Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1102 - AVS Forum | Home Theater Discussions And Reviews
 343Likes
post #33031 of 41194 Old 08-07-2010, 07:45 AM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 621
Originally Posted by gene9p View Post
has anyone had any experience with Oppo tech support sending in a player for repair and was it a one time fix for whatever problem you were having?
I am willing to give it a one time chance for fixing this problem.
OPPO has great service, and you probably won't find another company that will tell you they'll repair your player that has no warranty for FREE.
Hear that??? It's OPPOrtunity knocking.
Smarty-pants is offline
post #33032 of 41194 Old 08-07-2010, 09:25 AM
cwt
cwt's Avatar
Liked: 32
Originally Posted by djos View Post
Hi All, a friend of mine works for a small Aussie Production Company and they've just built a pro-cinema using HD-SDI and discovered that they have no way to play Bluray movies due to HD-SDI not supporting HDCP.
If they buy a OPPO BDP-83SE with HD-SDI Mod, will that solve their problems and does the Oppo HS-SDI mod pass HD Audio or would they have to use the analogue outs (hence why I've suggested the SE model)?
Hi djos ; heres a local company that may be able to help
http://www.blackmagic-design.com/products/hdlink/
Audio outputs are de embedded from the SDI input and then converted to analog at an incredible 24 bit. HDLink supports 6 channels out allowing easy monitoring of 5.1 surround sound audio. Audio is output on RCA connectors so you can easily connect to standard HiFi systems.
http://www.blackmagic-design.com.au/...iniconverters/
Jvb digital have been doing conversions ;but they had to reprogram a modded player iirc due to a new firmware not agreeing
cwt is offline
post #33033 of 41194 Old 08-07-2010, 09:53 AM
rdgrimes's Avatar
Quoted: 1993 Post(s)
Liked: 1321
I'd second the advice to go with an external solution for SDI. The available modded players are reported to have nothing but an HDMI->SDI converter built in. KISS, use an external converter so your player is stock.
rdgrimes is offline
post #33034 of 41194 Old 08-07-2010, 10:29 AM
Satcom15's Avatar
My Oppo 83 arrived yesterday. Now its down to the big box store to get a Panny 42 in plasma (G25 model -on sale thru today).
Satcom15 is offline
post #33035 of 41194 Old 08-07-2010, 11:53 AM
gene9p's Avatar
Quoted: 31 Post(s)
Liked: 31
yup..and it's going out Monday..
thanks everyone for your input
gene9p is offline
post #33036 of 41194 Old 08-07-2010, 05:00 PM
djos's Avatar
Quoted: 28 Post(s)
Liked: 24
Thanks mate but I cant see any mention of HDCP support on the external devices and that is the killer!
EDIT: I just found this in the tech specs:
"For legal reasons, capture devices from Blackmagic Design are designed not to capture, convert or transmit video or audio from copy-protected sources, e.g. video devices using HDCP."
Big Content are a bunch of complete retards!
The impossible often has a kind of integrity which the merely improbable lacks.
djos is online now
post #33037 of 41194 Old 08-08-2010, 12:59 AM
cwt
cwt's Avatar
Liked: 32
Only other device I can think of [ hdcp stripping like a hd fury ? ] requires a vp50 pro .http://www.anchorbaytech.com/product...on_hdi-sdi.php
Didnt know about big content but definately worth reading
http://www.techeye.net/business/big-...piracy-figures
edit; crystalio as well
cwt is offline
post #33038 of 41194 Old 08-08-2010, 10:42 AM
bvader's Avatar
Just wanted to report, I am having the tray opening issue with my ~ 1year old unit. All FW up to date etc, my unit is well cared for and moderately used over the last year. I Will be contacting OPPO Monday.
Long Live The Gorn!
bvader is offline
post #33039 of 41194 Old 08-08-2010, 04:19 PM
Jim Hef's Avatar
To the member that was having problems with Kick Ass: I was about to think that I should eject the disc due to it not loading, and quite awhile into the process, a loading screen showed up. You may just not have waited long enough.
Jim Hef is offline
post #33040 of 41194 Old 08-08-2010, 04:49 PM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
Kick-Ass will take a minute or so to load. This is particularly true at the BD-Java picture which will fill up 3/4 of the way then look like it freezes. It has not.
Also clear the Persistent Storage if the player never goes past Top Menu with a blank screen on the television.
Neuromancer is offline
post #33041 of 41194 Old 08-08-2010, 04:51 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
Or you can E-Mail support and receive this response:
"Disconnect all cables from the player and turn the player upside down. With the front of the player facing away from you, you should see an opening near the front. Inside of this opening there will be a white tab.
Slide this tab all the way to the left. You will hear the tray disengage.
Turn the player right-side up.
Pull the tray all the way out. Once it is fully extended, give the tray a quick tug.
Plug the power cable only into the back of the player. Press POWER.
Does the tray recall?
Press OPEN/CLOSE. Does the tray eject?
Best Regards,
Customer Service
OPPO Digital, Inc.
2629B Terminal Blvd.
Mountain View, CA 94043
Service@oppodigital.com
Tel: 650-961-1118
Fax: 650-961-1119"
post #33042 of 41194 Old 08-08-2010, 05:11 PM
bvader's Avatar
Best Regards,
Customer Service
OPPO Digital, Inc.
Tel: 650-961-1118
Fax: 650-961-1119"
Thanks neuro, I will do this. One thing I should have said is that it is an Intermittent failure, is the fix above for an intermittent failure or completely stuck. The behavior mine is exhibiting is that will open after 3-5 attempts, it does not seem to be permanently stuck.
Will report back.
Long Live The Gorn!
bvader is offline
post #33043 of 41194 Old 08-08-2010, 05:29 PM
Makaveli Tha Don's Avatar
Anyone else have problems with the movie Gamer?
It doesn't play for me unless I ENABLE BD live. How odd is that??
Makaveli Tha Don is offline
post #33044 of 41194 Old 08-08-2010, 06:45 PM
rdgrimes's Avatar
Liked: 1321
All part of the evil BD-Live plot to take over the world.
rdgrimes is offline
post #33045 of 41194 Old 08-08-2010, 07:20 PM
bvader's Avatar
Best Regards,
Customer Service
OPPO Digital, Inc.
Tel: 650-961-1118
Fax: 650-961-1119"
Well I tried the above... 3 Times and did a factory reset ...no luck...
Does the tray recall? Yes
Press OPEN/CLOSE. Does the tray eject? No. In fact I can't seem to get it to open on its own at all now.
Thanks, It was a good try... guess I will be calling OPPO, bummer.
Long Live The Gorn!
bvader is offline
post #33046 of 41194 Old 08-08-2010, 09:51 PM
Keith Mickunas's Avatar
Quoted: 103 Post(s)
Liked: 81
Kick-Ass sure is a pain. I had 859MB free in persistent storage, but I guess that wasn't enough, then it took a few minutes to load, but at least no trailers.
Blu-ray sure is the most user unfriendly format they could devise. Incredibly slow and totally unnecessary java menus, forced trailers that on some discs you can't even skip through, no stop and resume on most discs. And with some movies if you want to buy it you have to pay a lot because they throw in two discs not everyone wants.
Update: disc glitched during one of the key scenes. How frustrating. Initially I found some gunk on the disc, after a thorough cleaning there was no change though. Anybody else have any problems?
Keith Mickunas is offline
post #33047 of 41194 Old 08-08-2010, 09:59 PM
sillysam's Avatar
Same thing happened to my unit. Intermittent and then permanent. Couldn't get the tray to open. Oppo replaced the drive.
sillysam is offline
post #33048 of 41194 Old 08-08-2010, 10:52 PM
narkspud's Avatar
It appears to be a chronic problem with a certain loader they've been using. Happened to me too. The good news is you now get to experience Oppo's astonishing customer service, which is one of the main reasons a lot of us are here.
It is a bummer, but I bet it won't be as bummy as you might be thinking.
narkspud is offline
post #33049 of 41194 Old 08-09-2010, 07:11 AM
Dave_6's Avatar
Quoted: 26 Post(s)
Well I guess mine has finally quit reading discs. I seemed to have the same problems everyone else is having with Kick-Ass but it would finally load and play the movie fine. On Saturday afternoon, I put on the new remastered Gladiator and watched part of it and it worked fine. Then went to put Kick-Ass back in, and no matter what I did, it would not ever make it back to the Top Menu. I deleted persistent storage, disabled BD-Live, whatever. I then tried to watch Gladiator again, The Incredible Hulk, WOTW and everytime with them it would just say 'No Disc'.
Any idea(s) on what could be wrong with it?
PSN: DaveS78
Dave_6 is offline
post #33050 of 41194 Old 08-09-2010, 07:13 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1059 Post(s)
Liked: 987
It sounds like yet another loader problem - contact Oppo. It does seem like we're seeing a trend of a number of bad loaders all of a sudden here.
gsr is online now
post #33051 of 41194 Old 08-09-2010, 07:32 AM
Dave_6's Avatar
Quoted: 26 Post(s)
Ugh. Good thing I have a PS3, even if it is the old, loud hot one.
PSN: DaveS78
Dave_6 is offline
post #33052 of 41194 Old 08-09-2010, 07:34 AM
sillysam's Avatar
Indeed. Oppo made returning and getting back my player as easy as possible. And turnaround was very quick. I can't imagine any better customer service.
sillysam is offline
post #33053 of 41194 Old 08-09-2010, 10:19 AM
FreyTheater's Avatar
Well, My 83 is only a week or two away from being 1 year old - I'll be keeping my fingers crossed on this tray loader issue... and I probably just jinxed myself posting this...
One good thing, If I would have to send my 83 back for service anytime soon, I'll probably spring to get the SE upgrade done on it while it's in, since I use the 7.1 analog out to a Parasound 7100 for my audio...
FEEL an awesome 3D Blu-ray movie in the Frey Theater - Now with projection in glorious "FREYMAX" 3D!
FreyTheater is offline
post #33054 of 41194 Old 08-09-2010, 11:11 AM
JimL's Avatar
Same for mine as I posted here previously - had to finally send to Oppo and it was fixed and returned very quickly - no further issue, been working perfectly since.
JimL is offline
post #33055 of 41194 Old 08-09-2010, 11:47 AM
regs4's Avatar
OPPO will be releasing a new blu ray player ending 2010 or beginning 2011. No details at this time.
regs4 is offline
post #33056 of 41194 Old 08-09-2010, 11:55 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 987
Hopefully it will add the following features to the BDP-83:
1) FLAC support
2) Digital audio input to use the DAC for external sources
3) HDMI input so the ABT video processor can be used for external sources
3) Smoother fast forward / rewind functionality
4) 3D support
5) Cost $199
I think the above should address most of the questions and complaints that show up here over and over.
gsr is online now
post #33057 of 41194 Old 08-09-2010, 11:59 AM
XJ6
XJ6's Avatar
+1, mine was intermittently exhibiting the problem last week. Out of a few attempts (hitting the eject button on the front panel) it would fail to eject the tray once. Then yesterday it got bad: it happened every time I needed to change the disc. I hate being w/o it for a few days but I think I will have to send it in. Mine is one of the first fifty-nifty, BTW.
XJ6 is offline
post #33058 of 41194 Old 08-09-2010, 12:04 PM
progprog's Avatar
What's your source?
progprog is offline
post #33059 of 41194 Old 08-09-2010, 01:02 PM
wse
wse's Avatar
Quoted: 1976 Post(s)
Liked: 739
Same problem here I had to send it to Oppo and even so the warranty had expired the did all the work and I didn't have to pay anything at all including shipping Their turn around time was 24 hours it took longer to get there and to return than to fix the problem
Try that with any other brands, I am looking forward to their next release
Forget Sony, Denon, Marantz.... their customer service is horrendous
wse is offline
post #33060 of 41194 Old 08-09-2010, 01:04 PM
ccotenj's Avatar
Liked: 101
1) FLAC support
4) 3D support
5) Cost $199
lol...
don't forget separate bit rate counters...
- chris
ccotenj is offline
Reply Blu-ray Players
105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
