Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1339 - AVS | Home Theater Discussions And Reviews
AVS | Home Theater Discussions And Reviews > Blu-ray & HD DVD > Blu-ray Players > Official OPPO BDP-83 Owner's Thread [technical talk only]
Blu-ray Players
mattg3's Avatar mattg3
06:04 AM Liked: 118
post #40141 of 40149
01-21-2015 | Posts: 3,791
Well I did a little searching and found on the Oppo 93 it says the auto setting for dynamic range does nothing with dvd playback but with Blu-Ray it gives the disc its proper dynamic range.Not sure if it does the same with Oppo-83 or even what proper dynamic range on a Blu-Ray means.Does it limit or enhance dynamic range and what criteria does it use to determine this?
AVfile's Avatar AVfile
01:33 PM Liked: 68
post #40142 of 40149
01-21-2015 | Posts: 2,069
I don't know but it would only apply if you're using analog outputs. It should have no effect on the digital interfaces.
Bob Pariseau's Avatar Bob Pariseau
02:16 PM Liked: 1070
post #40143 of 40149
01-21-2015 | Posts: 28,239
^ Dynamic Range Compression is applied during the decoding of Bitstream audio. So it applies to the Analog outputs and also to HDMI LPCM output of Bitstream tracks.
It uses meta-data found in the Blu-ray tracks. The problem is, rather a few discs have been found to have bogus data -- leading to anemic dynamics if you leave Compression on.
My recommendation has always been to leave Dynamic Range Compression OFF in the OPPO. If sending Bitstream to an AVR, look for a similar setting in the AVR.
If you find a disc really is too dynamic for comfortable listening (with knocking the neighbors out of bed), then turn down Main Volume or go ahead and re-engage Dynamic Range Compression.
--Bob
06:19 PM Liked: 118
post #40144 of 40149
Thanks,very helpful
drunkpenguin's Avatar drunkpenguin
07:29 PM Liked: 61
post #40145 of 40149
Today | Posts: 1,443
ANyone else having problems loading oblivion? My oppo was recently upgraded and since then it wont load the bluray. Just hangs on loading. All other disks are fine. Oblivion doesnt appear scratched or anything. Just wondering if anyone else is having problems before I buy another copy of it.
wmcclain's Avatar wmcclain
07:53 PM Liked: 399
post #40146 of 40149
Today | Posts: 17,960
Have you tried this procedure? What do I do if a Blu-ray disc will not load or play, or if it freezes the player?
-Bill
07:59 PM Liked: 61
post #40147 of 40149
No I havent tried any of that! I'll try it when I can thanks for the tip!
djos's Avatar djos
08:38 PM Liked: 11
post #40148 of 40149
Today | Posts: 1,231
My BDP-83 has sort of died, it just sits there with the VFD saying "Hello" now and goes no further - I took out the mod-chip but this made no difference.
09:29 PM Liked: 1070
post #40149 of 40149
Today | Posts: 28,239
Disconnect everything from the player including power. Let it sit for a few minutes. Attach only power and see if it will power up based on the front panel display. If not call OPPO and they'll set you up for service.
--Bob
Tags: 105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
Gear in this thread - 105d by PriceGrabber.com
Reply Blu-ray Players
Subscribe to this Thread
Powered by vBadvanced CMPS v3.2.3
