Official Panasonic DMP-BD60/80 Owners Thread - Page 264 - AVS Forum | Home Theater Discussions And Reviews
Old 03-15-2011, 10:29 PM
MacinMan's Avatar
Quoted: 80 Post(s)
Liked: 30
Hey guys,
Just thought I'd toss out a question about support and 2010 product threads. I have unsubscribed from several of the threads I was following, because of the following reasons:
1, I had gotten to a point, where I wasn't getting much help from the thread I couldn't solve on my own, and my email was being flooded.
2. I know that the 2011 models are starting to show up, so wasn't sure how active these threads would continue to be. I think I have a pretty solid setup going currently. I have reset my BD601 to erase all network info, and I basically use it as a profile 1.1 player. The BD 85 is still connected to the network, for the occasional netflix or other stream, and to see if the firmware is still updated for a while. Same for the sony player in the bedroom.
Beyond that, I'm not sure how much more help the forum and threads will be to me at this time. This leaves the final question, will this particular thread continue to regularly be active for a while, considering this was a popular player, and the last from panasonic which will support people's older receivers, and other setups?
MacinMan is offline
Old 03-15-2011, 11:02 PM
rover2002's Avatar
Originally Posted by moxie1617 View Post
Start Viera Cast, go to settings, Navigation Beeps, and toggle OFF by pressing the Okay button on the remote.
Top man,
rover2002 is offline
Old 03-16-2011, 10:04 AM
L David Matheny's Avatar
Quoted: 17 Post(s)
Liked: 32
Originally Posted by MacinMan View Post
Hey guys,
Just turn off email notification. Then check your subscribed threads by going to http://www.avsforum.com/avs-vb/subscription.php when it's convenient.
L David Matheny is online now
Old 03-22-2011, 04:29 PM
CSEmoses's Avatar
Anyone know if there's a way to stream music from my PC with my BD-60?
I'm thinking not, but worth asking
CSEmoses is offline
Old 03-22-2011, 05:17 PM
MacinMan's Avatar
Quoted: 80 Post(s)
Liked: 30
If you have an AV capture card in the computer, you could always stream audio and capture it on the computer, or listen to it that way. If not then there is no network streaming abilities of this player. You'd have to get a 350 model from 2010, or a 2011 model panasonic player to have DLNA support. DLNA will only let you stream from the computer to the player though. If you want to go from the player to the computer, then the AV capture card is your only option.
MacinMan is offline
Old 03-22-2011, 05:54 PM
CSEmoses's Avatar
thanks.
Im just looking to stream from the computer to the player.
Thanks again
CSEmoses is offline
Old 03-22-2011, 06:12 PM
Tesla1856's Avatar
Quoted: 90 Post(s)
Liked: 66
Originally Posted by MSloss View Post
I got it this weekend, too. It was from the movie, not the device. I said no when it came up thinking it was for the device, not wanting to wait for it to complete. Afterwards, I went back to the BD65 setup and checked for updates. It said I was already current.
Mike
Do you think it was just "sensing" an incompatibility, and was telling you that you might need a normal firmware update? Maybe for some new protection?
There is an option about what kind of BD-Live content to allow. Maybe this option needs adjusting.
And while none of my discs require it, apparently some discs require an external flash memory storage device to be inserted for "temp work space memory".
Living Room Home-Theater:
Epson 8350 Projector (1080p @ 96") / Panasonic 850u 46" 1080p Plasma TV
Onkyo TX-sr607 AVR (7.2ch ~ HDMI ~ wrat-Amp 630 watts )
AppleTV-4 / Panasonic dmp-BD60 Blu-Ray Disc Player / Cisco 8742hdc DVR (TWC)
Harmony 670 Remote / HTPC (Kodi/Win10-64) Media Server PC / Synology 12tb Raid-5 NAS
Polk Audio Monitor Series-II Speakers (Large 6.1 Matched Separates) / psw-505 12-Inch Sub
Tesla1856 is offline
Old 03-22-2011, 06:26 PM
Tesla1856's Avatar
Quoted: 90 Post(s)
Liked: 66
Not that I know of (no DLNA).
However, you can fit a bunch on a USB flash drive
If you don't want to install a real Media Center PC, there are various hardware devices that will do this cheap. Some of the smaller WD and Roku units are pretty inexpensive.
If trying to get to iTunes Library, you might have other options depending on current setup.
Old 04-05-2011, 12:00 PM
MacinMan's Avatar
Quoted: 80 Post(s)
Liked: 30
Has anyone purchased a copy, or rented tron legacy with this player?
I own three blu-ray players:
Sony BDP-S570
Panasonic DMP-BD85
Panasonic DMP-BD601
On the 601, the 2D version on blu-ray makes the player click, and then return the disc is unreadable, in the functions menu it states Disc incompatible. If I power off the player, with the disc inserted, and back on, the disc behaves fine. The Classic version of tron loads fine on the 601 without issues.
Tron legacy loads fine on my other two players without having to power cycle.
I was wondering if there is some form of new copy protection on this disc, or if my drive's laser is starting to fail. The disc is brand new (purchased today). Did the usual checks, and the disc is clean.
I've ruled out defective disc since the 2010 models play it normally without issues, and with a power cycle, so does the 601.
Any ideas? I also posted to amazon reviews to see if anyone else there has had any issues.
MacinMan is offline
Old 04-05-2011, 01:05 PM
microbob's Avatar
Quoted: 36 Post(s)
Liked: 26
I've had the same thing happen on the same model player, Panasonic 601k on some Fox titles also. Not sure why a power cycle is required to play those discs.
Robert
microbob is online now
Old 04-06-2011, 09:34 AM
erikstormtrooper's Avatar
Quoted: 12 Post(s)
Sony BDP-S570
Panasonic DMP-BD85
Panasonic DMP-BD601
My DMP-BD80 plays the 2D Blu-ray of Tron Legacy just fine.
erikstormtrooper is offline
Old 04-06-2011, 09:41 AM
MacinMan's Avatar
Quoted: 80 Post(s)
Liked: 30
Well,
I called Disney today and explained what was going on. Their technician came to a firmware problem with the disc and player. My 85 from panasonic plays the disc just fine too, as does my sony player, you're player is a different model from the one having problems here. Anyway, thanks for the feedback.
MacinMan is offline
Old 04-06-2011, 09:58 AM
microbob's Avatar
Quoted: 36 Post(s)
Liked: 26
Hopefully, Panasonic will put out a new firmware fix for this issue soon.
Robert
Old 04-06-2011, 10:01 AM
MacinMan's Avatar
Quoted: 80 Post(s)
Liked: 30
Well, does panasonic even still support the 60/80 players? I haven't had a firmware update for my 601, in over a year.
MacinMan is offline
Old 04-09-2011, 01:10 PM
MacinMan's Avatar
Quoted: 80 Post(s)
Liked: 30
Hey guys,
I can confirm that the tron legacy 2D disc is incompatible with the panasonic DMP-BD60x player.
I got a disc from netflix today which is the exact same disc that came in my 5 disc retail set. The player exhibited the exact same behavior as my original copy. Symptoms:
When placing the disc into the tray, while the player is on, and closing the try yields, several seconds of disc spin-up, and clicking. Then, the message "Cannot Read, Check disc." pops up, After power cycling the unit, with the disc in the tray, the disc will load and play without further problems.
I made double sure the laser wasn't dirty, by running my Cyclone Clean Dr. optical lens cleaning disc (a brush based cleaner), without any resolve.
Considering 2 pressed copies had the same issue, leads me to believe, there is some form of new copy protection on this disc, making the player think it doesn't contain compatible data.
I checked panasonic's site, and connected the player to the network today, and there still is no firmware update.
MacinMan is offline
Old 04-09-2011, 01:49 PM
Tesla1856's Avatar
Quoted: 90 Post(s)
Liked: 66
Hey guys,
When you get a chance, can you try it with all this at the same time:
- SD Card inserted
- Connected to Internet
- Option in BD-60 set to allow all BD-Live Content
Old 04-11-2011, 09:45 AM
gingus's Avatar
Quoted: 26 Post(s)
I have played the retail version of the Tron Legacy. I borrowed it from my neighbor. I played fine without any problems. It did have the SD card in, and it is conntected to the internet. Not sure why it would need to be conneceted to the internet, but it has worked fine for me.
gingus is offline
Old 04-12-2011, 11:11 PM
eja
eja's Avatar
My DMP-BD60 didn't have any problem playing it (from Netflix).
eja is offline
Old 04-13-2011, 12:33 AM
MacinMan's Avatar
Quoted: 80 Post(s)
Liked: 30
Odd, I know the 60, and 601, use the same firmware, and are essentially the same player. I wonder, if my player's drive is failing then because I had two copies of the same disc have the same issue on the same player. It has the latest firmware 2.5, since the player hasn't had a firmware update in about a year, or a bit less. I disconnected it from the internet, so BDLive would be disabled. I do have a 1 GB SD card installed, and even reformatted the card, unplugged, and hard reset to factory settings. With all this said, the player still refused to read the content of this particular disc, unless I power cycled with the disc in the drive.
Other discs work without problems, including the other discs in the same package. My panasonic BD 85 works without a hitch, so does the sony S-570, and so does a magnavox profile 1.1 player, which has no internet or even profile 2 features.
I find it hard to believe, that a failing drive, would only present itself with only 1 disc. However, People on this thread, and the 55 thread, i think it was reported drive issues after about 2 years of use, which that player is very close to. Did any of those incidents, begin in a similar fashion ?
In all my history of optical media e.g. DVD/blu-ray i only had 1 defective DVD player, once I replaced it, i never had an issue with DVDs again, unless the disc itself had issues, but the main movie would always play, and the disc was always readable. From my experience, it seems like blu-ray will never be perfect, and always have bugs.
Does anyone want to take a stab at, why 3 out of 4 players will play this disc, and this one has issues? It makes absolutely no sense.
MacinMan is offline
Old 04-14-2011, 09:29 PM
twotrey's Avatar
Hello:
I just updated my firmware from 2.4 to 2.5 on the BD605, and now no menu comes up on screen when I hit the "setup" button on the remote though the display in the front shows the word "SETUP"... help please? Thanks in advance!
twotrey is offline
Old 04-15-2011, 11:21 AM
gerhard911's Avatar
Without more info I am going to guess the update reset your HD video output to something your TV does not support. Try connecting the BD605's standard definition video out (yellow RCA connector) to a corresponding video input of your TV. This should allow you to view the setup screen in 480i standard definition and check the HD output settings.
gerhard911 is offline
Old 04-19-2011, 08:31 AM
mil_on's Avatar
Hey guys,
Tron Legacy played fine on my DMP-BD60. No glitches at all.
mil_on is offline
Old 04-20-2011, 08:41 PM
JedFRaybould's Avatar
Earlier in the day I played the 2D version of Tron Legacy fine on my DMP-BD80. No glitches at all. Is there any secrets on what to enter on the feature titled "The Next Day: Flynn Lives Revealed" at the end where the Hi Scores screen.
Jed "Freddy" Raybould
JedFRaybould is offline
Old 04-20-2011, 09:48 PM
Quoted: 12 Post(s)
Enter ALL.
Old 04-25-2011, 03:32 PM
pdxfj's Avatar
Quoted: 22 Post(s)
Liked: 31
I can say that anything I've tossed into my BD-80 spins up and plays fine except for an annoying audio issue on some DTS-HD-MA tracks.
I'm getting random audio drops. It started with the Best Buy version of Despicable Me and even exchanging the disc at different stores the problem remains. I figured it was just a bad batch of discs since none of my other 60+ BD movies had the issue. Until yesterday evening while showing Tron Legacy, where I got one audio drop during the movie. Odd thing is the night before was two movies in a row one of which was Tron Legacy. Yes... I get a lot of company for movies to which I sit though several times.. doesn't bother me too much..
Seeing others post up issues around the two year mark makes me wonder if I'm reaching the end of life on my player. I'm fast approaching two years and many, many hours of use. Perhaps I'll try one of the suggested lens cleaners.
If I hadn't just spent a ton of dough upgrading my receiver and adding an amp I'd pick up an Oppo.
All my equipment has the latest firmware installed, I've tried other HDMI cables, etc.
If I see "END OF LINE" scroll across the BD-80's display I'll know I have deeper issues.
pdxfj is offline
Old 04-26-2011, 05:31 AM
CSonntag's Avatar
Quoted: 186 Post(s)
Liked: 65
Originally Posted by twotrey View Post
Hello:
Did this get resolved or figure out why it happpened?
Take responsibility for your own actions...society is not here to look after you...
In other words, if you order coffee, expect it to be hot for christsake!
CSonntag is offline
Old 04-26-2011, 02:19 PM
DECJ's Avatar
This is probably a dumb question, but do I need to do anything beyond just installing a SDHC card ... such as initializing it? Or is it just a "plug & play" type of thing?
DECJ is offline
Old 04-26-2011, 02:26 PM
gingus's Avatar
Quoted: 26 Post(s)
Just Plug and Play.
gingus is offline
Old 04-26-2011, 02:35 PM
DECJ's Avatar
Originally Posted by gingus View Post
Just Plug and Play.
Great ... thanks!
DECJ is offline
Old 05-01-2011, 12:38 AM
stewey1200's Avatar
i just got a roy orbison blu-ray from netflix and my bd60 won't play it.is there a way to tell if it is a damaged disc or a update is needed? this blu-ray was released in 2008.aren't updates required only for the newest releases? every other disc plays perfectly and i've never done any updates.
stewey1200 is offline
Blu Ray Players , dolby atmos , Oppo , Oppo Bdp 83 Blu Ray Player , Panasonic , Panasonic Dmp Bd60 Blu Ray Disc Player Black , Panasonic Dmp Bd80k Blu Ray Player , panasonic dmp-bd60
