BD370/390 LG Blu-ray player Master/Owners thread - Page 232 - AVS Forum | Home Theater Discussions And Reviews
post #6931 of 6940 Old 08-13-2016, 07:47 PM
dreamliner77's Avatar
Is anyone using their BD390 with Windows 10 with the Anniversary update installed?
I can no longer connect to network shares although the media servers still show and connect.
dreamliner77 is offline
post #6932 of 6940 Old 08-16-2016, 09:03 PM
Is anyone even still using their BD390?
post #6933 of 6940 Old 08-21-2016, 07:38 AM
Mark_Venture's Avatar
Quoted: 68 Post(s)
I have mine still hooked up, but I haven't used it in a long while...
i've been using a Fire TV (box) with Kodi (have tried SPMC/MrMC) for streaming my local videos/movies.
Mark_Venture is offline
post #6934 of 6940 Old 08-21-2016, 02:59 PM
I think I may have to move in that direction
post #6935 of 6940 Old 08-23-2016, 01:05 PM
Quoted: 68 Post(s)
Its worth it.
I use BD-Rebuilder to rebuild my blurays to MKVs. They works great with internal subs too. I don't have to use external SRT files like I did with my BD390/BD570 players. And its a much better gui for navigating my movies.
One negative is that the newer Fire TV's do not have optical audio out... So with my older Pioneer Elite receiver (no HDMI inputs on it) in the family room, I need to keep the older 1st Gen Fire TV box. I'm using a 2nd Gen Fire TV in my bedroom. The 2nd Gen is a little faster navigating the GUI, but doesn't have the optical audio out (however this isn't a problem in the bedroom since I don't have an AV Receiver and surround sound setup).
The Fire TVs also don't support Vudu, Cinemanow, or other Ultraviolet playback.
EDIT: 2nd Gen Fire TV with an HDMI Audio Extractor like https://www.amazon.com/dp/B00I4A12JG...I19RJAKZ01E4L1 works to give me optical out... (i.e. this solves the "no HDMI inputs" on my receiver issue)
post #6936 of 6940 Old 09-24-2016, 01:41 PM
baldylox's Avatar
I still have mine....for about 10 more minutes. Suddenly today My Media is locking up and shuts down the player. I've reset everything and no go . Off to find a quick fix. Maybe chromecast
baldylox is offline
post #6937 of 6940 Old 12-09-2016, 01:16 AM
Its worth it.
Is there a reason to use BD-Rebuilder vs Handbrake or just storing DVD/BD ISO's?
post #6938 of 6940 Old 12-09-2016, 07:05 AM
Quoted: 68 Post(s)
Direct to ISO of the original disc (i.e. no compression) take up too much space.
I started using BD-Rebuilder years ago when trying to shrink Blurays to fit on a 25gig BDR, or shrink to fit on a DualLayer DVD (i.e. DVD9) disc, and I've stuck with it because of how well its worked. BD-Rebuilder can output BD-25, BD9(dvd9), BD5(dvd5) formats as well as custom size, ISO's. So if you're looking to keep everything but make it smaller.
I could never get Handbrake's output to look clear/sharp.
BD-Rebuilder works, output always looks great, and I found its GUI easier to use, and its options simple to understand. It lets me EASILY pick different output options, different titles/playlists (If I'm doing movie only), handles embedded Subtitles to SRT files (which my BD390 and BD570 needed). It handles embeding subtitles into the MKV files, including FORCED. It can output 3D blurays as HSBS MKV, and it does 3D -> 2D conversion, etc. It handles the different audio tracks and formats, can process to remove HD audio if you wish.
BD-Rebuilder is "donation ware" (donate what you can/want to in order to keep it going), so its worth trying for yourself to compare.
post #6939 of 6940 Old 12-10-2016, 03:40 PM
post #6940 of 6940 Old 01-07-2017, 03:49 PM
mwhybark's Avatar
US BD390 region-free hack?
Hi all, thread searches aren't surfacing what I think I need, so I figured I'd just ask.
I scored the BFI multi-disc BR of Gance's "Napoleon" from Amazon around xmas and completely forgot about regionalization issues. Naturally, it's not set to play in the US. Poking around on the web I found hints that ages and ages ago, like circa 2009, Euro BD390 owners were able to reset the players to region-free but US-based owners did not appear to be able to do so.
Thread searches here on 'region free' seem to bring up related issues but no definitive answer to whether this nut was ever cracked. Anybody here recall if a means to reset US BD390s to region-free was ever found and shared?
I haven't tried any of the streaming features on this player in many years, it's still in my stack primarily because none of my other gear to hand is blu-ray and occasionally a BR disc comes through the house.
Thanks in advance!
mwhybark is offline
Reply Blu-ray Players
Lg Bd 370 Network Blu Ray Disc Player , Blu Ray Players , Lg Bd 390 Network Blu Ray Disc Player , Lg
