Momitsu bdp-899 Region Free Blu ray Player - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 234 Old 07-05-2009, 03:44 PM
mugupo's Avatar
should i get momitsu or the oppo blu-ray player with region free hack?
mugupo is offline
post #182 of 234 Old 07-05-2009, 04:16 PM
RapalloAV's Avatar
Quoted: 1302 Post(s)
Liked: 292
oppo
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #183 of 234 Old 07-05-2009, 06:59 PM
Dragonsf's Avatar
Does this player has patch update? has anyone experience disk problem?
See my previous post #169. I posted a link to a FW update.
Dragonsf is offline
post #184 of 234 Old 07-05-2009, 07:34 PM
Rachael Bellomy's Avatar
Location: Knocksville TN, capitol por republica de Polezannia
I managed to miss that. Thanks for the reminder....
In real life I am Dot Mongur champion of the International Pacman Federation. I don't play the game, I operate it.....no dot is safe from me....
Rachael Bellomy is offline
post #185 of 234 Old 07-06-2009, 07:02 AM
Ted_K's Avatar
I missed it too. Can you tell what it does?
Ted_K is offline
post #186 of 234 Old 07-06-2009, 05:41 PM
Dragonsf's Avatar
Actually no, my player was already up to date.
Dragonsf is offline
post #187 of 234 Old 07-06-2009, 06:09 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
So, the Momitsu doesn't automatically download firmware updates if it is connected to the internet?
Brandon A. DuHamel
Founder & Editor-in-Chief
TheaterByte
GoldenBoy is offline
post #188 of 234 Old 07-07-2009, 01:37 AM
Dragonsf's Avatar
Would you really like that? I wouldn't.
Dragonsf is offline
post #189 of 234 Old 07-07-2009, 05:53 AM
Ted_K's Avatar
I suspect mine may be as well. How can you tell?
Ted_K is offline
post #190 of 234 Old 07-07-2009, 06:02 AM
Dragonsf's Avatar
My SW Version is:PKG-DVD-1-4-064-RC
Dragonsf is offline
post #191 of 234 Old 07-07-2009, 12:46 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Well, I guess what I meant was, it doesn't give automatic firmware notifications like the other players do (if setup for that, at least). I think I worded my question incorrectly.
I guess it doesn't, because I downloaded the firmware and updated my player. If there were automatic notifications, I'm guessing it would have occurred by now, given the date listed on that file and how long I've had the Momitsu.
So, does anyone have any idea what the update does? I don't notice any added features, so perhaps it's just compatibility with certain discs, etc. that it fixes?
Brandon A. DuHamel
TheaterByte
post #192 of 234 Old 07-07-2009, 11:42 PM
Airboss's Avatar
Originally Posted by Rachael Bellomy View Post
Airboss, did you ever get the firmware update for your 905? My 805 required it. The latter productions runs of this series might not have needed it? I'm not sure. I got my 805 early and had to get it as I was using it with a Panasonic 30 then. If you had the PS3 back then, maybe you didn't experience the DTS Boom or pop at random spots in several Fox BD's...? I'm not sure what all the equipment combination are that were affected. If you didn't get the firmware update, that looms as one of the possible culprits.
Originally Posted by Airboss View Post
I don't believe I did, I'll check that out. Thanks for the help.
Ok, upgraded the firmware on my Onkyo and problem solved, no more DTS Boom or pop.
Now I have another question. I set my Momitsu BDP for SD Region Free and Blu Ray Region B but when I shut it off it reverts back to SD Region 1 and BR Region A, is this the norm? If I set it to SD Region Free and BR Region Free will it stay there or do you have to reset it each time you turn it on?
Once again, watched a SD DVD tonight using the BDP-899 and the up-converted image was outstanding!! This is becoming my favorite upconverting player.
"Marines have no qualms about killing Martians"
2011 List
2009 List
2008 List
Airboss is offline
post #193 of 234 Old 07-08-2009, 06:02 AM
Ted_K's Avatar
The player reverts back to Region A for blu-ray when it is powered off, since there is no equivalent to Region "0" for BD. If you set a code of 97350*, the player will stay in region "0" for SD, meaning that all-region play for SD sticks. And you're right, it's a great player overall, not just for SD!
Ted_K is offline
post #194 of 234 Old 07-08-2009, 07:38 AM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
But Airboss seems to be saying that his player is reverting back to SD Region 1 even after he has set it to SD Region-Free when he powers off the unit, which is not the way it is supposed to work, unless he is mistaken.
Brandon A. DuHamel
TheaterByte
post #195 of 234 Old 07-08-2009, 09:57 AM
Ted_K's Avatar
I would make sure that the second to last number is "0" again and see what happens. Mine definitely stays region-free for SD after powering off. Maybe he put in a "2", thinking it would stay region 2, or some else like that.
Ted_K is offline
post #196 of 234 Old 07-08-2009, 03:57 PM
EPlay's Avatar
Quoted: 76 Post(s)
Liked: 37
Or perhaps it makes a difference if you turn it off via remote (thereby putting it in "standby" mode) or if you use the indent button on the machine to turn it off?
I just received my Momitsu yesterday morning and have not had much time to play with it yet. I did test out that it does play the extras on "Feast of Love" (aka "Cup of Love") which my PS3 couldn't, and that "The Story of Anvil" will play (supposedly 1080i 50hz). Will probably not get a chance to really watch anything until the weekend.
EPlay is online now
post #197 of 234 Old 07-08-2009, 04:22 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Yes, I would think that turning the machine off completely via the power button on the front of the unit vs. putting it into standby with the remote could potentially wipe out the region-free setting. In fact, I think I recall that happening to me once, now that you mention it, but I'd have to double check that to say definitively.
Brandon A. DuHamel
TheaterByte
post #198 of 234 Old 07-09-2009, 09:58 AM
I breezed through the manual last night looking for how to check the firmware type. I found nothing. Anybody know how?
post #199 of 234 Old 07-09-2009, 10:08 AM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Sure,
Go into the "Setup" menu, and scroll down to the "System" settings, which is the second to the last icon on the bottom left. Then, scroll to the right a bit ad move down to where it says "Software Version."
Brandon A. DuHamel
TheaterByte
post #200 of 234 Old 07-10-2009, 06:01 PM
Ted_K's Avatar
I use the remote to power the unit on and off.
Ted_K is offline
post #201 of 234 Old 07-10-2009, 09:49 PM
Dragonsf's Avatar
This sets the unit to 'Standby'. 'Power off' is something different.
Dragonsf is offline
post #202 of 234 Old 07-11-2009, 02:29 PM
Ted_K's Avatar
I realize that. I was just indicating that is the procedure I use and perhaps that is why my SD region-free setting doesn't get cleared where some others' setting does.
Ted_K is offline
post #203 of 234 Old 07-11-2009, 05:01 PM
Airboss's Avatar
Ok, I checked it again last night and using the remote to turn the unit off the SD code remains intact, just not the BD code. I'll try later tonight and see what happens when the unit loses power (via power button or unplugging).
Not sure what happened the last time I was messing with it but I may have had to unplug it and that could be why I lost both SD and BD codes.
2011 List
2009 List
2008 List
Airboss is offline
post #204 of 234 Old 08-10-2009, 11:13 AM
Jacek Karpala's Avatar
Hi,
I just got my unit and noticed that the picture is much more vivid (the blacks are blaker and whites are whiter - almost oversaturated). Is there a way to adjust it on the unit? I didn't find a way yet...
Any firmware upgrades out there as off yet?
Jacek
Jacek Karpala is offline
post #205 of 234 Old 08-25-2009, 11:41 AM
Bleddyn H Williams's Avatar
I'm thinking of picking this one up. A couple of quick questions for Momitsu gurus...
I have a 1080i set that I have to use component video for, with HDMI for audio to an Onkyo 606.
* Is the Onkyo okay with outputting both component & HDMI at the same time?
* Reading this thread, there's a lot of 1080i/1080p talk. What would be good default settings for me on the Momitsu, and would I have to make any adjustments for various disc types?
Any help appreciated!
Bleddyn H Williams is offline
post #206 of 234 Old 08-25-2009, 08:51 PM
Dragonsf's Avatar
I received my player yesterday and I must say, there is no noise at all.
The PQ from BD is really good (on an 80" projector screen).
But I couldn't get the player to play any .ts or .mp4 from disk. Any ideas why?
Or does the player only play files from USB?
From my seller, I got the following link:
http://www.mediafire.com/?sharekey=0...5965eaa7bc68bc
Please see there for manuals and FW updates. I also learned, the machine is Linux based and can only use FAT32 formatted USB media.
All all playable video files must have an extension of .avi.
There seems to be a new FW available.
Dragonsf is offline
post #207 of 234 Old 08-26-2009, 01:33 AM
mike171979's Avatar
Dragon, I was just coming in here to say the same thing.
On the page where the updates can be found, the software version has just been revised on 8/23/09.
This might fix the problem with T2 Skynet Edition, I'll have to download it and try it out.
mike171979 is offline
post #208 of 234 Old 08-26-2009, 05:29 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
The firmware just posted does not fix the problem with T2 Skynet Edition. It still freezes. The firmware seems to have been uploaded to the site recently but if you check the main file it does not seem to be new. I have the original download and the new one posted and all files are the same with the same dates.
rwestley is offline
post #209 of 234 Old 08-26-2009, 07:56 PM
Dragonsf's Avatar
The main file is the Linux OS (as squashfs image). But the vmlinuz and .dat are from July.
So there must be some changes
Dragonsf is offline
post #210 of 234 Old 08-29-2009, 06:01 AM
ss9001's Avatar
Quoted: 338 Post(s)
Liked: 397
Is the Momitsu still being made? I've been going to HKFlix for a month or more, since its' one option for me to get a region free player - no stock & Momitsu has to resume production.
Also, Atacom's site seems to suggest it's no longer available.
What's the story?
ss9001
Steve
ss9001 is offline
Reply Blu-ray Players
Lg Bh200 Super Blu Blu Ray Hd Dvd Combo Player
