Official Panasonic DMP-BD60/80 Owners Thread - Page 276 - AVS Forum | Home Theater Discussions And Reviews
post #8251 of 8263 Old 06-21-2014, 06:56 AM
SSpectre's Avatar
Anyone having trouble with the LEGO Movie? My BD-60 won't read the movie with SD card in or out. Getting a "Cannot read. Please check the disc." error after the drive tries to start it a few times. It's the only disc of mine that won't read.
SSpectre is offline
post #8252 of 8263 Old 06-23-2014, 12:51 PM
erikstormtrooper's Avatar
I have no trouble with the Lego Movie blu-ray on my BD80.
erikstormtrooper is offline
post #8253 of 8263 Old 06-25-2014, 04:53 PM
Liked: 0
Cool
Hello all,
I am trying to assist someone in updating to a newer firmware. The player has problems with discs (' protections?). It is a DMP-BD60 with 1.7. I have twice burned the correct country's firmware file, once with ImgBurn as an ISO9660. Each time, the player displays L FVU and immediately ejects the disc. The update does not complete.
Does anyone have 2.64 on disc that can be converted to an ISO? Can someone offer recommendations? I do not have Roxio or Windows XP.
Thanks in advance.
Silekonn
silekonn is offline
post #8254 of 8263 Old 06-25-2014, 11:09 PM
hdcrack's Avatar
Originally Posted by silekonn View Post
I am trying to assist someone in updating to a newer firmware. The player has problems with discs (' protections?). It is a DMP-BD60 with 1.7. Can someone offer recommendations? I do not have Roxio or Windows XP.
Check with Panasonic to see if they will ship you a CD with the latest FW @ N/C. They used to offer this service. I had a DMP BD-60 b4 I upgraded to Oppo. After 4 years of playing every BD, the Panny started not playing certain discs.
hdcrack is offline
post #8255 of 8263 Old 06-26-2014, 06:01 AM
mdavej's Avatar
Quoted: 1277 Post(s)
Liked: 643
The key here is CD. Make sure you aren't burning to DVD.
mdavej is offline
post #8256 of 8263 Old 07-23-2014, 03:52 PM
Liked: 0
This is again a project of interest. I am looking at accomplishing this with a different brand of media. The Panasonic site, http://panasonic.jp/support/global/c...ica/index.html, says the disc must not be 'packet-written.' I have verified ImgBurn does not use packet writing. It also must be ISO9660. The question there is, Mode1 or Mode2/1, and then, Level 1, 2, or X with a Standard, DOS or ASCII character set. Anyone have suggestions?
silekonn is offline
post #8257 of 8263 Old 09-13-2014, 10:16 AM
Liked: 0
Other questions.
I am considering to purchase an used Panasonic DMP BD80 or BD80EG-K mainly to play Blu-Ray discs for its music (5.1 audio). For example Quadrophenia by the Who.
The Panasonic will be connected to a vintage quadraphonic amplifier that has 4 discrete inputs and four speakers. There is no sub woofer, there is no central speaker, just 2 front speakers and 2 rear speakers.
The manual that I found online says that you can switch off the center speaker, the Panasonic will compensate this by giving more low frequency sound to the 2 front speakers.
What about the center speaker?
Can this one be switched off too and will the Panasonic divide the sound of the center speaker over the 2 front speakers?
What is the difference between the Panasonic DMP BD80 and the BD80EG-K ?
If this Panasonic is not the right one for the application, which Blu-Ray player would you recommend to use in combination with a 4.0 amplifier?
Thank you in advance for your reply.
ceeveedee is offline
post #8258 of 8263 Old 11-13-2014, 08:43 PM
pelly's Avatar
Can't connect to the network anymore.
I have had this for several years and it has served me well, but today I can't connect through the network anymore. In the network section my Connection Test fails. I can't update firmware, can't access viera cast... I am not sure what is wrong. I swapped ethernet cables with our Xbox and get internet connection there so it is not that the router or cable are bad.
The only thing that has changed fairly recently is I got set up through openDNS for internet content filtering. I input their DNS settings into my router. I thought maybe I had to turn Auto DNS config off in the BD80 and put those DNS settings in, but that didn't work either.
Any thoughts on what might be the problem?
pelly is offline
post #8259 of 8263 Old 11-13-2014, 08:43 PM
pelly's Avatar
pelly is offline
post #8260 of 8263 Old 11-14-2014, 01:28 PM
Tesla1856's Avatar
Liked: 52
Fixed IP Address
Try giving it a Fixed IP address (similar to how you would setup a printer).
I had the same problems (with it no being able to obtain a Dynamic IP address from router). Since I switched BD-60 and plasma TV to Fixed IPs ... no more problems.
Living Room Home-Theater:
Epson 8350 1080p Projector (96") / Panasonic TH-46pz850u 46" 1080p Plasma TV
Onkyo TX-sr607 7.2 HDMI Audio/Video Amplifier/Receiver (630 watts)
Panasonic DMP-BD60 Blu-Ray Disc Player / Cisco 8742hdc DVR (TimeWarner)
Harmony 670 - Universal Remote / HTPC (XMBC/Win7-64) Media Server PC
Polk Audio Monitor Series II Speakers (Large 6.1 Matched Separates) / PSW505 12-Inch Sub
Tesla1856 is offline
post #8261 of 8263 Old 11-14-2014, 04:00 PM
danki6x's Avatar
Quoted: 18 Post(s)
Liked: 35
I have used Open DNS for a long time without problems. Also can try a router reboot (unplug, wait, plug in) in case it needs to assign another local IP address. Might also be able to firmware update via download and create DVD (not sure if still can, never tried) /Dan
danki6x is offline
post #8262 of 8263 Old 11-15-2014, 05:09 PM
pelly's Avatar
Thanks. I switched to a fixed IP and now it works again. Not sure what triggered it, but I am glad to be back and running again.
pelly is offline
post #8263 of 8263 Old 11-17-2014, 12:47 AM
eric923's Avatar
Hi guys,
I have a Panasonic DMP BD-60 blu ray player.
My question is right now I have the audio hooked from the blu ray player’s stereo analog outputs in the back. When Im watching a blu ray movie and I select an HD audio codec like DTS HD MA or Dolby True HD, will I still be getting the same High Res sound quality (although in 2 channel mode) via the stereo analog outputs from the blu ray player? I know it’ll all just be in 2 channels instead, but will the resolution of the audio still be High Res and of the same quality of the HD codec or might the player downgrade the resolution of the audio that comes out from the analog outputs?
Hope that made sense. lol.. Thx for any input.
eric923 is offline
Reply Blu-ray Players
Oppo , Oppo Bdp 83 Blu Ray Player , Blu Ray Players , Panasonic Dmp Bd80k Blu Ray Player , Panasonic Dmp Bd60 Blu Ray Disc Player Black , Panasonic
