Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1312 - AVS Forum | Home Theater Discussions And Reviews
 346Likes
post #39331 of 41211 Old 05-22-2014, 03:13 PM
ti-triodes's Avatar
Quoted: 270 Post(s)
Liked: 339
Originally Posted by Bronco70 View Post
That's why they are famous. My BDP-83 still going strong, next release will be upgrade time. My original 971 is still working. And the 983 is still the best up-converting DVD player of all time.
Joe
Don't forget the resale value. I got more for both my 971 and 983 than I paid for them new. Amazing.
laserjock II likes this.
ti-triodes is offline
post #39332 of 41211 Old 06-02-2014, 06:29 PM
dsidney's Avatar
Hi.
My 83 had never gave me any trouble before and I love it.
But suddenly my BDP-83 doesn't turn on anymore.
I haven't used for like two months. Then I rent a BR movie and when I tried to turn it on, nothing happens. No even the stand by led turns on.
I find it very strange how that could happen, because none of the other gear connected to the same energy conditioner (Panasonic Plasma, AV receiver, PS3, etc) had any problem.
My usage of it is very mildly.
Has anyone had this problem before ?
Does anyone have an idea what could have happened ?
[/B]
I don't live in USA, so to send it back to Oppo for repair would be cost prohibitive because of shipping costs and customs red tape work to do so.
Here I am afraid I won't find any tech-shop that will fix it.
Any help or input will be very much appreciated.
Thanks a lot.
dsidney is offline
post #39333 of 41211 Old 06-02-2014, 06:37 PM
laserjock II's Avatar
Quoted: 727 Post(s)
Liked: 397
Originally Posted by dsidney View Post
Hi.
[/B]
Thanks a lot.
The AC power cable is detachable.
Did you check on the unit side to make sure it is seated firmly?
dsidney likes this.
laserjock II is online now
post #39334 of 41211 Old 06-02-2014, 06:41 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2664 Post(s)
Liked: 3392
^ Check the power plug both at the wall outlet and at the back of the player to make sure both ends are properly inserted. Use another device to check that the wall plug is truly live. If using a voltage adapter, make sure it is still set to the correct voltage for the player.
If no easy fix that way, unplug the player from wall power, and disconnect EVERYTHING ELSE from the player. Press and hold the power button on the front panel for a few seconds to discharge any residual power. Release that and let the player sit for about 1/2 hour. Plug the player back in (LEAVING EVERYTHING ELSE DISCONNECTED) and see if it turns on using the front panel buttons. Try both the front panel power button and the front panel Tray Open button.
If still no luck, then the player likely needs service. Odds are its power supply has failed.
Get in touch with OPPO Tech Support. If they can diagnose what needs to be replaced, they may be able to ship you the parts.
--Bob
laserjock II and dsidney like this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #39335 of 41211 Old 06-04-2014, 09:20 AM
dsidney's Avatar
Hi Laserjock II.
Yes, I checked both ends of the power cord. On the unit side the connector was kind of loose (I am sorry for my English). It was not disconnected but was a bit loose.
I pushed it back in and it was still have some up and down flexibility to move a lite. I pulled it out and put it back but it still have a bit of vertical looseness.
I don't remember to have noticed this before, but I think it should be normal that way to allow the weight of the cable to pull it a bit. This cable is very heavy and pulls the connector vertically downward.
The other end is connected to a Power Conditioner and I tested it in another outlet to make sure, but still nothing happens.
I opened the cover of the 83 and checked the fuse on the power supply board and it seems to be OK, and I didn't notice anything wrong inside or that would look even suspect.
The thing still looks like new inside. Just the usual aspect of high quality build of the Oppo's machines.
The internal part of the connector of the power cord looks normal too (I mean no visual wire broken or smell of burned wire or anything strange).
Thanks a lot for the help.
dsidney is offline
post #39336 of 41211 Old 06-04-2014, 09:37 AM
dsidney's Avatar
--Bob
Bob,
Thanks for taking the time to try to help.
As you can see on my reply to Laserjock above, I tested a feel things already.
I am out of home for 16 days now and when I come back I will test your suggestions too. You are possible right on the power supply problem.
In the mean time I will connect Oppo too. They are always willing to help and they respond promptly.
I will let you guys know what will follow as soon as have new facts on this.
Thanks a lot.
dsidney is offline
post #39337 of 41211 Old 06-04-2014, 09:07 PM
Quoted: 727 Post(s)
Liked: 397
Hi Laserjock II.
No problem, I was hoping that was the problem.
I don't remember if there are any fuses on the power board but I could check and do some voltage measurements if you are wanting any of that as well.
post #39338 of 41211 Old 06-05-2014, 12:17 AM
dsidney's Avatar
Hi.
For sure there is a fuse on the power supply board, I saw it when I opened the player.
I didn't do any measurement though, but the fuse is visibly OK.
I appreciate the offer to do measurements but for now I will contact Oppo and see what they say about this.
If their answer didn’t help me then I will try to narrow the search to confirm the problem is in the power supply board and then I might accept your offer to help me further.
Thanks a lot for helping.
dsidney is offline
post #39339 of 41211 Old 06-06-2014, 05:36 AM
rahull's Avatar
You should either check the fuse voltage or replace it. I have seen them that appear good
but have come loose from the end cap and not work.
rahull is offline
post #39340 of 41211 Old 06-06-2014, 03:39 PM
ti-triodes's Avatar
Quoted: 270 Post(s)
Liked: 339
^ Agreed. You have to physically test the fuse outside the unit with at least a continuity tester.
post #39341 of 41211 Old 06-07-2014, 05:59 PM
dsidney's Avatar
Thanks for the tip.
I will check the voltage on the fuse too.
Oppo is willing to help me too, so I am not too concerned anymore with this.
They suggested me to do the same procedure that Bob Pariseau had suggested me above.
I believe this will reset the player to unstuck from any glitch.
In the end I will find out what is going and I will let you know.
It has never happened with my BDP-83 before and neither with my previous Oppo’s 2 DVD players.
dsidney is offline
post #39342 of 41211 Old 06-14-2014, 11:30 AM
gjamesk's Avatar
True Detective fail?
Has anyone else had problems with this disc set on the BDP-83? Plays fine on the PS3, but doesn't finish loading or play at all on the 83. Thanks for any help.
gjamesk is offline
post #39343 of 41211 Old 06-14-2014, 11:34 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2845 Post(s)
Liked: 2090
I've seen no reports. Have you tried this procedure: What do I do if a Blu-ray disc will not load or play, or if it freezes the player?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #39344 of 41211 Old 06-14-2014, 01:00 PM
gjamesk's Avatar
-Bill
Thanks Bill. That took care of it. I've had this player since its introduction and this is the first issue with any disc.
gjamesk is offline
post #39345 of 41211 Old 06-14-2014, 01:13 PM
wmcclain's Avatar
Liked: 2090
Very good!
We blame the disc authors for sloppy java programming on their titles, but the player could probably handle the issues more gracefully. It doesn't seem to happen as often on later models.
-Bill
post #39346 of 41211 Old 06-19-2014, 06:59 AM
weekendtoy's Avatar
Quoted: 259 Post(s)
Liked: 201
I was having the 'drawer not wanting to open' problem with my 83. I'm retiring the player down to the rec. room so I sent the unit back to Oppo for repair. I doubt my kids will remember to always leave a disc in the player.
Cleaned, repaired, updated and sent back (with better packaging and a new tote bag) at zero cost.
They easily got my $1,200 for my next player.
AVfile likes this.
I reject your reality and substitute my own.
weekendtoy is offline
post #39347 of 41211 Old 06-19-2014, 07:10 AM
wmcclain's Avatar
Liked: 2090
Welcome to the cult!
-Bill
post #39348 of 41211 Old 06-20-2014, 10:51 PM
Calypte's Avatar
After a lightning strike damaged my gear, I sent my BDP-83SE to Oppo for repair ($79 total). It went out on a Monday. It was back in my system four days later. Granted, I benefitted from being in Calif., thus cutting shipping time. But I got it back, fully repaired, while I was still waiting for another vendor to merely crack open the unit I sent to them.
Calypte is offline
post #39349 of 41211 Old 06-27-2014, 01:19 PM
edisonbaggins's Avatar
Liked: 0
Brand-new OPPO BDP-83 owner here (the unit is used though...)
Just sayin' hey. Lovin' it, so far!!!
edisonbaggins is offline
post #39350 of 41211 Old 07-05-2014, 09:29 PM
yellowcanary73's Avatar
Quoted: 12 Post(s)
Liked: 31
Anyone else having problems playing 300 Rise Of An Empire on your 83 I've tried everything unplugging power erase storage. But I can put the standard DVD in and it'll play just fine or I guess I could always play it on my 10 year old Panasonic BD10A but prefer to watch it through my projector on my 106 inch screen. Being a double Amputee it get a little hard crawling in and out of a wheelchair to try and get this Oppo to work.
yellowcanary73 is offline
post #39351 of 41211 Old 07-05-2014, 11:20 PM
Read the FAQ!
Liked: 3392
^ Report the disc to OPPO and they can check it out. Give them the bar code number off the disc packaging to be sure they are looking at the identical version.
Try changing your BD-Live setting. Some discs need that turned OFF. Some need it turned ON even if you do not have networking set up.
--Bob
post #39352 of 41211 Old 07-10-2014, 01:22 PM
Quoted: 727 Post(s)
Liked: 397
Hi.
Did you get a resolution yet?
post #39353 of 41211 Old 07-18-2014, 05:49 PM
Whatever1's Avatar
Quoted: 27 Post(s)
Question,
I have an 83SE and after playing a disc it comes out very warm. I have not noticed this on any other player I have.
Anyone have any thoughts ?
Whatever1 is offline
post #39354 of 41211 Old 07-19-2014, 04:38 PM
Jive Turkey's Avatar
Quoted: 230 Post(s)
Liked: 140
Originally Posted by Whatever1 View Post
Question,
Never concerned me.
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is offline
post #39355 of 41211 Old 07-19-2014, 11:25 PM
bebop654's Avatar
Hi guys,
I have an Oppo 83 and I was watching Season 1 of Lost on blu ray today and when I went to listen to the commentary the episode starts up and it's on auto fast forward.
The original audio for the episode is 5.1 Dts-Hd and it plays fine but when I switch over to commentary which is 2.0 DD it resumes with a sped up episode. Pressing play again fixes it but I just wanted to know is that normal for it to do that.
The episodes Im watching commentary on are Pilot part 1 and 2, Walkabout and The Moth. They have all done it.
Cheers
bebop654 is offline
post #39356 of 41211 Old 07-20-2014, 10:24 AM
Keenan's Avatar
Quoted: 2259 Post(s)
Liked: 2092
I think I already know the answer to my question but wanted to check with the very helpful folks here anyway.
I did a search for "drawer sticking"(1 return) and "tray sticking"(many returns) and I believe I suffer from the problem. When the player is not used for several days and I remotely(Harmony) try and open the tray it will stick and "cycle" and just not open. However, just the slightest pressure pulling outward on the the top lip of the tray it will open with a remote command and it will work fine the rest of the evening. After not being used again for a few days this whole sequence repeats itself.
Is a trip to Oppo in order? And will multi-region mods(JVB Digital) be left intact or should they be removed before shipping to Oppo?
Keenan is online now
post #39357 of 41211 Old 07-20-2014, 10:34 AM
rdgrimes's Avatar
Quoted: 2129 Post(s)
Liked: 1440
If you always leave a disc in the player it won't do that. But eventually it will wear to the point where nothing helps.
Oppo has been fixing these for free in the past, and turning them around in one day. You don't have to remove the mod, but you might put a note on the player telling them its there and you want to keep it. Of course the safest thing is to remove it, but mention it when you ask for the RMA..
rdgrimes is online now
post #39358 of 41211 Old 07-20-2014, 11:06 AM
Keenan's Avatar
Liked: 2092
Ah yes, I remember reading about that trick now.
I will very likely send it down to them eventually, probably a good idea to do it sooner rather than later in case they've(may change) changed their policy on repairing the problem free of charge.
Thanks much!
post #39359 of 41211 Old 07-20-2014, 12:27 PM
weekendtoy's Avatar
Quoted: 259 Post(s)
Liked: 201
Thanks much!
I recently had my 83 repaired. I believe Oppo's policy is that if the repair requires parts there is a $75 flat fee. My repair didn't cost anything as the description was 'the removal of dust, hair, and lint'.
Either way for me it was money well spent (shipping) just to get it cleaned and checked over as I will be using it in a secondary system for years to come.
post #39360 of 41211 Old 07-20-2014, 03:17 PM
Keenan's Avatar
Liked: 2092
Yes, the cost is not an issue for me, and I plan to keep the unit for many more years, but free is always nice!
Reply Blu-ray Players
105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
