Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 174 - AVS Forum | Home Theater Discussions And Reviews
 350Likes
post #5191 of 41227 Old 03-28-2009, 05:12 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3176 Post(s)
Liked: 2460
Originally Posted by mvp2005fan View Post
I didn't see any difference in the PQ, but I'm wondering if others have noted this. Perhaps the Pio is only indicating that the HDMI Deep Color handshake is working and not necssarily that Deep Color info is being passed?
I've not been able to test it myself, but have seen a couple of comments that it makes smoother gradients on some animation.
I suspect this is a very minor feature of the player.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #5192 of 41227 Old 03-28-2009, 05:32 AM
jhstn58's Avatar
Just started trying this puppy out but I did give Brick a try. CD side played fine on all discs. DVD-A side exhibited two distinct responses, both of them bad. Fear of Music and Remain in Light would lock the Oppo up shortly after inserting the disc and prior to any menu appearing on the screen. In these two instances I got no response from the R/C or the front of the unit other than to turn it off (which took a few seconds longer than usual). To eject the disc I had to press the eject button while the unit was off.
The other, more common, result was for the disc's menu to start but lock up prior to the menu completely loading. In these cases, the open button on the R/C did work.
I notice that the manual provides the following on page 3 under "Discs That Cannot be Played":
Some DualDiscs: A DualDisc is a two sided disc with DVD on one side and digital audio on the other side. The digital audio side does not meet the technical
specifications of the Compact Disc Digital Audio (CD-DA) format so playback is not guaranteed. P
That this is printed up front suggests this might be not be fixable with a FW update. Any thoughts?
JimS
Rough business this movie business. I may have to go back to loan sharking for a rest.
jhstn58 is offline
post #5193 of 41227 Old 03-28-2009, 05:36 AM
jhstn58's Avatar
BTW, even though my manual had a slip page instructing me to DL the latest version of the manual, the version included with my player is the same as the online version.
JimS
jhstn58 is offline
post #5194 of 41227 Old 03-28-2009, 05:51 AM
Tom899's Avatar
Quoted: 91 Post(s)
Liked: 27
Originally Posted by Tom899 View Post
Is there a list of problem discs? Whether it be BD, DVD-A, DVD, SACD, etc... Maybe we could have a sticky, or first page of thread with-in this thread that us users could add such discs with comments as to if the disc won't play at all, or time stamp, etc... so the rest of us can try them out. Just an idea.
Well, either this is not a good idea, not feasable, overlooked?
-Tom
Tom899 is offline
post #5195 of 41227 Old 03-28-2009, 06:04 AM
shinksma's Avatar
Location: Wandering the intertubes, on the way to damnation
Quoted: 80 Post(s)
Liked: 54
"Some DualDiscs: A DualDisc is a two sided disc with DVD on one side and digital audio on the other side. The digital audio side does not meet the technical
specifications of the Compact Disc Digital Audio (CD-DA) format so playback is not guaranteed. P "
The DVD-A side not playing is a known issue with the Oppo and is being addressed, as advertised in this thread. So the issues you experienced are supposed to be fixed "soon".
The text in the manual is referring to the "CD" side, which you didn't have any issues. But if you had issues, Oppo is basically saying "blame the DualDisc people - the CD side is out of spec".
More detail, AFAIK: The issue with the CD side of DualDiscs is purely a CD-laser head/pick-up design issue: The "CD" side of a DualDisc is not built to the specification of a CD, which is why it truly not a "Compact Disc" because it violates the tech spec, instead the DualDisc folks called it "Digital Audio" side of the disk. Depending on tolerances in the manufacturing of the particular disk you have and your player's CD laser head, it may or may not work properly, and no firmware can really fix this. However, in practice failure to read the "CD" side is very rare.
It's annoying, but since all the "CD" sides of your Brick DualDiscs worked, you seem to be in good shape.
Again, AFAIK,
shinksma
My opinions are my own, and do not necessarily reflect those of my captors.
shinksma is offline
post #5196 of 41227 Old 03-28-2009, 06:06 AM
jhstn58's Avatar
Just now trying out the DTS CD of Band on the Run. Two points: The audio of the first cut is delayed by about one second (the opening guitar lick is missing completely; sound kicks in with the first downbeat). When I start the CD I notice my Yamaha 2700 flashing for a moment before it locks into the DTS stream (via bitstream) or the PCM stream (via LPCM). Obviously that 's a bother, but the most unusual thing about this disc is that the 83 is playing the audio tracks at a faster speed than it should. Paul's voice is noticeably higher, and eyeballing the elapsed time, the clock appears to be slightly fast too (10% say). I'm still experimenting with other discs. Back soon with more.
JimS
jhstn58 is offline
post #5197 of 41227 Old 03-28-2009, 06:19 AM
wmcclain's Avatar
Liked: 2460
It sounds like a lot of work for someone. And you'd have to retest the entire list for each new firmware. In particular, I would not bother listing DVD-A problems until another revision or two.
But if you make such a resource and put it on the web, I will put a link in the FAQ.
-Bill
post #5198 of 41227 Old 03-28-2009, 06:32 AM
Tom899's Avatar
Quoted: 91 Post(s)
Liked: 27
-Bill
Thanks- probably a good idea but not worth the trouble than. I don't at the moment have the expertise to set this up. Everything on this thread is moving so fast its hard to keep up with the issues and problems.
-Tom
Tom899 is offline
post #5199 of 41227 Old 03-28-2009, 06:44 AM
winston9332's Avatar
Liked: 31
I sat down to watch Australia last night with the wife. Everything loaded in short measure and I entered the setup section of the menu, then audio and chose dts hd master audio and no subtitles, then the screen disappeared. The player continued to show top menu, but was otherwise unresponsive. I had to open the disc and reboot. Tried it again and black screen again. If I hit play directly from the menu, it played seamlessly.
After watching 30 minutes, I realized it was yet another bleeding edge technology feature of the oppo - bad movie blocker!
winston9332 is offline
post #5200 of 41227 Old 03-28-2009, 06:46 AM
Tom899's Avatar
Quoted: 91 Post(s)
Liked: 27
Good one!!
-Tom
Tom899 is offline
post #5201 of 41227 Old 03-28-2009, 06:50 AM
wmcclain's Avatar
Liked: 2460
I think I toggled through the audio on that one without difficulty; don't specifically recall. I do try to "exercise" each BR that I play.
It's been many months since I had a BR playback problem, apart from having to make audio sync adjustments from time to time.
-Bill
post #5202 of 41227 Old 03-28-2009, 07:04 AM
jhstn58's Avatar
As previously noted, Nightfly wouldn't play.
I've also noticed that the fast forward and rewind buttons do not work consistently on DVD-As. So far, on many discs I have to call up the display to get the FF or RW to work. Sometimes even that doesn't make a difference. All that elapses is the (real time) period that I spent with the FF or RW action engaged.
Finally I was unable to access several cuts on the DVD-A side of an AIX sampler Disc (the DVD-V side worked fine of course). None of the jazz music on the disc would play at all. And the only images that would appear - regardless of what music genre I was trying - were the classical album covers (perhaps it's related to the fact that I played the some classical cuts first, where everything seemed to be working fine).
Anyway, enough with the music critiques. Oppo knows it's got a bit of work to do to smooth out DVD-A and I'm encouraged by the prospect that, when it works, it sounds GREAT!
It's onto DVDs!
JimS
jhstn58 is offline
post #5203 of 41227 Old 03-28-2009, 07:07 AM
ehlarson's Avatar
Liked: 31
Originally Posted by toddthomas View Post
I just received Doctor Who, Season 3, disc 5 tonight via Netflix, and my 83 won't play its title menu. The disc was not in great shape, so I cleaned it with soap, water, and Windex, but still had the same problem. I then put the disc in my old DVD player (a Pioneer DV-588A which has had problems playing several scratched Netflix disks) and it played fine.
Here's the sequence of events:
- insert disc;
- press Stop to cancel resume from saved position if necessary;
- you're forced to watch or press Next to skip past the following:
-- FBI warning,
-- 2|entertain logo animation,
-- BBC logo animation,
-- promo for MI-5 series on DVD;
- up to this point, the 83's front panel display has been displaying "TITLE", but now it switches to "1 00:00:00", then increments to :01 and sometimes :02 before going back to :00. I know from successful playback on my old Pioneer that the top menu plays at this point.
- I'm now stuck; pretty much every button I thought might enable me to navigate somewhere else results in the red circle-slash displaying in the upper left corner of the screen.
Anyone else have this problem with this disc?
I do not have this problem with this disc. Plays fine for me.
"Nature Abhors a Vacuum Tube" -  J. R. Pierce
ehlarson is offline
post #5204 of 41227 Old 03-28-2009, 07:15 AM
DigVid's Avatar
I would never judge a player on a rental disc. I don't care how good a shape it appears to be in...
DigVid is offline
post #5205 of 41227 Old 03-28-2009, 07:21 AM
Craven More's Avatar
Quoted: 18 Post(s)
The exact same thing happened to me last night with Australia so it appears this is a problem discs for the 83.
Craven More is offline
post #5206 of 41227 Old 03-28-2009, 07:26 AM
Dave Vaughn's Avatar
Quoted: 1042 Post(s)
Liked: 1514
Australia gave me a problem the first time I played it with the exact same issue you report. The weird thing is I wasn't able to reproduce it!
When my contact at Oppo tried it, the same thing happened to him the first time he loaded the disc...very strange. This was on the last firmware, not the current. BTW, you're right about the movie not being very good!
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is online now
post #5207 of 41227 Old 03-28-2009, 07:26 AM
Liked: 1514
Craven,
See my previous post and see if you can recreate the issue.
post #5208 of 41227 Old 03-28-2009, 07:32 AM
yarrumc's Avatar
I can add one more playable DVDA to the bunch.
Steven Wilson: Insurgents
I did experience a lockup/restart with Dark Side of the Moon SACD, when I was in the setup, changing back and forth between settings. It could be that one of those toggles freaked it out , while the audio was still playing? I will have a chance to watch and test a few movies tonight, to get a better overall review.
yarrumc is offline
post #5209 of 41227 Old 03-28-2009, 07:34 AM
SwampDawg78's Avatar
Respectfully I would; the unit should play rentals (in reasonable shape) without issue. Customers shouldn't be put in a situation of spending hundreds to find out the machine doesn't handle rentals well, IMHO.
If the player can't handle the rentals my desire to buy dwindles significantly.
Oppo BDP-95
Rouge Audio Cronus Magnum Integrated Tube Amplifier
Rega RP6 Turntable
Monitor Audio RS6 Loudspeakers
SwampDawg78 is offline
post #5210 of 41227 Old 03-28-2009, 07:36 AM
Jim Hef's Avatar
Originally Posted by KingofKaty View Post
...The Jackson Browne "Running on Empty" DVD-A locks up on the title screen and won't play at all....
This disc was also problematic during the development of the 980H. It must have some authoring problems.
...another bleeding edge technology feature of the oppo - bad movie blocker!
Anyone else ordering up this movie is forewarned!!! Seems to run for about 6-8 hours!
Jim Hef is offline
post #5211 of 41227 Old 03-28-2009, 07:44 AM
toddthomas's Avatar
Okay, thanks for checking. I guess it's just the condition of the particular disc I was sent, but I'm surprised my old player can handle it and not the 83. It's the first rental I've tried; the Blu-ray version of _Let The Right One In_ will be the next.
toddthomas is offline
post #5212 of 41227 Old 03-28-2009, 07:49 AM
dreamtheatre's Avatar
Quoted: 60 Post(s)
Liked: 37
For Integra 9.8/Onkyo Pro 885 Owners for SACD Playback:
I have the player set to DSD. The display on the Integra shows DSD, but I can also use all the other surround modes (i.e. DPLII Music). Is there any advantage to leaving the Integra at DSD (not DSD Direct which, I think, disables Audessy).
Jim
LG 65EF9500 OLED Display
Oppo BDP-203,Schiit Bifrost Multibit DAC, MF V-LINK 192
Parasound P5, Marantz SR-6010, EAD PM 1000 and PM 500 amps
NHT 2.5i (2), NHT AC-1 (1), NHT 1.5 (2), PSB XA (4)
Outlaw Ultra X12 and LFM-1 EX subwoofers
dreamtheatre is offline
post #5213 of 41227 Old 03-28-2009, 07:55 AM
Smarty-pants's Avatar
Quoted: 750 Post(s)
Liked: 628
Jim
The advantage would be a matter of opinion... that you would be listening to the disc as the authors/artists intended it to be heard in DSD mode. If you would like to ad post processing to alter the soundstage, then that is up to you. Whatever sounds best to your ears should be what is important to you.
Smarty-pants is offline
post #5214 of 41227 Old 03-28-2009, 07:55 AM
Quoted: 18 Post(s)
Originally Posted by Dave Vaughn View Post
Craven,
I'll give it a try tonight. BTW, I could only get past the 1st 20 minutes of the film last night (no fault of the player).
post #5215 of 41227 Old 03-28-2009, 08:07 AM
Liked: 31
Know it's WAY off topic, but could not believe how BAD that movie was.
Still having intermittent issues with lipsynch on sd dvds - am i the only one?
post #5216 of 41227 Old 03-28-2009, 08:09 AM
rdgrimes's Avatar
Quoted: 2343 Post(s)
Liked: 1673
Turn off DVD-24p and see if that helps.
rdgrimes is online now
post #5217 of 41227 Old 03-28-2009, 08:13 AM
rdgrimes's Avatar
Liked: 1673
Originally Posted by winston9332 I sat down to watch Australia last night with the wife. Everything loaded in short measure and I entered the setup section of the menu, then audio and chose dts hd master audio and no subtitles, then the screen disappeared. The player continued to show top menu, but was otherwise unresponsive. I had to open the disc and reboot. Tried it again and black screen again. If I hit play directly from the menu, it played seamlessly.
Anyone having playback issues with specific BD discs, especially freezes or hangs while loading: Be sure that BD-Live is disabled in network setup, eject and try it again. BD-Live is prolly the #1 cause of these type issues and needs to be ruled out.
post #5218 of 41227 Old 03-28-2009, 08:17 AM
Liked: 31
oh bd live...yet another example of its wonderful value!
post #5219 of 41227 Old 03-28-2009, 08:26 AM
Immaculate Grand Phoobah
grubavs's Avatar
Location: on the noisy end of the Half Moon Bay, CA Airport
Quoted: 41 Post(s)
Liked: 32
Yep.
Now that's some fine feline
grubavs is offline
post #5220 of 41227 Old 03-28-2009, 08:35 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3526 Post(s)
Liked: 4526
Agreed.
In my testing the Oppo actually handles damaged discs BETTER than I'm used to from other players.
In any event, whatever happened with that one disc for the poster above needs to be tracked down regardless of the fact of it being a rental.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
Reply Blu-ray Players
105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
