Why is my thread locked? - AVS Forum
post #1 of 5 Old 05-12-2009, 11:32 PM - Thread Starter
ken15's Avatar
I wanted to post a reply to my thread from yesterday and noticed it's been locked. I'm sure I did nothing wrong. Could some please explain to me what's going on?
My thread was the one talking about not being able to see any difference between BD and DVD.
ken15 is offline
post #2 of 5 Old 05-12-2009, 11:39 PM
Franchot's Avatar
Your eyes are lying to you. There is a difference. You LOOK, but you do not SEE!
Just kidding with you. I'd guess that there is probably a thread like yours already. I know I've seen some in the past. Try the Search Function.
Franchot is offline
post #3 of 5 Old 05-13-2009, 04:14 AM
thebland's Avatar
Quoted: 127 Post(s)
Liked: 117
Yes.. if you can't see the difference between Blu Ray's 6X advantage in resolution, you either have a set up problem, your TV is standard def, your television size is less than 40" or your eyes are lying to you...
The problem is not Blu Ray.
There are more than a handful of [op amps] that sound so good that most designers want to be using them as opposed to discreet transistors. Dave Reich, Theta 2009
thebland is online now
post #4 of 5 Old 05-13-2009, 04:24 AM
AVS Club Gold
Browninggold's Avatar
Liked: 37
Grasshopper, when you can snatch the pebbles from my hand...you will see
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
post #5 of 5 Old 05-13-2009, 06:13 AM
Moderator
PooperScooper's Avatar
Quoted: 48 Post(s)
Liked: 73
If the thread was the first time the subject came up then it would still be around. However, the topic has been discussed many times in the previous *years* since the first HDM discs came out. Like somebody else said - it's not the format in general. It could be you picked a disc made from a bad/old master. Look in the BD disc Tier sticky thread at the top of the forum and watch a disc or two from Tier 0. If you can't see a difference, it's something on your end.
larry
Opportunity is missed by most people because it is dressed in overalls and looks like work. -- Thomas Alva Edison
PooperScooper is offline
Closed Thread Blu-ray Players
User Tag List
