Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1376 - AVS Forum | Home Theater Discussions And Reviews
 353Likes
post #41251 of 41276 Old 09-05-2017, 01:40 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3789 Post(s)
Liked: 4928
Originally Posted by trailblazer View Post
I have a BDP83, bought when they first came out, and last evening while watching a Blu Ray the video froze and stumbled. Tried to reset player and used different Blu Ray discs and the video would freeze and stumble and eventually stop.
I am able to play DVDs, CDs, SACDs and DVD-Audio without any problems. Once I go to play a Blu Ray I incur freezes.
Any help with resolving this problem would be appreciated. I also requested support from OPPO regarding this issue.
There are 2 lasers in the optical drive. The blue laser reads Blu-ray discs. The red laser reads the other types of discs. Sounds like you've got a problem with your blue laser.
The USUAL problem would simply be that the laser lens needs cleaning. OPPO can give you instructions for doing that yourself, or if you send the player in for flat rate service, they'll include cleaning it, as well as checking for proper operation afterwards.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #41252 of 41276 Old 09-05-2017, 01:52 PM
rdgrimes's Avatar
Quoted: 2482 Post(s)
Liked: 1785
Originally Posted by Tristan944 View Post
I bought a new BD of La La Land. It wouldn't load/play on my 83. I contacted Oppo and they recommended letting it sit for at least 8 minutes, and luckily it worked and it plays. But they also told me that if that recommendation doesn't work, it's because of new Java versions and there is no new firmware development on the 83.
This is concerning that Oppo doesn't provide longer support for their players. They products are well made and will last longer than cheap gear, therefore longer support should be provided. I believe the 93, the successor to the 83 was released in January of 2012. That makes the 83 only 5 1/2 years old.
Oppo DOES support the player. But firmware development comes from Mediatek, and Oppo has no control over that. The VRS processor is also a dead duck. If you need anything else for the player, or a repair, its fully supported as always.
rdgrimes is offline
post #41253 of 41276 Old 09-05-2017, 02:03 PM
trailblazer's Avatar
Quoted: 32 Post(s)
--Bob
Thanks for the feedback. Hopefully the blue laser only needs a cleaning.
trailblazer is offline
post #41254 of 41276 Old 09-05-2017, 03:53 PM
rdgrimes's Avatar
Liked: 1785
If you're opening it up to clean, be aware its a single Optical Power Unit, sort of a sandwich with both lasers in it. Clean everything, including the 2 rails that the whole unit rides on.
rdgrimes is offline
post #41255 of 41276 Old 09-06-2017, 02:07 PM
Quoted: 32 Post(s)
I did as you said as well as the information I received from OPPO and it worked for while, than about 20 minutes later it started acting up again whereby it would freeze and stutter and eventually freeze and stop. I tried this a couple of times and the same thing keeps happening. No problems with other media, only with Blu Ray discs. Seems odd it would work for awhile and than act up again. I don't see any dirt on the laser lenses, rails or the rubber spindle.
Waiting to hear back from OPPO as to what else can be done.
post #41256 of 41276 Old 09-06-2017, 02:08 PM
Quoted: 32 Post(s)
--Bob
post #41257 of 41276 Old 09-06-2017, 02:20 PM
Read the FAQ!
Liked: 4928
^ Odds are you will need to send in the player for service. OPPO offers reasonably priced, flat rate service for players out of Warranty. They'll get you going again.
--Bob
post #41258 of 41276 Old 09-06-2017, 02:29 PM
Quoted: 32 Post(s)
--Bob
Probably will do that if nothing else can be done by me. This player still works great except for this hiccup and I don't think there is a better player out there that compares to this.
post #41259 of 41276 Old 09-06-2017, 02:37 PM
rdgrimes's Avatar
Liked: 1785
Those 2 rails do need to be lubricated. I think they originally come with a tiny bit of white grease on them. I've read of people resurrecting failing optical drives by cleaning/lubing them.
Sounds like whatever is failing there is doing it when it gets warm.
rdgrimes is offline
post #41260 of 41276 Old 09-06-2017, 03:12 PM
Quoted: 32 Post(s)
You have a point about it failing when it gets warm. It runs fine for 10 to 15 minutes, than starts to act up. What kind of lube would you use on the rails?
post #41261 of 41276 Old 09-06-2017, 07:48 PM
rdgrimes's Avatar
Liked: 1785
Look closely, there may still be some on there you can spread around. I think very scant amounts of white grease if you have it. At this point how much harm can you do?
rdgrimes is offline
post #41262 of 41276 Old 09-07-2017, 07:41 AM
Dennis Oblow's Avatar
Quoted: 28 Post(s)
Liked: 33
These also have an issue with the loaders failing at some point. I sent mine in, they replaced the loader with a new one ,and had it back to me in Florida in about a week for 79.00 Great service.
Dennis Oblow is online now
post #41263 of 41276 Old 09-07-2017, 01:25 PM
Jason One's Avatar
Quoted: 12 Post(s)
Does anyone know if the HDCP 2.2 fix is likely to get an official firmware release?
Jason One is offline
post #41264 of 41276 Old 09-07-2017, 01:57 PM
rdgrimes's Avatar
Liked: 1785
Its only offered to those who ask for it. Not every setup has the issue.
rdgrimes is offline
post #41265 of 41276 Old 09-16-2017, 07:00 AM
Skytrooper's Avatar
Quoted: 225 Post(s)
Liked: 146
Lithium Grease. I seen it at Lowes in a squeeze tube. Great stuff to have around.
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
post #41266 of 41276 Old 09-16-2017, 07:15 AM
ed_in_tx's Avatar
Quoted: 211 Post(s)
Liked: 89
Having worked on DVD players in the past, I would recommend a lube specific for the purpose like Molykote EM-30L which you can buy on ebay for a few bucks. But if the player is doing OK with CDs DVDs etc and only failing with blu-ray discs, it's probably sliding fine. I would certainly suspect the optical block. Sounds to me like the blu-ray laser is failing. A trip to Oppo is likely needed.
ed_in_tx is offline
post #41267 of 41276 Old 09-16-2017, 10:20 AM
Quoted: 32 Post(s)
I tried everything to fix the issue but couldn't get it to work Sent to OPPO and they replaced the Optical Unit. I am scheduled to get the unit back next week. Hopefully no further issues.
post #41268 of 41276 Old 10-12-2017, 12:45 PM
manoharshetty9's Avatar
Quoted: 36 Post(s)
Hi There,
My unit was working fine until yesterday untill I connected my new 2tb external hdd to it via usb which was not being recognised by the player. Now it does not seem to read even my usb pen drive. The front LED display shows initial "USB IN" message but nothing gets read by the player. What do I do? Any advise/help appreciated.
manoharshetty9 is offline
post #41269 of 41276 Old 10-12-2017, 01:09 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3400 Post(s)
Liked: 2655
Originally Posted by manoharshetty9 View Post
Hi There,
Was the USB stick recognized before? Can you mount it on a computer and read the contents? Verify that the file system is FAT? Run disk check on it?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #41270 of 41276 Old 10-12-2017, 01:54 PM
Read the FAQ!
Liked: 4928
Hi There,
Your new drive may be drawing too much power from the player's USB port. Hook the drive up to external power. If the drive itself does not offer a way to attach external power, you can connect it to the OPPO via a powered USB hub.
--Bob
post #41271 of 41276 Old 10-12-2017, 11:07 PM
Quoted: 36 Post(s)
-Bill
Yes the USB stick was recognized and working fine before. In fact I also have another 1tb HDD which was also working fine on the OPPO 83SE. But now nothing is being read although the Front Panel LED does acknowledge and display initial "USB IN" information on insertion but does not show up on the TVscreen under Movies, Music, etc. All USB Devices are working fine when connected to my computer. The file systems on the USB Stick and the HDDs are FAT32.
Thanks Bill.
--Bob
I agree that the new 2tb HDD maybe drawing too much power but it is a portable HDD with only a USB port and I do not have a powered USB hub. But now my issue is that even my USB Pen/flash stick(32gb) and my USB HDD(1tb) which was working fine previously are not working on the OPPO aside from the initial acknowledgement on the Front Panel Led display "USB IN" sign.
Thanks Bob.
post #41272 of 41276 Old 10-13-2017, 04:44 AM
wmcclain's Avatar
Liked: 2655
Thanks Bill.
Thanks Bob.
That's mysterious. Contact OPPO Support and see what they say.
-Bill
wmcclain is offline
post #41273 of 41276 Old 10-13-2017, 07:16 AM
S-Blu's Avatar
Does anyone know where I can get a replacement optical drive for my oppo 83. Oppo have informed me I can send it to them, but I would rather not as I live in Australia. I think it would be less expensive if I replaced the optical drive myself, if I can get one. Anyone have any suggestions?
S-Blu is offline
post #41274 of 41276 Old 10-13-2017, 07:18 AM
wmcclain's Avatar
Liked: 2655
Did you ask OPPO if you could get a drive from them? I believe they have provided components before.
-Bill
wmcclain is offline
post #41275 of 41276 Old 10-14-2017, 06:10 AM
S-Blu's Avatar
I did contact Oppo and they did tell me that due to a shortage of parts, they no longer sell the optical drive. Although I can send it to them and they will repair it. I would rather not do that as I live in Australia. I think it would be less expensive to find a replacement optical drive and swap it out myself.
S-Blu is offline
post #41276 of 41276 Old 10-14-2017, 02:49 PM
progprog's Avatar
Quoted: 95 Post(s)
Liked: 73
Is the optical drive the electronics? Or the mechanical parts that move over & read the disc?
progprog is online now
Reply Blu-ray Players
105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
