Pioneer BDP-320/BDP-23FD Owner's Thread - Page 215 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #6421 of 6444 Old 04-22-2015, 04:28 PM
GPM
GPM's Avatar
Quoted: 20 Post(s)
??? Replace with what? These players haven't been available for years now.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
GPM is offline
post #6422 of 6444 Old 04-23-2015, 04:23 AM
Selden Ball's Avatar
Quoted: 2529 Post(s)
Liked: 1212
GM
In that case, you probably should consider getting a current model. Sony, Panasonic and Oppo are the brands favored here on AVS. Pioneer and Sharp tend to have relatively limited functionality in comparison.
Selden
Selden Ball is online now
post #6423 of 6444 Old 04-23-2015, 05:32 AM
dsskid's Avatar
Quoted: 261 Post(s)
Liked: 254
If I remember correctly, the newer Pioneers BD players are actually manufactured by Sharp.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #6424 of 6444 Old 04-23-2015, 11:09 AM
Liked: 1212
My Pioneer 120 certainly was. The only difference is the manufacturer's logo. However, my understanding is that the very latest generation of Pioneer's players were back to being their own. I dunno what'll happen with their next generation now that Pioneer's entertainment division is owned by Onkyo.
Selden
post #6425 of 6444 Old 04-23-2015, 05:42 PM
VMat's Avatar
GM
Exactly. I bought mine in 2009.
I did consider that for a second or two, but it just doesn't feel right. The player is nice. It works with all other titles I've got (as far as I know). And I'm almost sure it's not a hardware problem, but a software problem. What I'm considering more seriously is to buy a USB BD recorder, that would serve multiple purposes, including (hopefully) watching this particular title.
For the record, when I said 'lemon', I was referring to the disc, not the player.
Next step, I think, will be to take the player out of the cabinet, remove the cover, and clean it up.
Thank you all for the suggestions.
VMat
VMat is offline
post #6426 of 6444 Old 04-26-2015, 09:33 AM
VMat's Avatar
Update... I decided to try other discs (quite boring to wait for each one to load), and after about 20 tries, I found two other ones that won't play (Seven and Natural Born Killers, which I have watched not so long ago, but in 3.73, I believe). Now I do think it's a hardware issue... I'll try to open the unit and clean it up later today, if I have time.
Interesting, though, is that the Labyrinth + Enemy Of The State phenomenon persists. I reproduced it twice.
Anyway, I just posted this to be fair with you guys that told me it looked like a hardware issue.
Thank you all,
VMat
VMat is offline
post #6427 of 6444 Old 04-26-2015, 03:27 PM
Jed1's Avatar
Quoted: 99 Post(s)
Liked: 57
Thank you all,
I just tried Enemy of the State and Se7en in my 320 and both titles played fine. I am on 3.74 and I erased persistent storage before I tried each movie. I do have BD Live enabled. I do not have Natural Born Killers or Labyrinth.
"You lose it in here you're in a world of hurt"
Jed1 is online now
post #6428 of 6444 Old 04-27-2015, 09:55 AM
VMat's Avatar
Yeah, I've read a few posts on another forum about the BDP-51FD showing the same symptoms as my 320, and it seems that either it's a matter of cleaning the lens, or the drive is probably dying. And it gets progressively worse, until it can't read any more discs. Then I'll end up with a gorgeous, very expensive DVD/CD player.
By the way, the cleaning up didn't go very well. I thought I would open the unit and see the pickup lenses, but inside the player there's actually a SATA reader, enclosed in a metal case, like a computer optical drive. And I was too tired to go through the process of opening that one up. Outside the drive, everything was pretty clean, as if it were brand new.
Has anyone tried to connect a computer SATA drive to the player? I'm wondering if I could try to adapt a regular computer drive in there (for the fun of it).
VMat
VMat is offline
post #6429 of 6444 Old 04-27-2015, 10:49 AM
Jed1's Avatar
Quoted: 99 Post(s)
Liked: 57
Your Welcome! I cringe every time I hear some one having issues with these older players. I have the BDP 320, LG BH 200, and the OPPO BDP 83 and all are still working yet. Yes these players are a little slower than newer ones but they do their job. I don't want streaming apps on my players as this prevents the firmware from being rolled back.
I never really given much thought as to what I will buy to replace these units when they fail.
Jed1 is online now
post #6430 of 6444 Old 04-27-2015, 11:28 AM
blacklion's Avatar
I bought a couple of used 320s two years ago which I kept in storage against my 320 in use eventually failing.
Denon X4000: Yamaha AS500;TS500;CDS300: Pioneer BDP62FD;BDP23FD;DV58AV;DV610: Panasonic DMP-BDT500; Sony BDP-S790; Samsung PS60E6500
blacklion is offline
post #6431 of 6444 Old 04-27-2015, 11:39 AM
Jed1's Avatar
Quoted: 99 Post(s)
Liked: 57
Smart move. I wish I would have done that as I like the simplicity of these players. Actually these 320 can play the seamless branching titles without audio drop outs that my OPPO BDP 83 can not. I have to use LPCM over HDMI on the OPPO to get stable sound on those titles.
Jed1 is online now
post #6432 of 6444 Old 04-27-2015, 12:03 PM
VMat's Avatar
I'd love to find just one to buy, but here in Brazil, if I could find one, it would probably cost more than a new Samsung or LG, or even a Sony, with 1-year warranty.
I'm not even sure I should try to clean the lens. Maybe it will make things worse than they are now.
VMat
VMat is offline
post #6433 of 6444 Old 04-27-2015, 01:35 PM
Jed1's Avatar
Quoted: 99 Post(s)
Liked: 57
Here is the parts lists for the 320. Unfortunately the part you may need is the drive assembly and it is no longer available. I t wouldn't matter very much if it was available as it is $340.
http://parts.pioneerelectronics.com/...delNum=BDP-320
http://www.pioneerelectronics.com/PU...layers/BDP-320
Jed1 is online now
post #6434 of 6444 Old 04-27-2015, 02:01 PM
VMat's Avatar
Right, that's the one.
Right, not worth $340. I'd rather buy a new player.
VMat
VMat is offline
post #6435 of 6444 Old 04-27-2015, 03:40 PM
VMat's Avatar
I've just done the thing with Enemy Of The State again. I think I'm gonna tape it next time, because it's almost fun to watch...
VMat
VMat is offline
post #6436 of 6444 Old 05-10-2015, 06:10 PM
VMat's Avatar
Hey, I finally mustered up the courage to disassemble the whole thing and clean the lenses with a Lenspen. I also managed to leave two springs behind when putting it back together (and I think I lost one). I hope they are not too important...
Now the player is working again. I re-tested it with some discs that weren't playing before, and I can play them now - even The Wrestler. I hope it stays like that for another 6 years.
Thanks again for all the comments and suggestions!
VMat
VMat is offline
post #6437 of 6444 Old 05-10-2015, 06:17 PM
GPM
GPM's Avatar
Quoted: 20 Post(s)
Thanks for the update! I wonder though if just using an inexpensive BD cleaner system would be sufficient.
GM
GPM is offline
post #6438 of 6444 Old 05-11-2015, 05:45 AM
dsskid's Avatar
Quoted: 261 Post(s)
Liked: 254
The "extra" springs may have been the problem...
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #6439 of 6444 Old 05-12-2015, 11:25 AM
VMat's Avatar
Hopefully!
VMat
VMat is offline
post #6440 of 6444 Old 06-19-2015, 12:34 PM
RichManofAction's Avatar
BDP-23FD "Unknown Disc"
After loyal years of service, my 23FD has begun to give us problems. I need some help -
First off, is it worth cleaning the laser?
Second - How is the BDP-80? Is it just a Sharp player rebranded, or worth the purchase?
Lastly - is it me, or does the Xbox One sound like crap compared to my BDP-23? We tried watching Harry Potter: Order of the Phoenix last night on the XB1 and I had to pump the volume of the receiver up way beyond what we normally do just to hear the thing.
Any help is appreciated! Thanks -
RichManofAction is offline
post #6441 of 6444 Old 07-18-2015, 07:04 AM
Liked: 0
Pioneer BDP 320
Hello.
I took mine apart to clean the lasers and the two springs just dropped out, which may well explain the noise it was making last time I fired it up.
Can anyone explain exactly where those springs should be fitted.
Thanks in advance.
Emsley is offline
post #6442 of 6444 Old 01-06-2016, 06:47 AM
Liked: 0
Hi. Can anyone with firmware 3.74 verify if s infected with cinavia? Thanks
Fyzal Yusuf is offline
post #6443 of 6444 Old 01-06-2016, 09:54 AM
Jed1's Avatar
Quoted: 99 Post(s)
Liked: 57
This player is to old for that and will never have it.
Jed1 is online now
post #6444 of 6444 Old 01-07-2016, 08:19 AM
Liked: 0
I certainly hope so cause that fw is after 2012. If it's not cinavia infected i will update my 320 to 3.74
Reply Blu-ray Players
