New UD8004 Blu-ray top of range by Marantz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 11-04-2009, 03:45 AM - Thread Starter
hihi2009's Avatar
Specifying the characteristics of new MARANTZ
hihi2009 is offline
post #2 of 15 Old 12-04-2009, 04:12 PM
BuckNaked's Avatar
UD8004
Interested in reading some user reports on this.
BuckNaked is offline
post #3 of 15 Old 01-26-2010, 07:52 AM
Sight's Avatar
I wonder what load and play times are like on this player ?
Sight is offline
post #4 of 15 Old 01-31-2010, 01:34 PM
Krobar's Avatar
Quoted: 17 Post(s)
Probably very similar to the Denon 4010UD, they look like they share the same core Drive and core processing.
Marantz UD8004:
Denon DBP-4010UD:
I'm interested to hear of user comparisons, it looks like the Marantz has an upgraded PSU and Analogue Audio section but no DL4.
Krobar is offline
post #5 of 15 Old 10-19-2010, 09:31 AM
JimShaw's Avatar
Quoted: 315 Post(s)
Liked: 351
Need your thoughts before spending $$$$
I own a Marantz BD8002 Blu-ray player. (I run it through a Marantz SR7002 receiver)
Marantz has told me that switching out my player for their new UD8004 I would notice an improvement in sound.
This is something that I would do IF what they say is true.
Please, your thoughts
8.3 Surround, protected by APC H15
Speakers: SpeakerCraft: 6 AIM8 Fives & 2 TIME Fives used as Wides
Woofers: SVS PB13-Ultra (1), HSU MBM-12 MK2 (2)
Samsung UN78JS9500,. LG OLED55E6P
Oppo UHD-203 player, Denon X7200WA, Harmony 1100, Harmony Elite, 9 Noctua cooling fans
JimShaw is offline
post #6 of 15 Old 01-05-2011, 05:46 PM
Chuck Spin's Avatar
Does anyone know a regionfree hack for the 8004?
The "old" one out on the web stopped working after I did the latest updates.
Chuck Spin is offline
post #7 of 15 Old 12-17-2011, 02:08 PM
Ian13's Avatar
GDay to all
Purchased the Marantz UD8004 Universal Disc Player recently along with some other HT equipment not really knowing much about the HT caper.
Have it hooked up in a temp HT room with the Marantz AV7005 Pre/Pro via hdmi. I have had no issues with the unit, it has operated fantastically from day one.
I have started this thread to hopefully talk to others who own or have previously owned the UD8004 and any others who wish to join in on how they have connected their unit up to their AVR or Pre/Pro.
Are you letting the player do the video and audio and passing it through your AVR or Pre/Pro?
Are you letting your AVR or Pre/pro do all the work?
Is your player just doing the video and your AVR or Pre/pro doing the audio?
Is your player just doing the audio and your AVR or Pre/pro doing the video?
I'm asking these above questions cause i'm totally confused as to which way is best to get the best possible video and audio.
Keeping in mind i am new to this (have learned some things but got along way to go) and using the UD8004 only to play Blu ray and DVD movies at this stage. May one day venture into multi channel SACD.
Looking forward to any replies and advice
Ian13 is offline
post #8 of 15 Old 03-30-2012, 01:41 PM
Chuck Spin's Avatar
Originally Posted by Ian13 View Post
GDay to all
I actually inquired Marantz about this.
They replied when using the 8004 with the 7005 for audio the best result would be to hook up 7.1 cabling and let the 8004 do the remix.
post #9 of 15 Old 04-08-2014, 11:38 AM
timfinle's Avatar
Hello,
I was hoping someone can help me with this issue. starting last night, my ud 8004 won't allow the menu functions to operate. So I can not play or set the audio. I have tried with the remote and the player. Both CDs and DVDS play fine so I know it is not the connections if that would even be a possibility.
Has anyone had this issue before?
Tim
timfinle is offline
post #10 of 15 Old 04-08-2014, 02:12 PM
Super Moderator
teachsac's Avatar
Quoted: 783 Post(s)
Liked: 1285
Never seen this problem. Try a hard reset first by unplugging the player. If that doesn't work, try a factory reset.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #11 of 15 Old 08-21-2014, 05:12 PM
timfinle's Avatar
marantz u8004 not playing Blue ray discs
This is the second time now that my 8004 won't respond to input commands for operation of the disc player. I called Marantz on the first go round with this issue. They suggested putting in an SD card. I cleared the BD memory using the "erase BD data" setup. Did not need an SD card. Well the issue is back and this time using the "erase BD data" does not work. Put an SD card in and initialized it, Blue rays still not working. CD's and DVD's play.
I am ready to replace it, cannot deal with this continuing issue. The audio and video quality are excellent in my opinion so I would like to keep it. Has anyone else run into this issue and what was the solution?
timfinle is offline
post #12 of 15 Old 08-23-2014, 12:56 PM
timfinle's Avatar
Thanks Super Moderator.
I went back and tried what you suggested by unplugging the unit and it now plays my BD again. Sure would love for this issue to go away but, according to Marantz this will be on going as they do not clear the memory from BD discs upon shut off. The memory gradually builds up until it won't operate anymore then it must be cleared.
timfinle is offline
post #13 of 15 Old 08-25-2014, 02:33 AM
Daffietje's Avatar
Quoted: 54 Post(s)
They just do not learn to make a decent UD/BD at Marantz...
My advice : get it back, get your money back and buy an Oppo.
Sure, it is not perfect either and very occasionally it hangs (not while playing discs thank god), happened now 2 times in a couple of months but I am using it all the time.
My previous UD from Marantz had a lot more problems I can tell you that...
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #14 of 15 Old 09-02-2014, 01:00 PM
timfinle's Avatar
The problem is, the marantz sounds so good. Before I purchased it, I auditioned so many universal players that.... well you know what that takes. The issue I have now is every time I unplug it, it looses the network connection and I have to call the home theater guys who set it up to reprogram the remote. I think I have the SD card issue worked out so I should just be able to put a new SD card in if it happens again. If it works, its a cheap fix, only uses 2gb cards.
timfinle is offline
post #15 of 15 Old 12-28-2014, 08:32 AM
Chuck Spin's Avatar
In a sense my ud 8004 has stopped working.
That is it doesnt play bd 's and dvds . However it plays cds just fine.
Would a blu lens replacement fix the issue ? Is it an approachable operation for a desperate amateur ?
If someone reading having owned the ud have you changed bd player since owning the 8004 and what are your takings on the picture quality ?
I find the 8004 to be amazing on that, donno if any player comes close?
Reply Blu-ray Players
Marantz Bd8002 Blu Ray Disc Player , Marantz Sr7002 Surround Receiver
