Sherwood BDP-5004 - Much improved and it appears to be region free - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 175 Old 05-24-2010, 09:41 AM
Selden Ball's Avatar
Quoted: 3100 Post(s)
Liked: 1512
Originally Posted by kerpan View Post
One complication, I get a "you need to configure BD-Live" message every time the player starts up (I have tried to turn BD-Live off completely -- but STILL get this message).
Mine does too -- it's not connected to the internet, either. I consider it a minor annoyance. The status message goes a way after a short while.
Addenda -- I got it to work. My problem was actually a BRD that had a misleading code -- not the player.
That's great!
Selden
Selden Ball is offline
post #92 of 175 Old 06-08-2010, 05:46 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Well! I got one, now if some one guides me in the direction of region free hacking.
zoro is offline
post #93 of 175 Old 06-28-2010, 01:16 AM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Any idea if it play video files from usb storage drives?
zoro is offline
post #94 of 175 Old 07-12-2010, 08:12 AM
hobbes4444's Avatar
So are the 5004's shipping with the new firmware that disables all region functionality? Was thinking of ordering one, but if it's no longer all region capable, then no need. . .
hobbes4444 is offline
post #95 of 175 Old 08-10-2010, 08:51 PM
alansanders's Avatar
just received one from Amazon.com on Aug 8 2010 and is region free
Seems fine. 2 issues
Inserted regular DVD Time Travellers wife. Could find no way to skip all previews, except to FF (only 2X available) ALL BUTTONS GET RED CIRCLE. ALL. Is this going to happen every time I put in a DVD with previews? I have no library, just Netflixx which won't arrive til tomorrow.
Also received Sherwoods Netboxx and it too seems fine. But can't use iy's remote with the BDP-5004. Emailed Sherwood and they quickly and nicely replied : "...Unfortunately, Netboxx remote does not support controlling our Blu-ray players. We've already confirmed this error and will correct it for our future models as soon as possible..."
Still, happy with products
alansanders is offline
post #96 of 175 Old 08-11-2010, 04:07 AM
Liked: 1512
Whether or not you can skip previews is decided by the authors of the disc. My understanding is that NetFlix gets their own special versions of movie discs, which are not the same as the commercial versions you can purchase yourself.
If you don't already have one, you might want to consider getting a "universal learning remote" like one of the Harmony series.
Selden
post #97 of 175 Old 08-12-2010, 09:15 AM
danshane's Avatar
Quoted: 56 Post(s)
Liked: 60
Anyone had any issues with their BDP-5004 connected to a Mitsubishis DLP? When playing a disc (BD or DVD doesn't matter) with HDMI connection the screen will occasionally go blank. Switching to component connection will usually produce a picture, and if the HDMI cable is removed component will always work.
I have an idea it may have something to do with the Mits C9's annoying habit of trying to control peripherals based on which input is being used, but I'm not sure.
--Dan--
Be seeing you...
Dan Shane
danshane is offline
post #98 of 175 Old 09-02-2010, 01:54 AM
Todd Sigmon's Avatar
I have the same combination Dan and I haven't had any problems. Maybe a bad cable?
Todd Sigmon is offline
post #99 of 175 Old 09-08-2010, 06:32 AM
danshane's Avatar
Quoted: 56 Post(s)
Liked: 60
Thanks for the reply, Todd. Turned out the player had a physical HDMI connector problem, and Sherwood repaired the player under warranty. I'll have it back this afternoon.
Be seeing you...
Dan Shane
danshane is offline
post #100 of 175 Old 09-09-2010, 06:48 AM
danshane's Avatar
Quoted: 56 Post(s)
Liked: 60
Well, Sherwood replaced the main board with a new one, so now I have my HDMI feed back and looking good. Unfortunately, the new board is loaded with the March 2010 firmware that removes region switching, so I can't watch my imported Blu-rays anymore.
Anyone have the older firmware from August 2009 that I can use to downgrade my player? Also, not sure about the procedure for doing so.
--Dan--
Be seeing you...
Dan Shane
danshane is offline
post #101 of 175 Old 09-09-2010, 12:33 PM
danshane's Avatar
Quoted: 56 Post(s)
Liked: 60
Sherwood sent me the older firmware, so I'll try the downgrade tonight and report back.
--Dan--
Be seeing you...
Dan Shane
danshane is offline
post #102 of 175 Old 09-09-2010, 04:15 PM
danshane's Avatar
Quoted: 56 Post(s)
Liked: 60
Yep, downgrade was quick and flawless. All-region viewing is back.
Be seeing you...
Dan Shane
danshane is offline
post #103 of 175 Old 09-18-2010, 10:34 PM
mercurythewhite's Avatar
Hey guys. This is probably common knowledge but I accidentally upgraded the firmware on the Sherwood 5003 and it neutralized the region switching. Thankfully, I had a copy of the old firmware on a cdr and was able to switch back. I was stupidly under the impression that the latest firmware only effected the 5004 and momitsu.
Merc
mercurythewhite is offline
post #104 of 175 Old 09-24-2010, 07:00 PM
kerpan's Avatar
I just got a repaired BDP-5004 back from Sherwood -- and I have the same problem. I would be happy to just be able to play Region B discs (as I have something else that can play Region A ones). ;~{
I sent an e-mail to Sherwood, I hope I can get a copy of the old firmware too!
kerpan is offline
post #105 of 175 Old 09-27-2010, 10:59 PM
foofoobar's Avatar
Chalk up another satisified owner (so far ).
Received unit from Amazon with August 2009 firmware and after a couple of attempts played region B "Thirst" after entering 973502 (after power on with no disc etc).
I did run into an output resolution problem on my receiver with region B "Antichrist", but it's one of those nasties encoded at 50fps (player is set to 1080p / NTSC).
Edit: Problem solved -- forced resolution to 1080p instead of Auto.
I will tinker around and see if I can get around that problem, but so far I have been very impressed with the PQ / AQ.
foofoobar is offline
post #106 of 175 Old 09-30-2010, 11:04 AM
kerpan's Avatar
I got some March 2010 firmware from Sherwood -- not sure that this actually is old enough firmware. In any event, it doesn't seem to have helped solve my problem.
I wonder if the European BDP-904 uses the same sort of firmware? I can't test this, as I can't get a complete download from sherwood's German website.
kerpan is offline
post #107 of 175 Old 09-30-2010, 02:23 PM
Stereojeff's Avatar
Quoted: 112 Post(s)
Liked: 60
What firmware are you looking for?
Jeff Hipps
Sherwood
Stereojeff is offline
post #108 of 175 Old 09-30-2010, 05:56 PM
kerpan's Avatar
sent you a PM
kerpan is offline
post #109 of 175 Old 10-16-2010, 09:09 AM
GreatGonzo's Avatar
I'm sorry if I'm asking the obvious, but I cannot seem tofind the exact information I need in this thread - does the new firmware upgrade remove all region-free capability or does it just affect the blu-rays? I could live without that, but I really need the player to stay region-free for DVDs.
GreatGonzo is offline
post #110 of 175 Old 10-19-2010, 02:24 PM
danshane's Avatar
Quoted: 56 Post(s)
Liked: 60
It only disables Blu-rays from outside your region. DVDs still play fine, and no code need be entered to play them.
Be seeing you...
Dan Shane
danshane is offline
post #111 of 175 Old 10-25-2010, 06:53 PM
GreatGonzo's Avatar
Thank you! No I need to figure out where to download the 5&*#@ firmware....
post #112 of 175 Old 11-13-2010, 05:35 PM
JoelDS's Avatar
edit: Never mind, found the answer to my question.
JoelDS is offline
post #113 of 175 Old 12-23-2010, 12:22 AM
britz1's Avatar
Does anybody have the August 2009 firmware for the Sherwood 5004 blu ray player and is willing to share? I sent it off for repairs and they updated it to the March 2010 firmware and I can't play my region b blus. I'd greatly appreciate it!
britz1 is offline
post #114 of 175 Old 12-23-2010, 08:39 AM
danshane's Avatar
Quoted: 56 Post(s)
Liked: 60
You may download the firmware from this location:
https://slashtmp.iu.edu/files/downlo...%2F79176hr9jbo
The password is "sherwood" (without the quotes).
Be seeing you...
Dan Shane
danshane is offline
post #115 of 175 Old 01-06-2011, 12:10 PM
oblivionis's Avatar
I just ordered this player today. I downloaded the older firmware in case mine comes with the latest version. Are the instructions for loading firmware in the owner's manual?
oblivionis is offline
post #116 of 175 Old 01-08-2011, 09:35 AM
danshane's Avatar
Quoted: 56 Post(s)
Liked: 60
If they aren't all you need to do is burn the ISO to a CD. Insert the CD into the player and close the drawer. Follow the prompts.
Be seeing you...
Dan Shane
danshane is offline
post #117 of 175 Old 01-13-2011, 04:49 AM
Gunya79's Avatar
Can anyone try to play newest blu-ray discs like Avatar Special Edition (with new BD+ protection) on your Sherwood 5004? I guest you need firmware update in order to play it. And what about Avatar Bd-live? "Live Extras" are working or not?
Gunya79 is offline
post #118 of 175 Old 01-13-2011, 02:47 PM
danshane's Avatar
Quoted: 56 Post(s)
Liked: 60
I've not tried AVATAR on my Sherwood since I don't own the BD and don't intend to purchase anything except the 3D version should it ever become available to Panasonic non-owners. I wasn't that thrilled with the story itself, so I only want the 3D eye candy.
That doesn't answer your question though. So far I have not found a disc I cannot play, but that doesn't mean it won't happen eventually.
Be seeing you...
Dan Shane
danshane is offline
post #119 of 175 Old 01-14-2011, 04:27 AM
Gunya79's Avatar
Well, it's not the answer I hoped:-) Theoretically it won't play. Latest firmware update - March, Avatar was released on 22nd April and many BD-player's owners had a problem with the disc.
Gunya79 is offline
post #120 of 175 Old 01-21-2011, 10:36 AM
JGDragov's Avatar
Bought a Sherwood Region Free BDP-5004 from Buy.com. It only cost $109.99 with free shipping and I got it in a few days(today it came).
I got it because of it's region free DVD capabilities, as well as it's ability to play VCDs and SVCDs. Very happy to report that all these discs, and I tried many, played with no problem.
Amazingly, I cannot get one BLU RAY disc to play on this player. I received a "no disc" message after an attempt to play Toy Story 3. I then had all other Blu Ray discs ejected that I tried to play afterwards(i.e. Halloween, Terminator Salvation).I live in the US and these were all Region A discs. I even tried a UK Blu Ray of The Fog and the same issue. This disc has played on all my other Blu Ray players region free and not.
Not sure what my problem is but there must be something I'm missing. I find it hard to believe that a Blu Ray player could be so faulty that not one Blu Ray can play on it but every other disc can.
Has anyone had a similar issue? What, if any, suggestions might someone have about this problem? As always, input is greatly appreciated.
JGDragov is offline
Reply Blu-ray Players
Blu Ray Players , Sherwood
