Blu-ray hdmi to component out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-29-2009, 03:25 PM - Thread Starter
adil_s's Avatar
I want to play a blu-ray player on my Infocus X1 projector which only accepts component. What would be the best way to output blu-ray to component and what would be the best resoution I can get out of it?
adil_s is offline
post #2 of 7 Old 01-29-2009, 03:31 PM
Geezer's Avatar
Quoted: 20 Post(s)
1080i if your projector can display it.
HDMI will give you 1080P.
Component maxes out at 1080i.
Geezer is offline
post #3 of 7 Old 01-29-2009, 03:44 PM - Thread Starter
adil_s's Avatar
So can I directly get component output from the blu-ray player? or do i have to use some sort of a hdmi to component converter? thanks.
adil_s is offline
post #4 of 7 Old 01-29-2009, 03:49 PM
Geezer's Avatar
Quoted: 20 Post(s)
There may be an exception, but most players should have the downgraded connections available as an option. On my Sony, I have HDMI, component & even S-video/RCA.
Geezer is offline
post #5 of 7 Old 01-29-2009, 05:30 PM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
Infocus X1 only accepts up to 1080i anyway. All the Blu Ray players I've seen have component video out so you should be fine.
Make sure you have this adapter.
http://www.infocus.com/Accessories/C...SA_ADPT_R.aspx
My buddy used to have this projector so I know it works fine with component video at 1080i.
Afro GT
afrogt is offline
post #6 of 7 Old 01-30-2009, 06:59 AM - Thread Starter
adil_s's Avatar
great thanks for your responses - thats what i was looking for.
adil_s is offline
post #7 of 7 Old 01-30-2009, 09:11 AM
BuGsArEtAsTy's Avatar
Quoted: 328 Post(s)
Liked: 148
Note that you will NOT get DVD upscaling over component.
BuGsArEtAsTy is online now
Reply Blu-ray Players
