Official OPPO BDP-83SE Analog Audio Discussion Only Thread - Page 163 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 05-24-2010, 11:11 AM
MikeMc5506's Avatar
Quoted: 32 Post(s)
Originally Posted by magiapa View Post
Which RCA cables are good for OPPO DBP-83 SE?
My system is composed by:
Ampli: Sunfire TGR III
Speaker: Klipsch Heresy III
I initally went with monoprice. Bad idea! They are so stiff, the connection would break when I pushed the equipment back into racks. Ordered Blue Jean cables, and they are perfect. You can order the exact length you need, they come color coded for 5.1 or 7.1 which turned out to be very handy. I can't tell any difference in sound quality versus my Audio Quest/Topaz high end cables.
MikeMc5506 is offline
Old 05-24-2010, 11:37 AM
Smarty-pants's Avatar
Quoted: 749 Post(s)
Liked: 627
Well, you're not supposed to put undue pressure on the cables. Doing that is bad for any cable at any price. I've used Monoprice cables for a very long time, and have never had any trouble with them.
I have also been assured from audiophiles and professionals alike, that their premium analog cables are perfectly efficient for most systems, and there's likely no SQ improvement by using high end cables.
While BlueJeans also has very good quality cables, they are priced higher than Monoprice's cables. The fact that their analog cables are a bit more flexible, makes no difference in performance.
If that feature makes them a better fit for your setup, then that's good for you.
However, there is nothing wrong with the "quality"of Monoprice's analog cables.
A fantastic value for the price paid.
Smarty-pants is offline
Old 05-24-2010, 11:54 AM
MikeMc5506's Avatar
Quoted: 32 Post(s)
Just representing my own personal experience. I've used the same cabinet with retractrable shelves for 12 years, and never had a connection problem with the 3 or 4 other brands of high end cables I've used. I don't think the torque put on the monoprice cables was much different from a typical installation, as I have about 12 inches of open space behind the equipment when pushed in. The problem cost several days of trouble shooting, thinking I had a defective 83 SE, then maybe a defective Lex processor (Which had just been modified for 8 ch bypass) When I discovered the real problem, monoprice ignored my correspondence.
All that being said, when I had a good connection, I could not tell the difference in sound quality between monoprice and Blue jean, or Audio quest.
My advice is, unless you have unlimited space behind the equipment where even a slight torque on the cable can be avoided, don't try to save $50 on cables for a medium to high end sound system costing many times that.
Old 05-24-2010, 12:01 PM
Quoted: 749 Post(s)
Liked: 627
I hear where you are coming from... the frustration with troubleshooting... the experience with service... ect...
I don't mean to discount your own experience.
Perhaps you even got a bad batch of cables.
However, I have not had those problems with their cables.
And, I have about 7-8 inches of clearance behind my rack, and the Monoprice cables don't touch the wall.
Two different experiences recorded, helps others to make rational decisions.
Old 05-24-2010, 06:19 PM
djwobbrock's Avatar
Monoprice??? You get what you pay for!! I had all Monoprice cables on my analog connections from the SE. Had, I now have a boxfull that I can't stand. I couldn't believe the difference when I went with Audioquest King Cobra's. The difference is astounding, I have nine pairs of Audioquest King Cobra's. It was like going from my Panasonic BDP to the Oppo SE all over again. A fantastic value for the price paid!!!
djwobbrock is offline
Old 05-24-2010, 07:40 PM
Quoted: 749 Post(s)
Liked: 627
Spending that money seems to have made you quite happy.
Congratulations.
Old 05-24-2010, 08:59 PM
coyote2's Avatar
...over the last few weeks. Thank you all for the informative thread!
Originally Posted by Rachmaninoff View Post
...some CD's have showed minor dropouts.
have other noted this? frequently?
Originally Posted by salmonsc View Post
...there's a significant difference between the BDP-83NE, BDP-83SE - & the BDP-83 SE NuForce edition.
what's the difference between the NE and Nuforce? Is it "just" that one (which?) is their upgrade, and the other they sell new?
This Oppo product seems perfect for me even though I have little interest in BD playback. I'm trying to assemble a high bang-for-buck 2-channel analog audio system, to best approach my high demands on my limited means.
I'm leaning towards one of the Nuforce mods (I'm a half hour away from them, it would be nice to pick it up and avoid having UPS drop it a lot).
I'd love to see a few more A/B comparisons between the SE and NE and Modwright versions.
coyote2 is offline
sillysally's Avatar
Quoted: 841 Post(s)
Liked: 852
All though I don't advocate the use of any type of cables, King Cobra's are a very nice choice for interconnect cables (shorter the better).
ss
"Don't worry be happy"
sillysally is offline
Old 05-24-2010, 09:16 PM
dmusoke's Avatar
Quoted: 275 Post(s)
Liked: 146
Originally Posted by Kal Rubinson View Post
Doesn't matter, in general.
Thanks Kal ...
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
Old 05-24-2010, 09:19 PM
sillysally's Avatar
Quoted: 841 Post(s)
Liked: 852
[quote=coyote2;18684341]...over the last few weeks. Thank you all for the informative thread!
There is no real way to compare the differences between the three. Comparisons are just opinions.
Nuforce mods cost a lot less than Modright plus your BD-83SE is still covered where Modright is not.
The biggest differential between the SE and NE imo is the NE is clearer/cleaner sounding.
And if you decided to use your 2ch system for movies the Oppo does a great job of analog 2ch stereo down-mixing.
ss
Old 05-24-2010, 09:21 PM
sillysally's Avatar
Quoted: 841 Post(s)
Liked: 852
Wow we are really on a roll, I agree.
ss
Old 05-24-2010, 09:39 PM
sergiohm's Avatar
Quoted: 21 Post(s)
Right, I have Nordost Valhalla all the way, even in my bedroom
Seriously to me it does not make a difference as long as it is well built.
sergiohm is offline
Old 05-25-2010, 08:35 AM
DAB
DAB's Avatar
Quoted: 30 Post(s)
I have Monprice 5.1 Analog cables[+ two other sets for the external amp>RCA >XLR]+ [two more for the D2ch. set up] in my SE as well, 3ft long. I have had them for ~4yrs now. No issues with connections. I also have taken then 5.1 cables in/out quite often{beta testing the 83 & SE}. If it helps i have a buddy, who i just called that has a high end system and cable$$. Next week he is going to swap out his hi-end cables and bring them over here to see if we can hear a difference. Not expecting to hear a -major difference- but will be fun. I have a Modest mid-level system.5.1 . I also, have HDMI both by BJ and Mono- both work the same/have swapped them a few times. *BJ construction is much nicer and better for rougher environment-but $$X4 the price.
DAB is offline
Old 05-25-2010, 12:46 PM
Styln's Avatar
Liked: 26
Originally Posted by coyote2 View Post
...drop outs...
In thousands of hours of disc and streaming I've heard exactly one nonrepeatable drop out. That was on early firmware, so I'd say that bug was fixed. There was/is a bug where the beginning couple of seconds of a song won't play. There is a work-around (turn off auto-play) and that old bug has probably been fixed, too. (Not sure, as 999/1000 times I play a disc straight through) If you've read the thread, then you've probably read my reviews where I captured operational issues compared to a dedicated CDP. The Oppo has some drawbacks and you will probably need to hook up a monitor unless you only play redbook CDs. Not sure that's a mistake necessarily, but it is certainly vastly under utilizing the player's music making capabilities.
I was happy with the BDP-83 when it first came out - great audio bang for the buck and it surpassed one of my older Modwright Sony CDPs. The SE, is even better and surpassed my other older CDP. I'll probably get the NE upgrade eventually, but am in no hurry. So far, there has been no penalty for enjoying each step of the upgrade process as I too live close to Oppo & NuForce .
Styln
Styln is offline
Old 05-25-2010, 03:09 PM
djwobbrock's Avatar
Congratulations.
Smarty-pants,
No I was not happy to spend the money. I have been unemployed for over a year and a half. But outing the Monoprice anaolg interconnects after two years, for Audioquest King Cobra cables (at half the cost of my Oppo SE, for all nine pairs) was such a significant improvement in sound, that the Monoprice cables will never see my system again. Nothing wrong with the Monoprice cables except the sound/tone they produce. You can do so much better, but they are cheap! Glad you are happy with Monoprice! I used to think they were great for the money, until I auditioned several other brands and compared over the last three months. There is no cost to try different cables, as most sellers will give you thirty days, just like Oppo.
Old 05-25-2010, 04:23 PM
coyote2's Avatar
I do like that, thanks! Unless I read a few comparisons of the sound of the NE and the Modright (which I suppose is rather unlikely, few are going to have both), I expect to grab a NE.
that is a great relief, thank you!
coyote2 is offline
Old 05-25-2010, 05:55 PM
Styln's Avatar
Liked: 26
Originally Posted by dmusoke View Post
Thanks Styln:
Makes sense .... I was debating whether its worth the extra $250 I'd pay Dan ModWright to add the stereo balanced option on my SE. I have a feeling I'll hang on to it
Another Modwright player coming up We expect a full report, dmusoke. The least you can do after we saved you 250 bucks
Styln
Styln is offline
Old 05-25-2010, 06:11 PM
dmusoke's Avatar
Quoted: 275 Post(s)
Liked: 146
Styln
Maybe....after room treatments and speaker position optimizations which could take a really long while
dmusoke is offline
Old 05-25-2010, 06:35 PM
JetSnake's Avatar
What features does the "special edition" have over the regular BDP-83, and why is it needed?
JetSnake is offline
Old 05-25-2010, 06:48 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
It's all about analog audio, and only about analog audio. The Oppo website has the details in the BDP-83SE product description.
BIslander is offline
Old 05-26-2010, 04:02 PM
trevor-b's Avatar
Sorry ... wrong forum! Will post to the Oppo 83 forum.
trevor-b is offline
Old 05-26-2010, 09:48 PM
R8der's Avatar
Quoted: 76 Post(s)
Liked: 41
Smarty-pants,
Step right up boys and girls.....this here snake oil will not only cure any calamity, but it will also make your speakers sing like they never have! Yes, you are unemployed and can't afford a burger right now, but have no fear....this magical elixir will produce incredibly improved musical notes which will be your solace as you starve to death.
Marantz AV8802A, Sunfire Signature Grand (425W x 5), Sunfire TGA-7201 (200W x 7), Oppo UDP-203, Vizio P-75, Phase Technology PC8.5 (FL, FR, SL, SR), Phase Technology PC-Center, Phase Technology PC-60 (RSL, RSR), KEF Ci200rr (FHR, FHL, RHR, RHL), Epik Tower Sub
R8der is offline
Old 05-27-2010, 06:59 AM
erniec's Avatar
I find it a bit ironic that anyone would refer to another product category in this way on a forum that presumes and advances the premise that the 83SE audio is superior to other DVD/CD players. Especially when we alll know that 90% of the people probably believe that there is no such thing as a better sounding unversal/dvd/blu-ray/cd player.
Over the I years have spent a lot of money on both cables and CD playback gear, and in my opinion I am convinced that the 83 SE at a fraction cost is as good or better than the the Theta, Mark Levison stuff that I have owned. On the other hand I have close minded friends that refuse to accept the fact that a $900 universal player is or even can be at the same level as multi thousand dedicated CD players etc.
Regarding the cable game, my bottom line is yes they do and can sound different but the one thing I am convinced of is that there is absolutely no correlation between price and performance.In other words it wouldn't suprise me if an $18 Blu Jeans Cable sounded better than a "high end" interconnect that cost $1800. Having an open mind is why some folks can accept that the Oppo 83SE's audio performance is as good as it get's and others will dismiss it because it is too expensive and just snake oil, or it doesn't cost enough to really be considered a high end product.
30 years ago when I tried my first pair of Monster Cable interconnects I was astonished by both the improvement and the fact that they were selling for the unheard of price of $93 a meter. Since that time I have had a lot of wire in my systems. Yes some are better than others, some are just different and some are actually worse. Cable performance is very system and room dependent.
erniec is offline
Old 05-27-2010, 08:06 AM
sbjork's Avatar
Not only that, but cable discussions are very thread-dependent!
(Sorry, but while I hate sounding like the "topic police," I hate a potentially lengthy digression about the relative merits of cables slightly more!)
sbjork is offline
Old 05-27-2010, 05:43 PM
Repdetect's Avatar
Quoted: 13 Post(s)
My advice is read about The 10 Biggest Lies in Audio,
http://www.theaudiocritic.com/back_i...ritic_26_r.pdf
and save the $50 and by more music.
Sony HW40 ES, Oppo BDP-103, Gallo Classico CL-4/ Classico CL-C Center/ 2-CL-10 Subs/ Classico CL-2 surrounds, Emotiva UMC-200/ XPA-5/ XPA-3, Toshiba HD-A3. Roku X, Darbee Darblet, Silver Ticket 110" White Screen  "All rooms, speakers and ears are different, trust your own ears."
Repdetect is offline
Old 05-27-2010, 08:33 PM
EyeintheSky's Avatar
Amen.
And more money does not always buy better sound. But it can. . .
EyeintheSky is offline
Old 05-27-2010, 08:54 PM
Ruined's Avatar
Quoted: 268 Post(s)
Liked: 89
I agree that Monoprice cables are too stiff, and mine are also now sitting in a box unused. They are so stiff that in addition to breaking connection, they can even damage the ports on your equipment (applies more to HDMI, but can also occur with RCA). I find that paying a few extra bucks for Blue Jeans is worth it for the more flexible cable w/ nicer connectors they offer.
Ruined is offline
Old 05-27-2010, 11:42 PM
R8der's Avatar
Quoted: 76 Post(s)
Liked: 41
A player with better DACs can definitely have an effect on performance, hence this thread. My issue is those people who claim that their uber-expensive "cable of the gods" can outperform simple 12-guage lamp cord are full of bull excrement. When they go on to claim they tested all these cables and heard the difference I laugh.
Numerous audio experts have offered up rewards for those who can prove in a blind test the difference between Snakeoil A3000's and Radio Shack baling wire.....yet nobody has collected as of yet. I just hate to see somebody claim they spent their last dollar on cables versus rent because it was that important, and sucker just one person into believing this tallest tale in the audio world. Please. The King isn't wearing any clothes. Nada. He's naked as a jaybird. Give it a fricking rest already! Yes, you wasted your money....why do you feel the need to convince others to be equally ignorant?
Ok, off the soap box. I guess I just have an aversion to ignorance. My bad!
R8der is offline
Old 05-28-2010, 12:04 AM
sillysally's Avatar
Quoted: 841 Post(s)
Liked: 852
There is no need to get insulting or think others should not express there views. Yes your post is your bad!
Old 05-28-2010, 12:11 AM
sillysally's Avatar
Quoted: 841 Post(s)
Liked: 852
I am glad to see you are little by little coming around.
btw I had a HDMI BJ cable about 4 years ago and it broke my HDMI input on my Denon SDDVD player, but then again I didn't know much back then.
ss
