Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1332 - AVS Forum
 88Likes
post #39931 of 39948 Old 11-26-2014, 06:15 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 523 Post(s)
Liked: 957
^ "Expendables 3" has a Dolby Atmos audio track, which means the track is TrueHD 7.1. Unless you are attempting to use an Atmos speaker setup, you should set the 83 to HDMI LPCM output (or use the multi-channel Analog outputs) when playing TrueHD 7.1 tracks.
If you are attempting to use an Atmos speaker configuration you will need to use HDMI Bitstream output. If that's giving you issues, get in touch with OPPO Tech Support with details on the AVR you are using.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #39932 of 39948 Old 11-26-2014, 06:26 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 2046 Post(s)
Liked: 598
Originally Posted by bob pariseau View Post
"expendables 3" has a dolby atmos audio track, which means the track is truehd 7.1. Unless you are attempting to use an atmos speaker setup, you should set the 83 to hdmi lpcm output (or use the multi-channel analog outputs) when playing truehd 7.1 tracks.
If you are attempting to use an atmos speaker configuration you will need to use hdmi bitstream output. If that's giving you issues, get in touch with oppo tech support with details on the avr you are using.
--bob
=> http://www.avsforum.com/forum/showthread.php?p=29360842
NorthSky is offline
post #39933 of 39948 Old 11-26-2014, 07:47 PM
tr4a's Avatar
Originally Posted by NorthSky View Post
Thank you to NorthSky.
I was having the audio dropouts on
Expendables 3. I did try LPCM and it worked.
I was having trouble with the French import of
Open Range so I figured it was time for a cleaning.
Might try the new firmware just to see if it solves
the Open Range loading issues.
Steve
tr4a is offline
post #39934 of 39948 Old 11-26-2014, 08:08 PM
NorthSky's Avatar
Liked: 598
Steve
Bob is the man! ...Pariseau.
* I love 'Open Range', starring one of my favorite actors; Robert Duvall.
NorthSky is offline
post #39935 of 39948 Old Yesterday, 02:49 PM
trailblazer's Avatar
Just loaded the latest update on my BDP83 and I am stuck at FW 21%. Any idea's of how I would get out of this situation. I have been at this point for 30 minutes thus far. Never ran into this problem before. Any help would be appreciated.
trailblazer is online now
post #39936 of 39948 Old Yesterday, 04:10 PM
Read the FAQ!
Quoted: 523 Post(s)
Liked: 957
If it is still Downloading the firmware you can just power cycle the OPPO and try again. Pull the power plug if need be. The firmware install doesn't start changing anything until the download is complete.
--Bob
post #39937 of 39948 Old Yesterday, 04:24 PM
Jed1's Avatar
Quoted: 18 Post(s)
Liked: 30
--Bob
If OPPO and MediaTek still have the hood open on the 83 series, maybe they can work on a fix for the audio drop out issue. Any hope for this?
Jacob305 likes this.
"You lose it in here you're in a world of hurt"
Jed1 is offline
post #39938 of 39948 Old Yesterday, 06:01 PM
--Bob
Tried your suggestion, but no good. No display in the front nor can I get any info from the screen via HDMI. I can power on and off but nothing happens. Tried on/off button as well as pulling power cord. Guess I am going to have to call OPPO tomorrow. Thanks for your help Bob.
post #39939 of 39948 Old Yesterday, 07:03 PM
Jacob305's Avatar
Quoted: 17 Post(s)
Liked: 24
+1.
Jacob
Jacob305 is online now
post #39940 of 39948 Old Yesterday, 07:14 PM
NorthSky's Avatar
Liked: 598
The audio dropouts also happen in some Denon and Pioneer Blu-ray model players.
Time for firmware updates from few BD player manufacturers; thanks to that new 'The Expendables 3' on Blu-ray. ...With an Atmos* audio soundtrack.
Meanwhile, to all them people having audio issues with your different brand BD players, set the Audio Out to LPCM instead of Bitstream.
* Only when you purchase it @ the store, because the rental from Redbox and Netflix have no Dolby Atmos on them, just a poor lossy audio soundtrack.
The times we live in...not the times we dreamed of.
NorthSky is offline
post #39941 of 39948 Old Yesterday, 07:31 PM
Jed1's Avatar
Quoted: 18 Post(s)
Liked: 30
Yes LPCM over HDMI. Our good friends at Sony (usual suspect number one and founder of Blu ray) blessed us OPPO 83 owners with the audio drop out issue with the release of Total Recall 2012.
Jed1 is offline
post #39942 of 39948 Old Today, 02:03 AM
Ka1hode's Avatar
I would also like to add my appreciation to OPPO for their diligence in investigating the FOX authoring issue and supporting our BDP83 investment with a firmware update.
^ This firmware does NOT address the various, older problems for which there were already well known workarounds -- e.g., use Bitstream output for DTS-HD MA 7.1 tracks, use LPCM output for TrueHD 7.1 tracks, and the procedures already described in the FAQ for dealing with movies which do not start from Top Menu (such as Erasing Persistent Storage). This firmware is SPECIFICALLY for this new issue of "Wrong Disc" errors, resulting from Fox's oddball, new authoring technique.
--Bob
Still - wishing that *this* problem, existing in ALL firmwares since it was introduced in the BDP83-52-0816B release subsequent to BDP83-50-0424 (back in August 2010), would be addressed:
Known Bug: MKV files which are not exactly 16:9 may show up as the incorrect aspect ratio. The workaround is to set Primary Output to "Component" to force the decoder to perform the aspect ratio controls. Note: setting Primary Output to "Component" will degrade DVD and Blu-ray picture performance, so you have to set Primary Output back to "HDMI" whenever you watch DVD or Blu-ray videos.
As I recall, this 'bug' was introduced in the beta update attempting to address an MKV rendering problem caused by an update to a popular MKV authoring program of the time. In the four years since, authoring software has moved on and all current MKVs render correctly on BDP83-50-0424. It would be really nice if OPPO could revisit this issue and possibly issue an update that would revert rendering to the earlier 0424 scheme.
Can't fault me for wishing ...
Chris
Ka1hode is offline
post #39943 of 39948 Old Today, 11:05 AM
Liked: 0
Originally Posted by Neuromancer View Post
Try these instructions from OPPO
If this does not work, then the player will need to be repaired.
Thank you!
The front end of the cover seems to be attached to the back of the control panel somehow, so the front edge cover will not lift off or pull out.
I don't want to use any force...
This thing is built like a tank btw.
art.vandelay is online now
post #39944 of 39948 Old Today, 11:33 AM
On Thanksgiving day I turned on my BDP-83 and it asked to update to the latest firmware which I did by hitting the OK button. Update started but never completed. Hung up at FW 21% on the display on the unit and screen and could not do anything afterwards. Since the unit was not doing anything for hours, I shut it off and afterwards I now have no display in the front nor can I get any info from the screen via HDMI. Tried outputting to composite and no display either. I can power on and off and open/close the draw but nothing happens. Tried on/off button as well as pulling power cord. Has anyone ever come across this situation whereby the update hung and just killed the unit? I went from a perfectly working unit to a completely dead unit from an update. Not very happy right now. Unfortunately OPPO is on holiday till Monday so I can't get any hep from them. If anyone out there has an answer to my dilemma , I would greatly appreciate your help.
post #39945 of 39948 Old Today, 11:46 AM
Liked: 0
Originally Posted by art.vandelay View Post
Thank you!
nevermind...
"Lift the rear of the top
cover through 45° while pulling it free from the front panel."
post #39946 of 39948 Old Today, 11:53 AM
Read the FAQ!
Quoted: 523 Post(s)
Liked: 957
Trailblazer,
OPPO Tech Support often monitors their email even on holidays. Try emailing instead of phoning. Use the Contact page on the OPPO Digital Support site.
--Bob
post #39947 of 39948 Old Today, 12:38 PM
Liked: 0
Nope, didn't work.
post #39948 of 39948 Old Today, 12:53 PM
Trailblazer,
--Bob
I left them an e-mail and voice message.
Reply Blu-ray Players
Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
