Official PS3-Slim Master Thread-Post all comments and questions here! - Page 33 - AVS Forum | Home Theater Discussions And Reviews
post #961 of 1011 Old 10-18-2010, 09:20 AM
crakarjax's Avatar
Quoted: 56 Post(s)
Tested out the new Netflix app this morning.
Pros:
- MUCH better UI
- No disc required
Cons:
- Did not give me 5.1 (astroboy for my kids... probably should have 5.1?)
- Controls are different; Not sure what resolution it was because the Triangle button doesn't seem to work as it does in all other videos
Definitely worth it just for the lack of disc alone, and the new UI is just gravy.
crakarjax is offline
post #962 of 1011 Old 10-18-2010, 09:21 AM
crakarjax's Avatar
Quoted: 56 Post(s)
BTW, what is up with the annoying ads covering the posts? Lame.
post #963 of 1011 Old 10-18-2010, 09:32 AM
UHD Addict
aaronwt's Avatar
Quoted: 5194 Post(s)
Liked: 3102
Pros:
- MUCH better UI
- No disc required
Cons:
I checked the new arrivals(or whatever it's called) and looked at a couple of 30Rock episodes. They had 5.1 audio. But the PS3 was only sending 5.1 DD when I had the 5.1 Dolby Digital Plus selected in the audio track selection of the Netflix application.
Here there some setting to receive DD+? i have no problem receiving bitstreamed DD+, or Dolby True HD from BD titles from my PS3 slim.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #964 of 1011 Old 10-18-2010, 09:34 AM
UHD Addict
aaronwt's Avatar
Liked: 3102
what Ads? I see nothing here like that.
aaronwt is offline
post #965 of 1011 Old 10-18-2010, 09:40 AM
RobertWy's Avatar
Quoted: 12 Post(s)
Liked: 27
I see ads, but they are to the side of some (not all) of the posts.
Robert
RobertWy is offline
post #966 of 1011 Old 10-18-2010, 12:25 PM
crakarjax's Avatar
Quoted: 56 Post(s)
Yeah they don't cover the post text actually... they are one the right side of the first post. I feel like this site is slowly getting more and more ads.... even text is highlighted now and if you mouse over it you see a popup ad!
post #967 of 1011 Old 10-18-2010, 08:04 PM
TheRatPatrol's Avatar
Quoted: 67 Post(s)
Liked: 59
Where exactly is that application at?
TheRatPatrol is online now
post #968 of 1011 Old 10-19-2010, 08:34 AM
crakarjax's Avatar
Quoted: 56 Post(s)
It should be under the whats new section.
post #969 of 1011 Old 11-12-2010, 05:08 PM
crakarjax's Avatar
Quoted: 56 Post(s)
Originally Posted by bussinessbrktrgh View Post
If you hack your PS3 to play downloaded games is it any chance to trash it or is it safe?
In other words, you are asking to be banned from this forum?
post #970 of 1011 Old 11-27-2010, 09:11 PM
ddesai2984's Avatar
IS there a downside to using my PS3 has the main unit for everything...
Gaming... probably alot
Streaming Hulu Plus and Netflix
and heavy bluray and dvd watching
Is there a difference in PQ with the PS3 vs a stand alone like a Sony s560 or a S570 blu ray player
ddesai2984 is offline
post #971 of 1011 Old 11-27-2010, 09:57 PM
nc88keyz's Avatar
Quoted: 153 Post(s)
Liked: 78
Honestly , the ps3 is among the best of the best for BD players. It gets great support and updates. The Only minor issue is that it will not bitstream lossless audio streams such as DTS MA nad Dolby True HD on 3D Blurays.
Whether this is limitation of the player or the hardware I am not convinced just yet. Perhaps sony wanted to get 3D support out as quick as possible.
Noted several places previously, this does not affect bistreaming on 2D bluray playback. Sony has made strides to bring great "added value" to the PS3,
Vudu,
Hulu +
3D movies, demos if thats your thing.
I truley believe Sony will get bitreaming working on 3D be reoptimizing something here or there. "Hopefully"
HT1: UN78JS9500, AVR: AVRX-7200WA, AMP: UPA-7, SPKRS: L/R: Veritas 2.3I C: 2.0CI SUR: V2.0R,, SUB: SVS SB13Ultra x2 ATMOS: 4X RC-6C, NUC i5/KODI, ChromeBox/KODI, ShieldTV
HT2: LC80LE844U, AVR: AVR4311CI, SPKRS: L/C/R: Veritas 2.2C, SUR: RC-RCRx2, SUB: 10.3x2
STORAGE: DS1812, DX513 x 2 - 4TBx18 Hybrid Raid, (It Just Works!!) R/C: HarmonyOneX2, Harmony880x1
nc88keyz is offline
post #972 of 1011 Old 11-28-2010, 03:11 AM
mesasone's Avatar
No IR receiver, so it won't work with most of your universal remotes. You can buy USB IR dongles, but unfortunately I don't think they will turn the PS3 on since it won't respond to the USB ports while powered off. Kind of a bummer.
I think there are some remotes that support Bluetooth, but not sure what kind of support they offer for the PS3.
IBEW Local 1362
Speakers: Energy RC-70 (L/R), RC-LCR (center), RC-RCR (surround)
Subwoofer: UM18-22 in 4cu sealed box powered by iNuke 6000DSP
mesasone is offline
post #973 of 1011 Old 11-28-2010, 01:46 PM
pitviper45's Avatar
If you use Logitech universal remotes they sell an adapter for the PS3 that can turn it on and off (converts IR commands to bluetooth, I believe). I have one of these and it works very well.
pitviper45 is offline
post #974 of 1011 Old 11-29-2010, 08:17 AM
crakarjax's Avatar
Quoted: 56 Post(s)
I have the IR4PS3 and it works EXTREMELY well.
post #975 of 1011 Old 01-16-2011, 07:18 PM
jsmiddleton4's Avatar
Quoted: 589 Post(s)
Liked: 199
My Circle button isn't backing my PS3 out of Netflix, Hudu Plus, etc. Anyone else having problems?
I've had to use the PS key and then quit command on the xmb menu.
Circle command is working in other applications/areas of the menu.
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is offline
post #976 of 1011 Old 01-16-2011, 10:42 PM
WhatHappend's Avatar
That is the way they designed the apps.
WhatHappend is offline
post #977 of 1011 Old 01-17-2011, 07:12 AM
crakarjax's Avatar
Quoted: 56 Post(s)
Yeah, took me a while to figure out how to exit Netflix!
post #978 of 1011 Old 01-19-2011, 02:21 PM
E46M3's Avatar
I'm sure this has been discussed but I can't seem to find answers...
I have a PS3 slim bitstreaming to Onkyo 807. My question is under audio settings, I select HDMI then the screen prompts you to select either automatic or manual output. Do i just select manual and check all boxes with all the different codecs in the next screen? Or do I just select automatic? For what reasons would you choose manual or automatic???
thanks!
E46M3 is offline
post #979 of 1011 Old 01-19-2011, 05:33 PM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
thanks!
I would suggest looking at the PS3 FAQ Thread
drhankz is online now
post #980 of 1011 Old 02-13-2011, 09:46 AM
mallu2u's Avatar
Have a quick Q for those who use harmony to control their PS3 with the harmony ps3 adapter. Once you install the adapter, do the activities "Play DVD" or "Play Netflix" directly play those two or does it only switch PS3 on and you have still have to navigate to video and play those yourself using your harmony remote?
Thanks in advance.
mallu2u is offline
post #981 of 1011 Old 02-13-2011, 01:11 PM
Quoted: 67 Post(s)
Liked: 59
Thanks in advance.
When you do "play DVD" it will switch to the PS3, and once you insert the DVD, it should start playing it automatically.
You still have to navigate the menus to play Netflix, I don't think theres a "hot button" for it yet.
post #982 of 1011 Old 02-13-2011, 02:23 PM
mallu2u's Avatar
What if the DVD is already in. Does it directly play or you have to navigate to video and select DVD to play it?
mallu2u is offline
post #983 of 1011 Old 03-06-2011, 04:58 PM
Highlander1976's Avatar
I'm hoping someone here can help me with an audio issue that has been giving me a bunch of problems.
Let me start with my setup:
Denon 3808CI Receiver (Latest Firmware)
Sony PS3 (Slim Version)
Energy Speakers
Standard HDMI Cable From PS3 to receiver (Mono-Price Brand)
Ok, I recently purchasd a new PS3 Slim because it is able to bistream DTS-MA and True-HD. Well to say the least, I have been having some weird sound issues.
I am be experiencing what members on the forum are calling the "DTS BOMB". Basically, when I set the PS3 to Bitstream and play a Master Audio Encoded Disc (Example Scott Pilgrim VS The World), I get random popping sounds that from what I can tell is the dreaded "DTS-BOMB". From my tests using differnet discs such as:
Scott Pilgrim
The Family Guy "Its a Trap"
I keep getting random popping sounds throughout the movie. I have even rewinded certain parts of the movie that made the popping sound and sometimes the sound will repeat, sometimes it wont. It is very Random.
Another issue I'm having is also playing discs with True-HD. If I play a movie in True-HD, I am getting a somewhat electronic noise through my speakers as if the receiver cant decode it.
I should also mention that when I set the PS3 back to "Linear PCM", the audio problems go away completely.
Are these issues related?
Is it my receiver that is the problem?
Is it the new PS3?
I really hope someone can help me out because I dont know what to think. I'm leaning towards the Receiver as the issue.
Could anybody give me some help and possible insight to what I could try next?
From what I have tested, I assume it can only be one of 3 things:
1.) The Denon has a glitch with the sound processor
2.) The HDMI Cable is faulty Maybe?
3.) The PS3 is faulty or is having an issue with the Denon 3808?
Thanks In advance.
Highlander1976 is offline
post #984 of 1011 Old 03-06-2011, 07:36 PM
wreckedpig's Avatar
^ My bitstreaming has been messed up lately too. Last night HD audio bitstreaming stopped working all together. The menu audio and the audio during the previews worked fine bitstreaming(dd 2.0 and 5.1). Once I started the movie everything went silent. Switching to PCM fixed everything.
It has worked fine for over a year so I am assuming it has to be something with one of the latest firmware updates.
wreckedpig is offline
post #985 of 1011 Old 07-20-2011, 11:42 AM
AtDaBeach's Avatar
Anyone know if the DD+ was ever fixed for Netflix and Vudu?
AtDaBeach is offline
post #986 of 1011 Old 08-25-2011, 05:37 PM
avman09's Avatar
It seems that after the last Netflix software update a couple of days ago when I play a DD5.1 movie I am getting PCM multichannel 7.1 but there would be no sound in the surround back. Before this update I would be getting DD5.1+PLIIxMV. I also made sure the settings on my AV7005 was unchanged, i.e. selected 5.1+PLIIxMV like it has always been.
I double checked my PS3 setting to make sure bitstream was selected and it was. I then tried playing a DD5.1 DVD and it would bitstream okay showing DD5.1+DPLIIxMV.
Has anyone else experienced the same?
avman09 is offline
post #987 of 1011 Old 11-22-2011, 11:26 AM
mstrength's Avatar
I have the 250GB slim PS3 and I've been having problems with it reading certain blu-ray discs. It plays every game I have (only 4) and every DVD just fine and even plays some blu-rays without a problem.
The wife wanted to watch Twilight again before she went to see the new Vampire crap so I put in the blu-ray. All I got was a loud clunking noise and nothing ever showed. I put in the DVD and it loaded fine. Is there some sort of fix for this type thing?
mstrength is offline
post #988 of 1011 Old 11-22-2011, 11:37 AM
MasterofBlasting's Avatar
I think this is a fairly common issue. I too have the 250GB slim, but mine plays everything fine. Do you have it actively connected to the internet? Sometimes a blu-ray will not play if it is started while you are actively connected to the internet. Also, try deleting the BD_Data folder from your PS3. It may be stopping playback.
If that doesn't work, a firmware update may do the trick.
MasterofBlasting is offline
post #989 of 1011 Old 11-22-2011, 11:41 AM
mstrength's Avatar
It might be connecting via wireless but I have never played any games online. I don't really do much gaming with it at all. Do you have the steps to check it? I have never really done anything to it other than plugging it in and having it find my TV 3D capable.
Where can I find the BD_Data folder?
post #990 of 1011 Old 11-22-2011, 11:50 AM
Oh ok. Some blu-rays have internet access associated with them. They may try and connect while it's initially trying to load. BD_Data should be under the "Videos" section on the PS3's home screen. You should be able to delete it from there. Press triangle when highlighting the BD_Data folder, and select delete.
To disable internet connections go to Settings>Network Settings>Internet Connections. You should see options to either enable or disable it.
Reply Blu-ray Players
Playstation 3 160gb System
