Official Panasonic DMP-BD60/80 Owners Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
Old 04-14-2009, 05:48 AM
Paul Logan's Avatar
Quoted: 28 Post(s)
Click on the you tube video and it will fill the screen
Paul Logan is offline
Old 04-14-2009, 07:03 AM
scottyb's Avatar
Quoted: 20 Post(s)
Originally Posted by dandan123 View Post
Why do all blu ray players look cheap and plasticy ?
I was hoping the BD80 would look better but unfortunately no.
Try the Denon players.
scottyb is offline
Old 04-14-2009, 09:29 AM
boylan13's Avatar
Quoted: 17 Post(s)
Originally Posted by JJHXBR View Post
I already tried this as it seemed like a logical fix.
Unfortunately it makes no difference on or off.
Still changes the 7.1 sound setting every time the unit powers off.
I am totally bummed that this is not working correctly, as blu-ray picture quality on the Panny 80 is much better than my previous Sony S550.
At this point I am going to send it back, and give the New Oppo 83 a try.
You should at least contact Panasonic to report the problem first. Is there a specific Blu-ray title that you can reproduce the problem with? If you let me know specific titles and chapter or time marks into the movie where the problem is most obvious after turning the player on and off I can try to test this myself on our BD80 (assuming I have the title) to see if I see/hear anything similar. If not, then you may just have a bad unit that needs to be replaced (most likely scenario).
-CB
Chris Boylan
Home Theater Editor
Big Picture Big Sound
boylan13 is offline
Old 04-14-2009, 09:52 AM
rveras's Avatar
Boylan13,
I remember an issue involving Panasonic's BD35/55 players and Onkyo receivers. I believe it was something related with 7.1 LPCM soundtrack if I recall correctly. I remember you telling us that Panasonic was working with Onkyo on this issue. Do you know if anything happen?
rveras is offline
Old 04-14-2009, 12:49 PM
jmaccool's Avatar
Originally Posted by BIslander View Post
Sorry, but I don't think I can be of further assistance. Perhaps someone else can help.
I appreciate your effort but this in not something that I can get from a manual or from someone's logic. I would guess that someone will have to have had this issue, resolved it and then provide the answer. Perhaps I will resolve it then I can post it here for future assistance. Again thanks!!
jmaccool is offline
Old 04-14-2009, 02:08 PM
Raymond42262's Avatar
I'll try it when I get home tonight.
If I get a hdmi / dvi cable....is that what I need to use the tv as a computer
monitor?
Raymond42262 is offline
Old 04-14-2009, 06:16 PM
Roger_M's Avatar
I'm curious. I've got the BD-60 but I see many mentions of the DMP-BD605. What is the difference?
Roger_M is offline
Old 04-14-2009, 06:39 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
BD605 is only sold at Costco/Sam's Club. No difference.
Foxbat121 is online now
Old 04-14-2009, 07:17 PM
benjosevilla's Avatar
It comes with a short HDMI cable in the box. I'm not sure if the BD-60 comes with one.
benjosevilla is offline
Old 04-14-2009, 07:50 PM
mariofer's Avatar
The regular BD60 (BB, Cruchfield) does not bring and HDMI cable, just a set of analog cables.
mariofer is offline
Old 04-15-2009, 05:16 AM
rgathright's Avatar
Quoted: 216 Post(s)
Liked: 26
Originally Posted by millerwill View Post
Look, there are a bunch of old family tapes, etc., and I'm not going to the hassle of converting them all to cd. And it would be more convenient to have a tape player in the Panny BR than finding an old separate box on Ebay. Provided, of course, that having the VHS player in the BD-70 doesn't in some way degrade the BD performance; but from what I hear the BD-70 is identical to the 60 except for the addition of the tape player.
I would like to know if anyone has tried this one out also? I have a ton of VHS tapes that I was thinking of converting to disk. But the copy-writing issues has been my hold-up.
Sony XBR-75X850C - Living Room
Samsung UN60J6300AFXZA - Bedroom
rgathright is offline
Old 04-15-2009, 08:35 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 265
On any inquiry to Panasonic, their reply was that the 70 will be available in May.
millerwill is online now
Old 04-15-2009, 08:38 AM
Road Rash's Avatar
My audio cables will be delivered today so I'll be able to hook up and play around with the 5.1 analog later on. My old H/K av receiver does not do the 10-15db sub boost so I'm sure I'll be doing a lot of fiddling around with the settings to get it to sound good. At least I have a lot of headroom to go up from my normal setting on my Klipsch sub. I'll just have to remember to turn it back down when I'm done.
If I can get the analog set up correctly I'll use it when I'm watching a movie. If the rest of the family uses my BD80 I do have the remote set up with coax digital as the default.
"If you know everything, you must be misinformed"
^ old Japanese proverb ^
Road Rash is offline
Old 04-15-2009, 09:09 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Even without a specific SW boost in your AVR, you may be able to set up your receiver to work for both analog and digital without needing to change the sub volume when switching back and forth. After increasing the sub volume to provide the boost for analog, try re-calibrating the digital side. That will likely mean lowering the digital sub output by the same amount you increased it at the sub.
BIslander is offline
Old 04-15-2009, 10:42 AM
dcassidy's Avatar
Has anyone had a problem with the BD80 whereby a DVD+RW or DVD+R created with the AVCHD is coming back with 'This disk is incompatible' - THe supplied SD-DISK with the unit plays AVCHD files OK.
I used tsMuxeR_1.9.1 to create the structure from a .mkv file and then used ImgBurn 2.4.4.0 to write to the disk. I tried both Create ACCVD and Create Blu-Ray in the tsMuxR and this darned error message consistently comes back.
I feel I am just not carrying out one simple step ?? Maybe one of you also had this problem and found a magic moment of EUREKA that you might like to share ;-)
Cheers,
Desmond.
dcassidy is offline
Old 04-15-2009, 10:43 AM
methos75's Avatar
Quoted: 79 Post(s)
Liked: 32
I purchased a BD60 last night, and I need to know if their is an way to force 24p playback from it. It will not pass on a 24p signal to my receiver, even though my PS3 and HD-DVD player have no issues doing so.
methos75 is offline
Old 04-15-2009, 11:32 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
Cheers,
Desmond.
If I'd take a guess, your authoring tool does not create correct AVCHD structure. Most early software tools create wrong type of 'AVCHD' which is actually 'BD on DVD', not AVCHD. Most players now no longer support BD on DVD type disc, only the true AVCHD disc which has the different directory structure. There is a link to a web site explain the diferences posted early in this thread. Do a search.
Old 04-15-2009, 11:51 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 265
Since I will be using HDMI for audio and video, I have been thinking that I would go for the BD60, since the only thing the 80 seemed to offer over it was 7.1 analog audio, which I will not use.
However in looking at the User Manual, there is one feature the BD80 has, that the 60 doesn't, which seems like it might be useful: 'High Clarity Sound'. This is an option to turn off the power to the analog video circuits (i.e., the Component video output) if one is using HDMI, and this is said to produce less interference for the audio channels, and produce a higher quality audio.
I would be very interested if those of you with the BD80--and use HDMI connections--would try out this feature; i.e., listen to the audio with the 'High Clarity Sound' option 'on' and with it 'off', to see if you can perceive any difference. Would greatly appreciate it. If there's no diff, I will stay focused on the BD 60, but if there is a significant improvement I might consider the 80. TIA!
Old 04-15-2009, 12:03 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
I think you looked at it from the wrong perspective. What I got from this is that if you use HDMI for video and analog 7.1 for audio, turning off analog video circuitary may potentially benefit analog audio quality.
If you also use HDMI for audio, the interference from analog video circuity will not have much impact on digital audio at all. That's why it is not available on BD60.
Old 04-15-2009, 12:05 PM
krisjan's Avatar
The Panasonic players will not force 24fps. This option will only be available to select in the player menu if the display/projector advertises its capability via EDID.
krisjan is offline
Old 04-15-2009, 12:23 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 265
Ah, thanks Foxbat! What you say makes a lot of sense. I had wondered how current in the analog video circuitry could affect the digital audio output ("it's all just 0's and 1's"), and your explanation points out that it really wasn't referring to this.
So this simplifies my choice, to just focus on the BD60.
Old 04-15-2009, 01:08 PM
methos75's Avatar
Quoted: 79 Post(s)
Liked: 32
Ah that sucks, I know my receiver can pass 24p no problems because my other devices do it, the Panny just will not though for what ever rerason.
methos75 is offline
Old 04-15-2009, 01:11 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
If your receiver is an Onkyo, it is a known issue (for Onkyo) and there is a way to work around it by turning off OSD from receiver IIRC.
Old 04-15-2009, 01:13 PM
methos75's Avatar
Quoted: 79 Post(s)
Liked: 32
No its a Sony ES5200
methos75 is offline
Old 04-15-2009, 02:26 PM
boylan13's Avatar
Quoted: 17 Post(s)
Originally Posted by rveras View Post
Boylan13,
Yeah, Panasonic told me Onkyo had a fix for it and that they (Onkyo) would contact me about it directly. That was 5 months ago.
The issue was that the BD35/BD55 would output 7.1-ch PCM soundtracks as 7.1-channel PCM (correct behavior), but the Onkyo xx5 series receivers (and their Integra counterparts) would omit the rear speaker information (the rear two channels of the 7.1-ch mix would be silent). Panasonic determined that they were sending a valid PCM bitstream but the Onkyo receivers were not decoding it properly. It only affected actual native PCM 7.1 soundtracks (like "3:10 to Yuma") and I think it was fixed in Onkyo's xx6 model line (e.g., works fine in the 606, 706, etc.). Also, there was a work-around - if you turned off 24p output (in the player), the rear speaker sounds magically re-appeared!
I didn't test this with the BD80 to see if it still occurs (I expect it does), because I no longer have the 605 receiver in my review system. I have no idea whether Onkyo has made any kind of fix available for owners who want to ship their receivers in for an update. The Onkyo site seems to still only be mentioning that early firmware upgrade for the 605 to support DTS-HD and Dolby TrueHD decoding (old news!).
-CB
Chris Boylan
Home Theater Editor
boylan13 is offline
Old 04-15-2009, 02:41 PM
Road Rash's Avatar
I spent some time this afternoon setting up the analog and while I need to tweak it some more I can say I'm pleased with the results. There doesn't seem to be much of a difference in quality but the analog is better than the core DD/DTS. I notice a bit better separation and an overall cleaner sound.
I didn't think of that and I'll give it a go. Thanks.
Old 04-15-2009, 03:01 PM
carledwards's Avatar
I've had the opportunity to run the BD80 through its paces lately including a number of recent blu-ray titles and everything has been spot-on perfect. Recently released discs included "Slumdog Millionaire" and "The Day the Earth Stood Still." Flawless performance. I'm particularly pleased with this player's sound and color rendering, too. I could swear that reds, in particular, are more vivid when compared to the BD30 and my Tosh XA2. I'm sure it's all in my mind, however. Probably an example of post-purchase justification! Still, this is a very good BD player, I think.
In all, a good Profile 2.0 upgrade from the BD30. And I was very happy with the 30!
BTW, I'm using a firmware-updated Yamaha 1800 (w/Sony sub and a combination of Michael Green and Yamaha speakers) and a Sony KDS55A2020. Everything via HDMI to the Receiver and on to the TV.
carledwards is offline
Old 04-15-2009, 03:05 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 265
Very nice! Any comments yet on pq of unconverted dvd?
PS Question: if you connect everything via HDMI, can you say why you got the 80 rather than the 60?
Old 04-15-2009, 04:26 PM
joerod's Avatar
Quoted: 613 Post(s)
Liked: 494
I am nearly done with "my take" on the BD60. Will post it shortly...
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
Old 04-15-2009, 04:29 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 265
Super! Will be particularly interested in any comparative comments re the Oppo 83 you have played with, if you are so inclined. (BTW, your help last year with the Onkyo 805 was life-saving for me; not sure I've ever really thanked you sufficiently!)
Blu Ray Players , dolby atmos , Oppo , Oppo Bdp 83 Blu Ray Player , Panasonic , Panasonic Dmp Bd60 Blu Ray Disc Player Black , Panasonic Dmp Bd80k Blu Ray Player , panasonic dmp-bd60
