BD370/390 LG Blu-ray player Master/Owners thread - Page 126 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #3751 of 6944 Old 11-23-2009, 11:46 AM
captaincelluloid's Avatar
JUST TO CONFIRM THIS:
Originally Posted by cgould View Post
i don't know of any bluray media that actually invokes this "image constraint token" copy protection.
[b]so, trust that any bluray movies you buy now & for a while, will shine at 1080i on your component rptv, like mine. No worries!
Yeah, that's my understanding as well and I assume that it does
HOWEVER, Can any owner CONFIRM that the 390 does in fact output 1080 I over COMPONENT.
Also, can any owner confirm that the component
outputs will work if HDMI is plugged in for
AUDIO output.
AND what are the details on the analog bass management. Is the low crossover variable?
Thanks in advance . . . getting this info from the
manufacturer's manuals is getting more difficult
and more obfuscated.
-30-
Film Is NOT DEAD -- it is the Gold Standard against which all other formats are measured
Support ORIGINAL ASPECT RATIO
captaincelluloid is offline
post #3752 of 6944 Old 11-23-2009, 12:18 PM
beekermartin's Avatar
Quoted: 87 Post(s)
AUDIO output.
-30-
I can't imagine it not working with component for video and HDMI for audio. The only time it may not is if you select 24hz output. Most players will turn off the other video outputs when 1080p/24 is selected.
beekermartin is offline
post #3753 of 6944 Old 11-23-2009, 12:28 PM
andefeldt's Avatar
I just got made a cable connection from my router to my living room where my BD390 is located. Now my movies are streamed without problems from my NAS.
When I turned on my BD390 yesterday I noticed that a new firmware was available. I haven't been able to figure out what the new firmware includes and if it's "safe" to update. I read something about a former firmware that didn't relly work that well. How about the latest firmware? And what does it include?
andefeldt is offline
post #3754 of 6944 Old 11-23-2009, 01:17 PM
massmanjr's Avatar
I just bought this brand new on Amazon for $209--that includes shipping. At checkout, apply promotion code: CHASEBLR Current list is $259, promotion code drops price to $209. I believe this code applies only if you already have an Amazon Visa card.
massmanjr is offline
post #3755 of 6944 Old 11-23-2009, 01:19 PM
Stew4msu's Avatar
Also available from ABC Warehouse for $199 + shipping ($9.80 for me, bringing the total to $208.80)
Stew4msu is offline
post #3756 of 6944 Old 11-23-2009, 02:34 PM
bouhhan's Avatar
thanks for that - just picked this up - looking forward to testing it out.
that man is my exact double. that dog has a puffy tail!
bouhhan is offline
post #3757 of 6944 Old 11-23-2009, 06:08 PM
tightrope's Avatar
Quoted: 12 Post(s)
Thanks for sharing, good deal indeed.
I just ordered my (second) BD-390
tightrope is offline
post #3758 of 6944 Old 11-23-2009, 06:14 PM
blurayinfo's Avatar
Originally Posted by another schmo View Post
390 has wireless built in. 370 only has a wired connection so wireless requires an ethernet "gaming adapter" or similar.
The 390 has built in wifi the 370 does not. If you need it to be wifi get the bd390. Its a great player!
blurayinfo is offline
post #3759 of 6944 Old 11-23-2009, 06:20 PM
sacarmic's Avatar
Quoted: 13 Post(s)
Any chance these will get an upgrade to use Pandora?
sacarmic is offline
post #3760 of 6944 Old 11-23-2009, 06:22 PM
blurayinfo's Avatar
You should always update the firmware when prompted. I think the newest firmware upgrade also includes a Vudu option. So yes absolutely update that firmware!
post #3761 of 6944 Old 11-23-2009, 06:24 PM
Argonese's Avatar
OK......I finally completed reading from page 46 to page 126. I am looking to buy a Blu Ray Player - most likely on Friday. I started looking at the Oppo but after reading reviews on the 390, I decided to check out the AVS forum to scan for potential issues. The only thing that causes any concern is the lip sync that some have encountered. What I get from reading is that as long as I am going through an AVR receiver with HDMI connections, I should have no problem.
I would appreciate if some of the more frequent posters would verify they have no issues or correct me if I am wrong. Seems like one of the regulars would want to put this issue to bed......
Argonese is offline
post #3762 of 6944 Old 11-23-2009, 06:44 PM
sd_smoker's Avatar
I don't think I can put the issue to bed, but I'm using HDMI to my TV and coax to my 5.1 DD/DTS receiver with no lip-sync issues. I've used both DTS Re-encode and PCM Pass-through without issue.
sd_smoker is offline
post #3763 of 6944 Old 11-23-2009, 07:02 PM
budven's Avatar
I just bought this player last Sunday and I am very happy with it. I have it connected to my LG 55LH90 via HDMI and then to a Sony receiver via the optical output. I am not having any lip sync issues and I am getting 5.1 sound with it. I also really like the wifi. Right now I have it connected though a wireless connection but Verizon provides a very weak router so I really need to connect with it directly to the router.
budven is offline
post #3764 of 6944 Old 11-23-2009, 07:52 PM
jsayers's Avatar
Originally Posted by morda View Post
Well, I tried to exchange BD390 for the different one, and the second one does the same thing. I looked through Denon forums and it seems that other people have the same issue with BD390 and Denon 2310. What's confusing is I also have a Denon 1610 in the family room, and BD390 bitstreams just fine to it; on the other hand I also have a Panasonic BD55 and LG BH200, and both bitstream fine to 3310. So it looks to me that there is some kind of compatibility issue between LG BD390 and Denon 2310/3310 and possibly 4310 as well. I will try to contact both LG and Denon and suggest that everyone who has the same problem will do the same. Unfortunately I dont have much hope that this will be resolved; however it definitely won't be fixed if I dont try.
I just purchased the 390. I have the same issue you described with your 2310. The 390 works with your 1610 no problem? What are your settings? I get the blue light but no sound.
jsayers is offline
post #3765 of 6944 Old 11-23-2009, 09:13 PM
PeZzy's Avatar
If it ain't broke, don't fix it.
If you're not missing anything or not having any problems, then there's no need to risk a firmware update. Just look through this thread to see people who have had problems with certain updates.
PeZzy is offline
post #3766 of 6944 Old 11-23-2009, 09:21 PM
PeZzy's Avatar
I've only noticed lip sync issues with the playback of xvid and mkv files. I just adjust the audio delay on a computer.
PeZzy is offline
post #3767 of 6944 Old 11-23-2009, 10:41 PM
mossypete's Avatar
Folks:
I just bought a BD370 to hook up to my Vizio GV42LF 42" lcd.
I unplugged the HDMI cable from my xbox360 ( which works perfectly at 1080p) to try the BD370 out but I got a horribly distorted picture whorls of color, flashing screen, practically unreadable, etc. tried another HDMI port - different cable - all possible settings on the TV and BD370 - no joy
I even unplugged everything for 5 minutes and rebooted all, LCD first then BD370
So I figured it's defective and swapped it out for another one at BB
Same problem
It works fine using component cables at 1080i
The visio specs say it can do 1080P/60hz ( and the info pane on the Vizio says 1080P on the horribly distorted picture)
The vizio and xbox360 work at 1080P xbox reports HDCP link restored and Vizio info pane report 1080p
One weird thing is when the BD370 boots up, the initial LG screen with the progressively lit dots comes up just fine - fills the screen ( at 480i SD) so some signal is coming across the HDMI cable.
any ideas out there
pete moss
mossypete is offline
post #3768 of 6944 Old 11-24-2009, 03:43 AM
sportage's Avatar
Im getting better streaming thru wireless than wired. I thought the 390 was Gigabit lan, not so. Should have been...
I can't see avoiding playback issues with vudu hdx using any wireless, or less than Gigabit wired. Since the 390 is not, at some point a full vudu movie in hdx will probably encounter the "loading" pause quite often. Trailers in hdx are short enough to get by.
I have both the linksys dual 610n router and the netgear dual 3700. I am finding the linksys provides better wired response with vudu compared to the netgear, where the netgear is better at wireless than the linksys.
sportage is offline
post #3769 of 6944 Old 11-24-2009, 05:31 AM
cyberpine's Avatar
Team,
Will the 370 Navigate Windows File Shares?
Is there any Digital File format (AVI/WMV/MPEG) that it will play from a Network Share or USB? Know of DVD Network Blu-ray that can do this?
BTW, I just purchased a PS3 with 250gb. It won't see NTFS formated USB drives (which I know the 370 can) and it won't play the AVI files my CAsio Exilim digital camera produces. I think it's going back.
cyberpine is offline
post #3770 of 6944 Old 11-24-2009, 06:01 AM
another schmo's Avatar
How fast is your internet connection if you believe a 100Mb wired ethernet connection is the bottleneck? A 1080P Blu-Ray with a TrueHD soundtrack is under 40Mbps. I'm sure a Vudu hdx film is much less than that.
another schmo is offline
post #3771 of 6944 Old 11-24-2009, 07:15 AM
RonV's Avatar
VUDU states 4.5 mbps for HDX. This is minimum since HDX uses variable bitrate encoding. I have 10.5 mbps down and most of the time I have three bars of HDX showing. Ocassionally I catch it at 2 bars and I assume this is due either internet delays or the bitrate of that section of the movie exceeded my 10.5 mbps down.
VUDU Evangelist
My Twitter: http://twitter.com/VUDUEvangelist
VUDU Blog: http://blog.vudu.com/
Go do that VUDU that you do so well! - Headley Lemarr, Blazing Saddles
RonV is offline
post #3772 of 6944 Old 11-24-2009, 07:39 AM
hotrodbob1976's Avatar
Can it play ISO files. I have tons of BD rips using Tsmuxer that are BD Disk file structure i.e. BDMV and Certificate folder. I then create ISO's so I can play them from my HTPC. Does anyone know if the 390 will play them? Thanks.
hotrodbob1976 is offline
post #3773 of 6944 Old 11-24-2009, 07:49 AM
Quoted: 87 Post(s)
Originally Posted by mossypete View Post
Folks:
Same problem
any ideas out there
pete moss
Can you get into the setup menu? If so try to select different resolutions to narrow down when it happens. Does your TV accept 24hz? If not make sure you have 60hz selected.
post #3774 of 6944 Old 11-24-2009, 08:00 AM
mossypete's Avatar
Thanks - I tried 24 hz...no joy
everything through the HDMI cable is distorted 480i through 1080i/p
but the same cable supports 1080p from the xbox
I thought the first 370 was bad but I'm having difficulty believig the 2nd one is bad too
Next experiment is to try another TV
post #3775 of 6944 Old 11-24-2009, 08:06 AM
Quoted: 87 Post(s)
I would try another tv to eliminate the player as the problem. If you don't have one available just bring it to the store you bought it from and ask them to hook it up to a tv.
post #3776 of 6944 Old 11-24-2009, 08:44 AM
kevindef's Avatar
I recently purchased the LG BD370 and really have enjoyed the player. I am outputting Video via component video to my Hitachi HDTV which is about 6 years old, so it doesn't have HDMI. I am outputting Audio to my Sony Receiver via HDMI and get 7.1 and all the decoding just fine. In the LG player I have selected "Auto" for Resolution. My TV goes to 1080i, so I know I can't use 1080p. Is it better to select 1080i as the resolution or is "Auto" a better choice. "Auto" seems to do well, but am I missing anything??? Thanks for any help. Kevin
kevindef is offline
post #3777 of 6944 Old 11-24-2009, 09:24 AM
Quoted: 87 Post(s)
I would select 1080i.
post #3778 of 6944 Old 11-24-2009, 09:33 AM
JediMaster109's Avatar
I have a Netgear WNDR3700 and the BD390, I have watched 3 HDX movies and with all 3 I have never had a stop at all, also watched one on a Linksys WRT160 and just one pause... So far my VUDU experience has been A+!
TWC Milwaukee - HTPC with Windows Media Center
JediMaster109 is offline
post #3779 of 6944 Old 11-24-2009, 10:34 AM
sb1
sb1's Avatar
Quoted: 418 Post(s)
Liked: 359
Just to share an experience I had using the "auto" selection...
When I first hooked the player up, it was about 5 minutes before everyone was ready to watch the movie we had them over for, so I didn't have time to mess with the settings. I later found out that "auto" was selected in the resolution menu, and it was sending the wrong rez to my projector, hence a slightly fuzzy picture. Now I don't use the auto function, but rather adjust it manually according to which display I'm using. It's always been my experience that sending the display its native resolution is the best option.
Stephen.
Chances are very good that I was drinking when I posted the above.
sb1 is offline
post #3780 of 6944 Old 11-24-2009, 12:42 PM
maxwellimus's Avatar
Hi, I have currently owned my 390 for about 2 months now. And I feel iffy about it.
I stream a lot of video from my computer and I have called tech support to solve the audio drop out problem. I would have to set my resolution to 720p in order for the audio drop out to stop while playing a stream from my computer. The tech said that this is due to the fact that what I am streaming is not at 1080p.
My TV is an 46LG50 and is capable of 1080p output.
Another issue at hand is playing blu ray movies. When i set the resolution to 1080p (I'm assuming all blu-rays is at 1080p), the audio drop out would occur again, though not as frequent as streaming from my computer at 1080p resolution. I called tech and they said that I would need to set my resolution at 1080i since, she says, not all blu-rays are recorded at 1080p.
This confused me a lot. I'm not sure why I paid for a blu-ray player that can't play movies at 1080p, what blu-ray was meant for. If i wanted 1080i I could have just kept my DVD upconverter.
I wanted to know if this is true, and if anyone else is experiencing this issue with audio drop outs?
maxwellimus is offline
Reply Blu-ray Players
Lg Bd 370 Network Blu Ray Disc Player , Blu Ray Players , Lg Bd 390 Network Blu Ray Disc Player , Lg
