BD370/390 LG Blu-ray player Master/Owners thread - Page 14 - AVS Forum | Home Theater Discussions And Reviews
post #391 of 6940 Old 06-03-2009, 10:25 PM
bobbyslav's Avatar
Originally Posted by adamharsma View Post
I have a bd 390 linked up wireless to my pc everything is connected but I can't get the music I bought from itunes to work. Only music that was imported from cd's works. What do i need to do?
Burn your itunes purchased songs to a CD and then rip them in MP3 format... that or search for some program that might be able to convert and strip them off DRM directly on your computer.
bobbyslav is offline
post #392 of 6940 Old 06-03-2009, 11:22 PM
chokitin's Avatar
I own the LG BD 390, but have had the following problem.
Most of my mkv files are over 4 GB. The LG wont read them when I try to stream them, and the FAT32 system for a pen drive wont let me use big files.
How do you guys watch these kind of files?
Help appreciated.
chokitin is offline
post #393 of 6940 Old 06-04-2009, 12:48 AM
mugupo's Avatar
Help appreciated.
Download the program called MKV2vob, it convert the mkv to mpeg and h264 file under 4gb possible, very fast convert (mpeg one)
mugupo is offline
post #394 of 6940 Old 06-04-2009, 12:49 AM
mugupo's Avatar
So BD 370 can also read mkv, mpeg file same as bd 390? anyone know the source that said bd 370 ha 10 bit and 390 has 12 bit color processor. What color bit is samsung 1600/3600 or panasonic bd 60/80?
mugupo is offline
post #395 of 6940 Old 06-04-2009, 01:43 AM
stangvert's Avatar
I burn my MKV to a dvd and play them back on the player. I also reformatted my 32 gig usb flash memory to NTFS and I can put very large MKV files onto it. Playback on the USB flash is great.
stangvert is offline
post #396 of 6940 Old 06-04-2009, 01:47 AM
stangvert's Avatar
I haven't tried DVD -RW. I don't have any discs.
post #397 of 6940 Old 06-04-2009, 01:51 AM
mugupo's Avatar
can the LG 370 or 390 display bitrate information like ps3?
mugupo is offline
post #398 of 6940 Old 06-04-2009, 05:37 AM
ikdo's Avatar
stangvert, do u have the bd370 or the bd390? Thanks,
ikdo is offline
post #399 of 6940 Old 06-04-2009, 09:28 AM
Scoob's Avatar
Quoted: 30 Post(s)
Liked: 25
Originally Posted by mr stroke View Post
just read that Cnet review and find it odd as well. Everyone in this thread has stated the only difference in the players was WiFi, audio, and internal memory, and that the video processor was the same between both players?
I'm starting to wonder about that particular reviewer. I just looked it up and realized that he is the same guy who reviewed the Philips 7200 when it came out. He said that it had poor BD video quality. ( he said that it introduced jaggies during 1080i60 playback) However, all of the other reviewers claimed it had excellent video quality. Not only that several owners of the player on this forum and Blu-ray.com did the same tests and could not reproduce jaggies. I have to say that his information doesn't make any sense in relation to the LG370 and LG390. To say there is big differences in video playback is counterintuitive. I think he may be flat wrong. I wish I could do some side by side tests. I don't suppose anyone on here owns both machines do they?
Scoob is offline
post #400 of 6940 Old 06-04-2009, 12:09 PM
kmccleave's Avatar
Originally Posted by 4davis View Post
A number of posts state that the BD370 is incompatible with certain D-Link routers. It appears that this incompatibility is with the D-Link relaying DNS.
Try the following:
Choose the static IP option on the BD370 and reserve an IP on router.
On the BD370, make the following entries:
IP: xxx.xxx.xxx.xxx (use your reserved IP)
Subnet: 255.255.255.0 (usually, match with your topology)
Gateway: 192.168.0.1 (default for D-link, use your router IP)
DNS: 4.2.2.1 (use Level 3 DNS instead of router)
Thats it. It should work like a champ. At least mine did.
Good luck.
I bought the 370 yesterday and am having difficulty connecting it to my wireless router. I've a D-Link and it will read the Subnet. But how do I enter in the Gateway and DNS numbers? I read another post that mentioned an on-screen keyboard.
How do I reserve an IP on my router?
I'm not really technical so I don't have a good idea of what I'm doing. Any help would be appreciated.
kmccleave is offline
post #401 of 6940 Old 06-04-2009, 01:43 PM
SpHeRe31459's Avatar
Quoted: 16 Post(s)
I feel like I'm going to have to march down to Fry's or BB or something and insisit they hook up a 370 and I'll throw in a test disc!
SpHeRe31459 is offline
post #402 of 6940 Old 06-04-2009, 01:55 PM
Chefbeldar's Avatar
You can format your USB flash/hd to NTFS, BD390 will read it and you can copy >4GB files to the flash/HD.
Bryan
Chefbeldar is offline
post #403 of 6940 Old 06-04-2009, 04:50 PM
mugupo's Avatar
it will a slight different 12 bit is higher than 10 bits, so for $100 more than is wortht the moeny especially if you need the wifior the 7.1 analog audio.
mugupo is offline
post #404 of 6940 Old 06-04-2009, 05:46 PM
tightrope's Avatar
I received my 390 today and the connection to my wireless network was a breeze, even though I am not really technical neither. Let your LG player detect your network, select it in the list that comes up, then enter your password. As far as the network settings, I left the default options ("Dynamic" and "Auto"), and it took care of the rest. Let us know how that works.
tightrope is offline
post #405 of 6940 Old 06-04-2009, 11:34 PM
yamahafj's Avatar
This review states that the BD 390 can not take mkv-files. That is incirrect, right?!
http://gizmodo.com/5255151/lg-bd390-...rget-about-blu
yamahafj is offline
post #406 of 6940 Old 06-05-2009, 12:21 AM
ikdo's Avatar
Bryan
Hi, any1 knows if this is also true for bd370? I cant get my bd370 to play .mkv files on a NTFS formatted flash/HD. :-(
ikdo is offline
post #407 of 6940 Old 06-05-2009, 02:27 AM
stangvert's Avatar
I have the bd390
post #408 of 6940 Old 06-05-2009, 02:33 AM
stangvert's Avatar
The bd390 can't stream MKV, but it can play them back on a dvdr or a usb flash drive.
post #409 of 6940 Old 06-05-2009, 04:25 AM
yamahafj's Avatar
Suunds good. And you can get DTS and HD-DTS out of these MKV-files also?
Have you tested different codecs - sometimes not all of them work.
yamahafj is offline
post #410 of 6940 Old 06-05-2009, 04:51 AM
Tasador's Avatar
Can This Player play DVD in PAL format ??
Did someone tested ?
Tasador is offline
post #411 of 6940 Old 06-05-2009, 08:30 AM
bobbyslav's Avatar
I tried the BD370 and it does play PAL.
post #412 of 6940 Old 06-05-2009, 08:31 AM
brookskent's Avatar
If this is redundant, I did a search and panned the thread. Impressive forums by the way.
I am having some difficulty hooking up the wireless piece for the BD390. (newly purchased). I set it to "Dynamic" and "Auto" and it tells gives the the error that my Dynamic IP is not avail.
I used WEP2 for security, I am not sure if its related to the "keys." (not sure what that means. I am sure I have the PW right.
I have checked my Linksys WRT54G Router and verified that DHCP is active. What am I missing?
brookskent is offline
post #413 of 6940 Old 06-05-2009, 10:59 AM
GizmoDVD's Avatar
The American 370 can not play any movie files via USB. Period.
The European 370 can.
Many people here claiming 370 plays movie files is because they own a European model.
GizmoDVD is offline
post #414 of 6940 Old 06-05-2009, 11:24 AM
mugupo's Avatar
can the u.s. 390 play most of the media file on the usb drive? does it bitstream audio from receiver?
mugupo is offline
post #415 of 6940 Old 06-05-2009, 11:34 AM
kmccleave's Avatar
I'm just an idoit.
I ended up going to Wal-mart yesterday to buy an ethernet cable to hookup on my own that works great. So I go home today for lunch today and notice that the bottom of the remote slides open and that is where the keyboard is to enter in the numbers for the IP and DNS. I had no idea that was there. So I'll try that after work and return the ethernet cable.
But now I'm thinking about getting rid of the the 370 and going 390.
post #416 of 6940 Old 06-05-2009, 01:16 PM
brookskent's Avatar
Network passwords are case sensitive, right? /feels like an idiot
post #417 of 6940 Old 06-05-2009, 03:26 PM
Quoted: 16 Post(s)
That has nothing to do the digital processing (scaling/deinterlacing), that's an analog output specification.
post #418 of 6940 Old 06-05-2009, 06:20 PM
xgin's Avatar
I'm just an idoit.
Dang, so that's where the zoom is! I really should of looked at the manual.
xgin is offline
post #419 of 6940 Old 06-05-2009, 09:20 PM
tightrope's Avatar
Apparently, this can be achieved on the 390, as stated in the manual (p. 41). Has anyone tried?
post #420 of 6940 Old 06-05-2009, 09:26 PM
WormInfested's Avatar
Quoted: 63 Post(s)
Liked: 48
I used the name your price on 6ave site and got a counteroffer for a great price on the LG 390 blu ray player. Would this be a better player than Oppo's or about the same? i know the price is less but how is the processor? can i fix the video settings like gamma or black level? I have a ps3 but i want a standalone which i know is better.
Pioneer Elite SC-05
JBL Studio S312II fronts, JBL Studio S10IIs mid and S8IIs rear.
Single JBL S38 center channel
Power Sound Audio V1800 & DIY 18" Ported Sub
Oppo BDP-103
BenQ W7500 & Silverticket 110" matte white 16:9
WormInfested is offline
Reply Blu-ray Players
Lg Bd 370 Network Blu Ray Disc Player , Blu Ray Players , Lg Bd 390 Network Blu Ray Disc Player , Lg
