Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 345Likes
Old 03-13-2009, 09:13 PM
Chad T's Avatar
Originally Posted by Rob Tomlin View Post
So you weren't here when Warner announced they were going Blu-ray exclusively?
Yeah, I was, but pretty much ignored most of those threads/posts due to the overbearing emotional content. I take it those threads beat this one out by a long shot?
Wonder if this one sets a record for a hardware related thread?
Have an Onkyo 805 receiver and having trouble setting up Audyssey? HERE is a mini how-to.Click HERE to check out my comparison review of 5 different projection screen fabrics.
Chad T is offline
Old 03-13-2009, 09:15 PM
Steve Goff's Avatar
Quoted: 323 Post(s)
Liked: 152
Originally Posted by Neuromancer View Post
Suggested or proved? There is a major difference between the two.
Shawn Fogg did the suggesting, based on the photos, and he says there are not enough data lines. He has a business modifying players to provide multichannel digital outputs and usually knows what he is talking about. Here is what he said: "The BD83 doesn't do this though, it always feeds PCM to the DACs. I know the original info about the BD83 said otherwise but they have changed this. If you look at the connections feeding the analog board there simply aren't enough data lines for DSD to be fed to the board."
Looking at the posted photo, on the board I think I see traces running to all of the DSD inputs of the multichannel DAC, but I can't trace them back to discrete input pins on the connector from the main board.
Steve Goff
Steve Goff is online now
Old 03-13-2009, 09:16 PM
k2_1971's Avatar
Alaska, Hawaii, and Canada are excluded, so are other countries (due to region differences).
Even if they had accidentally chose someone who was from Alaska, Hawaii, or Canada, the order would be waved because it is against their Terms and Conditions for the Early Adoption Program.
"Due to time and logistics limitations, the Early Adoption Program is open to customers within the 48 contiguous U.S. states. "
Ah well... was hoping they'd change their stance on who they'd send out units to. Luckily I have a fair amount of patience. I can hold out til the official release.
k2_1971 is offline
Old 03-13-2009, 09:22 PM
Petrus's Avatar
Dude, ya live on the North Shore. Go outside!
Life is hard. It's harder if you're stupid.
Petrus is offline
Old 03-13-2009, 09:22 PM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
Basing the suggestion on photos alone is not sufficient. My original post remains unaltered.
Neuromancer is offline
Old 03-13-2009, 09:24 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
Originally Posted by Geof View Post
If they randomly select IP addresses it seems like it accomplishes the task - random locations and random participants.
No, selection is based off of your location on the Blu-ray Interest List. They may weed out incompatible applicants due to e-mail address, country code, IP address or other means before actually running the numbers through Random.org.
Old 03-13-2009, 09:31 PM
winston9332's Avatar
Liked: 31
Location on the blu ray list was limited to country i believe:
http://oppodigital.com/blu-ray-bdp-8...-Register.aspx
winston9332 is offline
Old 03-13-2009, 09:32 PM
Steve Goff's Avatar
Quoted: 323 Post(s)
Liked: 152
Other of his posts may suggest he has hands on experience, too, and was suggesting to others to look at the connectors to confirm what he said.
Steve Goff
Old 03-13-2009, 09:33 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
Yes it was, but that doesn't mean you had not lied. Hell, when I was younger, I would get into porn sites by stating I was 18 (when I was not).
Old 03-13-2009, 09:34 PM
Quoted: 1393 Post(s)
Liked: 587
So what does this mean? Will audio quality suffer?
JimP is offline
Old 03-13-2009, 09:36 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
Looking at photos and determining what it can and can't do is not verifiable proof. Unless he has tried to perform a mod, or used the player and can replicate a sequence which shows a DSD to PCM conversion has occurred over analog, there is no proof.
Until someone can direct proof bu using the actual product, there will be no alteration of the First Post.
Old 03-13-2009, 09:37 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
It would mean that the player always converts DSD to PCM over the analog outputs. That is, there is no native SACD DSD streaming over the analog outputs.
Old 03-13-2009, 09:38 PM
sasser204's Avatar
How is the remote?
sasser204 is offline
Old 03-13-2009, 09:40 PM
k2_1971's Avatar
I'm sunburned man... crispy. I am takin' a break! Heh
k2_1971 is offline
Old 03-13-2009, 09:41 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
Originally Posted by sasser204 View Post
How is the remote?
Fully backlit; well layed out. One of the best remotes I have seen bundled with a player.
rdgrimes's Avatar
Quoted: 1997 Post(s)
Liked: 1328
Originally Posted by FTWMike View Post
From the manual's Audio Setup wizard section (PG-23):
If you connect the player to a receiver supporting HDMI 1.3 and high bit rate audio formats, selecting the Advanced setting is recommended. Menu click sound and Secondary Audio Program are turned off by default to preserve the original quality of the main audio content.
So it appears that if your setup meets the qualification's noted, you can defeat the menu click sounds.
MC
Nope. The disc over-rides those settings if you are using LPCM audio over HDMI.
rdgrimes is offline
Old 03-13-2009, 09:44 PM
sasser204's Avatar
Where can I find an image of the remote?
Old 03-13-2009, 09:55 PM
xradman's Avatar
Originally Posted by rdgrimes View Post
I've noticed that since switching the player to HDMI-LPCM, I have been hearing a lot of the annoying menu button sounds. I expect this is a "benefit" too.
What nitwit decided that button sounds was a good idea? Hmmmm? Prolly the same one that chose BD-JAVA programming.
In defense of the button sounds, with how slow the first generation players were in response to button commands (both red and blue), button sounds were an absolute necessity to prevent machine lockups and unintended responses to multiple button pushes.
Addicted to shiny round discs with HD content
My Home Theater
My Movie Collection
BDP-83 EAP (second group)
xradman is offline
Old 03-13-2009, 10:02 PM
avsinkhole's Avatar
Is this what is in dispute?
(From the BDP-83 manual)
DSD – SACD DSD data is output over HDMI without any conversion. For the analog audio
outputs, DSD data is converted into analog signal directly by the internal DAC. If you use a receiver that supports HDMI v1.2a with DSD over HDMI, or you prefer the sound quality of straight DSD to analog, please select this option.
avsinkhole is offline
Old 03-13-2009, 10:11 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2259 Post(s)
Liked: 2824
DSD - SACD DSD data is output over HDMI without any conversion. For the analog audio
Yes, someone claims to have looked at the actual circuit board and determined that the manual is wrong as regards DSD -> Analog without any intermediate conversion to LPCM.
*reaches for tin-foil hat kept handy for just such occasions*
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
Old 03-13-2009, 10:31 PM
sfogg's Avatar
On the CS4382 for PCM Audio for 8 channels you have
Master Clock Pin 6
L/R Clock on pin 7
SDIN1 Pin 8 (PCM serial data for 2 channels)
SDIN2 Pin 11 (PCM serial data for 2 channels)
SDIN3 Pin 13 (PCM serial data for 2 channels)
SDIN4 Pin 4 (PCM serial data for 2 channels)
Bit Clock Pin 9
For DSD at the DAC you have
DSD-Serial Clock Pin 42
DSDA1 Pin3 (DSD serial data 1 channel)
DSDB1 Pin2 (DSD serial data 1 channel)
DSDA2 Pin1 (DSD serial data 1 channel)
DSDB2 Pin48 (DSD serial data 1 channel)
DSDA3 Pin47 (DSD serial data 1 channel)
DSDB3 Pin46 (DSD serial data 1 channel)
DSDA4 Pin45 (DSD serial data 1 channel)
DSDB4 Pin44 (DSD serial data 1 channel)
NOTE: The CS4382 does not share any pins between DSD and PCM input. It is 9 totally different pins into the DAC for 8 channels of DSD.
To control the CS4382 you also need two lines:
SCL Pin 15 serial control port clock
SDA Pin 16 Serial Control Data
Now look at the ribbon cable feeding the audio board.
+5v
DGND (Digital Ground)
SACLK (Master Clock)
S3CK (bit clock)
SLRCK (LR-Clock)
DGND (ground)
DATA0 (PCM Serial Data for 2 channels)
DATA1 (PCM Serial Data for 2 channels)
DATA2 (PCM Serial Data for 2 channels)
DATA3 (PCM Serial Data for 2 channels)
DGND (ground)
SDIN (PCM Serial Data for 2 channels, 2 channel downmix DAC)
DGND (ground)
SCL (Serial control port clock)
SDA (Serial control data)
DGND (ground)
DGND (ground)
DGND (ground)
DGND (ground)
RST (Reset)
DGND (ground)
Shawn
sfogg is offline
Old 03-13-2009, 10:36 PM
sfogg's Avatar
BTW, anyone that wants to try and 'scope this... play a SACD (with HDMI set to DSD) and then look at pin 7 and Pin 42 on the CS4382.
If you see a clock on pin 7 the DAC is receiving PCM. If you see a clock on pin 42 it is receiving DSD.
If it is PCM the frequency of the clock on pin 7 is the sampling rate of the data being fed to the DAC.
Shawn
sfogg is offline
Old 03-13-2009, 11:09 PM
sharkshark's Avatar
Quoted: 14 Post(s)
ah, good times... *sniff*
sharkshark is offline
Old 03-13-2009, 11:10 PM
Read the FAQ!
Liked: 2824
Well this should take us in some interesting directions no matter which way it turns out!
I wonder whether we'll be able to get a response from any of the EE's at Oppo over the weekend?
--Bob
Old 03-13-2009, 11:12 PM
Dave Vaughn's Avatar
Quoted: 894 Post(s)
Liked: 1341
Agreed 100%. This is on par with the remote that ships with DVDO's Edge, which is excellent. I still use a Universal remote, but the BD83 remote is the best I've seen on a Blu-ray player, and I've reviewed a lot of them.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is offline
Old 03-13-2009, 11:18 PM
sharkshark's Avatar
Quoted: 14 Post(s)
Originally Posted by sfogg View Post
On the CS4382 for PCM Audio for 8 channels you have...
for the record (and I know this is the subject of debate) such incredibly techy posts like this make me supremely happy... I mean, so much is just rambling back and forth, it's nice to see someone with far more Electronics experience than I show a way formally of testing assumptions rather than basing it on hunch (or a manual that's undergoing changes).
It's the upping-the-ante of the nerd level that I find amusing.
Neuro is of course right not to change the first post based on this theory, but it's undeniable that the evidence is compelling. Now, whether or not this is a deal breaker for some is certainly up for debate (being able to -hear- the difference would be up for grabs, certainly). Still, if there is an error/misreprentation, there's clearly enough from your post to at least verify with Oppo engineers just what's going on here...
Old 03-13-2009, 11:50 PM
Rob Tomlin's Avatar
Yes it was, but that doesn't mean you did not lied. Hell, when I was younger, I would get into porn sites by stating I was 18 (when I was not).
Without question, this is the best post in the entire thread!
Rob Tomlin is offline
Old 03-14-2009, 12:07 AM
sharkshark's Avatar
Quoted: 14 Post(s)
yeah, worries me that Neuro had the internet when he was 18... man, I feel old... The worst thing I was doing at that age was lying in order to play Leisure Suit Larry....and that was by answering questions about the Beatles correctly!
Old 03-14-2009, 12:12 AM
vld
vld's Avatar
Quoted: 32 Post(s)
Liked: 44
Damm! I never knew that you could lie on the internet!
vld is offline
Old 03-14-2009, 12:22 AM
da Choge's Avatar
Finally, we get some pizazz to this thread. Bring it on!
da Choge is offline
105d , 83se , Blu Ray Players , Oppo , Oppo Bdp 83 Blu Ray Player
