of 1920x1080 would have noticably higher resolution than your current projector's resolution of 1024x768. That alone would make a big difference in your movie and video experience. It might not be entirely good, though. It's amazing how many actors have minor facial defects. (Watching a widescreen presentation letterboxed on your current projector would be not much better than SD. Or do you use an anamorphic lens?)
Probably not. The scaler in your projector is old enough that the newer scaler designs available in current generation hardware probably are better: many of them include features that were only available in high-end scalers just a few years ago.
Selden
post #164 of 180 Old 04-23-2012, 12:32 PM
Quoted: 195 Post(s)
Liked: 141
I'm not using an anamorphic lens. For 16:9 displays, I'm really only seeing 576p. It's really a nice picture, though, and I'd like to at least use the PJ till the bulb goes bad. I have a ways to go, though. Like you say, HD isn't always friendly.
I wouldn't mind buying a nice 1080p PJ, but my room is only wired for Component. HDMI cable install isn't going to happen, as it's technically difficult and I don't want to tear into the walls and ceiling. I'm waiting for wireless transmission from my BD to the ceiling mounted PJ.
post #165 of 180 Old 04-23-2012, 12:49 PM
Liked: 1700
If you're enjoying it, by all means keep using it!
Understood.
Some business-class projectors have been available for a while which include wireless and ethernet connectivity. I haven't been following the entertainment projector industry very closely since I got my new projector about 18 months ago, so I don't know if wireless is available in them. (Like you, I don't plan to upgrade for a while. I've only got about 1K hours on a bulb rated for 5K at low power.)
I doubt that BD players will be transmitting on wireless networking for a while, although computers already can, so an HTPC system might work. If your cables are in a conduit, you could consider HDMI over ethernet, although you might have to sacrifice your current cables.
Not that I'm encouraging you to spend all that money now, you understand, just mentioning some possibilities.
Selden
post #166 of 180 Old 04-23-2012, 01:09 PM
Quoted: 195 Post(s)
Liked: 141
The Epson 5010e has wireless capability now. Don't know how many others do. It may take a while for the that technology to mature, but that's okay. My bulb has 260 hours on it, so it's probably good for 500 more movies.
post #167 of 180 Old 11-23-2012, 08:28 AM
chuft's Avatar
Wow, been awhile since I have been to this wonderful forum. I hope someone has some advice for me.
Back in the day I bought my Samsung DLP HDTV, and a Samsung HD931 upconverting DVD player to go with it. I now have a hefty collection of standard DVDs. I was always very pleased with the upconverting capability of the HD931, with its Faroudja or whatever technology.
Recently the HD931 died, and I looked around for highly rated upconverting standard DVD players. I ended up getting a Philips DVP3560, both for its high marks in upconverting as well as its ability to play PAL discs, and be region free.
Well, its upconverting picture quality strikes me as greatly inferior to what my HD931 could do. frown.gif I thought a much newer player would be able to upconvert as well or better than something from 2004 for a much cheaper price, but apparently that is not the case. Back then a HD931 was about $300.
Incidentally my TV uses a DVI interface, not HDMI, so I had to use a HDMI-out DVI-in cable to send the signal from the player to the TV. Could this be causing an image quality issue? It seems unlikely since it should just be the video digital signal, which should be exact, but I am no expert.
Anyway, assuming the player is to blame, I am wondering if there is a blu-ray player out there with upconverting capabilities on a par with the old HD931. Or does one need to to find a standard player with older tech similar to the HD931? I have heard of "Oppos" but they seem very rare and quite expensive compared to what the HD931 cost me back then.
Any advice would be appreciated.
chuft is offline
post #168 of 180 Old 11-23-2012, 08:49 AM
wmcclain's Avatar
Liked: 2591
HDMI->DVI should give the same performance as HDMI alone. DVI is always (?) RGB color space, so make sure the display is not insisting on YCbCr.
Otherwise, recalibrate for each input device to get the best results.
OPPOs are not rare here.
-Bill
post #169 of 180 Old 11-24-2012, 07:20 AM
Nisei's Avatar
Quoted: 14 Post(s)
I've always wondered how people are using their AV receiver for upscaling of HDMI signals. I've had 2 BD players so far and both could only output either a fixed resolution you choose or Automatic setting. When I want to use my AV receiver to do the upscaling I would have to manually set my BD player to 480p every time I watch a DVD. Why don't these players have an option to output the original source signal?
Youth is wasted on the wrong people.
Nisei is offline
post #170 of 180 Old 11-24-2012, 07:31 AM
wmcclain's Avatar
Liked: 2591
Some players do have a Source Direct option. You'll get 480i for DVD and 1080p23.976 for most Blu-rays.
-Bill
post #171 of 180 Old 11-24-2012, 07:44 AM
moxie1617's Avatar
Oppo's and the current Sony's support 480i output. When I first got my Sony BDP590 I tested deinterlacing and scaling of the TV vs the AVR vs the player. In no case did my AVR produce the best picture.
Originally Posted by moxie1617 View Post
I am really suprised the player has this feature. It always seemed like you had to pay for an Oppo,or more,to get source direct. I played with some DVD's yesterday using 480i output. Using the superbit version of The Fifth Element I looked at the video Capabilities of my receiver and TV. As far as best video upconversion the Sony won. My TV came in second, Panny GT30, and the Anchor Bay processor in my Pio VSX-1021 came in last. The Pio had problems with noise in dark scenes. Both the Pio and Panny had problems with jaggies. The Sony did the best, that's what I expected, but I was suprised how well the TV did with a good 480i input.
BTW, original resolution does output 480p with a 480i source.
moxie1617 is online now
post #172 of 180 Old 11-24-2012, 09:01 AM
chuft's Avatar
-Bill
Thanks. Unfortunately I don't know how to recalibrate and I have read it can destroy your TV if you don't know what you are doing. Can't afford to hire someone to do it either.
It sounds like Oppo's are the way to go nowadays for serious quality upconversion combined with blu-ray capability. I don't understand all the audio stuff so the BDP-103 sounds like the unit for someone like me, who mostly cares about high video quality from a standard DVD.
chuft is offline
post #173 of 180 Old 11-24-2012, 09:43 AM
wmcclain's Avatar
Liked: 2591
Operating the user controls with a calibration disc can do no harm, and the results can be very impressive.
-Bill
post #174 of 180 Old 11-26-2012, 09:37 AM
Liked: 1700
As I recall, the "destroying your TV" warnings were for CRTs. Burn-in of the phosphors and over-stressing their high-voltage power supplies were possibilities if you set the brightness and contrast too high. Both are irrelevant for modern solid-state TVs and projectors.
Modern BD players in the $200 range, like the Sony BDP-S790 and Panasonic DMP-BDT500 can be a cost-effective alternative to Oppo players (which start at about $500). Both of those players include a variety of upscaling options.
Selden
post #175 of 180 Old 11-26-2012, 10:59 AM
GibsonEX's Avatar
Hm, it looks like Sony's S790 is among the best when it comes to DVD upconversion, which is one of the main selling points in my case. It was recommended to me in the other thread too. I was thinking about Oppo, but this seems to be great alternative price-wise. Any idea how much better is S790 compared to an aging Pioneer BDP320?
GibsonEX is offline
post #176 of 180 Old 11-26-2012, 03:22 PM
chuft's Avatar
Actually I had never heard of calibration until I got my DLP back in (2004?), and I read then that if you went into the hidden technician-only service menu and fiddled with the settings you might end up permanently losing the picture (since it would go black and you could not see to undo what you had done, or something along those lines). It certainly sounded intimidating and a lot of people recommended hiring a professional to calibrate HDTVs.
Thanks very much for mentioning this, now that I look into it a lot of people seem to think the Sony has the same upconverting quality as an Oppo. Hopefully it is better than the Philips DVP3560, which really disappointed me after my Samsung HD931.
I am sure the Oppo has features the Samsung doesn't, at that price, but I suspect I would not know how to take advantage of them.
chuft is offline
post #177 of 180 Old 11-26-2012, 07:00 PM
chuft's Avatar
Speaking of TV calibration when getting a new DVD player, what do you guys think of this? Best Buy has a free service for "Silver" members that says:
"TV Calibration – Having an HDTV is one thing. Having it personalized to your exact needs is another. Our ISF-certified installers will come to your home and calibrate your HDTV so you're seeing it the way it was meant to be seen."
Is this worth doing, or is it worth what you pay for it (nothing) ? Anyone know whether they go into the service menus, or just use the user controls?
chuft is offline
post #178 of 180 Old 12-04-2014, 12:04 AM
brycenesbitt's Avatar
Question Upscale in the DVD player or in the TV. Which is better?
Lots of DVD or Blu-ray players can upscale content.
But my 1080p TV can do this also.
Which of the two is more suited to the job and why?
brycenesbitt is offline
post #179 of 180 Old 12-04-2014, 01:55 PM
Liked: 1700
The one to use is the one which does it better. You have to try them to find out. The differences might be subtle enough that you might have to use video calibration signals to see the difference.
When you select the resolution in the BDP, some BDPs use a fixed refresh rate. E.g. setting it to 1080p might also cause its output to always be at 60fps. This might or might not be desirable when playing 1080p24 content.
Many BDPs also include a setting for the type of color-space to transmit. (YUV 4:2:2, YUV 4:4:4, RGB, etc). Again, you have to find out which works best for your combination of equipment.
Some AVRs and cable boxes also provide scaling. Again, you have to try them.
In some cases, setting a fixed output resolution in a cable box can eliminate some kinds of HDMI dropouts.
Selden
post #180 of 180 Old 05-27-2015, 05:14 PM
jazzycat's Avatar
Quoted: 213 Post(s)
Liked: 98
Hello. I have a question about blu ray players and conversion of sd dvds. I recently acquired a 50" Panasonic plasma tv, and I want to upgrade my player. I have hundreds of dvds. I'm wondering what the best player would be for getting the best PQ for old dvds while also getting great performance for newer content. Also would like a fast load time. I was looking at the Sony 5500 or 6500, as I've seen too many problems with the newer Panasonic 360. I can't yet afford an oppo.
From reading a couple of pages here, it seems the TV can do it or the BDP. I'm not real clear how this works. If this is the case though, how important is that aspect of a player? (I'm new to all of this, so I don't yet understand it all.)
Help please!
(I'm hoping this is the right place to ask this question, since it's about upconversion of sd dvds. If not, can a moderator please move the post for me? thanks!)
jazzycat is offline
Reply Blu-ray Players
1080p , Denon Dvd 3800bdci Blu Ray Disc Dvd Cd Player , dvd , upscale
