Panasonic BD-35: how to play MKV/AVCHD on sd card? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-01-2009, 04:14 PM - Thread Starter
NirvClub's Avatar
Hi
Supposedly on the BD-35, the SD card will play AVCHD files.
I found a guide on bitburners.com which explains how to convert .MKV files to AVCHD using an application called tsMuxeR. So far so good.
I tried copying the two folders that the software outputs to my SD card:
\\BDMV
\\CERTIFICATE
But when I put the SD card in my BD-35, it won't recognize any files.
I also tried putting them under a directory called \\ACVHD but no change. I even tried running the AVCHDme.exe application to change the filenames, but no luck. The SD-35 won't recognize the AVCHD video.
So, basically, how do I get the BD 35 to play my AVCHD video? Or even better, how do I play an MKV file on the BD 35 without converting it to, say, DivX (i.e. quality loss) or burning it to DVD? I want to be able to play it from the SD card.
Thanks so much.
NirvClub is offline
post #2 of 4 Old 02-01-2009, 04:21 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 954
Welcome.
Please use the owners threads for questions regarding functunality of specific players. If you run a search in the forum, you might find an answer to your question.
http://www.avsforum.com/avs-vb/showt...75161&page=328
Good luck,
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #3 of 4 Old 02-01-2009, 08:12 PM
Donnie Eldridge's Avatar
Originally Posted by teachsac View Post
Welcome.
Good luck,
S~
FTW
And, the BD35 will not play MKV files.
Donnie Eldridge is offline
post #4 of 4 Old 02-01-2009, 08:16 PM
rboster's Avatar
Quoted: 886 Post(s)
Liked: 742
Thanks guys for your assitance with this new member.
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is offline
Closed Thread Blu-ray Players
