Official Samsung BD-P1600 Owners/master thread - Page 113 - AVS Forum | Home Theater Discussions And Reviews
post #3361 of 3602 Old 03-18-2011, 11:14 AM
lmacmil's Avatar
Quoted: 65 Post(s)
Liked: 41
Originally Posted by bob650 View Post
I am using a Rosewill RNX-N1 which I bought from NewEgg about a year ago for $30 and it works.
I have a Rosewill RNX-G1 so I will give it a try. Thanks.
lmacmil is offline
post #3362 of 3602 Old 03-18-2011, 08:26 PM
lmacmil's Avatar
Quoted: 65 Post(s)
Liked: 41
My RNX-G1 didn't work on my first attempt. Can't find my router for some reason. Gotta play around some more.
lmacmil is offline
post #3363 of 3602 Old 03-19-2011, 07:58 AM
brodermo's Avatar
Originally Posted by brodermo View Post
Bricked my 1600 too going from 2.13 to 2.15. I've had no other problems with this player for 2 years and have done multiple FW updates. I'll likely send the unit in Monday if unable to find any other fix. They said they'll send a refurb if unable to fix mine
Very interesting, wonder if they determined the last update was bad and pulled it; there's no other references to it on their webpage. Since my player is now stuck at "LOAD" I don't think I can install this again, but at least giving it a shot before mailing in my player for repair.
Got back my player and it's working fine after repair. Samsung paid shipping both ways. I shipped it on March 7th and received it back on March 17th.
Came back with 2.15 firmware and prompts me 2.16 is available for download. I'm certainly being leary about upgrading now and will wait a few months...
brodermo is offline
post #3364 of 3602 Old 03-19-2011, 01:13 PM
cyberpine's Avatar
I'm on Windows 7 pro x64 and can stream on my PS3. Can I see pics and play music from my network through the Samsung bpd1600? How. Right now I'm on the same network and can stream netflix directly with no problem.
If not, can you recommend a DVD player that can play netork files and do netflix?
cyberpine is offline
post #3365 of 3602 Old 03-19-2011, 07:20 PM
mrfranc's Avatar
No, I believe. I have the BDP1590 witch it's the same and it doesn't.
Take a look at: www.oppodigital.com model BD-P93 witch is my principal BD player.
mrfranc is offline
post #3366 of 3602 Old 03-19-2011, 10:09 PM
Bishop_99's Avatar
I turned on my Blu-ray player and I was notified that the 2.16 version was available. Since the 2.15 firmware brought on the problem that I couldn't play the new Fox Blu-ray movies, I upgraded to the 2.16 to see if it fixed the problem. Thankfully I can now play the Fox Blu-ray movies I was having problems with. The firmware has fixed the problem. I'm happy about that
Bishop_99 is offline
post #3367 of 3602 Old 03-20-2011, 07:39 AM
cyberpine's Avatar
Does that model BD-P93 support DLNA and work with widows media stream.. shame to have to upgrade.
Here's the manual link for the BD-P1600 AND 1590, i did not see any reference to windows or DLNA
Samsung BD-P1600 MANUAL PDF
post #3368 of 3602 Old 03-20-2011, 09:46 AM
hartlenb's Avatar
BDP1600 can't play network files. BD-C5500 has DLNA support.
hartlenb is offline
post #3369 of 3602 Old 03-20-2011, 10:08 AM
mrfranc's Avatar
Yes, it does. I use Twonky as DLNA server on my Win7, because my music it's store as flac and WMP doesn't supported. I also use Playon to stream Hulu, Revision shows, etc. to the player.
mrfranc is offline
post #3370 of 3602 Old 03-20-2011, 04:41 PM
lmacmil's Avatar
Quoted: 65 Post(s)
Liked: 41
My G1 did not work. Apparently does not have the same RALink chipset as the Samsung and the N1.
lmacmil is offline
post #3371 of 3602 Old 03-20-2011, 07:34 PM
bob650's Avatar
My RNX-N1 worked right out of the box, all I had to do was go through the wireless setup menu in the Samsung.
I don't know for sure, but I believe the N1 (as opposed to G1) makes some sort of difference. I read something about the particular chipset that was used in the N1 matches the Samsung. Might look at this Amazon link, it lists a bunch of reviews talking about Samsung compatability:
http://www.amazon.com/Rosewill-RNX-N...0671005&sr=1-1
Again, I'm not sure of this latest version, but my RNX-N1 from a year ago works perfectly. Mine is white, but this newer one is black.
bob650 is offline
post #3372 of 3602 Old 03-20-2011, 10:06 PM
Audiorookie's Avatar
Question - I finally bought some decent front speakers and plan to listen to a lot more music now.
I don't own a CD player but I do have my Sammy Blu-Ray. I know it plays audio CDs - is there any reason to get a separate CD player to push the music through my AVR or is the Blu-Ray player going to read and send the digital content exactly the same as a CD player?
Audiorookie is offline
post #3373 of 3602 Old 03-20-2011, 11:53 PM
Kuningas's Avatar
BD-P1600 can read CD-Audio but can not play music at all. If you want quality sound buy CD player (Onkyo, Rotel, Cambridge Audio, NAD, etc).
Kuningas is offline
post #3374 of 3602 Old 03-21-2011, 07:04 AM
RedZeppelin's Avatar
Just out of curiosity, on what do you base that statement? I've always found music to sound just fine on the 1600. Then again, while I enjoy music and am picky about my sound system, I'm not "a $300 audio cable sounds better than a $10 cable" picky, so perhaps a frame a reference is in order.
RedZeppelin is offline
post #3375 of 3602 Old 03-21-2011, 09:12 AM
Kuningas's Avatar
On comparing with CD players. If you'd have one you never listen music on samsung.
Kuningas is offline
post #3376 of 3602 Old 03-21-2011, 09:38 AM
lmacmil's Avatar
Quoted: 65 Post(s)
Liked: 41
Here is what Crutchfield says.
Q: How good are Blu-ray and DVD players at playing music CDs?
A: Blu-ray and DVD players make excellent CD players, and current models can also play audio CD-Rs and CD-RWs and MP3 CD-R/RWs you record yourself with a CD recording deck or computer CD-R/RW drive. Some players can also play high-resolution audio, like SACD, DVD-Audio, or both.
A Blu-ray or DVD player's advanced disc transport and digital-to-analog converters are designed for the demanding task of reading and processing the huge amounts of audio and video information on Blu-rays and DVDs. By comparison, playing a music CD is a piece of cake. Based on our experience, these players sound at least as good as a typical CD player.
You can bet that since Crutchfield is in the business of selling audio components, if they thought you needed a CD player in addition to a Blu-Ray player, they would say so.
lmacmil is offline
post #3377 of 3602 Old 03-21-2011, 10:24 AM
Al Sherwood's Avatar
Quoted: 739 Post(s)
Liked: 271
Other manufactures use RALink chipset, is there anyway to determine which is the one that works? (other then trial and error).
Having said that I just bought a MSI wireless dongle and although I don't know what chipset it has the included software is by RALink... I'll give it a try and report back.
Al
Al Sherwood is offline
post #3378 of 3602 Old 03-21-2011, 11:47 AM
mrfranc's Avatar
The DAC and clock used on the 1590/1600 are not good enough for serious music listening. Even if you using HDMI or any digital connection for that matter there too much jitter. After listening for some time from the Samsung it becomes fatiguing.
mrfranc is offline
post #3379 of 3602 Old 03-21-2011, 02:57 PM
. . . After listening for some time from the Samsung it becomes fatiguing.
I feel that way about Pink Floyd.
Again, I feel like a frame of reference would be useful here.
There are some who do things like coating their speaker wires with extra virgin olive oil from the Abruzzo region of Italy in order to prevent frequencies on the extreme ranges from escaping (Because as we all know, oil from the Toscano region tends to lock in the higher frequencies while letting the low end escape, therefore creating an unbalanced sound.)
Then there are those who think 8-tracks sound great.
I'm somewhere in the middle, a few notches above* people who buy Home Theater in a Box(tm) systems. I'm picky, but I'm also not rich, so I buy the best stuff I can afford. I've listened to a lot of music on my 1600 ranging from rock to classical to jazz, and "fatigue" is something I've never experienced.
If you're closer to the first group I mentioned then obviously your reaction will be different, but if you're anywhere near my group I think you'll be perfectly pleased with CDs on your 1600.
*By "above" I do not mean "better" in a snobbish way. Nor do I mean to besmirch any type of audiophile. I'm just trying to create a classification system that will help put into context opinions about the 1600's capabilities (or lack thereof) as a CD player.
post #3380 of 3602 Old 03-21-2011, 04:33 PM
2.16 fix update
So far with 2.16 installed I've not been able to reproduce the audio sync problem I was having with Iron Man 2. Before when watching it with audiophile mode selected the audio would lose sync within a few seconds of playing. I played bits of several chapters today, some more than once, and it never lost sync. Maybe 2.16 fixed it.
post #3381 of 3602 Old 03-21-2011, 04:57 PM
lmacmil's Avatar
Quoted: 65 Post(s)
Liked: 41
Unless the listening tests are conducted in such a way that the listener does not know which source he is listening too, they aren't really valid. Everyone is biased by their perceptions.
lmacmil is offline
post #3382 of 3602 Old 03-21-2011, 04:57 PM
mrfranc's Avatar
I get you. I'm not rich either. What I use for CD player where I have the Samsung is an old DVD (Oppo 980) player that happens to play SACD and have in my opinion better sound.
mrfranc is offline
post #3383 of 3602 Old 03-21-2011, 05:30 PM
Right. Just like wine snobs can be tricked by cheap wine in bottles with expensive labels. I'm just talking generalities, not scientifically accurate blind tests.
post #3384 of 3602 Old 03-21-2011, 06:29 PM
samsurd2's Avatar
The real kicker is to keep your speaker wires when not in use in an air tight container along with a large wedge of imported provolone cheese from the Lombardia region. Don't use provolone from the Veneto region as it doesn't preserve the audio properties of the wires over as long a period of time.
samsurd2 is offline
post #3385 of 3602 Old 03-21-2011, 08:50 PM
lmacmil's Avatar
Quoted: 65 Post(s)
Liked: 41
The Ralink 2870 is used in both the Samsung and Rosewill RNX-N1 adapters which is apparently why the Rosewill N1 works but the G1 does not.
lmacmil is offline
post #3386 of 3602 Old 03-26-2011, 05:36 PM
I was watching an episode of Star Trek TOS from the Season 2 Blu set and the audio jumped out of sync by a second or two. Obviously not all of the bitstream audiophile issues have been fixed by 2.16. Sigh.
post #3387 of 3602 Old 03-27-2011, 08:38 AM
Quoted: 739 Post(s)
Liked: 271
Either I am doing it wrong or the MSI adapter I have does not have that chipset, the TV didn't even recognize that I had plugged it in?
Al
post #3388 of 3602 Old 04-02-2011, 08:07 AM
Milwaukeesk's Avatar
Quoted: 24 Post(s)
Does anybody have a copy of firmware version 2.15? I just upgraded to 2.16 and almost nothing will play so I want to try to roll it back. Thanks.
Milwaukeesk is offline
post #3389 of 3602 Old 04-03-2011, 07:28 AM
cgking114's Avatar
I would like this also. I can play DVD's but BluRays skip like carzy since 2.15 and 2.16. Any help would be appreciated.
cgking114 is offline
post #3390 of 3602 Old 04-04-2011, 12:37 PM
MrHT's Avatar
Quoted: 68 Post(s)
Call Samsung and report the issue....
MrHT is offline
Reply Blu-ray Players
Samsung , Samsung Bd P1600 Blu Ray Player , Blu Ray Players , Samsung Ln32a330 32 Inch 720p Lcd Hdtv , Xbox 360 Media Remote
