Official Panasonic DMP-BD60/80 Owners Thread - Page 278 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #8311 of 8314 Old 08-02-2017, 10:25 PM
Tesla1856's Avatar
Quoted: 119 Post(s)
Liked: 68
Originally Posted by mariokrt64 View Post
After several days and tries I was able to get it updated with the player online...
however the problem with playing some bluray disc persists...probably the unit is showing its age and there may be an issue with the blue laser as it played the one cd and dvd that I attempted, flawlessly...
thanks
Well, at least its running the latest firmware now ... good work.
Yeah, the blue-laser and I think the motor must also spin faster for Blu-Ray discs.
I had a problem with a few discs a while back. They were fixed by inserting (proper spec and speed) 8gb SD-Card. It think it had something to do with BluRay-Live.
Anyway, this one was inexpensive long ago and new ones are even cheaper. If this one ever dies, I'll probably get a Sony next time.
Living Room Home-Theater:
Epson 8350 Projector (1080p @ 96") / Panasonic 850u 46" 1080p Plasma TV
Onkyo TX-sr607 AVR (7.2ch ~ HDMI ~ wrat-Amp 630 watts )
AppleTV-4 / Panasonic dmp-BD60 Blu-Ray Disc Player / Cisco 8742hdc DVR (TWC)
Harmony 670 Remote / HTPC (Kodi/Win10-64) Media Server PC / Synology 12tb Raid-5 NAS
Polk Audio Monitor Series-II Speakers (Large 6.1 Matched Separates) / psw-505 12-Inch Sub
Tesla1856 is offline
post #8312 of 8314 Old 08-09-2017, 10:25 AM
mariokrt64's Avatar
Quoted: 42 Post(s)
I can hear the motor running so maybe its that or most probably the blue laser (misaligned?)...Its not really the cost but that I may be a little attached to this unit....it was about $200 in 2009 when I bought it, but the built qualitiy is above the charts (metal case, 8 lbs wt., etc.) when compared to my 2 yr old Samsung plastic cheap fabrication...
Think I will give it a proper burial when times comes, as it appears to still be able to play CD's and DVD's.....LOL
mariokrt64 is offline
post #8313 of 8314 Old 08-09-2017, 10:58 AM
Tesla1856's Avatar
Quoted: 119 Post(s)
Liked: 68
If it consistently plays your older Blu-Ray disks, then the blue-laser and motor are likely OK.
If it's just the newer BD that's won't play (and you have a network connection and SD-Card installed) I would say it's a firmware issue (BD-60/80 can't handle the newer protection type).
post #8314 of 8314 Old 08-10-2017, 06:11 AM
mariokrt64's Avatar
Quoted: 42 Post(s)
It doesn't...I thought the problem was the FW but after the update I was only able to play one after loading several old ones....the one DVD and CD I loaded played fine...that's why I thought the issue may be related to the blue laser?...I don't have an SD card but almost never had one, just for a brief time initially..I have a network cable connected now for the update but not in the past, except when new..
thanks
Reply Blu-ray Players
Blu Ray Players , dolby atmos , Oppo , Oppo Bdp 83 Blu Ray Player , Panasonic , Panasonic Dmp Bd60 Blu Ray Disc Player Black , Panasonic Dmp Bd80k Blu Ray Player , panasonic dmp-bd60
