Denon DBP-4010UDCI - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1261 of 1271 Old 09-23-2015, 01:28 PM
Liked: 0
DBP-4010UDCI Info
Hello everybody.
I just got a minty (with the exception of the front display which is burned out) Denon DBP-4010UDCI player for free this afternoon. I have yet to get it home as the local dealer who had it is looking for a replacement display... According to him the guy that owned it has more gear than he knows what to do with and brought the unit in because of the display being out and just said to give it to whomever wants it... My dealer tested it out and said it works just fine.
So what I need to know is that what should I look out for with this unit, and can it be updated to run Netflix, Hulu and Pandora?
Any info is appreciated.
Thank you in advance.
Stratman67 is offline
post #1262 of 1271 Old 09-23-2015, 03:20 PM
jasonmichaelh's Avatar
Quoted: 193 Post(s)
Liked: 81
The answer is NO, NO, and NO. No Apps at all. And it can't and do 3D either.
But congratulations on getting a great videophile and audiophile quality piece of equipment for free!
The only big problem I've seen reported here is that the lens sometimes gets dirty or the laser burns out. BUT, a cheap fix has been documneted here if you are capable.
If you are not listening to SACD's, calibrating your picture, or don't have a Denon receiver/pre-pro to use Denon-link with, you may want to consider selling it and getting something inline with your usage scenario (apps).
jasonmichaelh is online now
post #1263 of 1271 Old 03-19-2016, 08:32 AM
Liked: 0
Hi everobody,
I am transferring my post from another thread, when it was proven that the player is wrong, not the receiver.
It is about a strange and annoying problem, the facts are as follows:
For 7-8 years I am an owner of Denon AVR-3808A receiver and Denon DBP-4010UD player, both bought and located in Europe. This combination worked (and works) like a charm, coupled with 5.1 set of serious speakers.
Recently I upgraded the receiver firmware via Ethernet and all seemed well after that, till I played some Blu-ray discs on my 4010UD and saw that BD audio stream is not sent as a bitstream signal to the receiver. Whatever I choose from the disc audio menu - Dolby True HD, DTS-MA HD, Dolby Digital or DTS, everytime the receiver shows PCM MULTI CH IN - no digital stream decoding.
The player is set to BITSTREAM and the receiver is set to INPUT - HDMI. There is only one HDMI cable between the two components - no other connections.
I replaced the HDMI cable, tried another HDMI socket on the receiver - no result. Whatever BD disc I play, whatever audio option I choose, I see only MULTI CH IN and receiver display "Audio input signal monitor" shows a 48kHz PCM 3/2/.1 signal is coming in.
Resetting the both units to factory defaults and manually configuring them did not help either.
This fault is present only with Blu-Ray discs. All other audio and video discs and digital audio formats work OK - DVD discs in DTS 5.1 or DD 5.1, Super Audio CD, DVD Audio, DTS audio CD, etc.
Comitting some tests with another BD player, with the same HDMI cable and same receiver settings, all worked just fine - I saw at last Dolby TrueHD and DTS-MA shining on my receiver's display, nomore PCM Multi Channel In!
Switched back the same HDMI cable to 4010UD and the MULTI CHANNEL IN problem re-appeared. In fact the player keeps on decoding and doesn't send a bitstream signal to the receiver when playing Blu-rays, whatever I set. This is not a proper behaviour.
I don't know, recently I cleaned the player lenses and readability was much improved. The next step is to replace the optical unit of 4010UD - cheap and easy option.
Any advice or help would be highly appreciated, I really have no idea why there is no Bitstream signal anymore coming out with Blu-Rays played on my Denon DBP-4010UD.
chess11 is offline
post #1264 of 1271 Old 03-19-2016, 11:56 AM
Digione's Avatar
Quoted: 23 Post(s)
Liked: 37
Originally Posted by chess11 View Post
Hi everobody,
Have you disabled BD Effect Sound in the Audio setup Menu and set the BD Audio Mode to HD Audio Output using the Mode switch on the remote? Both of these would be set to their default positions after a firmware upgrade.
chess11 likes this.
Digione is offline
post #1265 of 1271 Old 03-19-2016, 03:53 PM
Liked: 0
Talking
You made a miracle, mate - thank you so much!
BD audio effect in the Setup was off - I checked the settings several times, but the key was that neglected MODE button on the remote - I did totally forgot about it and there is no such option in On-Screen Setup, so I simply missed it!
As you suppose, MODE was set to default MIX Audio. Changing it to HD Audio fixed it all - pure and virgin bitstream signal rushed on its way to the receiver!
Thanks again, I was completely confused, I was even thinking to replace my 4010... madness!
chess11 is offline
post #1266 of 1271 Old 03-20-2016, 06:59 AM
MoFoHo's Avatar
Quoted: 13 Post(s)
Glad to see a few folks still have this machine. I still love mine, although I have to take it apart from time to time, to give the laser lens a clean!
ImaStar likes this.
MoFoHo is offline
post #1267 of 1271 Old 03-20-2016, 08:03 AM
Digione's Avatar
Quoted: 23 Post(s)
Liked: 37
I am just glad you got it working again after the firmware upgrade. I have been caught by the MODE button several times.
Yes I love this machine but it is sooooo... slow loading compared to my OPPO 103; and now for the 3rd time my DL4 has stopped working. Last time it was the digital board in my AVP, times before that I had to completely unwire the whole AVP and start from scratch to get DL4 back, this time nothing.
Luckily I have only had to clean my lens once in the past three years.
Well, with 4K, HDR and immersive sound on the horizon I will probably not worry about loosing DL4 (DL3 still works) as new players, pre's and projectors are in my future .
Digione is offline
post #1268 of 1271 Old 03-20-2016, 08:05 AM
Quoted: 23 Post(s)
Liked: 3
This is the top model AV receiver for Denon?
ONSADE is offline
post #1269 of 1271 Old 03-20-2016, 09:51 AM
Digione's Avatar
Quoted: 23 Post(s)
Liked: 37
Its not an AV receiver but a BluRay player.
The A1 and 4010/A100 were the Denon top of the line BluRay players. The DBT-3313UDCI is now the top of the line but in no way compares to the previous models and does not support the original Denon Link connection. I think that Denon "lost their way" and handed the "reigns" over to Marantz when they were bought out by D&M Holdings.
I had quiet a few friends that worked at Denon HQ here in Mahwah, everyone was "let go", and I find the company to be somewhat of a shell now compared to what it was when it created some real leading edge audio hardware.
ImaStar and Gerhard_Bader like this.
Digione is offline
post #1270 of 1271 Old 12-15-2016, 12:24 PM
MoFoHo's Avatar
Quoted: 13 Post(s)
Originally Posted by gregot View Post
Hi,
being from France, I came here today to share what I just found out about the optical lens module of the Denon DBP-4010UD player.
The following is true for the european version of this player, so it should be the same for the US "CI" version.
I have encountered, as many others have, a problem with the optical lens of the 4010 which didn't last very long (a few years). It wouldn't play any blu-ray disc after some time.
I had it replaced under warranty once. Then it failed again. But now the warranty coverage has expired and a repair from an authorized Denon technician is way too expensive.
So I decided to take care of it myself.
After a search of my own, I found out that the optical lens module inside the Denon DBP-4010UD looks exactly the same as the one inside the Sony Playstation 3, model name: KES-410a
On the photograph shown below, you can see the PS3 lens module on the left and the original Denon lens module on the right:
I purchased this KES-410a and placed it myself as a replacement for my old Denon optical module to see what would happen...
...And it worked just fine.
And it plays everything: CD, DVD-V, DVD-A, SACD, BD.
The KES-410a is very easy to find and very cheap too.
There are many videos available on YouTube that show how to change the lens in a PS3. I f you manage to strip down your Denon player until you can access the reading mechanism, you'll be able to replace the lens.
So if your Denon 4010 player doesn't play blu-ray discs any more, give it a try
Greg.
Hi everyone. I know this thread is pretty much dead now, but I just wanted to ask, has anyone else tried this fix? I just have, and it's pretty easy. The new KES-410A laser cost all of £10 (delivered) from Ebay.
I took some pictures if anyone else fancies carrying out open heart surgery on their beloved high end Denon blu-ray player...
1.Firstly, remove the outer case (obviously).
But before powering off, make sure to eject the disc tray, and simply unplug the unit from the mains.
2. Remove the video board (above the transport) by removing all the screws, and unplugging the 2 ribbon cables. I just leave all the other connections alone and flip the board.
3. There's just 2 tiny screws holding the top of the transport lid on, giving access to the laser block.
4. The laser block runs on 2 rails, and is driven by the lead screw (on the right). The white plastic component to the right of the laser block only 'sits' on the lead screw, so it will just lift off when you remove the laser block. The laser block is only electrically connected by the wide flat ribbon cable. Just lift up the black leading edge of the cable connector, and the ribbon cable comes right out.
5. You only need to gently prise the far ends of both rails up (opposite end to the drive spindle). To make this easier, slightly undo the 2 spring steel components holding the rails in place. I didn't even remove them completely, just loosened then enough to rotate them out of the way (and a gentle nip to hold them in that place). After that, just gently prise the 2 shafts upwards, and glide the old laser block off. You just need to re-fit the lead screw captivation bar to the underside of the new laser block (one screw).
6. Fitting the new laser block is just a reversal of the procedure.
I hope this has been of some help.
ID:	1832465   Click image for larger version
ID:	1832481   Click image for larger version
ID:	1832489   Click image for larger version
ID:	1832497   Click image for larger version
ImaStar and Digione like this.
MoFoHo is offline
post #1271 of 1271 Old 05-28-2017, 05:52 AM
SoundofMind's Avatar
Liked: 166
Hello everybody.
I just got a minty (with the exception of the front display which is burned out) Denon DBP-4010UDCI player for free this afternoon. I have yet to get it home as the local dealer who had it is looking for a replacement display... According to him the guy that owned it has more gear than he knows what to do with and brought the unit in because of the display being out and just said to give it to whomever wants it... My dealer tested it out and said it works just fine...
Hi guys,
My DBP-A100 suddenly developed a FPD issue:it went dark except for displaying "ON" or "OFF" when powered on/off. Thinking I must have touched the wrong button somewhere, I went through the GUI, which works fine, but did not see an option to turn off/on the FPD. I then resorted to RTFM and found on p34 an explanation of the "display" button on the remote. Cycling through as described I saw no change except on the GUI. Undeterred, I found on p30 a description of "Temporary Display" in the GUI and switched this on. To my relief, it indeed fully restores the FPD-BUT only for a few seconds each time I enter a command such as play or stop.
Oh I also tried I tried a soft reset powering off and pulling the power cord for 30 sec.
I am hesitant to use "Initialize" to reset to factory default as it can be tricky reestablishing the Denon Link connection with my AVR-A100.
Anyone have another suggestion? TIA
Yes, I still like playing with Dalis.
SoundofMind is offline
Reply Blu-ray Players
Blu Ray Players , Denon
