Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 427 - AVS Forum | Home Theater Discussions And Reviews
 345Likes
Old 05-29-2009, 10:53 AM
rdgrimes's Avatar
Quoted: 1997 Post(s)
Liked: 1328
Originally Posted by Northern Light View Post
I've been having exactly the same issue running the analog outs through my Parasound Halo C2. For me, there are no pops as long as the TV connected to the player via HDMI/DVI is turned on. In my case it's an older Toshiba rear projection HDTV that only has a DVI input. As soon as the TV is turned off, the pops come back, unless I unplug the HDMI/DVI cable. I agree that pure audio mode does not help. Very strange and irritating!
As long as HDMI audio is enabled in the player, it's not strange at all. If it does this with HDMI audio disabled, then it's a bug that should be worked out. Also be aware that many monitors have "hot" HDMI ports even when turned off.
rdgrimes is online now
Old 05-29-2009, 11:08 AM
kirko's Avatar
Originally Posted by kirko View Post
I will. This week just has been crazy (at work) and haven't had a chance yet.
I'm just trying to get an idea from people who have already done it. Basically, what's the optimal BDP-83 audio setting for DVD/BD playback AND audio setting for CD and SACD playback.
I have both connections to Onkyo 875 -- HDMI 1.3 and Analog stereo.
From what I read:
multichannel audio (SACD, DVD, BD) over HDMI should be:
  • HDMI Audio - Bitstream
  • SACD Output - DSD
CD audio over analog stereo should be:
  • HDMI Audio - Off
  • SACD Output - PCM
But is there a compromise setting? I mean I don't want to change these settings every time I go back and forth between CD/BD. I'm not aware of any button that does that switch. It's not a big deal to leave HDMI Audio in Bitstream setting, but is there any faster way to switch between DSD and PCM. If not, then I'll probably leave it in DSD at all times.
Originally Posted by rdgrimes View Post
HDMI audio can be either bitstream or PCM according to your needs. Never any need to turn it off.
SACD should be set to PCM any time you wish to use analog outs, and can be left at PCM all the time with no loss of quality.
All this is covered in the FAQ and manual.
Last night I set up this configuration on BDP-83 (connected via HDMI and Analog stereo):
  • SACD Output - PCM
and used multiple MP3s to play around with settings on AVR. I tried 3 different settings on Onkyo 875 (via stereo connection):
  1. Direct
  2. Pure Audio
  3. Stereo
To me, Direct sounded the "dullsest". Pure Audio was a bit better. Stereo had the best depth - the musical instruments seemed a lot "closer" to me. I still haven't tested any CDs, so it may change.
kirko is offline
Old 05-29-2009, 11:09 AM
boiler_maker's Avatar
Okay, I have read many of the posts here, but not all of them.
Here is my question: Is this Oppo that we have all been waiting for worth the price or not? The wait has been very long and much anticipated. I'd like to make the jump but I already did that once with the Toshiba A-2 and I want to get a unit that I'm happy with for a few years.
Receiver: Harman Kardon DPR2005
Front Speakers L/R: Athena Audition AS-B1; Front Speaker Center: Athena Audition AS-C1
Surround Speakers: Advent from 1988
Subwoofer: Dayton 10" 100 Watt powered sub
DVD Player: Oppo BDP-103
Display: Panasonic TC-P55VT60
boiler_maker is offline
Old 05-29-2009, 11:17 AM
rdgrimes's Avatar
Liked: 1328
  • SACD Output - PCM
  1. Direct
  2. Pure Audio
  3. Stereo
I'm gonna suggest you use something other than MP3 for judging audio quality. The player is capable of so much more. I'd use a 2-ch SACD, or at least a VERY well mastered CD.
Old 05-29-2009, 11:26 AM
Coyote Waits
htwaits's Avatar
Quoted: 920 Post(s)
Liked: 2030
All of us are no longer waiting.
htwaits is offline
Old 05-29-2009, 11:33 AM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
The only question to ask yourself is if there is anything you want a player to do and do well that the Oppo doesn't do.
JazzGuyy is offline
Old 05-29-2009, 11:35 AM
gonk's Avatar
There is no one answer to that. For some people, no Blu-ray player will be worth $500 - either because they can't afford it or because their needs can be satisfied with a basic entry-level Panasonic or Sony for somewhere around $250. What I will say is that I continue to believe that this thing could have been priced another $100 higher and still been a killer value.
I also had (still have) an HD-A2. This is no HD-A2. I can see being happy with the BDP-83 for a long, long time.
gonk
Beta tester: BDP-83 / BDP-80
gonk is offline
Old 05-29-2009, 11:39 AM
gonk's Avatar
Both Direct and Pure Audio would be bypassing your Audyssey room correction and bass management (assuming that the 875 receiver behaves like my 885 processor does), while Stereo does not. I wonder if that is contributing to your findings.
gonk
gonk is offline
KIDSMD1's Avatar
I've had my 83 now for 2 weeks and everything I've played has played flawlessly and I love every source (BD, AVCHD - music only, SACD and DVD-A). I appreciate AVS and especially this thread and I know my success has been because I have followed the excellent advice noted here.
However I have a problem that perhaps I have overlooked it's being addressed here and before I emailed OPPO I thought I would present it here: MY 83 is connected to an Anthem D2 via HDMI 1.1 and my HDMI audio is set to LPCM and SACD output is PCM. My overall setup is 7.1 with large Front and Center speakers and dual subwoofers.
The problem I have is that a Chesky (Audiophile vocal recording) SACD that is recorded as a "STEREO ONLY!!" SACD recording, is played back through all speakes (i.e. multi-channel) no matter what I change via the 83's setup. I've tried changing the SACD priority to stereo, the speaker config to downmix to stereo (which is not needed with a D2) and still all speakers play. I do not use analog outs at this time, so this has not been tried (I hate to go thru the pains of bass management problems or lose my room correction with my ARC application from my D2). My confusion lies in that with my PS3 this disc worked perfectly using the same HDMI connection to my D2.
Any help is appreciated!! Thanks!!
[b]DrJ
KIDSMD1 is offline
Old 05-29-2009, 11:40 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2690 Post(s)
Liked: 1921
Isn't "worth" always subjective? How can anyone answer that for you? I suppose you could put up a poll.
The other one that gives me metaphysical disorientation is "Will I see/hear any difference between..." How can anyone say what another person will see or hear?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Old 05-29-2009, 11:47 AM
rdgrimes's Avatar
Liked: 1328
When you use the OSD in the player, what does it say the audio is? 2.0 or 4.0? Chesky is famous for weird surround modes.
On the surface it sounds like your D2 is set to apply some decoder to 2-ch audio. None of the downmix or speakers settings in the player will effect the digital outs.
Old 05-29-2009, 11:48 AM
Okay guys, I fully understand that A/V in general is very subjective. Maybe a rephrasing of my question would be better received:
For those that now own the BDP-83, is anyone regretting the purchase?
I am more than willing to shell out $500 for a nice player. I can read about the features and decide which of them are important to me. But like many people, I don't want to take the time to personally test several units to compare. That's why I come to avs. I trust the information I gather from this forum and I enjoy reading many of the posts. I have used information from avs to purchase many items in the past and it's a nice little technical shortcut that people can take without relying on tainted reviews by some of the commercial web sites.
Again, thanks for keeping this forum lively. Those of us that enjoy A/V but don't allow ourselves time to become true experts really appreciate this type of information.
--Brian
Old 05-29-2009, 11:53 AM
rdgrimes's Avatar
Liked: 1328
For those that now own the BD-83, is anyone regretting the purchase?
The guy who just sold one on eBay for $650 prolly isn't regretting the purchase.
--Brian
There's aren't "several players" to try in this class. The Oppo stands completely alone. It's a matter of whether you want the features or not. But even if you only want the stellar DVD upscaling and BD playback, it's worth every penny. The discontinued Oppo 983 is still selling used at full retail prices, what does that tell you?
Old 05-29-2009, 11:59 AM
Q of BanditZ's Avatar
How about the guys flipping it for $800?
My answer to boiler_maker is this:
I'm a notorious fence sitter. I get buyer's guilt pretty easily...even before I pull the trigger.
If I use the Oppo for nothing else except BD and DVD I will easily feel like I've gotten my money's worth.
Great ISF Job by Chad B.
Q of BanditZ is offline
Old 05-29-2009, 12:01 PM
ca1ore's Avatar
I guess people cannot answer simple questions in 'technical talk' threads. From my perspective, the answer to you question is a resounding YES! I've paid far more for far less over the years. Take the plunge!
Certainty and conviction are a sure sign you don't know what you're talking about! The world is not black and white, rather shades of grey!
ca1ore is offline
Old 05-29-2009, 12:02 PM
KIDSMD1's Avatar
THANKS!!! I had forgotten to change my Bass Management in my D2 to Music which plays in stereo mode.
[b]DrJ
KIDSMD1 is offline
Old 05-29-2009, 12:06 PM
wmcclain's Avatar
Liked: 1921
--Brian
The magazine reviews will start trickling in over the next few weeks/months. They are all going to say "Killer product from a great company. Why can't the other guys do this? Here's hoping OPPO makes a cheaper stripped down version..."
The more technically oriented lab-bench people will be just as positive.
-Bill
Old 05-29-2009, 12:10 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
--Brian
No regrets at all. The only thing I can't figure out is how they can sell a player that does all the things this one does and does well at the price they are asking. Everything else that seems to be at all close as far as feature sets and quality is at least 4 or 5 times the price.
JazzGuyy is offline
Old 05-29-2009, 12:16 PM
gonk's Avatar
As a beta tester, I can't answer that one in a way that will be useful to you. I certainly don't regret the time I've spent working with the player as it has matured to be the consumer-ready product it is today. I have also recommended it to several friends already, based on the fact that I trust they won't regret taking my advise.
gonk
gonk is offline
Old 05-29-2009, 12:23 PM
kirko's Avatar
Yeah, I will definitely do more evaluation on a good CD and will report back. I think that MP3 files I've used aren't even of a good quality.
Correct, I'm also running SMS-1 for my sub. What are your settings on 885?
kirko is offline
Old 05-29-2009, 12:27 PM
stevec325's Avatar
Brian,
I'd guess that about 99% of the folks here are going to tell you they are about 99% satisfied with the -83.
So, I'll net it out for you...
Buy it and don't look back. You will not find a better player at almost any price. I think it's as good or better than the Pio -09,which goes for almost 8X more.
It's pretty much "future proof" (if there is such a thing), has most all of the audio and video high end features, is built extremely well, has outstanding support and for the price - you are truly getting an audiophile (no flames please) and a videophile quality product.
End of discussion. I have spoken. Now, go buy the damn thing and report back how much you love it. That is all
-steve
My HT Setup - updated 12/25/2012
"...and all the science, I don't understand. It's just my job, five days a week."
stevec325 is offline
Old 05-29-2009, 12:29 PM
gonk's Avatar
I've also got an SMS-1 on my sub at the moment. The SMS-1 is always working for the subwoofer signal, but in Direct and Pure Audio modes there's no bass management to generate a subwoofer signal when you are playing a stereo source like an MP3 file, so the only time the SMS-1 and the sub had any chance of getting a signal was when you were in Stereo mode.
I've used so many different arrangements during beta testing that frankly I lose track of how I've got it set up at times. I've even used the multichannel analog connection pretty frequently, although that's the only time I generally use a mode similar to Direct (both Direct mode and the multichannel analog input operate without any of the DSP features like bass management and Audyssey).
gonk
gonk is offline
Old 05-29-2009, 12:35 PM
mrtwstr's Avatar
I wonder how stringent they are on the invites... I had one that expired mid-May but had forgotten about it. I just broke it out and ordered. Wonder if I'll be rejected
mrtwstr is offline
Old 05-29-2009, 12:41 PM
ca1ore's Avatar
One thing I didn't try was setting HDMI audio to 'off'. Perhaps this will solve the problem without having to fiddle around with unpluggung the HDMI cable.
ca1ore is offline
Old 05-29-2009, 01:03 PM
osogovo's Avatar
I own DV 981 and BDP 83 When " on" the dvd player's power and navigation butons have blue light on,while the blu ray player has only the power buton lit up.I tried the dim control too.Is this how is supose to be?I looked at pictures on OPPO's website and the playback/navigation buton seem to have that blue light on'I was wondering if it's just my 83.
osogovo is online now
Old 05-29-2009, 01:05 PM
I like this attitude.
Old 05-29-2009, 01:21 PM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
There is no lighting on the navigation keys. Only the Power button and the VFD light up.
Neuromancer is offline
Old 05-29-2009, 02:04 PM
Franchot's Avatar
Quoted: 210 Post(s)
Liked: 165
I think you'll find that Oppo will send you one. (I was ten days past my expiration date when I ordered and they honored it.) Plus, it appears Oppo will soon be making this available to everyone, so they've got nothing to lose by allowing you to purchase one at this time.
Franchot is offline
Old 05-29-2009, 02:05 PM
Sango's Avatar
Quoted: 16 Post(s)
Originally Posted by wmcclain View Post
It is of negligible benefit, but you can judge for yourself. See the FAQ for more: -Bill
Thanks Bill for the information. I will keep deep color off.
A few days earlier a member (name ?) posted about deep color, I don't exactly remember what was said. It was something like Deep Color wasn't within specifications or wasn't standard yet. Could affect the picture if the set is calibrated for deep color and one and not the other or vice versa.
Sango is offline
Old 05-29-2009, 02:15 PM
Jim Hef's Avatar
Forum member bbar asked me to test a DTS HD-MA 5.1 disc for audio transmission. The test was if decoded by the player, and sent to my AVR as LPCM via HDMI, would there be sound in the rear channels. There was, although at a much lesser volume than the side surrounds. I didn't set downmix to 5.1 from my usual 7.1 setting, but my AVR indicated it was receiving a 5.1 signal and outputting a 5.1 signal. When set to bitstream the 5.1 and let the receiver do the decoding, the rear surrounds are quiet. Is this a bug, and is this known? I don't remember reading about this.
Jim Hef is offline
105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
