The Pioneer Elite BDP-09FD Owner's Thread... - Page 292 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #8731 of 8758 Old 04-02-2015, 02:57 PM
b curry's Avatar
Quoted: 450 Post(s)
Liked: 250
Originally Posted by prepress View Post
I wonder what sort of weird codes are built into these discs. There's been no new firmware for awhile.
Originally Posted by DVD MAN View Post
My BDP-09 always has issues with loading Lion Gate and 20th Century Fox titles,but they always play.
I notice a loading time improvement when I disconected the internet hard line from the player.
Lionsgate titles have given problems to a lot of BD players with their authoring scheme, especially older machines where there is a limited amount of processing power available; a hardware limitation. The Hunger Games: Mockingjay is a recent example from Lionsgate were older machines are not able to bitstream audio without drop-outs. If this is the case, there is no firmware fix, the hardware is simply not robust enough to handle the situation.
Anecdotally, I've had problems with this series of Pioneer machines (BDP- 05, 51, 09) being able to load or load with consistency several 20th Century titles.
b curry is online now
post #8732 of 8758 Old 04-02-2015, 05:26 PM
prepress's Avatar
Quoted: 120 Post(s)
Liked: 88
I've heard that Fox titles were tricky at times. I remember the last calibration of my Kuro, (by Kevin Miller) when he wanted to use a BD of a James Bond flick; the 09 didn't like it, but it played okay on the Oppo 83. I think that was a Fox movie. The one or two Lionsgate films I have were no problem.
VPI, Grado, SME, Pioneer Elite, Magnum Dynalab, Oppo, DVDO, McIntosh, JJ, Mirage, Kimber, Transparent, MIT, Pangea, Wireworld, Shunyata, PS Audio, Furman, Sanus
prepress is offline
post #8733 of 8758 Old 04-05-2015, 02:43 PM
cbono's Avatar
Anyone having any problem with any BD and their BDP-095FD should be sure they try without having their player connected to the internet. For example, my problem with the District 9 BD went away as soon as I disconnected. Given how lame BD-live content has ever been, and the now rather unlikely probability of any firmware updates, can anyone state a valid reason for keeping their player continuously connected to the internet?
cbono is offline
post #8734 of 8758 Old 04-07-2015, 04:29 PM
prepress's Avatar
Quoted: 120 Post(s)
Liked: 88
I would agree. The only time I connect mine is for a firmware update, as I too have no interest in BD-Live material.
If there ever is another firmware update, I'm pretty confident it would be the last.
prepress is offline
post #8735 of 8758 Old 04-13-2015, 03:19 PM
bacardis's Avatar
Liked: 0
I would agree with the above answers.
I found the Blu-ray picture to be the same for the BDP-09 as compared to the Pioneer BDP-05/51; they use the same SoC. Like wise for the audio, they all use the same DAC's the 09 just has more of them giving it an inaudible difference IMHO; the difference is on paper for signal-to-noise ratio. The 09 had a very small advantage for DVD playback compared to the BDP-05/51, but not night and day. I've owned all three of these machines and still have the BDP-05.
I have two OPPO's now, one of them on a Pioneer plasma and they have no short comings IMHO.
You have to do what you're comfortable with but I would point out there is a reason your seller is selling the unit for more than a 50% discount. It's nearly a 7 year old machine with a checkered repair/reliability history. Repair parts are getting hard to find and a drive replacement can cost as much as a new OPPO BDP-103 which I think is as good if not better than the BDP-09.
Personally, if it were me, I'd buy the OPPO BDP-103D and call it a day.
Good luck and Caveat emptor.
Hello
I just want to key in about the Oppo 103 which at present I have and used to have a 105(sold very quickly). The Oppo's use the Sabre ES9018 dac chip which I think has great resolution and extension, but at the other end sounds very thin in the midbass to lower end. I am looking to buy a Pioneer BDP 05 or 09 which uses 8 Wolfson Dacs running in dual mode. I think these dacs or even Burr Browns are balanced better than the 9018. I think for a test try one against the oppo and see for yourself. Let it settle in a few weeks and give your conclusions. When I get my Pioneer BDP 05 I will compare it to the 103. I will definitely end up selling it off. When I had my 105(2channel analogue) I put it up to a Emotiva UMC-200 for processing in analogue and it blew it out of the water. I know many people like me enjoy the bass depth and authoritative low end in a multichannel movie setup or even two channel stereo. I think the oppo's need to be better balanced in the range especially if one has a very revealing system. One queation: is the Pioneer 09 a better buy than the 05? Please any comments will be of help..THX.
bacardis is offline
post #8736 of 8758 Old 04-13-2015, 10:24 PM
lnarbi's Avatar
Quoted: 222 Post(s)
Liked: 68
Is it better ? Yes. Is it worth it ? Depends on you.
Same debate as for today's LX58 vs LX88.
The 05 is already pretty good, the 09 will retain it's sonic signature, only improving it.
lnarbi is offline
post #8737 of 8758 Old 04-14-2015, 10:22 AM
b curry's Avatar
Quoted: 450 Post(s)
Liked: 250
Originally Posted by bacardis View Post
Hello
For me, you would have to define what "better buy" means.
For audio, the Δ change between the 05 and 09 both using the Wolfson WM8740 DAC's is a 3dB improvement in SNR wired single ended vs. differential mode. While this is an improvement for signal to noise ratio and can no doubt be measured, I do not believe it will make an audible difference in sound as the change is very small and the single ended configuration has an already excellent 117dB SNR. At best the change would be very small in dynamic range and not the overall sound anyway.
If you check the SNR of your AVR or pre/pro amplifier combination you may well have a SNR from the control or amplifier section that negates any benefit you may gain with either unit. That is your AVR or pre/pro amplifier combination may have more noise than the 05 or 09 which would mask the benefit. So for me the 05 would be the better buy because I would have the same sound for less money. If you want bragging rights for higher SNR then the 09 is the better buy I guess.
FYI, here is the data sheet and specs for the WM8740 so you can see the information from the source. http://www.cirrus.com/en/pubs/proDat...M8740_v4.4.pdf
The other primary difference between the 05 and 09 is that the 09 did a very slightly better job with DVD video. But you really need the machines side by side running the same material to see any difference IMHO. Again, that made the 05 a better buy for me.
YMMV.
post #8738 of 8758 Old 04-19-2015, 11:36 AM
bacardis's Avatar
Liked: 0
Pioneer 05 vs 09
The thing is that I would like a USB port and the 09 has one and the 05 doesn't. Now the top aMarantz UD 7007 has one and it uses the new 1756 chip and has USB port. Used for $700 ish. I don't know how it would compare to the pioneer 09. Anyone know? Thx....
bacardis is offline
post #8739 of 8758 Old 04-19-2015, 12:48 PM
Jon S's Avatar
Quoted: 908 Post(s)
Liked: 283
The USB port on the Pioneers are only for BD-Live capability. It offers nothing else useful unlike the Oppo USB ports which can be used as a file source.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #8740 of 8758 Old 05-04-2015, 02:01 AM
BLUTRIG's Avatar
Originally Posted by JA Fant View Post
Many Thanks! BLUTRIG
has this been recently?
YES about a week before your post,Pioneer said don't have any for theBDP-09FD
BLUTRIG is offline
post #8741 of 8758 Old 06-16-2015, 01:57 PM
prepress's Avatar
Quoted: 120 Post(s)
Liked: 88
Originally Posted by HDTVAV View Post
So it seems that the only differences between the LX88 and the LX58 are that the 58 doesn't have:
Three-Chamber Structure
Highly Rigid Center Frame
Anti-Vibration Paint
Large-Capacity Power Supply Transformer
Precision Audio
Audio Scaler
Balanced Analogue Audio Output
Are the Precision Audio and Audio Scaler even relevant if you are using HDMI?
The DACs are different as well. The 88 uses a (presumably) higher-grade chip (ES9018) versus the 85 (ES9011).
prepress is offline
post #8742 of 8758 Old 08-29-2015, 06:58 AM
prepress's Avatar
Quoted: 120 Post(s)
Liked: 88
A question for those who use their 09 in a 2-channel setup. In the "Speaker Setup" menu, do you use "Stereo" or Lt/Rt?
prepress is offline
post #8743 of 8758 Old 09-22-2015, 02:41 PM
cbono's Avatar
http://hdguru.com/relief-headed-to-m...rs/#more-16702
Too bad Pioneer wasn't a class act regarding all the $2200 MSRP BDP-09FD drive repairs paid for out of pocket by consumers who thought they were buying a world class product made by a world class company.
filmoreXXX likes this.
cbono is offline
post #8744 of 8758 Old 09-22-2015, 03:05 PM
Gary16's Avatar
Quoted: 61 Post(s)
Never had a problem with my 09. Still works fine. I'd call it a world class product.
Gary16 is offline
post #8745 of 8758 Old 09-22-2015, 07:16 PM
G-Rex's Avatar
Quoted: 632 Post(s)
Liked: 402
My 09 still going strong as well, never needing repair. Looking forward to a UHD version of the Pioneer 09.
G-Rex is offline
post #8746 of 8758 Old 10-22-2015, 04:09 PM
Jurassic World BD
Anybody else having issues with the Jurassic World BD? Once I get to the menu, if I hit "Play" or "Resume film" it just loops the main menu video only, without the menu selections. It gets stuck here requiring a reboot of the machine. None of the remote buttons seem to do anything to bypass the loop.
saffron_boots is offline
post #8747 of 8758 Old 10-24-2015, 02:35 AM
rider's Avatar
Is that the only BD you're having problems with?
A couple/few years ago there was a similar problem with a Terminator BD, IIRC; that required a firmware update to resolve. I hope that's not the case this time....
"I am determined to be cheerful & happy in whatever situation I may be; for I have also learned from experience that the greater part of happiness or misery depends upon our dispositions & not upon our circumstances."
Martha Washington
rider is offline
post #8748 of 8758 Old 10-24-2015, 11:37 AM
A couple of other niggly things have happened with recent purchases. Seems tied to BD Live, but can't be completely sure. Tested the discs in an OPPO BDP-95 I also have: all worked fine.
Probably a firmware issue (I have 2.74 installed). I had assumed they settled the Blu-ray spec by now...
post #8749 of 8758 Old 10-24-2015, 12:12 PM
rider's Avatar
Have you tried Jurassic with the internet disconnected?
Martha Washington
rider is offline
post #8750 of 8758 Old 10-24-2015, 01:39 PM
lnarbi's Avatar
Quoted: 222 Post(s)
Liked: 68
Instead of launching the movie normally have you tried to search chapters, and launch the first one, or the second one then back to the first ?
I couldn't start mad max fury road (on LX08 though) from the menu, but when I launched first chapter from the chapters menu it worked.
lnarbi is offline
post #8751 of 8758 Old 10-24-2015, 06:09 PM
Yes. Same problem. You CAN start the movie by going to the chapters menu. You can also start the movie, by accident, through the extras menu (when the internet is disconnected). Basically, there's a request to the Universal server every time you do something. If the internet is missing, it starts the film, with the notable exception of "PLAY" and "RESUME FILM", if it hasn't been started (through some other means) already.
This seems to indicate that the BD has NO extra features on the disc and uses a server on the internet instead. I wonder if it's checking to see that the disc is legit, and not a copy. Don't know.
Also, I've isolated my experimentation by removing all the stored data on the Flash drive, to ensure that there was no preloading occurring.
To me, this all reeks of a distributor's attempt the curtail piracy, by breaking the spec (a la Sony's attempt at circumnavigating the CD red book), all under the guise of enhanced features...
post #8752 of 8758 Old 10-24-2015, 07:06 PM
rider's Avatar
Well that's good news that at least it's playable. I already bought the disk but I'm not currently home to try playing it on the 09. At least I know I can keep it now and don't have to return it...
Martha Washington
rider is offline
post #8753 of 8758 Old 11-01-2015, 01:13 AM
lnarbi's Avatar
Quoted: 222 Post(s)
Liked: 68
No problem here with JW zone B on LX08 player (same firmware).
So far the only problematic one is mad max fury road, I have to launch from the chapters otherwise it hangs on the EDV... notice.
lnarbi is offline
post #8754 of 8758 Old 03-26-2017, 09:43 PM
Liked: 0
Pioneer BDP-09FD with Denon 3805 audio
Hello all,
New to the forum here and so glad that I can ask some questions to hopefully get some answers. Thank you for your time.
I have a Denon 3805 receiver that I use along with a Denon POA2400 amp that I hooked my front speakers up via pre outs on my 3805 for power source only. Same with my center hooked up to a Marantz MA700 mono amp strictly for my center via the pre outs on my 3805.
Mind you I just have 3 speakers hooked up. My rear surrounds are not hooked up yet but when I do I will be using another Denon POA200 for the rears hooked up via the 3805 pre outs. No speakers hooked directly to my 3805, all through separate power amps.
Now here is my dilemma...
I recently acquired a Pioneer BDP-09FD blu-ray player and I want to take advantage of its audio capabilities. I have that hooked straight to my Pioneer Kuro KRP-500M monitor via hdmi. I know my Denon 3805 has no hdmi ports to get maximum audio from the blu-ray player.
Is there another way other than optical out that I can use to connect the audio out ports directly from the player to my 3805. Right now I'm using optical out for the sound ( it does sound good too), but a I would like to use the separate audio channels from the player if possible. It seems like I'm limited on the sound upgrade unless I upgrade my processor with hdmi. I like my 3805.
Any advice would be welcome. Thanks so much.
Lonnie
562lonnie is offline
post #8755 of 8758 Old 07-11-2017, 09:31 PM
Liked: 0
Pioneer Elite BDP-09FD HDMI Audio Choices
Hello all,
I 've noticed on the user manual on this player that to get better sound out of it you can hook 2 separate HDMI cables to it. 1 HDMI cable to a receiver and another HDMI to a monitor via Kuro link and sub. Now when I did this all that is decoded is DTS Neo 6 not True HD or DTS MSTR HD audio like before. I removed it back to using only one HDMI and on she came...HD audio. Did I do something wrong or is using 2 HDMI cables for something other than HD audio? I have a Marantz AV7005 processor I use with my Pioneer 09FD.
Thanks so much,
Lonnie
post #8756 of 8758 Old 07-13-2017, 03:45 PM
Jon S's Avatar
Quoted: 908 Post(s)
Liked: 283
IIRC, you would get the best sound using the analog outs of the BDP-09FD... You should not be using the digital ports. if you use the analog ports, you would be using the Burr-Brown DACs in the player. if you use the HDMI cable, the digital signal is passed to the AVR for decoding.
Jon S is offline
post #8757 of 8758 Old 07-13-2017, 06:42 PM
Liked: 0
Would it still be possible to get true HD audio using the analog out DAC's or would it just be stereo for all speakers? I thought you couldnt get HD audio without HDMI.
post #8758 of 8758 Old 07-14-2017, 01:34 PM
Jon S's Avatar
Quoted: 908 Post(s)
Liked: 283
to clarify, to get the best sound from CDs you would use the analog outputs... On newer codecs on movies you would have to send the signal out via HDMI to have your AVR decode it. if the AVR cannot handle the newer codecs, then both of this will be moot.
Jon S is offline
Reply Blu-ray Players
Blu Ray Players , Pioneer , Pioneer Bdp 09fd Elite Blu Ray Player , Sony
