NEW: Sony's BDP-N460 w/streaming - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1291 of 1303 Old 01-09-2014, 09:40 AM
EJcal's Avatar
Originally Posted by bswiz View Post
True. Here's a list of the Sony BD players and what features are supported for Netflix.
https://support.netflix.com/en/node/443
EJcal is offline
post #1292 of 1303 Old 10-24-2014, 03:49 PM
tomnan24's Avatar
Quoted: 105 Post(s)
Liked: 30
Do I need my Bluray connected to my network
I have a Sony BDP-N460. It can connect to my network with an ethernet cable or I can buy a dongle to make it wireless. I've never bothered with either.
I was thinking about replacing it with one that is wireless, but I can't think of a good reason to bother to connect it to the network as I have a smart TV.
Is there any?
tomnan24 is online now
post #1293 of 1303 Old 10-24-2014, 03:57 PM
Latinoheat's Avatar
Quoted: 1114 Post(s)
Liked: 889
Is there any?
The only reason other than using the apps in the player is to be able to update your player. If you already only use the tv apps and don't want to ever update your player there is no reason to. For new players it's usually needed to be able to play new movies as they come out.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #1294 of 1303 Old 10-24-2014, 04:18 PM
tomnan24's Avatar
Quoted: 105 Post(s)
Liked: 30
Thanks, that's a good reason, I wasn't aware of that. My 58" Samsung plasma has been broken(for good) for over a year. I have been using my bedroom 37" Dynex for a main TV so I haven't watched many movies. I will be doing more of that since I have finally bought a new TV.
Latinoheat likes this.
post #1295 of 1303 Old 12-30-2014, 05:21 PM
Liked: 1
Hi,
Hope everyone who's celebrating is having a nice holiday!
Anyway, been trying to find an answer for this problem from several sources with no luck, so thought I'd ask here since there are so many knowledgeable members. My problem is with my Sony BDP-N460 Bluray player - about 4 years old, I think, according to the receipt (which doesn't seem all that old.) Up until now, I've had no problems playing BD disks (is that redundant?) and think this player has a great picture and a great selection of Internet apps, but when I tried playing my latest BD, "The Maze Runner" from 20th Century-Fox, the BD wouldn't play past about 10 seconds of the 20th Century-Fox fanfare at the very beginning. It then goes into "Pause" mode with a black screen and the "Pause" icon and "BD Pause" showing in lower left corner. Blue light shows through tray door while this is in pause then, after about a minute of the black screen, player shuts itself down!
I installed the latest firmware and followed all directions from Sony that they suggested to correct the problem: deleting BD Data; resetting all settings; unplugging unit from power for a minute or two; firmware update (even though the player showed the latest version was already installed), but none of those actions corrected the situation.
Any advice on how to solve this problem would be appreciated! The only advice I got for this problem in the Sony forum was to buy a $49 Samsung! lol But, I have a Samsung "Smart Media Set Top Box" and it has very few apps, compared to my Sony BD player (and I also bought a Samsung LED HDTV but took it back after only 2 days, it was so bad compared to my Sony that it hurt my eyes watching it, even after spending 2 days trying to adjust color, brightness, etc. to be more lifelike!)
Thanks for reading this and for your help!
Happy New Year!
P.S. I thought the problem might be the disk, so took it back and exchanged it for a new, sealed one, but the new disk still has the same problems when I try to play it. Also, the included DVD plays fine; it's just the BD that won't play.
teke978 is offline
post #1296 of 1303 Old 12-31-2014, 01:16 PM
motorhead0922's Avatar
Originally Posted by teke978 View Post
Hi,
Happy New Year!
Hi Teke.When you say you did a firmware update, does that include this week's update? My player just got one, after not needing one for years.
motorhead0922 is offline
post #1297 of 1303 Old 12-31-2014, 05:25 PM
Liked: 1
Hi, and thanks for the reply!
Yes, I installed the newest firmware that came out on 24 December 2014...version ending in .195, I think...and it did no good
Thanks, again, and have a Happy New Year!
teke978 is offline
post #1298 of 1303 Old 12-31-2014, 09:56 PM
bguzman's Avatar
Quoted: 50 Post(s)
Liked: 523
Did you try turning off BD-Live?
HT, Mitsubishi HC6500, 106" screen, Panasonic TC-P50G10, Oppo BDP-103, Toshiba A35, Panasonic LX-1000U, Pioneer Elite CLD-95, Faroudja NRS, DirecTV H21-100, PS3, Pioneer Elite SC-85, Def Tech; SM 450, CLR 2002, BP2X, Klipsch KSB 1.1(X4), Pro Sub 100, Polk PSW125
Old School, Sony PS-5500->Denon 103r->AU-320 SUT, Dual 1219->Shure M91ED, Kyocera DA-610cx, Pioneer SA-1000, Polk Monitor 10A
bguzman is offline
post #1299 of 1303 Old 01-02-2015, 06:58 PM
Liked: 1
No, but I'll give it a try!
teke978 is offline
post #1300 of 1303 Old 01-03-2015, 05:14 PM
Liked: 1
Well, I tried your suggestion, but no difference.
I even removed the USB thumb drive altogether - same result - then, after reformatting it on my computer and verifying it, reinserted it after shutting down and unplugging the BD player for a few minutes, but same result: the 20th Century-Fox fanfare plays, then the player pauses, screen goes black, except for the "Pause" icon, for a couple minutes, then the BD player shuts itself off!
I have a feeling it might be some DRM code 20th CF put on the disk that Sony hasn't gotten around to incorporating an appropriate decoder into its firmware...or I could be completely wrong about that! lol It's just that the disk DOES play in a cheap Samsung that's newer than my Sony, so why doesn't it play in a better, though older but up-to-date on firmware, Sony?
So, if anyone has any other ideas - maybe a rep from Sony who reads these posts? - I'd appreciate hearing from you about a solution. I don't really want to discard this player - the new Sonys are so strange-looking and cheap-looking compared to mine and, if they have the same software, who knows if the result would be any different?
Thanks for the help!
teke978 is offline
post #1301 of 1303 Old 01-19-2015, 05:08 PM
aboroman's Avatar
Did anybody else's cease to output DTS-HD Master? Mine absolutely refuses to play this and only outputs 2 channel PCM when I try, many resets and serial setting changes later. It still outputs dolby digital like a champ in non-english. I wonder if it was that last update. Reading through this thread, mine has never had an issue playing any blu-ray ever for what its worth.
aboroman is offline
post #1302 of 1303 Old 08-11-2015, 09:04 AM
garyoNC's Avatar
Anybody having streaming problems w/NETFLIX? All kinds of video artifacts, stopping, missing video, no network access. I was ready to blame NETFLIX when I decided to try my HT PC and it streams NETFLIX without a single problem. My 460 was a very early model which needed the firmware update to even stream anything. It is almost 6 years old. The funny thing is the mechanicals work perfectly, playing any disc is very good and my blu-rays look as good as when I first got the player. It is usually the mechanicals to give some problems before anything electronic. Oh well, I guess maybe an OPPO is in my future.
garyoNC is offline
post #1303 of 1303 Old 08-12-2015, 04:10 PM
bswiz's Avatar
Quoted: 73 Post(s)
Liked: 32
I haven't used the N460 for Netflix streaming for a long while! The interface is so clunky compared to all the options out there now and if I remember right, Netflix is limited to 720p on it. Pick up an Amazon FireTV or Chromecast or some other <$100 option and it will blow away the N460!
bswiz is offline
Reply Blu-ray Players
