Official Samsung BD-P1600 Owners/master thread - Page 100 - AVS Forum | Home Theater Discussions And Reviews
post #2971 of 3602 Old 07-16-2010, 07:15 PM
LeeDee's Avatar
Originally Posted by cplcarlman View Post
Is anyone else having issues playing Warner Home Video Blu Ray movies?
The last two movies that would not play in my BD-P1600 were "Invictus" and "Book of Eli". Both of these disks will play the FBI warning and then the previews on the disk. Then the loading screen (a spinning disk with a red line on it) will spin around for a few seconds and then go into a perpetual hang.
After this, the only way to get the player to do anything is to turn it off.
Is there anyone out there that can confirm, or provide a solution, to this issue?
I do have the latest firmware installed, and I have tried the Samsung "hold FF button to reset" trick.
I have the same problem with Invictus: It gets to the load (spinning disk) screen then locks up. The only way out is to turn off the player. No solution.
LeeDee is offline
post #2972 of 3602 Old 07-18-2010, 07:32 AM
JimtN01's Avatar
This is the first BD from Netflix that didn't play right. It goes thru the previews and then basically stops the player - says that there's "no signal". The player does not respond to any orders until stopped and restarted. I'm on 2.09.
I have no other discs to try so I've asked Netflix to send another copy.
Everything else seems to work OK.
JimtN01 is offline
post #2973 of 3602 Old 07-18-2010, 08:10 AM
RedZeppelin's Avatar
FWIW, I just discovered that the 2.09 firmware seems to have fixed the Snow White BD memory problem. Now when I first put in the disc it says "I see you've finally returned" (or something to that effect) rather than "This is your first visit."
RedZeppelin is offline
post #2974 of 3602 Old 07-18-2010, 07:18 PM
jshorr's Avatar
Hello all,
I will add that I seem to have the same problem with new Warner releases from Netflix. In particular Sherlock Holmes and Book of Eli. Both freeze on the spinning disc. Both play fine in my PS3. I'm on the latest firmware. I've sent the info along to Samsung, hopefully they will fix this soon.
jshorr is offline
post #2975 of 3602 Old 07-18-2010, 08:29 PM
hobbes9's Avatar
Originally Posted by jshorr View Post
Hello all,
Interesting. I've been playing Sherlock largely without issue (IIRC) since it came out. At any rate, it's playing well enough right now.
hobbes9 is offline
post #2976 of 3602 Old 07-18-2010, 09:22 PM
jshorr's Avatar
Are you on the latest firmware and using HDMI? I read a thread on a CNET forum where this guy started getting this problem with Terminator Salvation (Warner) only after applying the latest firmware. And he gets the same thing on Sherlock Holmes.
jshorr is offline
post #2977 of 3602 Old 07-19-2010, 06:13 PM
velvet4269's Avatar
I'm having a new issue: I have a Samsung 40" LED TV along with the BD-1600 player. Up until the last month or so, AnyNet+ was working just fine - the TV had no problem recognizing when I turned on the DVD player. Now, all of a sudden, it keeps telling me the AnyNet+ device isn't connected.
AnyNet+ is turned on on both the DVD player & the TV, HDMI cable is connected, Network is connected via the router, both have the most recent firmware. What am I missing?
velvet4269 is offline
post #2978 of 3602 Old 07-20-2010, 05:23 PM
JimtN01's Avatar
Well, they sent another and it was worse - made the 1600 stop cold after the preview! In the meantime we played a Cirque de Soleil OK from beginning to end.
Something weird about the SONY BD that it didn't like.
JimtN01 is offline
post #2979 of 3602 Old 07-21-2010, 01:44 AM
in0wh3r3ul1v3's Avatar
Anyone else having issues with Inglorious Basterds? Never had a problem before, but the disc won't even start playing now. I have to shut the player down because it freezes.
in0wh3r3ul1v3 is offline
post #2980 of 3602 Old 07-21-2010, 09:53 AM
milou6's Avatar
Try disabling BD-Live. Just a thought.
milou6 is offline
post #2981 of 3602 Old 07-21-2010, 10:08 AM
cdnscg's Avatar
Quoted: 299 Post(s)
Liked: 50
I doubt it was the BD. I bought both the 1600 & 3600 because they were competitively priced (inexpensive). Both are erratic, and have the same different problems from time to time. Lip sync issues, scenes that speed up, and just not playing discs that played earlier. They are in different rooms, hooked to different equipment. As I stated earlier, I guess you get what you pay for. Next time I'll shell out the extra $, and buy a higher end unit.
cdnscg is offline
post #2982 of 3602 Old 07-21-2010, 10:15 AM
MrHT's Avatar
Quoted: 68 Post(s)
Same here. In fact, I sold my 1600, but still kept my 3600 for the bedroom. Never use it anymore ever since I bought a replacement for my 1600. It just sits in my bedroom, lol. But yeah, both my 1600 and 3600 had the same problems and allergic reactions to the firmware updates. This is why the excuse that I got a lemon is VERY questionable.
MrHT is offline
post #2983 of 3602 Old 07-21-2010, 10:24 AM
cdnscg's Avatar
Quoted: 299 Post(s)
Liked: 50
Did you replace the 1600 with the Sony 360, and how to you find it's loading time & stability. I have a 300, but the loading time is terrible.
cdnscg is offline
post #2984 of 3602 Old 07-21-2010, 10:40 AM
MrHT's Avatar
Quoted: 68 Post(s)
Yes, the Sony BDP-S360 is what I replaced it with. Loading time is slow, but stability is excellent. It's going on 6 months now and I still haven't encountered one problem with it. I use it daily and it never froze, hiccuped, had any lip sync issues, or any other problems. It's been rock solid. And I only had to update the firmware once, which was when I first bought it.
I was going to buy another one to replace the 3600, but then I realized that I really don’t watch much in the bedroom. So going through the hassle of selling it and then buying a new player would be too much and not worth it. I can make do with one player. I’ll probably just use the 3600 as a secondary DVD player or something since it seems to have no problem playing DVDs.
MrHT is offline
post #2985 of 3602 Old 07-21-2010, 05:48 PM
stevelion's Avatar
I have the exact same issue with "Invictus" and "Book of Eli" in my BDP-3600. Firmware version 2.09. The movies play fine on my Panasonic player. I contacted Samsung a couple weeks ago about Invictus and they were no help...."try reflashing"...followed by "...if that doesn't work, must be your player and you'll have to send in fro repair." I'm calling them again.
stevelion is offline
post #2986 of 3602 Old 07-24-2010, 11:32 AM
div2's Avatar
I haven't upgraded the firmware in my BDP-1600 for over one year and I haven't experienced any problems with the playback of any discs. At this point I'm reluctant to rock the boat by upgrading to version 2.09. Any contrary opinions? Thanks!
div2 is offline
post #2987 of 3602 Old 07-24-2010, 02:42 PM
lmacmil's Avatar
Quoted: 65 Post(s)
Liked: 41
I watched Invictus last week on my 1600 firmware 2.05 and had no problems.
lmacmil is offline
post #2988 of 3602 Old 07-24-2010, 04:12 PM
MarkEHansen's Avatar
Quoted: 23 Post(s)
I'm in roughly the same boat. I haven't found any reason (yet) to upgrade, so I haven't.
MarkEHansen is offline
post #2989 of 3602 Old 07-25-2010, 10:17 AM
div2's Avatar
Thanks for the response; I'm sticking with whatever firmware version that I last installed...
div2 is offline
post #2990 of 3602 Old 07-25-2010, 11:41 AM
cheapie's Avatar
Originally Posted by carbon summit View Post
+1
I was looking forward to seeing if the new update would have the new internet stuff that the 2010 line up has. I thought I read the new ones had hulu but I just read some reviews and I guess it doesn't. Thats what I really would like to see added.
What are the odds we'll be getting hulu plus on this machine? If we did, I think I'd cancel my dtv.
cheapie is offline
post #2991 of 3602 Old 07-25-2010, 02:59 PM
hobbes9's Avatar
Just about nil. Don't even know that any of the latest generation are going to be getting it but the highest end (kind of like what they did with the 25x0 when Netflix first came out). Heck I don't think I've read anything about even the highest end current gen players getting it?
hobbes9 is offline
post #2992 of 3602 Old 07-28-2010, 08:45 AM
JimtN01's Avatar
Reading here makes you watch for problems. I've had none except the two tries with Extraordinary Measures. Invictus (from NetFlix) played fine except that you were forced to see all the previews.
Last night we put in August Rush and got picture but no sound. No sound on Netflix streaming either. Turned the player off and back on, and sound was OK. Just hope that doesn't portend some kind of failure!
JimtN01 is offline
post #2993 of 3602 Old 07-28-2010, 12:35 PM
I've had the occasional odd issue such as that too that requires a reboot, and my player is still going strong (/knocks on wood). I wouldn't worry about it unless it starts happening frequently.
post #2994 of 3602 Old 07-29-2010, 10:54 PM
LowBudget5.1's Avatar
Anyone else have trouble with audio sync and playback issues with the new Clash of the Titans Blu-ray? I bought the move brand new yesterday and am having all kinds of problems with the 2.09 firmware. It loses audio when the pull Zeus's statue down at the beginning. And when they first start off on the trek to the witches in the woods the audio gets completely out of sync. I didn't even bother finishing it until I can figure out what the deal is.
LowBudget5.1 is offline
post #2995 of 3602 Old 08-03-2010, 09:43 AM
sauron256's Avatar
I'm having the same playback issue after "successfully" flashing to 2.09 this weekend via the web portal. My copy of District 9 (Sony Pictures) has always played fine on my P1600 until last night. This latest flash pretty much appears to be the cause of my play-back issues. I get the initial FBI warning message when I run the BD disk followed by no signal to the TV - almost like it's an HDCP handshake issue.
I have tested Avatar on my player and it works fine with the 2.09 firmware. Based on this, it has the be this current firmware version causing my problems.
I will try to re-flash it tonight via ISO file. It looks like the folks who did it that way are having better luck.
Is anyone else having problems with Sony disks - in particular District 9?
sauron256 is offline
post #2996 of 3602 Old 08-03-2010, 11:05 AM
Originally Posted by sauron256 View Post
. . .Is anyone else having problems with Sony disks - in particular District 9?
Just saw your post. I have D9 but haven't tried it since I updated to 2.09. I'll try it and post results.
post #2997 of 3602 Old 08-03-2010, 02:36 PM
samsurd2's Avatar
I just received Invictus from Netflix. I saw this post so I popped the disk into my BD-P1590 which has been upgraded to 2.09. I had no problems with it loading and playing.
samsurd2 is offline
post #2998 of 3602 Old 08-03-2010, 05:25 PM
j2benz's Avatar
Have the same problem too. Movies that have the same behavior as what cplcarlman stated are: "Body of Lies" and most recent movie "Clash of Titans"
I just have the spinning discs logo then it would stop. My player would stay like that. Have to turn off player.
All other blue ray movies are playing.
Hope there will be a firmware fix on this.
j2benz
j2benz is offline
post #2999 of 3602 Old 08-04-2010, 08:25 AM
sauron256's Avatar
Well, I tried the last ditch re-flash using the ISO file. It went very smoothly and completed w/o a hitch.
However, D9 still refused to play. Firmware 2.09 is not looking good. I've got a new Oppo BDP 80 on the way to replace this Samsung POS.
post #3000 of 3602 Old 08-04-2010, 10:46 AM
MrHT's Avatar
Quoted: 68 Post(s)
That's kinda harsh to say, no?
MrHT is offline
Reply Blu-ray Players
Samsung , Samsung Bd P1600 Blu Ray Player , Blu Ray Players , Samsung Ln32a330 32 Inch 720p Lcd Hdtv , Xbox 360 Media Remote
