Official PS3-Slim Master Thread-Post all comments and questions here! - Page 22 - AVS Forum | Home Theater Discussions And Reviews
Old 12-09-2009, 03:10 PM
drhankz's Avatar
Quoted: 78 Post(s)
Liked: 65
Originally Posted by quinn1016 View Post
thanks, i will buy another one tonight and see if it helps. I am also going to seek out another blu ray payer just to see if it works any better, and start the narrowing process
There are ONLY THREE possibilities
drhankz is online now
Old 12-09-2009, 03:39 PM
WhatHappend's Avatar
It recognized the cable, asked if i wanted to switch to HD, and have it automatically optimize my settings. It looked great...for a few minutes. As I was completing the setup process, the screen flashed, and it went black.
Change the PS3 HDMI video setting to manual and disable the 1080p resolution and give it a try.
If that works, it looks like you cable may be bad.
WhatHappend is offline
Old 12-09-2009, 05:34 PM
streaker76's Avatar
I purchased the PS3 Slim in September. I have a Marantz SR8002 (updated firmware) receiver with HDMI from PS3 to receiver. I have the setting on bitstream. I loose the picture and audio when I ffwd or rwd BLURAY MOVIES ONLY. If I change the setting to PCM all is fine.
I've tried two different PS3s same problem with the second Slim before and after the firmware 3.10 that was issued a couple weeks back
Use to have a Panny BD30K, no issues with bitstreaming.
I also reset the defaults on the Slim as well.
I just went a got a PannyDB60 this evening to test it out. Sure enough when selecting bitstream I have no issues what so ever when ffwd or rwding.
It's clearing the PS3 that has the issues when bitstreaming. I've spoken with the PS3 Tech Support and he said it's a compatibility issue with the HDMI on my reciever. I'm going to have to disagree as I've ruled out the Marantz and the Panny. I've tried to different Slims which have the same issues. How do I go about getting this straightened out.
If the links don't work let me know. I've attached a couple clips with 2 movies on the Panny and 2 on the PS3 showing what the issues are.
Hopefully this new firmware that PS3 is issuing on the 10th will help.
http://s837.photobucket.com/albums/z...t=MVI_4597.flv
PS3 Slim
http://s837.photobucket.com/albums/z...t=MVI_4595.flv
PS3 Slim
http://s837.photobucket.com/albums/z...t=MVI_4594.flv
Panny DB60
http://s837.photobucket.com/albums/z...t=MVI_4593.flv
Panny DB60
Help and Thanks
Steve
streaker76 is offline
Old 12-09-2009, 05:39 PM
tingham's Avatar
Quoted: 62 Post(s)
Liked: 30
You might want to check out this thread. http://www.avsforum.com/avs-vb/showt...itstream+issue
Go Phillies! Go Eagles! Go Sixers! Go Flyers!
tingham is offline
Old 12-09-2009, 05:45 PM
praveenk25's Avatar
I originally asked the question here but let me ask here in Slim thread as well. I previously had PS3 40GB and didn't had this aspect ratio issue. With slim, DVDs and Netflix streaming always shows aspect ratio problem. Movie characters looks compressed/fat and I'm sick of that.
I have it set in PS3 as 'letterbox'. Any idea what else needs to change?
praveenk25 is offline
Old 12-09-2009, 05:59 PM
tingham's Avatar
Quoted: 62 Post(s)
Liked: 30
I don't know about Netflix, but with DVD's did you try setting the BD/DVD upscaler settings to "normal" on the PS3?
tingham is offline
Old 12-09-2009, 06:02 PM
praveenk25's Avatar
Yes it is set to Normal. Thx.
Old 12-09-2009, 06:18 PM
tingham's Avatar
Quoted: 62 Post(s)
Liked: 30
Weird! Are you running the signal thru a AVR?
tingham is offline
Old 12-09-2009, 06:30 PM
streaker76's Avatar
Thanks, I've been through that thread as well with some postings. It was mostly to do with the 3.0 issues. I thought I would keep it under the Master Slim Thread....
Does anyone have any ideas on how to go about getting the issue fixed with Sony? They seem to think it's not their product but I disagree.
Old 12-09-2009, 06:39 PM
praveenk25's Avatar
Yes, Yamaha RXV-663 as pre-pro. Blu rays works fine and so does my cable HD receiver. My previous PS3 didn't had this problem.
Old 12-09-2009, 06:42 PM
tingham's Avatar
Quoted: 62 Post(s)
Liked: 30
That stinks man. I think it's a strange issue between the Slim and your Marantz, and I have no idea if you will ever be able to solve it...Good Luck. Why don't you just use LPCM?
tingham is offline
Old 12-09-2009, 06:45 PM
tingham's Avatar
Quoted: 62 Post(s)
Liked: 30
If I was you, with all your components "turned on", I would try the " Restore Default Settings" option on the PS3.
tingham is offline
Old 12-09-2009, 08:10 PM
streaker76's Avatar
I know that I could use PCM, I choose the bitstream but can't get it to work properly. It's also a very debatable topic which doesn't belong on this thread.
It really sucks that I can't get a straight answer from either Sony or Marantz. That's why I turned here.
Steve
Old 12-10-2009, 10:18 AM
quinn1016's Avatar
Thanks, I will give it another try. Last night I was able to manually chose the output options, and selected the 1080p, and it did work. After going about my evening... I gave it another try, and the same problem was happening. Even this morning after manually choosing the settings, it stoped working after I ejected the disk and would not read the HDMI feed.
I will try the non 1080p option later. I am also going to pick up another cable and possibly an open box blu ray player to try a different HD device. It will help me see if it is the TV at least.
quinn1016 is offline
Old 12-10-2009, 11:04 AM
Erik Westlund's Avatar
streaker76: I may have an answer. But first I'm thinking out loud here to help brainstorm. Because I would like to know the results.
Could it be that the PS3 slim may not have a processor well enough suited for it and it's on the edge of this capability?
One benefit of the Panasonic BD players is that it has a 10 bit (or 12 bit in the case of the BD60) D/A converter. So if this is the case, then the Bitstream has more information to process and the pannys do a better job of this function. I know that the signal is fully digital (bitstream and PCM) but at some point this has to be converted so that we can hear and see what we are playing.
http://www.panasonic.com/apps/match-...y/DMP-BD60.pdf
... But ... It still may be your Receiver, even with a firmware Update. Your Marantz may not have the hardware processing power to swiftly convert this from a Digital to Analogue signal. Or if it's converted in the panny player the Marantz can not keep up with this signal.
This would be my next guess. So I would call Marantz about it and talk to a new person. Maybe you can send your receiver in for a new chip? They've done that before with their receivers in the past when there was a hardware upgrade available. It just depends on the way they made your model to adapt or not. And if you talk to the right people.
... Or if all else fails. Purchase or borrow a different receiver to find this out. ... You could just live with PCM. The debate for which is better is to small VS not having signal at all, right?
ew
Help and Thanks
Steve
Erik Westlund is offline
Old 12-10-2009, 12:44 PM
pochoboy's Avatar
Quoted: 27 Post(s)
movies bitstream from the ps3 slim is louder than pcm from the ps3. With bitstream my Pio Recv'r does DD and DTS 5.1. I can't say for sure what the ps3 pcm sends to my recv'r though.
pochoboy is offline
Old 12-12-2009, 10:11 AM
streaker76's Avatar
ew
Wow. Great information. Thank you very much. I spoke with PS3 tech support and he could tell me what size of D/A Converter the PS3 had. All he said was the processor was big. He then just suggested using HDMI straight to my TV then using optical to my receiver. Not sure if I can still get DTS-MA with optical. Thought it needed enough bandwidth to pass the info. Could be wrong.
I sent an email to the guy I've been dealing with at Marantz with the information you passed off to me. I'm also going to call him on Monday and see what he's come up with.
Anyways thanks very much for you information.
Steve
Old 12-12-2009, 12:05 PM
andydumi's Avatar
HDMI to TV and then optical to receiver will not get you DTS-MA. As you said, not enough bandwidth.
HDMI to receiver is the only way to do it.
Weird that it loses it only at ffwd/rew. I would guess its a receiver issue, as I have not heard of anything similar with any other brand of receiver and the PS3. But it is also possible it is an issue with that particular PS3.
Do you have another receiver or another PS3 you can borrow and test?
andydumi is offline
Old 12-12-2009, 01:28 PM
KBMAN's Avatar
Quoted: 256 Post(s)
Liked: 142
Got a question,
When you do a PS3 to PS3 transfer via ethernet, do you loose the data on the old PS3????
KBMAN is online now
Old 12-12-2009, 03:27 PM
streaker76's Avatar
I have used two PS3 slims and tested. Both on bitstream, same issue. I haven't had the opportunity to use another receiver. My neight has an Onkyo 705 and Slim. I'm going to his to try it hopefully soon.
I've tested with a Panny BD60 and DID NOT have any issues with bitstream.
Steve
Old 12-13-2009, 07:42 AM
tingham's Avatar
Quoted: 62 Post(s)
Liked: 30
This is a good thought, but unfortunately it's not the case. There are lots of slim owners that are hooked up via their AVR's that don't have the issue, including myself. Just out of curiosity streaker76, have you tried a different hdmi input on your Marantz. They are all independent, and a particular port may have an issue?
tingham is offline
Old 12-13-2009, 08:24 AM
rdclark's Avatar
Quoted: 291 Post(s)
Liked: 573
Yes, but that conversion happens in the AVR after the signal is sent by the player. The player's D/A converters go entirely unused unless you are using one of the player's analog outputs. Even if you are sending LPCM and doing the decoding in the player, this happens entirely in the digital domain.
The AVR converts the audio to analog only when it's done with processing and sends it to the amplifier stage.
Wide Awake
on the Edge
of the World
rdclark is offline
Old 12-13-2009, 08:27 AM
eddy_winds's Avatar
No
My mom works for Sony, and she brought home a copy of "Starhawk BETA"
I quickly slipped it into my trusty PS3, and started playing.
GOOZEX Game/Movie Exchange
eddy_winds is offline
Old 12-13-2009, 08:30 AM
rdclark's Avatar
Quoted: 291 Post(s)
Liked: 573
Originally Posted by eddy_winds View Post
No
Although Sony is quick to point out that save-game data from certain protected games won't be transferred.
See the notes and comments on firmware 3.15 here.
Wide Awake
on the Edge
of the World
rdclark is offline
Old 12-13-2009, 07:35 PM
streaker76's Avatar
I tried different HDMI inputs and all did the same thing. Issues and issues.
Old 12-15-2009, 10:46 AM
But of course! rdclark You are correct. .. I don't know why that didn't cross my mind when I sent that...
...I was thinking that the Marantz is compliant with HDMI, but it may not truly be for the latest 1.3a+ HDMI processing. That's what I was thinking with my latter comment and how this could mean that the weaker Marantz D/A processor stage is tripping up, perhaps.
p.s.
[ this is another reason why I don't like receivers. They look to have expansion with all those impressive series of inputs. But that is no sure-fire way to stay compatible with future technologies. That being said. I still buy to replace my receivers, every few years, like many of us. Sadly, it's only because it is usually cheaper to do this versus purchasing a separate preamp/processor with amp configuration. And then replace the pre/proc just as often as you would a receiver.]
[ I love separates. Does it show? ]
ew
Old 12-15-2009, 06:48 PM
moodyman's Avatar
I want to store Bluray flicks on my PC and use the media server capabilities of the SLIM to to watch them. I know this can be done but I can't find a definitive answer regarding the TrueHD/DTS-MA tracks..will they be preserved?? Will I be able to bitstream them out of the Slim to my receiver?? If anybody can link me some good info it would be much appreciated....
moodyman is offline
Old 12-15-2009, 07:10 PM
If you put the movies on a USB HDD (in the correct format), connected to the PS3, you will be able to bitstream TrueHD/DTS-MA. SONY's media streaming software on the PS3 blocks HD audio streams and any DTS streams (there is a trick around the DTS issue).
Old 12-18-2009, 04:37 PM
dazz87's Avatar
Quoted: 79 Post(s)
Liked: 40
having an annoying issue with my slim after the latest firmware update. For some weird reason my controller are not syncing with the ps3. This is happening on both dualshock and sixaxis controllers The light on the controllers keeps on blinking like its trying to sync but it never does. I then will have to connect the controller to the usb plug and then unplug for it to work. Sometimes I will need to turn off the ps3 and then turn it back on in order for the controller to sync. I have no issue turning on the ps3 with both controllers but for some reason it will not sync afterward. Anyone else?
dazz87 is offline
Old 12-19-2009, 05:07 AM
moodyman's Avatar
yep..this was a known problem resulting from firmware upgrade 3.10. Installing 3.15 should fix it...
moodyman is offline
Playstation 3 160gb System
