Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1343 - AVS | Home Theater Discussions And Reviews
post #40261 of 40270 Old 03-07-2015, 05:52 PM
petetherock's Avatar
Quoted: 258 Post(s)
Liked: 81
Need some help :
My oppo nuforce has died and attempts to get repairs done by the local rep have been unsuccessful.
I understand its the power supply of board ?
Does anyone have a contact or email of some one at oppo USA who might be able to help ?
I have another oppo but this was a good player and I am just seeing if I can fix it.
petetherock is online now
post #40262 of 40270 Old 03-07-2015, 05:55 PM
Smarty-pants's Avatar
Quoted: 321 Post(s)
Liked: 218
http://www.oppodigital.com/ContactUs.aspx
petetherock likes this.
~Dave
...Theater Room Setup...
JVC DLA-RS40-U... Oppo BDP-105D... Toshiba HD-XA2... Uverse VIP-2250... Roku Streaming Stick... Emotiva XPA-3... Onkyo TX-SR805
JBL LC2 (x3) ... JBL L820 (x6) ... SVS PB10-ISD (x2) ... SVS 20-39-PCI
Smarty-pants is offline
post #40263 of 40270 Old Yesterday, 11:49 AM
Liked: 0
Problem whit my oppo bdp-83
I have a BR Player BDP-83. It was plugged without working for several months (I saw the red light of the power button woorking several times) and when I tried to turn it on, I realised that it doesn´t work. I want to know if there´s some person that has had the same proble and if there´s a solution before sending it to the technical service.
The answer to my inquiry from OPPO was:
Gabriel,
Disconnect all cables from the player, including the HDMI, analog, and power cables. If your player was hardware modified to support alternative regions, please try removing this kit and returning the player to stock.
Press and hold the POWER button on the front panel of the player for 5 seconds. Release.
Reconnect just the power cable, connecting it direct toy our walled power outlet, bypassing any switch, power conditioner or transformer.
Press POWER.
Does the player then show HELLO, then OPPO then eventually NO DISC or LOADING?
Best Regards,
Customer Service
OPPO Digital, Inc.
2629B Terminal Blvd.
Mountain View, CA 94043
foquito2015 is offline
post #40264 of 40270 Old Yesterday, 01:22 PM
Quoted: 321 Post(s)
Liked: 218
^ You've got the best advice on how to troubleshoot it direct from Oppo.
There is no other way to fix it other than, perhaps try leaving it unplugged without power
over night instead of just for a minute. I have seen where that might make a difference sometimes.
Other than that, if it still doesn't work, it will need to be sent to Oppo for repair.
~Dave
post #40265 of 40270 Old Yesterday, 02:13 PM
snowghost's Avatar
I just emailed Oppo, but do you think this might help my issue? Some of the functions such as Info and Audio Track do not respond to the remote control. Just started happening on my 2009 very, very lightly used unit. I'd hate to have to replace it as I just bought a cheap LG to handle 3D. The BDP-83 does all the rest, including SACD and DVD-A. Awesome player.
"The best long distance runners eat raw meat, run naked and sleep in the snow."
snowghost is offline
post #40266 of 40270 Old Yesterday, 02:38 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 810 Post(s)
Liked: 1100
^ With that sort of problem the first thing to do is put fresh batteries in the remote. Make sure they are both inserted the correct way around. If the problem started AFTER you put in fresh batteries, then you may have some dud batteries.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #40267 of 40270 Old Today, 10:40 AM
weekendtoy's Avatar
Quoted: 88 Post(s)
Liked: 61
Is X-man Future Days Past one of the titles giving the 83 fits?
After inserting the Neflix Blu Ray the machine displays 'wrong disc' and then ejects the disc.
I reject your reality and substitute my own.
weekendtoy is offline
post #40268 of 40270 Old Today, 10:45 AM
rdgrimes's Avatar
Quoted: 709 Post(s)
Liked: 354
Sounds more like a defective disc. Try washing it.
rdgrimes is offline
post #40269 of 40270 Old Today, 12:58 PM
Quoted: 321 Post(s)
Liked: 218
^ Yep, usually when a disc refuses to play at all, that means the disc is defective,
or there's something mechanically wrong with the player, or you are using a disc that is incompatible with the player.
Since it's a NF disc, we know it's compatible, and if other BDs play ok in the player, then that would mean there's
nothing wrong with the player, thus meaning it's most likely a bad/dirty/scratched/warped/flawed disc.
Other things to try is to make sure you have the latest firmware installed in the player,
and if so, you can also try re-installing the same firmware over top of it to make sure it's the original isn't a flawed installation.
Also could try resetting the player to factory default settings, then try the disc again, then re-enter all of your personalized settings.
Most that probably isn't necessary if you have the latest firmware already and other BDs play ok.
If that's true, then again we come back to the logical choice of it being a bad disc.
~Dave
post #40270 of 40270 Old Today, 05:19 PM
Rich86's Avatar
Quoted: 67 Post(s)
Liked: 37
Yes - I believe the X-Men Future Days IS a problematic disc for the Oppo 83 & your "wrong disc" message is what has been reported. However, I believe Oppo released a firmware update to address the problem, so you might look into that on the Oppo site.
http://www.oppodigital.com/blu-ray-b...e-60-1110.aspx
A long-time audio/video addict!
Rich86 is online now
Reply Blu-ray Players
105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
Gear in this thread - 105d by PriceGrabber.com
