Official Samsung BD-P3600 Owners/Master thread - Page 109 - AVS Forum | Home Theater Discussions And Reviews
post #3241 of 3254 Old 12-18-2012, 11:25 AM
luckyrod's Avatar
I used to be able to go back to an older version of software by plugging in the USB with the older version on it while the machine was on. After 2.22 I could no longer do this as the player would tell me that the software is old. Sorry to have to tell you this.
luckyrod is offline
post #3242 of 3254 Old 12-18-2012, 12:30 PM
Jetrell69's Avatar
Originally Posted by luckyrod View Post
Hey Jetrell69 can you still see shared folders on your computer with 2.22?
I don't use my machine this way but if I put a disc in with folders I can still see them. I hope that helps give some encouragement.
http://www.justanswer.comwww.dog.justanswer.com/recorders-and-players/6w0ye-ra-amm.html
^^^^a little blurb about factory reset ...... you can try it and go from there.
Jetrell69 is offline
post #3243 of 3254 Old 02-17-2013, 06:05 PM
bcrules82's Avatar
Question: When streaming content off a PC has anyone encountered problems with it playing content at the wrong frame rate?
Since this is an American box (NTSC) my best guess is that it is playing 25fps content (PAL) at 30fps, causing everything to be a bit faster. Still watchable, but all the voices are obviously higher pitched.
bcrules82 is offline
post #3244 of 3254 Old 06-10-2013, 12:02 PM
scrappinJudy's Avatar
ince the last update (I don't use this BD player often!), my Network Connection Test works; all tests pass.
However I cannot use any of the apps -- Netflix, Pandora, YouTube -- they all say system not connected to internet.
suggestions????
scrappinJudy is offline
post #3245 of 3254 Old 06-11-2013, 03:32 PM
ok, got Netflix to work yesterday, very very slowly. for about 2 minutes (streaming from my queue).
then it quit & gave me an error message!
still hoping for some suggestions!
post #3246 of 3254 Old 08-23-2013, 10:33 AM
bigdaddyhen's Avatar
Living in a temporary situation, so my setup is a bit different than normal. I have the samsung BD-P3600 hooked up to a Visio XVT423SV via hdmi. Just doing audio through the tv. Issue I am having is the volume keeps fluctuating when watching movies. I don't have any sound issues watch cable through a Motorola cable box (using just hdmi again), nor do I have issues streaming through the tv (Netflix on wireless through the tv, not the P3600). I tried swapping cables and inputs with the cable box, but doesn't help. Is there something in the settings I need to do differently, or is there an issue with the unit ? Didn't really use the player all that much before, but previously had it running through a 5.1 receiver via optical with no problems that I can remember.
bigdaddyhen is offline
post #3247 of 3254 Old 08-23-2013, 03:06 PM
Super Moderator
teachsac's Avatar
Quoted: 861 Post(s)
Liked: 1397
See if your TV has a Dolby Volume (or equivalent) setting. That will level out te volume throughout the movie.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #3248 of 3254 Old 08-29-2013, 05:51 PM
gajahduduk's Avatar
Mine stopped playing blurays, would not delete BD-Live content, and could not be reset by any method. Chucked it in the garbage.
gajahduduk is offline
post #3249 of 3254 Old 10-28-2013, 07:33 PM
The_Nephilim1's Avatar
Quoted: 47 Post(s)
Hi All,
I have this player hooked to my Marantz 4001 AVR w/7.1 Analog Connections. Please don't ask me to use the HDMI as it broke .. wink.gif
I was wondering since I use the 7.1 inputs on the receiver what would be the best way set the Speaker levels .. I do not have Test tones on the Receiver for 7.1 channel input.. I have test tones on the player but they go so fast it is utterly useless..
I was thinking I may need to get a Blu ray Test disc. I seen AIX has one is this anygood??
The_Nephilim1 is offline
post #3250 of 3254 Old 02-07-2014, 03:15 PM
tomalamix's Avatar
Hy everyone...
As i ran through the web i realized that, correct me if i miss understood, this player have the hardware it needs to put outside proper 3D images. Its fair enough to think that there will be a FW from Samsung (less likely) or a hack to put it working (more likely)?
Thanks for your contribution
tomalamix is offline
post #3251 of 3254 Old 02-07-2014, 03:58 PM
Super Moderator
teachsac's Avatar
Quoted: 861 Post(s)
Liked: 1397
The 3600 will not support Blu-ray 3D, nor will it ever. It does not have the hardware specs to support it.
S~
tomalamix likes this.
teachsac is offline
post #3252 of 3254 Old 02-08-2014, 06:56 AM
tomalamix's Avatar
thanks for a prompt reply!
So i have to put it away somewhere. i have bought a samsung F7000 lcd with 3d and i want to take all the juice from it and this player wont help doing that. so im forced to retire it. there is some player you can point me? I dont want to spend a lot of €€ on it like this bd-3600, just a plain and simple 3d player with optical output and thats it.
thanks again!
Tom
post #3253 of 3254 Old 08-07-2014, 09:26 PM
jeffbon's Avatar
I'm confused. I have a Samsung BD-P3600 1080p Blu-Ray Disc Player connected to a Samsung HL67A750 LED DLP TV.
My standard DVDs are either in the center of the screen with black bars on all 4 sides (Last of the Mohicans) or run the entire width of the screen with black bars on the top and bottom (Gladiator).
Is this normal upconverting?
jeffbon is offline
post #3254 of 3254 Old 08-08-2014, 04:08 AM
chroma601's Avatar
It depends on the DVD mastering. "Widescreen" on the box doesn't necessarily mean Anamorphic. The DVD case should say "Enhanced for 16 x 9 TVs" to indicate an anamorphic presentation, which will still have letterboxing with 2.24 aspect ratios. Blu Ray presentations are always designed for widescreen TVs, so you won't get the postage stamp effects from the outmoded 4 x 3 letterbox some older DVDs employed.
Sent from my SCH-I535 using Tapatalk
Aibohphobia: The fear of palindromes
chroma601 is offline
Reply Blu-ray Players
