Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 89 - AVS Forum | Home Theater Discussions And Reviews
 345Likes
post #2641 of 41204 Old 03-13-2009, 10:31 AM
rdgrimes's Avatar
Quoted: 2067 Post(s)
Liked: 1389
Originally Posted by James W. Johnson View Post
Guys, quick question. Is the Oppo going to be $599 after the EAP ? Reason I am asking is if I am chosen in the next 100 the $100 savings would be a push towards getting one. Because I am on the fence on this player, if its gonna be $499 then I should probably just wait awhile.
thanks
Nobody knows. But it's still a bargain at $599. If it doesn't have that value to you then you're looking at the wrong player.
rdgrimes is online now
post #2642 of 41204 Old 03-13-2009, 10:33 AM
XJ6
XJ6's Avatar
Originally Posted by Mike__P View Post
A few pages back XJ6 indicated he didn't get sub woofer output over the analog outs using a test disc. Has anyone confirmed that the sub woofer outs work with other test material?
Originally Posted by rdgrimes View Post
Yes. This issue is only with a couple of test discs AFAIK, and is being worked on if not already fixed. Very much under control at this point.
I am trying to reply to this inquiry again as the thread was temp. suspended yesterday.
Rdgrimes, I sincerely hope that you have insider info and your statement of "very much under control" is correct. I also hope that it is just 1 of those silly mistakes a programmer can make and not part of a more complex issue. Think about it, DD decoding problem in 2009? A scary thought, isn't it?
XJ6 is offline
post #2643 of 41204 Old 03-13-2009, 10:33 AM
jam88's Avatar
Originally Posted by tommypeters View Post
Yes, 24/96 is totally unlistenable, isn't it...?
If it comes from a lossy codec that may be the case, I don't know. Otherwise I don't agree. The DVD-Audio discs at 96/24 that I've listened to sound from very good to phenomenal, certainly better than CD versions. One example is the Dire Straits Brothers in Arms 20th Anniversary Edition dual-disc, the DVD-A side sounds excellent, way better than the Vertigo SBM CD remaster or the West German Vertigo CD that I also own. Actually, Chuck Ainlay, the engineer that mastered both the DVD-A (MLP) and the SACD discs, prefers the sound on the DVD-A.
jam88 is offline
post #2644 of 41204 Old 03-13-2009, 10:40 AM
jam88's Avatar
Originally Posted by Bob Pariseau View Post
I stand corrected. The issue is not with 7.1 DTS-HD MA decoding in the Oppo but rather with 5.1 DTS-HD MA decoding where the Oppo is limited to 96KHz although DTS-HD MA itself on Blu-Ray supports up to 192KHz 5.1.
Thanks for reposting this info!
--Bob
That's alright, I had guessed that little slip-up. It is I who thanks you for all the excellent and informative posts you've published on this thread and that I've had the pleasure to read; I've learned so much.
jam88 is offline
post #2645 of 41204 Old 03-13-2009, 10:48 AM - Thread Starter
Neuromancer's Avatar
Quoted: 83 Post(s)
Liked: 319
He can't be more accurate without breaking NDA. Be patient, you will see why he is not worried about this bug.
It is, as it only effects certain scenarios. You only had one disc at your disposal, and this disc caused the lack of a subwoofer signal. AVIA, DVE, and even the THX Optimizer found on Star Wars do not produce the same error. It is very specific to the Dolby Digital signal used on that DIY Audio DVD and some test patterns found on other Blu-ray/DVD media.
Neuromancer is offline
post #2646 of 41204 Old 03-13-2009, 11:11 AM
Jim Hef's Avatar
Originally Posted by jam88 View Post
If it comes from a lossy codec that may be the case, I don't know....
Jam, I believe that he was being sarcastic with his post, and meaning that 24/96 is great sound as it is, and to not worry about getting 24/192. As for that Brothers in Arms disc, it was one of the discs that broke the 980 when it was under development, and Oppo was able to very quickly remedy this with a firmware fix. Their staff is quite adept at diagnosing a problem and then quickly fixing it.
Jim Hef is offline
post #2647 of 41204 Old 03-13-2009, 11:12 AM
elementBike's Avatar
Up to 40 YES votes now.
Some of the comments by EAPr's indicate the product's stability is beyond my pre-release expectations. OPPO is being very conservative, which I appreciate. Spent a few moments over on the DISH DTV PAL thread--an entirely different approach to new product release over there!
Are you sure you have everything, Otis?
I've never had any complaints yet!
EAP Snubbed  Random Number Generator Impaired
elementBike is offline
post #2648 of 41204 Old 03-13-2009, 11:13 AM
kendo70433's Avatar
Originally Posted by winston9332 View Post
I trust no one has heard anything from Oppo on the selection of the second 100 participants? I know folks thought we would hear today or Monday. I trust that once folks receive the email they'll notify the thread...
Are you kidding?!? When the emails start arriving we'll have 500 new posts in hours chatting up the event: winners, losers, sour grapes, nervous breakdowns...
Should be entertaining.
kendo70433 is offline
post #2649 of 41204 Old 03-13-2009, 11:18 AM
rdgrimes's Avatar
Liked: 1389
If we said more, Oppo will send over their knee-cappers and take our players away.
Neuromancer, I assume that bug has to do with the LFE channel being the only one active, was I wrong? Something that never occurs in normal DD discs.
post #2650 of 41204 Old 03-13-2009, 11:23 AM
sillysam's Avatar
I was thinking the same thing.
BTW, any word yet on the newly chosen?
sillysam is offline
post #2651 of 41204 Old 03-13-2009, 11:23 AM
James W. Johnson's Avatar
?? How can I possibly put a value on a player that I have not seen in action? If Larry, Curly and Moe all love the performance of the 83 on their displays does that mean that I am going to like it ? No it does not.
"If it doesn't have that value I am looking at the wrong player"
What value are you reffering to ?
Perhaps I am misunderstanding what you said above?
James W. Johnson is offline
post #2652 of 41204 Old 03-13-2009, 11:35 AM
John Ballentine's Avatar
The 17-18 "key" features are darn nice (including the bag)- but most important to me is day-after-day reliability. Disc "freezes" (which sometimes require the need to unplug the player to re-boot) are beyond embarrassing when you have guests over for a movie. Hopefully the BDP-83 will be superb in this area.
John Ballentine is offline
post #2653 of 41204 Old 03-13-2009, 11:37 AM
DennyH's Avatar
So sorry but that is YOUR opinion only. Others may have different monetary priorities. Especially in this economic uncertainly. To some, including myself, the difference of $100 is a lot. If its not to you, good on you.
"If it doesn't have that value to you then you're looking at the wrong player."
Ferrets are Family/ Ferrets Corner
DennyH is offline
post #2654 of 41204 Old 03-13-2009, 11:41 AM
rdgrimes's Avatar
Liked: 1389
It's not complicated. If the feature set in this player doesn't have the value to you then you should look at a different player. If you are interested in THIS feature set then the value is a no-brainer.
There is currently no other player available with this feature set at any price. There will soon be one other player with a similar feature set that will sell for 6-7 times the price of the Oppo.
Used Oppo 983s are currently selling at full retail. Here you get that, plus a BD player, plus even more features for another $200. That is a screaming good deal.
post #2655 of 41204 Old 03-13-2009, 11:41 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2526 Post(s)
Liked: 3174
I think you will be pleased in that regard. This was a key element the Beta testers were looking at before the EAP units were released.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #2656 of 41204 Old 03-13-2009, 11:47 AM
thebland's Avatar
Quoted: 1501 Post(s)
Liked: 852
It has my stamp of approval on it. That's all you need (and yes I also own a $1200 BD player and $2000 BD player). I have been putting through its paces and find I am using my $2K player less and less....
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
post #2657 of 41204 Old 03-13-2009, 11:53 AM
narkspud's Avatar
Doesn't mean you won't. Unless you've decided not to.
I don't think Larry, Curly or Moe were in the EAP. Maybe second round?
narkspud is offline
post #2658 of 41204 Old 03-13-2009, 11:54 AM
jam88's Avatar
Oh well, maybe I missed the sarcastic intent. It left me somewhat wondering...
Oppo service certainly seems above and beyond most companies in this business, certainly the big name players that don't care anymore.
Just as an example, when you read the manual, it's so well explained and laid out. When I go through some of my Panasonic, Toshiba, Samsung, etc. manuals, it's difficult to find an answer, they're terrible.
jam88 is offline
post #2659 of 41204 Old 03-13-2009, 11:58 AM - Thread Starter
Quoted: 83 Post(s)
Liked: 319
That is indeed the case. When the subwoofer channel is the only one available, the player seems to not be able to handle the subwoofer channel over analog (HDMI bit stream and decoding is not effected, however).
This is why it is only on certain test discs, as most patterns and all movies use a full Dolby Digital track.
post #2660 of 41204 Old 03-13-2009, 12:02 PM
gonk's Avatar
This is a very good example - and a personal pet peeve. I find many of the electronics user's manuals to be almost a hindrance to using the equipment, but OPPO has made a point of trying to produce manuals that are well-structured, informative, and actually helpful. In this specific case, OPPO has put probably three generations of the 83's guide in front of the beta testers and listened to every comment that the testers offered.
gonk
Beta tester: BDP-83 / BDP-80
gonk is offline
post #2661 of 41204 Old 03-13-2009, 12:03 PM
TapOrSnap's Avatar
After reading the comments and reviews from the beta testers and EAP(ers) I believe that the BDP-83 will be ready for general release by the end of the month (if not already). But, I think OPPO has misjudged the demand for this player and does not have enough inventory to meet the current demand. Which is one of the reasons they are dragging out the EAP program.
(just my opinion based on reading between the lines and indirect comments I've received from emailing OPPO)
TapOrSnap is offline
post #2662 of 41204 Old 03-13-2009, 12:06 PM
rdgrimes's Avatar
Liked: 1389
So in essence, the bug was due to the specific test discs being authored incorrectly or at least out of the norm.
post #2663 of 41204 Old 03-13-2009, 12:08 PM - Thread Starter
Quoted: 83 Post(s)
Liked: 319
Originally Posted by sharkshark View Post
... ever test that SACD to see if it's volume matched (DSD/PCM), or is there a disparity like on the 980.
SPL C Weight, Fast at 70dB using Telerec 1812 Overture Track 8 (Left Channel White Noise) going into a Yamaha RX-V3800 with HDMI at 1080p/60Hz resolution:
OPPO DV-980H
DSD: -10.5
PCM: -1.5
Pioneer DV-48AV
DSD: -10.5
PCM: -10.5
OPPO BDP-83
DSD: -10.5
PCM: -7.0
post #2664 of 41204 Old 03-13-2009, 12:08 PM
Robert Cook's Avatar
Quoted: 34 Post(s)
Liked: 55
However, the question (originally brought up by Princess Aurora) remains as to how exactly a player goes about downsampling audio data that it apparently does not have sufficient processing power to decode in the first place. I suggested that this would be possible if DTS-HD MA has a lossless 96 kHz extension layer between the core DTS layer and an additional 192 kHz lossless extension layer, but I do not know whether this is the case. If it is, then the BDP-83 could simply be ignoring some data while producing a lossless 96 kHz version of the soundtrack, but if it isn't, then it may only be decoding the lossy DTS core in the specific case of 5.1/192 soundtracks. Some clarification from OPPO would be nice. Would a beta-tester (who has a closer connection to OPPO and a BDP-83 on hand) like to fire off a query to OPPO, or should I go ahead and do it?
There is also an issue with the BDP-83 manual claiming support for 7.1/192/24 Dolby TrueHD soundtracks, which is beyond what Dolby currently claims (as far as I'm aware). In this case, the concern is certainly not a lack of capability (in fact it's the opposite), but this raises questions as to who really knows what is going on nevertheless.
Robert Cook is offline
post #2665 of 41204 Old 03-13-2009, 12:13 PM
rdgrimes's Avatar
Liked: 1389
Nothing is being dragged out. The player will most certainly be in full release on the day that Oppo decides it's ready. If past experience is any guide, they are usually no more than 2-3 weeks behind on orders, so they have a fairly short lead time for new production runs. There's no real incentive for a small company to have inventories sitting around.
post #2666 of 41204 Old 03-13-2009, 12:16 PM
rdgrimes's Avatar
Liked: 1389
A good point, but in the absence of any 7.1 24/192 discs to test with, we'll never know.
post #2667 of 41204 Old 03-13-2009, 12:16 PM - Thread Starter
Quoted: 83 Post(s)
Liked: 319
There would be no incentive for dragging out small sales (50, then 100 units several weeks later) when you can make a large splash (selling all of your inventory) with specific restock dates which you can take pre-orders on (ie. make money). Right now OPPO can only lose sales/revenue because people can't purchase the product.
The Early Adoption Program is not designed to allow for stockpiling. It is designed as a market study to ensure that the player is indeed ready for widespread public use.
post #2668 of 41204 Old 03-13-2009, 12:19 PM
alfbinet's Avatar
I suspect that this piece won't be sitting around for long! My prediction is that the 83 is going to fly off the shelves. I know I want one and I already have a Pio 51FD (which I am very satisfied with) that will be moved to a second TV.
Chad Billheimer rocks as a ISF Calibrator for Ohio.
Roller Coaster season is upon us. Proud member of American Coaster Enthusiasts (ACE) Woodies Rule!
alfbinet is offline
post #2669 of 41204 Old 03-13-2009, 12:27 PM
winston9332's Avatar
Liked: 31
Do get the feeling there will be a deluge of Pioneer 51s and panny 55s on ebay in about two weeks!
winston9332 is offline
post #2670 of 41204 Old 03-13-2009, 12:30 PM
videoaddikt's Avatar
Quoted: 32 Post(s)
Well, if they jumped into full production then folks would be complaining they did not spend much time evaluating concerns. Ya just can't win, I tell ya!!
Samsung PN51F8500, Emotiva UMC200, Emotiva XPA-5, Samsung BD-H5900 BluRay, Dish Hopper, Furman Elite pf-15 conditioner, Dali Ikon (Ikon6, Vokal2, OnWalls) Outlaw Audio LFM-EX subwoofer.
videoaddikt is offline
Reply Blu-ray Players
105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
