Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1075 - AVS Forum | Home Theater Discussions And Reviews
 353Likes
post #32221 of 41276 Old 06-21-2010, 08:24 AM
fitzcaraldo215's Avatar
Quoted: 38 Post(s)
Liked: 42
Originally Posted by Big Picture View Post
The dialogue in my system system is now less than clear, mumbly is the best way to describe it. At one point earlier it was fine. I am using an HDMI connection to my pre-amp. Are there any Oppo 83 settings that I can check to make sure it is optimized for dialogue?
Thank you.
No, but make sure your center channel speaker/amp are working.
fitzcaraldo215 is offline
post #32222 of 41276 Old 06-21-2010, 08:27 AM
Duck05's Avatar
Great explanation and right on target. Most consumers have never heard of Oppo and do not appreciate the capabilities of these players (and in many cases not miss then, either).
The price differential often stops most people as all they really want is a "player" and do not understand the nuances that these players provide. This forum is an excellent education opportunity but trying to sift through so many posts is frustrating to most novices.
The FAQ and the first post contains the "meat" but it is still a lot to absorb for someone wanting just a "blu ray player" and expecting to be similar to DVD.
Duck05 is offline
post #32223 of 41276 Old 06-21-2010, 08:47 AM
Jim Hef's Avatar
It would be interesting to look back and see the number of posts that discussed the "upcoming" -83 after the announcement that Oppo had seeded beta units to the fortunate few, and during the "nifty fifty" period. That alone sparked quite a few posts on this thread.
Jim Hef is offline
post #32224 of 41276 Old 06-21-2010, 09:47 AM - Thread Starter
Neuromancer's Avatar
Quoted: 96 Post(s)
Liked: 370
Originally Posted by rdgrimes View Post
My feeble memory recalls this issue being reported before. However the player should eject any disc by using the eject button in a standby state.
Logical errors may occur due to a blank disc being put in (player tries to read the disc prior to ejecting, which causes some kind of logic loop. Shouldn't occur, but who knows).
Obviously, the fix is to avoid loading any blank discs.
Blank discs have been known to completely kill the laser head. Do not put a blank disc in the player.
Neuromancer is offline
post #32225 of 41276 Old 06-21-2010, 09:57 AM
rdgrimes's Avatar
Quoted: 2482 Post(s)
Liked: 1785
In theory, from a standby state the disc should be ejected before any read command is initiated in the loader. Unless the loader is never really switched off, which is possible. Perhaps the original loader is different in this regard. We know that the newer loaders open in 4 sec from the power-on command, which is not enough time to read a disc or even check for a disc.
rdgrimes is offline
post #32226 of 41276 Old 06-21-2010, 10:52 AM
Smarty-pants's Avatar
Quoted: 751 Post(s)
Liked: 628
Good point rdgrimes on newer loader vs older loader.
Seems a good chance that may be the answer to whether the particular disc in question will or will not eject.
Neuromancer, suggesting a blank disc may kill the laser is a shocking revelation!
So again, I reiterate...
Smarty-pants is offline
post #32227 of 41276 Old 06-21-2010, 11:35 AM
fallenbuddha's Avatar
Originally Posted by wmcclain View Post
In the FF bug I recall playback would skip ahead 4 minutes 15 seconds (= 255 seconds, a suspicious number). I have not seen that for a long time. Are you running current firmware? If you are seeing it or other skipping behavior and can replicate it you should certainly work with OPPO support on it.
Happens to me all the time with the current firmware. Not a big deal, but quite annoying nonetheless.
fallenbuddha is offline
post #32228 of 41276 Old 06-21-2010, 02:09 PM
Gov
Gov's Avatar
Quoted: 121 Post(s)
Liked: 186
Ditto!
Main HT Room: Panny TC-P65VT60 (calibrated by Chad B), Denon AVR-4311, Comcast X1 DVR, Apple TV3, Sony BDP-S5100, Speakers: Ascend Acoustics Sierra Towers, Sierra Horizon and HTM-200SE, Dual Power Sound Audio XV15 Subwoofers
Basement HT Room: Panny TC-P58V10 (Black Level Restored!), Denon AVR-E300, Comcast X1 STB, Sony BDP-S590, Speakers: Ascend Acoustics CBM-170SE (L/R), Ascend Acoustics CMT-340SE-C, Wave Crest HVL-1 (Surr) and Dual Power Sound Audio XV15 Subwoofers
Gov is offline
post #32229 of 41276 Old 06-21-2010, 02:20 PM
NutFlush's Avatar
Hi,
I just got my OPPO BDP 83-SE and connected it to my Epson EH-TW5500 projector via HDMI (direct cable link not going through amplifier, because I only use the analog outs).
What I experience is that it takes a long time (more than 5 to 10 seconds) to get a stable picture. Prior to that all I see is black with some erratic vertical lines jumping around. Especially the Transformers BluRay takes a long time and I miss a few seconds of the animated menues.
Any ideas if this is a problem caused by the OPPO or rather by the EPSON? Or is this HDMI at work (all kind of talking back and forth between the components)?
Any settings I should change to speed up the sync?
Thanks for your input!
NutFlush is offline
post #32230 of 41276 Old 06-21-2010, 02:28 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3400 Post(s)
Liked: 2655
Originally Posted by NutFlush View Post
Hi,
It takes two to handshake so it is probably a joint problem. Is this the first HDMI source you have connected to the display?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #32231 of 41276 Old 06-21-2010, 06:04 PM
mikejedi123's Avatar
Quoted: 72 Post(s)
Liked: 64
Hello all, I just ordered a OPPO BDP-83 about 3 hours ago! Thanks smarty pants and others who have given me advice on buying this unit.. I can't wait and super-excited.. will probably retire my Oppo 980 which has been great and will retire my BDP-05 Pioneer .. i will kill two birds with one stone and have a better unit overall.. Thanks again to this forum and people.. i had help choosing my YAMAHA rx-v2700 years ago here and am still quite happy with the unit.. it powers my Def Tech 7002 and clr 2500 and sunfire subwoofer to amazing clean levels..looking forward to the oppo!! I finally pulled the trigger!
Mike in Vegas
mikejedi123 is offline
post #32232 of 41276 Old 06-21-2010, 06:29 PM
Tristan944's Avatar
Quoted: 27 Post(s)
Originally Posted by mikejedi123 View Post
Thanks smarty pants and others who have given me advice on buying this unit.. I can't wait and super-excited. Thanks again to this forum and people.
Mike in Vegas
I agree, the people in here rock!
Tristan944 is offline
post #32233 of 41276 Old 06-21-2010, 06:52 PM
Jay5298's Avatar
Quoted: 21 Post(s)
Does anyone know if Oppo plans on a firmware update to allow compatiblility of these type of discs?
Jay5298 is offline
post #32234 of 41276 Old 06-21-2010, 07:10 PM
Mactavish's Avatar
Liked: 29
Originally Posted by GermanMan View Post
It doesn't but the aesthetics of integrating with the rest of the kit to create an attractive gear rack has value to some folks. To some folks, it apparently is worth spending and extra $2k. Its not my place to judge how valuable a person finds a feature.
Thanks for sharing your deep insight about "features"!
Mactavish is offline
post #32235 of 41276 Old 06-21-2010, 07:19 PM
Mactavish's Avatar
Liked: 29
Originally Posted by Styln View Post
Very subtle hint
Styln
[begin CD-R FAQ quote]
There are pens recommended specifically for writing on CD-Rs. Examples
include the Dixon Ticonderoga "Redi Sharp Plus", the Sanford
"Powermark", TDK "CD Writer", and Smart and Friendly "CD Speed Marker".
Some of these are relabeled Staedtler Lumocolor transparency markers,
which are water-based. Never use a solvent-based pen on a CD-R.
Many people have had no problems with the popular Sanford "Sharpie"
pens, which are alcohol-based. Other people say they've damaged discs by
writing on them with a Sharpie. In any event, the Ultra Fine pen looks
almost sharp enough to scratch, so sticking with the Fine Point pen is
recommended.
So long as you use the right kind of pen, it's okay to write directly on
the top surface of the CD, label or no. If the prospect makes you
nervous, just write in the clear plastic area near the hub, or only use
discs with a printable top surface.
post #32236 of 41276 Old 06-21-2010, 07:43 PM
butchgo's Avatar
Have any of you had any problems with the playback of this disk?
The reason I ask is now my 83SE will freeze at chapter 7 @ 1:07:32 every time with the latest firmware.
I have sent my disk to Oppo for their evaluation but they will not receive it until tomorrow but I was just curious if anybody else has had this problem.
BDP-95 owner
butchgo is offline
post #32237 of 41276 Old 06-21-2010, 07:52 PM
rdgrimes's Avatar
Liked: 1785
It's being looked into, but the outcome is uncertain since it's a loader issue.
rdgrimes is offline
post #32238 of 41276 Old 06-21-2010, 10:38 PM
swlee's Avatar
I just tried playing my brand-new BR of The Hunt for Red October on my 83 (latest firmware) -- no problems at all.
swlee is offline
post #32239 of 41276 Old 06-22-2010, 12:57 AM
NutFlush's Avatar
-Bill
Until now I had a player that output a signal via DVI that I fed into the EPSON with an adapter from the DVI cable into the HDMI socket. I don't know if there was any handshaking going on (I doubt it).
I would like the OPPO to output BluRay and DVD as 1080p. So I wonder if there's a way to shorten (or suppress) all that handshaking and set the EPSON to this specific input signal?
Any idea what takes so much time?
NutFlush is offline
post #32240 of 41276 Old 06-22-2010, 03:36 AM
wmcclain's Avatar
Liked: 2655
Not specifically, no. You might try an Epson thread to see what can be done on the display end.
Blu-ray discs often have complicated startup sequences which go through a variety of material, some of which require a new handshake.
-Bill
wmcclain is offline
post #32241 of 41276 Old 06-22-2010, 03:50 AM
djos's Avatar
Quoted: 28 Post(s)
Liked: 24
-Bill
Seems like a good time to mention the War ........
*sighs*
The impossible often has a kind of integrity which the merely improbable lacks.
djos is offline
post #32242 of 41276 Old 06-22-2010, 06:22 AM
kwolfman's Avatar
In the Oppo set Video Setup->Output Resolution to "1080p", not "Auto". The 1080p setting will avoid the handshaking. You will also want to set the 1080p24 Output to "On" since your Epson can handle that just fine.
kwolfman is offline
post #32243 of 41276 Old 06-22-2010, 06:23 AM
william06's Avatar
Quoted: 234 Post(s)
Liked: 127
-Bill
I have the Oppo 83 going through my Onkyo 5007 HDMI sub out to my Epson 9500UB same as ur 5500 does the same thing on BR Or when I switch to other sources. I believe it is a handshake issue with the Epson. I always miss a couple of seconds of intro whe I start a disc. Only issue I have so far with the Epson at about 90 hrs. Firmware 1.02
Lg oled65G7P
Samsung K950
Sony x1000es
Lg 970
Toshiba X1 HD-DVD
Rocket fish HDMI 2.0 HDMI 4K switch 5x1
william06 is offline
post #32244 of 41276 Old 06-22-2010, 06:32 AM
NutFlush's Avatar
Yep, I did that already, but it didn't speed anything up.
NutFlush is offline
post #32245 of 41276 Old 06-22-2010, 06:40 AM
william06's Avatar
Quoted: 234 Post(s)
Liked: 127
No difference for me either way. The only thing I never did was to try to imput the oppo directly to the PJ. I do not find this such an inconvienence that I want to keep changing cables. If the Oppo had two HDMI outputs I would just go direct for the PJ.
Lg oled65G7P
Samsung K950
Sony x1000es
Lg 970
Toshiba X1 HD-DVD
post #32246 of 41276 Old 06-22-2010, 06:42 AM
NutFlush's Avatar
BTW: If I do that (which I did) and I want the OPPO to upscale DVD to 1080p why do I need to set the TV standard? Does it make any difference whether I set it to NTSC or PAL or Auto? Maybe setting it to PAL or NTSC can speed up the "negotiations"???
NutFlush is offline
post #32247 of 41276 Old 06-22-2010, 06:48 AM
wmcclain's Avatar
Liked: 2655
PAL or NTSC determines whether the player produces 50hz or 60hz when it is not producing 24hz.
-Bill
wmcclain is offline
post #32248 of 41276 Old 06-22-2010, 08:57 AM
Jim Hef's Avatar
Do you have HDMI control set to On in either the player, the projector, or both? If so, turn them Off.
Jim Hef is offline
post #32249 of 41276 Old 06-22-2010, 09:28 AM
NutFlush's Avatar
Sorry, but what do you mean by "HDMI control"? I couldn't find that in the manual either.
NutFlush is offline
post #32250 of 41276 Old 06-22-2010, 09:47 AM
AvidHiker's Avatar
Quoted: 24 Post(s)
Liked: 45
I use a DVI connection as well (with forced resolution output) - there are still handshakes, and plenty of them. My understanding is that handshakes are required for ANY use of the HDMI output due to HDCP encryption (DVI is usually HDCP compliant). Just something I've learned to live with.
AvidHiker is offline
Reply Blu-ray Players
105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
